1 |
2 |
3 |
Routines for building out-of-core octree data structure |
4 |
5 |
Adapted from: Kontkanen J., Tabellion E. and Overbeck R.S., |
6 |
"Coherent Out-of-Core Point-Based Global Illumination", |
7 |
EGSR 2011. |
8 |
9 |
Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) |
10 |
(c) Fraunhofer Institute for Solar Energy Systems, |
11 |
Lucerne University of Applied Sciences & Arts |
12 |
13 |
14 |
$Id$ |
15 |
16 |
17 |
18 |
#include "oococt.h" |
19 |
#include "oocsort.h" |
20 |
21 |
22 |
/* Test for empty/full input queue, return pointer to head/tail */ |
23 |
#define QueueFull(q) ((q) -> len == (q) -> cap) |
24 |
#define QueueEmpty(q) (!(q) -> len) |
25 |
#define QueueHead(q) ((q) -> data + (q) -> head * (q) -> recSize) |
26 |
#define QueueTail(q) ((q) -> data + \ |
27 |
(q) -> head + (q) -> len - 1) * (q) -> recSize) |
28 |
29 |
30 |
/* Input queue from heap */ |
31 |
type struct { |
32 |
void *data = NULL; |
33 |
/* Queue head, length (from head), capacity and record size */ |
34 |
unsigned head, len, cap, recSize; |
35 |
} OOC_BuildQueue; |
36 |
37 |
38 |
static OOC_BuildQueue *QueueInit (OOC_BuildQueue *q, unsigned recSize, |
39 |
unsigned capacity) |
40 |
/* Initialise queue of #capacity records of size recSize each; returns queue |
41 |
* pointer or NULL if failed. */ |
42 |
43 |
if (!(q && (q -> data = calloc(capacity, recSize)))) |
44 |
return NULL; |
45 |
46 |
q -> cap = capacity; |
47 |
q -> recSize = recSize; |
48 |
q -> head = q -> len = 0; |
49 |
50 |
return q; |
51 |
52 |
53 |
54 |
static int QueuePush (OOC_BuildQueue *q, const void *rec) |
55 |
/* Append record to queue tail; returns new queue length or -1 on failure */ |
56 |
57 |
int tail; |
58 |
59 |
if (!q || !rec) |
60 |
return -1; |
61 |
62 |
if (q -> len >= q -> cap) |
63 |
/* Queue full */ |
64 |
return -1; |
65 |
66 |
tail = (q -> head + q-> len++) % q -> cap; |
67 |
memcpy(q -> data + tail * q -> recSize, rec, q -> recSize); |
68 |
69 |
return q -> len; |
70 |
71 |
72 |
73 |
static int QueuePop (OOC_BuildQueue *q, void *rec) |
74 |
/* Remove record from queue head; returns new queue length or -1 on failure */ |
75 |
76 |
if (!q || !rec) |
77 |
return -1; |
78 |
79 |
if (!q -> len) |
80 |
/* Queue empty */ |
81 |
return -1; |
82 |
83 |
memcpy(rev, q -> data + q -> head * q -> recSize, q -> recSize); |
84 |
q -> head = (q -> head + 1) % q -> cap; |
85 |
86 |
return --q -> len; |
87 |
88 |
89 |
90 |
static OOC_Idx *OOC_BuildRecurse (OOC_Octree *oct, OOC_Node *node, |
91 |
FVECT org, RREAL size, unsigned depth, |
92 |
OOC_Queue *queue, FILE *heapFile, |
93 |
FILE *nodeFile, FILE *leafFile) |
94 |
/* Recursive part of OOC_Build(); insert records from input queue into |
95 |
* octree node and subdivide if necessary. Returns number of records in |
96 |
* subtree. */ |
97 |
98 |
if (QueueEmpty(queue) || !InNode(QueueHead(queue))) |
99 |
/* Input exhausted or queue head outside node */ |
100 |
return 0; |
101 |
102 |
if (InNode(QueueTail(queue)) && QueueFull(queue) && |
103 |
depth < oct -> maxDepth) { |
104 |
105 |
106 |
else { |
107 |
108 |
109 |
110 |
111 |
112 |
OOC_Octree *OOC_Build (OOC_Octree *oct, unsigned recSize, unsigned leafMax, |
113 |
unsigned maxDepth, const char *heapFileName, |
114 |
const char *nodeFileName, const char *leafFileName) |
115 |
/* Build out-of-core octree from unsorted records of size recSize in |
116 |
* heapFileName, such that leaves contain <= leafMax records, except those |
117 |
* at maxDepth. Nodes and leaves are output separately to nodeFileName and leafFileName, |
118 |
* respectively. Returns octree pointer on success, else NULL. */ |
119 |
120 |
OOC_BuildQueue queue; |
121 |
void *rec = malloc(recSize); |
122 |
FILE *heapFile = fopen(heapFileName, "rb"), |
123 |
*nodeFile = fopen(nodeFileName, "wb"), |
124 |
*leafFile = fopen(leafFileName, "wb"); |
125 |
126 |
if (OOC_Init(oct, recSize, leafMax, maxDepth) < 0) { |
127 |
perror("OOC_Build: failed octree init"); |
128 |
return NULL; |
129 |
130 |
131 |
if (!heapFile) { |
132 |
perror("OOC_Build: failed opening heap file"); |
133 |
return NULL; |
134 |
135 |
136 |
if (!nodeFile || !leafFile) { |
137 |
perror("OOC_Build: failed opening node/leaf output file"); |
138 |
return NULL; |
139 |
140 |
141 |
/* Init and fill queue from heap file */ |
142 |
if (!rec || !QueueInit(&queue, recSize, leafMax + 1)) { |
143 |
perror("OOC_Build: failed input queue init"); |
144 |
return NULL; |
145 |
146 |
147 |
do { |
148 |
if (feof(heapFile) || !fread(rec, recSize, 1, heapFile)) { |
149 |
perror("OOC_Build: failed reading from heap file"); |
150 |
151 |
QueuePush(&queue, rec); |
152 |
} while (!QueueFull(&queue)); |
153 |
154 |
if (!OOC_BuildRecurse(oct, oct -> root, queue, |
155 |
heapFile, nodeFile, leafFile)) |
156 |
return NULL; |
157 |
158 |
fclose(heapFile); |
159 |
fclose(nodeFile); |
160 |
fclose(leafFile); |
161 |
162 |
return oct; |
163 |
