--- ray/src/rt/oocbuild.c 2015/02/24 19:39:26 2.1 +++ ray/src/rt/oocbuild.c 2016/05/17 17:39:47 2.3 @@ -7,16 +7,18 @@ EGSR 2011. Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) - (c) Fraunhofer Institute for Solar Energy Systems, - Lucerne University of Applied Sciences & Arts + (c) Lucerne University of Applied Sciences and Arts, + supported by the Swiss National Science Foundation (SNSF, #147053) ======================================================================= - $Id: oocbuild.c,v 2.1 2015/02/24 19:39:26 greg Exp $ + $Id: oocbuild.c,v 2.3 2016/05/17 17:39:47 rschregle Exp $ */ #include "oococt.h" #include "oocsort.h" +#include +#include /* Test for empty/full input queue, return pointer to head/tail */ @@ -24,14 +26,16 @@ #define QueueEmpty(q) (!(q) -> len) #define QueueHead(q) ((q) -> data + (q) -> head * (q) -> recSize) #define QueueTail(q) ((q) -> data + \ - (q) -> head + (q) -> len - 1) * (q) -> recSize) + ((q)->head + (q)->len-1) % (q)->cap * (q)->recSize) -/* Input queue from heap */ -type struct { - void *data = NULL; - /* Queue head, length (from head), capacity and record size */ - unsigned head, len, cap, recSize; + +/* Input queue for bottom-up octree construction */ +typedef struct { + void *data; + unsigned head, len, cap, recSize; /* Queue head, length (from head), + capacity and record size */ + FILE *in; /* Input file for data records */ } OOC_BuildQueue; @@ -52,112 +56,294 @@ static OOC_BuildQueue *QueueInit (OOC_BuildQueue *q, u static int QueuePush (OOC_BuildQueue *q, const void *rec) -/* Append record to queue tail; returns new queue length or -1 on failure */ +/* Append record to queue tail; return new queue length or -1 on failure */ { - int tail; - - if (!q || !rec) + if (!q || !rec || QueueFull(q)) return -1; - - if (q -> len >= q -> cap) - /* Queue full */ - return -1; - tail = (q -> head + q-> len++) % q -> cap; - memcpy(q -> data + tail * q -> recSize, rec, q -> recSize); - + ++q->len; + memcpy(QueueTail(q), rec, q -> recSize); + return q -> len; } static int QueuePop (OOC_BuildQueue *q, void *rec) -/* Remove record from queue head; returns new queue length or -1 on failure */ +/* Remove record from queue head and return in rec if not NULL; return new + * queue length or -1 on failure */ { - if (!q || !rec) + if (!q || QueueEmpty(q)) return -1; - if (!q -> len) - /* Queue empty */ - return -1; + /* Return head if rec != NULL */ + if (rec) + memcpy(rec, QueueHead(q), q -> recSize); - memcpy(rev, q -> data + q -> head * q -> recSize, q -> recSize); q -> head = (q -> head + 1) % q -> cap; return --q -> len; } -static OOC_Idx *OOC_BuildRecurse (OOC_Octree *oct, OOC_Node *node, - FVECT org, RREAL size, unsigned depth, - OOC_Queue *queue, FILE *heapFile, - FILE *nodeFile, FILE *leafFile) +static int QueueFill (OOC_BuildQueue *q) +/* Read records from q -> in until the queue is full; return queue + * length or -1 on failure */ +{ + static void *rec = NULL; + + if (!rec && !(rec = malloc(q -> recSize))) + return -1; + + while (!QueueFull(q) && !feof(q -> in) && + fread(rec, q -> recSize, 1, q -> in)) + QueuePush(q, rec); + + return q -> len; +} + + + +static OOC_DataIdx OOC_BuildRecurse (OOC_Octree *oct, OOC_Node* node, + FVECT org, RREAL size, unsigned depth, + OOC_BuildQueue *queue) /* Recursive part of OOC_Build(); insert records from input queue into - * octree node and subdivide if necessary. Returns number of records in - * subtree. */ + * octree node and subdivide into kids if necessary. Returns number of + * records in subtree or OOC_DATAIDX_ERR if failed. */ { - if (QueueEmpty(queue) || !InNode(QueueHead(queue))) + int k; + const RREAL kidSize = size * 0.5; + + if (!oct || !node) + return OOC_DATAIDX_ERR; + + if (QueueEmpty(queue) || + !OOC_InBBox(oct, org, size, oct -> key(QueueHead(queue)))) /* Input exhausted or queue head outside node */ return 0; + + if (QueueFull(queue) && depth < oct -> maxDepth && + OOC_InBBox(oct, org, size, oct -> key(QueueTail(queue)))) { + /*************************** SUBDIVIDE NODE ************************* + * At least leafMax + 1 records (since the queue is full) lie inside + * the current node's bounding box, and maxDepth has not been reached + * ==> subdivide this node. + * (Note it suffices to only test the queue tail against the bounding + * box, as the records are in Z-order) + ********************************************************************/ + OOC_Node kid [8]; + OOC_DataIdx dataCnt; + FVECT kidOrg; + +#ifdef DEBUG_OOC_BUILD +FVECT key; +unsigned k2 = 0; +#endif - if (InNode(QueueTail(queue)) && QueueFull(queue) && - depth < oct -> maxDepth) { - + /* We recurse on the nonempty kids first, then finalise their nodes so + * they are ordered consecutively, since the parent only indexes the 1st kid */ + for (k = 0; k < 8; k++) { + /* Clear kid node and get its octant origin */ + OOC_CLEARNODE(kid + k); + + VCOPY(kidOrg, org); + OOC_OCTORIGIN(kidOrg, k, kidSize); + + /* Recurse on kid and check for early bailout */ + if (OOC_BuildRecurse(oct, kid + k, kidOrg, kidSize, + depth + 1, queue) == OOC_DATAIDX_ERR) + return OOC_DATAIDX_ERR; + +#ifdef DEBUG_OOC_BUILD +if (!QueueEmpty(queue)) { +VCOPY(key, oct -> key(QueueHead(queue))); +k2 = OOC_Branch(oct, org, kidSize, key, NULL); +if (OOC_InBBox(oct, org, size, key) && k2 < k) { + fprintf(stderr, + "OOC_BuildRecurse, node subdiv: unsorted key [%f, %f, %f] with " + "octant %d (last %d with bbox [%f-%f, %f-%f, %f-%f])\n", + key [0], key [1], key [2], k2, k, + kidOrg [0], kidOrg [0] + kidSize, kidOrg [1], kidOrg [1] + kidSize, + kidOrg [2], kidOrg [2] + kidSize); +}} +#endif + } + + /* Now finalise consecutive kid nodes, skipping empty ones */ + for (k = 0; k < 8; k++) + if ((dataCnt = OOC_DATACNT(kid + k))) { + /* Nonzero kid ==> allocate and set node */ + if (!NewNode(oct)) { + fputs("OOC_BuildRecurse: failed to allocate new node\n", + stderr); + return OOC_DATAIDX_ERR; + } + OOC_SETROOT(oct, kid + k); + + /* Sum kid's data count to parent's and check for overflow */ + if ((dataCnt += node -> node.num) <= OOC_DATAIDX_MAX) + node -> node.num = dataCnt; + else { + fputs("OOC_BuildRecurse: data count overflow in node\n", + stderr); + return OOC_DATAIDX_ERR; + } + + /* Set kid index in parent (if first kid) and corresponding + * branch bit. The kid is the most recent node and thus at the + * end of the node array, which coincides with the current + * subtree root */ + if (!node -> node.branch) + node -> node.kid = OOC_ROOTIDX(oct); + + OOC_SETBRANCH(node, k); + } } else { + /****************************** MAKE LEAF **************************** + * Queue contains no more than leafMax records, queue tail lies + * outside node's bounding box, or maxDepth reached + * ==> make this node a leaf. + *********************************************************************/ + RREAL *key; + +#ifdef DEBUG_OOC_BUILD +OOC_MortonIdx zIdx, lastzIdx = 0; +FVECT /* key, */ + lastKey, kidOrg; +unsigned lastk = 0; +#endif + + /* Mark as leaf (note it's been cleared by the parent call) */ + OOC_SETLEAF(node); + + while (!QueueEmpty(queue) && + OOC_InBBox(oct, org, size, (key = oct->key(QueueHead(queue))))) { + /* Record lies inside leaf; increment data counter for octant + * containing record. */ + + if ((k = OOC_Branch(oct, org, kidSize, key, NULL)) < 0) { + /* Shouldn't happen, as key tested within bbox above */ + fprintf(stderr, "OOC_BuildRecurse: buggered Morton code, " + "disruption in space-time continuum?\n"); + return OOC_DATAIDX_ERR; + } + + if (node -> leaf.num [k] == OOC_OCTCNT_MAX) { + /* Currently we're buggered here; merge records instead? */ + fprintf(stderr, "OOC_BuildRecurse: data count overflow in " + "leaf: depth = %d, count = %d\n", + depth, node -> leaf.num [k]); + return OOC_DATAIDX_ERR; + } + + ++node -> leaf.num [k]; + +#ifdef DEBUG_OOC_BUILD +/* VCOPY(key, oct -> key(QueueHead(queue))); */ +if ((zIdx = OOC_KEY2MORTON(key, oct)) < lastzIdx) { + fprintf(stderr, "OOC_BuildRecurse, make leaf: unsorted zIdx %020ld for " + "key [%f, %f, %f] (previous zIdx %020ld for " + "key [%f, %f, %f]\n", zIdx, key [0], key [1], key [2], + lastzIdx, lastKey [0], lastKey [1], lastKey [2]); +} + +VCOPY(kidOrg, org); +OOC_OCTORIGIN(kidOrg, k, kidSize); +if (k < lastk || zIdx < lastzIdx) { + fprintf(stderr, + "OOC_BuildRecurse, make leaf: unsorted octant %d (last %d) with " + "bbox [%f-%f, %f-%f, %f-%f] for key [%f, %f, %f] with zIdx %020ld " + "(last [%f, %f, %f], zIdx %020ld)\n", + k, lastk, kidOrg [0], kidOrg [0] + kidSize, + kidOrg [1], kidOrg [1] + kidSize, kidOrg [2], kidOrg [2] + kidSize, + key [0], key [1], key [2], zIdx, + lastKey [0], lastKey [1], lastKey [2], lastzIdx); +} +lastk = k; +lastzIdx = zIdx; +VCOPY(lastKey, key); +#endif + + /* Remove record from queue */ + QueuePop(queue, NULL); + } + + /* Refill queue for next node(s) */ + if (QueueFill(queue) < 0) { + fputs("OOC_Build: failed input queue fill\n", stderr); + return OOC_DATAIDX_ERR; + } + } - } + return OOC_DATACNT(node); } + -OOC_Octree *OOC_Build (OOC_Octree *oct, unsigned recSize, unsigned leafMax, - unsigned maxDepth, const char *heapFileName, - const char *nodeFileName, const char *leafFileName) -/* Build out-of-core octree from unsorted records of size recSize in - * heapFileName, such that leaves contain <= leafMax records, except those - * at maxDepth. Nodes and leaves are output separately to nodeFileName and leafFileName, - * respectively. Returns octree pointer on success, else NULL. */ +OOC_Octree *OOC_Build (OOC_Octree *oct, unsigned leafMax, unsigned maxDepth) +/* Bottom-up construction of out-of-core octree in postorder traversal. The + * octree oct is assumed to be initialised with its origin (oct -> org), + * size (oct -> size), key callback (oct -> key), and its associated leaf + * file (oct -> leafFile). + + * Records are read from the leafFile and assumed to be sorted in Z-order, + * which defines an octree leaf ordering. Leaves (terminal nodes) are + * constructed such that they contain <= leafMax records and have a maximum + * depth of maxDepth. + + * Note that the following limits apply: + * leafMax <= OOC_OCTCNT_MAX (see oococt.h) + * maxDepth <= OOC_MORTON_BITS (see oocsort.h) + + * The maxDepth limit arises from the fact that the Z-ordering has a limited + * resolution and will map node coordinates beyond a depth of + * OOC_MORTON_BITS to the same Z-index, causing nodes to be potentially read + * out of sequence and winding up in the wrong octree nodes. + + * On success, the octree pointer oct is returned, with the constructed + * nodes in oct -> nodes, and the node count in oct -> numNodes. On + * failure, NULL is returned. */ { OOC_BuildQueue queue; - void *rec = malloc(recSize); - FILE *heapFile = fopen(heapFileName, "rb"), - *nodeFile = fopen(nodeFileName, "wb"), - *leafFile = fopen(leafFileName, "wb"); + OOC_Node root; - if (OOC_Init(oct, recSize, leafMax, maxDepth) < 0) { - perror("OOC_Build: failed octree init"); + if (!oct || !oct -> size) { + fputs("OOC_Build: octree not initialised", stderr); return NULL; } - - if (!heapFile) { - perror("OOC_Build: failed opening heap file"); - return NULL; - } - if (!nodeFile || !leafFile) { - perror("OOC_Build: failed opening node/leaf output file"); + if (!oct -> leafFile) { + fputs("OOC_Build: empty leaf file", stderr); return NULL; } + + oct -> leafMax = leafMax; + oct -> maxDepth = maxDepth; + queue.in = oct -> leafFile; + rewind(queue.in); - /* Init and fill queue from heap file */ - if (!rec || !QueueInit(&queue, recSize, leafMax + 1)) { - perror("OOC_Build: failed input queue init"); + /* Init queue and fill from leaf file */ + if (!QueueInit(&queue, oct -> recSize, leafMax + 1) || + QueueFill(&queue) < 0) { + fputs("OOC_Build: failed input queue init\n", stderr); return NULL; } - - do { - if (feof(heapFile) || !fread(rec, recSize, 1, heapFile)) { - perror("OOC_Build: failed reading from heap file"); - - QueuePush(&queue, rec); - } while (!QueueFull(&queue)); - - if (!OOC_BuildRecurse(oct, oct -> root, queue, - heapFile, nodeFile, leafFile)) + + /* Clear octree root and recurse */ + OOC_CLEARNODE(&root); + if (OOC_BuildRecurse(oct, &root, oct -> org, oct -> size, 0, &queue) == + OOC_DATAIDX_ERR) return NULL; - - fclose(heapFile); - fclose(nodeFile); - fclose(leafFile); + + /* Finalise octree root */ + if (!NewNode(oct)) { + fputs("OOC_Build: failed to allocate octree root\n", stderr); + return NULL; + } + OOC_SETROOT(oct, &root); + /* Passing OOC_ROOT(oct) avoids annoying compiler warnings about (&root) + * always evaluating to true when calling OOC_DATAIDX() */ + oct -> numData = OOC_DATACNT(OOC_ROOT(oct)); return oct; }
