root/Development/ray/src/rt/oocbuild.c
Revision: 2.3
Committed: Tue May 17 17:39:47 2016 UTC (9 years, 6 months ago) by rschregle
Changes since 2.2: +261 -75 lines
1 /*
2 =======================================================================
3 Routines for building out-of-core octree data structure
4
5 Adapted from: Kontkanen J., Tabellion E. and Overbeck R.S.,
6 "Coherent Out-of-Core Point-Based Global Illumination",
7 EGSR 2011.
8
9 Roland Schregle (roland.schregle@{hslu.ch, gmail.com})
10 (c) Lucerne University of Applied Sciences and Arts,
11 supported by the Swiss National Science Foundation (SNSF, #147053)
12 =======================================================================
13
14 $Id: oocbuild.c,v 1.23 2015/09/15 13:32:13 taschreg Exp taschreg $
15 */
16
17
18 #include "oococt.h"
19 #include "oocsort.h"
20 #include <stdlib.h>
21 #include <string.h>
22
23
24 /* Test for empty/full input queue, return pointer to head/tail */
25 #define QueueFull(q) ((q) -> len == (q) -> cap)
26 #define QueueEmpty(q) (!(q) -> len)
27 #define QueueHead(q) ((q) -> data + (q) -> head * (q) -> recSize)
28 #define QueueTail(q) ((q) -> data + \
29 ((q)->head + (q)->len-1) % (q)->cap * (q)->recSize)
30
31
32
33 /* Input queue for bottom-up octree construction */
34 typedef struct {
35 void *data;
36 unsigned head, len, cap, recSize; /* Queue head, length (from head),
37 capacity and record size */
38 FILE *in; /* Input file for data records */
39 } OOC_BuildQueue;
40
41
42 static OOC_BuildQueue *QueueInit (OOC_BuildQueue *q, unsigned recSize,
43 unsigned capacity)
44 /* Initialise queue of #capacity records of size recSize each; returns queue
45 * pointer or NULL if failed. */
46 {
47 if (!(q && (q -> data = calloc(capacity, recSize))))
48 return NULL;
49
50 q -> cap = capacity;
51 q -> recSize = recSize;
52 q -> head = q -> len = 0;
53
54 return q;
55 }
56
57
58 static int QueuePush (OOC_BuildQueue *q, const void *rec)
59 /* Append record to queue tail; return new queue length or -1 on failure */
60 {
61 if (!q || !rec || QueueFull(q))
62 return -1;
63
64 ++q->len;
65 memcpy(QueueTail(q), rec, q -> recSize);
66
67 return q -> len;
68 }
69
70
71 static int QueuePop (OOC_BuildQueue *q, void *rec)
72 /* Remove record from queue head and return in rec if not NULL; return new
73 * queue length or -1 on failure */
74 {
75 if (!q || QueueEmpty(q))
76 return -1;
77
78 /* Return head if rec != NULL */
79 if (rec)
80 memcpy(rec, QueueHead(q), q -> recSize);
81
82 q -> head = (q -> head + 1) % q -> cap;
83
84 return --q -> len;
85 }
86
87
88 static int QueueFill (OOC_BuildQueue *q)
89 /* Read records from q -> in until the queue is full; return queue
90 * length or -1 on failure */
91 {
92 static void *rec = NULL;
93
94 if (!rec && !(rec = malloc(q -> recSize)))
95 return -1;
96
97 while (!QueueFull(q) && !feof(q -> in) &&
98 fread(rec, q -> recSize, 1, q -> in))
99 QueuePush(q, rec);
100
101 return q -> len;
102 }
103
104
105
106 static OOC_DataIdx OOC_BuildRecurse (OOC_Octree *oct, OOC_Node* node,
107 FVECT org, RREAL size, unsigned depth,
108 OOC_BuildQueue *queue)
109 /* Recursive part of OOC_Build(); insert records from input queue into
110 * octree node and subdivide into kids if necessary. Returns number of
111 * records in subtree or OOC_DATAIDX_ERR if failed. */
112 {
113 int k;
114 const RREAL kidSize = size * 0.5;
115
116 if (!oct || !node)
117 return OOC_DATAIDX_ERR;
118
119 if (QueueEmpty(queue) ||
120 !OOC_InBBox(oct, org, size, oct -> key(QueueHead(queue))))
121 /* Input exhausted or queue head outside node */
122 return 0;
123
124 if (QueueFull(queue) && depth < oct -> maxDepth &&
125 OOC_InBBox(oct, org, size, oct -> key(QueueTail(queue)))) {
126 /*************************** SUBDIVIDE NODE *************************
127 * At least leafMax + 1 records (since the queue is full) lie inside
128 * the current node's bounding box, and maxDepth has not been reached
129 * ==> subdivide this node.
130 * (Note it suffices to only test the queue tail against the bounding
131 * box, as the records are in Z-order)
132 ********************************************************************/
133 OOC_Node kid [8];
134 OOC_DataIdx dataCnt;
135 FVECT kidOrg;
136
137 #ifdef DEBUG_OOC_BUILD
138 FVECT key;
139 unsigned k2 = 0;
140 #endif
141
142 /* We recurse on the nonempty kids first, then finalise their nodes so
143 * they are ordered consecutively, since the parent only indexes the 1st kid */
144 for (k = 0; k < 8; k++) {
145 /* Clear kid node and get its octant origin */
146 OOC_CLEARNODE(kid + k);
147
148 VCOPY(kidOrg, org);
149 OOC_OCTORIGIN(kidOrg, k, kidSize);
150
151 /* Recurse on kid and check for early bailout */
152 if (OOC_BuildRecurse(oct, kid + k, kidOrg, kidSize,
153 depth + 1, queue) == OOC_DATAIDX_ERR)
154 return OOC_DATAIDX_ERR;
155
156 #ifdef DEBUG_OOC_BUILD
157 if (!QueueEmpty(queue)) {
158 VCOPY(key, oct -> key(QueueHead(queue)));
159 k2 = OOC_Branch(oct, org, kidSize, key, NULL);
160 if (OOC_InBBox(oct, org, size, key) && k2 < k) {
161 fprintf(stderr,
162 "OOC_BuildRecurse, node subdiv: unsorted key [%f, %f, %f] with "
163 "octant %d (last %d with bbox [%f-%f, %f-%f, %f-%f])\n",
164 key [0], key [1], key [2], k2, k,
165 kidOrg [0], kidOrg [0] + kidSize, kidOrg [1], kidOrg [1] + kidSize,
166 kidOrg [2], kidOrg [2] + kidSize);
167 }}
168 #endif
169 }
170
171 /* Now finalise consecutive kid nodes, skipping empty ones */
172 for (k = 0; k < 8; k++)
173 if ((dataCnt = OOC_DATACNT(kid + k))) {
174 /* Nonzero kid ==> allocate and set node */
175 if (!NewNode(oct)) {
176 fputs("OOC_BuildRecurse: failed to allocate new node\n",
177 stderr);
178 return OOC_DATAIDX_ERR;
179 }
180 OOC_SETROOT(oct, kid + k);
181
182 /* Sum kid's data count to parent's and check for overflow */
183 if ((dataCnt += node -> node.num) <= OOC_DATAIDX_MAX)
184 node -> node.num = dataCnt;
185 else {
186 fputs("OOC_BuildRecurse: data count overflow in node\n",
187 stderr);
188 return OOC_DATAIDX_ERR;
189 }
190
191 /* Set kid index in parent (if first kid) and corresponding
192 * branch bit. The kid is the most recent node and thus at the
193 * end of the node array, which coincides with the current
194 * subtree root */
195 if (!node -> node.branch)
196 node -> node.kid = OOC_ROOTIDX(oct);
197
198 OOC_SETBRANCH(node, k);
199 }
200 }
201 else {
202 /****************************** MAKE LEAF ****************************
203 * Queue contains no more than leafMax records, queue tail lies
204 * outside node's bounding box, or maxDepth reached
205 * ==> make this node a leaf.
206 *********************************************************************/
207 RREAL *key;
208
209 #ifdef DEBUG_OOC_BUILD
210 OOC_MortonIdx zIdx, lastzIdx = 0;
211 FVECT /* key, */
212 lastKey, kidOrg;
213 unsigned lastk = 0;
214 #endif
215
216 /* Mark as leaf (note it's been cleared by the parent call) */
217 OOC_SETLEAF(node);
218
219 while (!QueueEmpty(queue) &&
220 OOC_InBBox(oct, org, size, (key = oct->key(QueueHead(queue))))) {
221 /* Record lies inside leaf; increment data counter for octant
222 * containing record. */
223
224 if ((k = OOC_Branch(oct, org, kidSize, key, NULL)) < 0) {
225 /* Shouldn't happen, as key tested within bbox above */
226 fprintf(stderr, "OOC_BuildRecurse: buggered Morton code, "
227 "disruption in space-time continuum?\n");
228 return OOC_DATAIDX_ERR;
229 }
230
231 if (node -> leaf.num [k] == OOC_OCTCNT_MAX) {
232 /* Currently we're buggered here; merge records instead? */
233 fprintf(stderr, "OOC_BuildRecurse: data count overflow in "
234 "leaf: depth = %d, count = %d\n",
235 depth, node -> leaf.num [k]);
236 return OOC_DATAIDX_ERR;
237 }
238
239 ++node -> leaf.num [k];
240
241 #ifdef DEBUG_OOC_BUILD
242 /* VCOPY(key, oct -> key(QueueHead(queue))); */
243 if ((zIdx = OOC_KEY2MORTON(key, oct)) < lastzIdx) {
244 fprintf(stderr, "OOC_BuildRecurse, make leaf: unsorted zIdx %020ld for "
245 "key [%f, %f, %f] (previous zIdx %020ld for "
246 "key [%f, %f, %f]\n", zIdx, key [0], key [1], key [2],
247 lastzIdx, lastKey [0], lastKey [1], lastKey [2]);
248 }
249
250 VCOPY(kidOrg, org);
251 OOC_OCTORIGIN(kidOrg, k, kidSize);
252 if (k < lastk || zIdx < lastzIdx) {
253 fprintf(stderr,
254 "OOC_BuildRecurse, make leaf: unsorted octant %d (last %d) with "
255 "bbox [%f-%f, %f-%f, %f-%f] for key [%f, %f, %f] with zIdx %020ld "
256 "(last [%f, %f, %f], zIdx %020ld)\n",
257 k, lastk, kidOrg [0], kidOrg [0] + kidSize,
258 kidOrg [1], kidOrg [1] + kidSize, kidOrg [2], kidOrg [2] + kidSize,
259 key [0], key [1], key [2], zIdx,
260 lastKey [0], lastKey [1], lastKey [2], lastzIdx);
261 }
262 lastk = k;
263 lastzIdx = zIdx;
264 VCOPY(lastKey, key);
265 #endif
266
267 /* Remove record from queue */
268 QueuePop(queue, NULL);
269 }
270
271 /* Refill queue for next node(s) */
272 if (QueueFill(queue) < 0) {
273 fputs("OOC_Build: failed input queue fill\n", stderr);
274 return OOC_DATAIDX_ERR;
275 }
276 }
277
278 return OOC_DATACNT(node);
279 }
280
281
282
283 OOC_Octree *OOC_Build (OOC_Octree *oct, unsigned leafMax, unsigned maxDepth)
284 /* Bottom-up construction of out-of-core octree in postorder traversal. The
285 * octree oct is assumed to be initialised with its origin (oct -> org),
286 * size (oct -> size), key callback (oct -> key), and its associated leaf
287 * file (oct -> leafFile).
288
289 * Records are read from the leafFile and assumed to be sorted in Z-order,
290 * which defines an octree leaf ordering. Leaves (terminal nodes) are
291 * constructed such that they contain <= leafMax records and have a maximum
292 * depth of maxDepth.
293
294 * Note that the following limits apply:
295 * leafMax <= OOC_OCTCNT_MAX (see oococt.h)
296 * maxDepth <= OOC_MORTON_BITS (see oocsort.h)
297
298 * The maxDepth limit arises from the fact that the Z-ordering has a limited
299 * resolution and will map node coordinates beyond a depth of
300 * OOC_MORTON_BITS to the same Z-index, causing nodes to be potentially read
301 * out of sequence and winding up in the wrong octree nodes.
302
303 * On success, the octree pointer oct is returned, with the constructed
304 * nodes in oct -> nodes, and the node count in oct -> numNodes. On
305 * failure, NULL is returned. */
306 {
307 OOC_BuildQueue queue;
308 OOC_Node root;
309
310 if (!oct || !oct -> size) {
311 fputs("OOC_Build: octree not initialised", stderr);
312 return NULL;
313 }
314
315 if (!oct -> leafFile) {
316 fputs("OOC_Build: empty leaf file", stderr);
317 return NULL;
318 }
319
320 oct -> leafMax = leafMax;
321 oct -> maxDepth = maxDepth;
322 queue.in = oct -> leafFile;
323 rewind(queue.in);
324
325 /* Init queue and fill from leaf file */
326 if (!QueueInit(&queue, oct -> recSize, leafMax + 1) ||
327 QueueFill(&queue) < 0) {
328 fputs("OOC_Build: failed input queue init\n", stderr);
329 return NULL;
330 }
331
332 /* Clear octree root and recurse */
333 OOC_CLEARNODE(&root);
334 if (OOC_BuildRecurse(oct, &root, oct -> org, oct -> size, 0, &queue) ==
335 OOC_DATAIDX_ERR)
336 return NULL;
337
338 /* Finalise octree root */
339 if (!NewNode(oct)) {
340 fputs("OOC_Build: failed to allocate octree root\n", stderr);
341 return NULL;
342 }
343 OOC_SETROOT(oct, &root);
344 /* Passing OOC_ROOT(oct) avoids annoying compiler warnings about (&root)
345 * always evaluating to true when calling OOC_DATAIDX() */
346 oct -> numData = OOC_DATACNT(OOC_ROOT(oct));
347
348 return oct;
349 }
