root/radiance/ray/src/rt/o_mesh.c
Revision: 2.5
Committed: Fri Mar 14 21:27:46 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.4: +12 -6 lines
# User Rev Content
1 greg 2.1 #ifndef lint
2     static const char RCSid[] = "$Id$";
3     #endif
4     /*
5     * Routines for computing ray intersections with meshes.
6     *
7     * Intersection with a triangle mesh is based on Segura and Feito's
8     * WSCG 2001 paper, "Algorithms to Test Ray-Triangle Intersection,
9     * Comparative Study." This method avoids additional storage
10     * requirements, floating divides, and allows some savings by
11     * caching ray-edge comparisons that are otherwise repeated locally
12     * in typical mesh geometries. (This is our own optimization.)
13     *
14     * The code herein is quite similar to that in o_instance.c, the
15     * chief differences being the custom triangle intersection routines
16     * and the fact that an "OBJECT" in the mesh octree is not an index
17     * into the Radiance OBJREC list, but a mesh triangle index. We still
18     * utilize the standard octree traversal code by setting the hitf
19     * function pointer in the RAY struct to our custom mesh_hit() call.
20     */
21
22     #include "copyright.h"
23
24     #include "ray.h"
25
26     #include "mesh.h"
27
28     #include "tmesh.h"
29
30
31 greg 2.2 #define EDGE_CACHE_SIZ 251 /* length of mesh edge cache */
32 greg 2.1
33     #define curmi (edge_cache.mi)
34     #define curmsh (curmi->msh)
35
36
37     /* Cache of signed volumes for this ray and this mesh */
38     struct EdgeCache {
39     OBJREC *o; /* mesh object */
40     MESHINST *mi; /* current mesh instance */
41     struct EdgeSide {
42     int4 v1i, v2i; /* vertex indices (lowest first) */
43     short signum; /* signed volume */
44     } cache[EDGE_CACHE_SIZ];
45     } edge_cache;
46
47
48     static void
49     prep_edge_cache(o) /* get instance and clear edge cache */
50     OBJREC *o;
51     {
52     /* get mesh instance */
53     edge_cache.mi = getmeshinst(edge_cache.o = o, IO_ALL);
54     /* clear edge cache */
55     bzero((void *)edge_cache.cache, sizeof(edge_cache.cache));
56     }
57
58
59     static int
60     signed_volume(r, v1, v2) /* get signed volume for ray and edge */
61     register RAY *r;
62     int4 v1, v2;
63     {
64     int reversed = 0;
65     register struct EdgeSide *ecp;
66
67     if (v1 > v2) {
68     int4 t = v2; v2 = v1; v1 = t;
69     reversed = 1;
70     }
71 greg 2.2 ecp = &edge_cache.cache[((v2<<11 ^ v1) & 0x7fffffff) % EDGE_CACHE_SIZ];
72 greg 2.1 if (ecp->v1i != v1 || ecp->v2i != v2) {
73     MESHVERT tv1, tv2; /* compute signed volume */
74 greg 2.4 FVECT v2d;
75 greg 2.1 double vol;
76     if (!getmeshvert(&tv1, edge_cache.mi->msh, v1, MT_V) ||
77 greg 2.2 !getmeshvert(&tv2, edge_cache.mi->msh, v2, MT_V))
78 greg 2.1 objerror(edge_cache.o, INTERNAL,
79 greg 2.2 "missing mesh vertex in signed_volume");
80 greg 2.4 VSUB(v2d, tv2.v, r->rorg);
81 greg 2.1 vol = (tv1.v[0] - r->rorg[0]) *
82 greg 2.4 (v2d[1]*r->rdir[2] - v2d[2]*r->rdir[1]);
83 greg 2.1 vol += (tv1.v[1] - r->rorg[1]) *
84 greg 2.4 (v2d[2]*r->rdir[0] - v2d[0]*r->rdir[2]);
85 greg 2.1 vol += (tv1.v[2] - r->rorg[2]) *
86 greg 2.4 (v2d[0]*r->rdir[1] - v2d[1]*r->rdir[0]);
87 greg 2.1 if (vol > .0)
88     ecp->signum = 1;
89     else if (vol < .0)
90     ecp->signum = -1;
91     else
92     ecp->signum = 0;
93     ecp->v1i = v1;
94     ecp->v2i = v2;
95     }
96     return(reversed ? -ecp->signum : ecp->signum);
97     }
98
99
100     static void
101     mesh_hit(oset, r) /* intersect ray with mesh triangle(s) */
102     OBJECT *oset;
103     RAY *r;
104     {
105     int4 tvi[3];
106     int sv1, sv2, sv3;
107     MESHVERT tv[3];
108 greg 2.5 OBJECT tmod;
109 greg 2.1 FVECT va, vb, nrm;
110     double d;
111     int i;
112     /* check each triangle */
113     for (i = oset[0]; i > 0; i--) {
114 greg 2.5 if (!getmeshtrivid(tvi, &tmod, curmsh, oset[i]))
115 greg 2.1 objerror(edge_cache.o, INTERNAL,
116 greg 2.2 "missing triangle vertices in mesh_hit");
117 greg 2.1 sv1 = signed_volume(r, tvi[0], tvi[1]);
118     sv2 = signed_volume(r, tvi[1], tvi[2]);
119     sv3 = signed_volume(r, tvi[2], tvi[0]);
120     if (sv1 != sv2 || sv2 != sv3) /* compare volume signs */
121     if (sv1 && sv2 && sv3)
122     continue;
123     /* compute intersection */
124     getmeshvert(&tv[0], curmsh, tvi[0], MT_V);
125     getmeshvert(&tv[1], curmsh, tvi[1], MT_V);
126     getmeshvert(&tv[2], curmsh, tvi[2], MT_V);
127     VSUB(va, tv[0].v, tv[2].v);
128     VSUB(vb, tv[1].v, tv[0].v);
129     VCROSS(nrm, va, vb);
130     d = DOT(r->rdir, nrm);
131     if (d == 0.0)
132     continue; /* ray is tangent */
133     VSUB(va, tv[0].v, r->rorg);
134     d = DOT(va, nrm) / d;
135     if (d <= FTINY || d >= r->rot)
136     continue; /* not good enough */
137     r->robj = oset[i]; /* else record hit */
138     r->ro = edge_cache.o;
139     r->rot = d;
140     VSUM(r->rop, r->rorg, r->rdir, d);
141     VCOPY(r->ron, nrm);
142 greg 2.2 /* normalize(r->ron) called & r->rod set in o_mesh() */
143 greg 2.1 }
144     }
145
146
147     int
148     o_mesh(o, r) /* compute ray intersection with a mesh */
149     OBJREC *o;
150     register RAY *r;
151     {
152     RAY rcont;
153     int flags;
154     MESHVERT tv[3];
155 greg 2.5 OBJECT tmod;
156 greg 2.1 FLOAT wt[3];
157     int i;
158     /* get the mesh instance */
159     prep_edge_cache(o);
160     /* copy and transform ray */
161     copystruct(&rcont, r);
162     multp3(rcont.rorg, r->rorg, curmi->x.b.xfm);
163     multv3(rcont.rdir, r->rdir, curmi->x.b.xfm);
164     for (i = 0; i < 3; i++)
165     rcont.rdir[i] /= curmi->x.b.sca;
166     rcont.rmax *= curmi->x.b.sca;
167     /* clear and trace ray */
168     rayclear(&rcont);
169     rcont.hitf = mesh_hit;
170     if (!localhit(&rcont, &curmi->msh->mcube))
171     return(0); /* missed */
172     if (rcont.rot * curmi->x.f.sca >= r->rot)
173     return(0); /* not close enough */
174     /* transform ray back */
175     r->rot = rcont.rot * curmi->x.f.sca;
176     multp3(r->rop, rcont.rop, curmi->x.f.xfm);
177     multv3(r->ron, rcont.ron, curmi->x.f.xfm);
178     normalize(r->ron);
179     r->rod = -DOT(r->rdir, r->ron);
180 greg 2.5 /* get triangle */
181     flags = getmeshtri(tv, &tmod, curmsh, rcont.robj, MT_ALL);
182 greg 2.1 if (!(flags & MT_V))
183     objerror(o, INTERNAL, "missing mesh vertices in o_mesh");
184 greg 2.5 r->robj = objndx(o); /* set object and material */
185     if (o->omod == OVOID && tmod != OVOID) {
186     r->ro = getmeshpseudo(curmsh, tmod);
187     r->rox = &curmi->x;
188     } else
189     r->ro = o;
190     /* compute barycentric weights */
191 greg 2.1 if (flags & (MT_N|MT_UV))
192     if (get_baryc(wt, rcont.rop, tv[0].v, tv[1].v, tv[2].v) < 0) {
193     objerror(o, WARNING, "bad triangle in o_mesh");
194     flags &= ~(MT_N|MT_UV);
195     }
196     if (flags & MT_N) { /* interpolate normal */
197     for (i = 0; i < 3; i++)
198     rcont.pert[i] = wt[0]*tv[0].n[i] +
199     wt[1]*tv[1].n[i] +
200     wt[2]*tv[2].n[i];
201     multv3(r->pert, rcont.pert, curmi->x.f.xfm);
202     if (normalize(r->pert) != 0.0)
203     for (i = 0; i < 3; i++)
204     r->pert[i] -= r->ron[i];
205 greg 2.3 } else
206     r->pert[0] = r->pert[1] = r->pert[2] = .0;
207
208 greg 2.1 if (flags & MT_UV) /* interpolate uv coordinates */
209     for (i = 0; i < 2; i++)
210     r->uv[i] = wt[0]*tv[0].uv[i] +
211     wt[1]*tv[1].uv[i] +
212     wt[2]*tv[2].uv[i];
213 greg 2.3 else
214     r->uv[0] = r->uv[1] = .0;
215 greg 2.1
216     /* return hit */
217     return(1);
218     }
