root/radiance/ray/src/rt/o_mesh.c
Revision: 2.16
Committed: Wed Jun 18 22:16:31 2025 UTC (3 days, 21 hours ago) by greg
Changes since 2.15: +4 -2 lines
fix: Forgot to reset r->rox on intersection
2 static const char RCSid[] = "$Id: o_mesh.c,v 2.15 2019/03/01 02:03:33 greg Exp $";
5 * Routines for computing ray intersections with meshes.
6 *
7 * Intersection with a triangle mesh is based on Segura and Feito's
8 * WSCG 2001 paper, "Algorithms to Test Ray-Triangle Intersection,
9 * Comparative Study." This method avoids additional storage
10 * requirements, floating divides, and allows some savings by
11 * caching ray-edge comparisons that are otherwise repeated locally
12 * in typical mesh geometries. (This is our own optimization.)
13 *
14 * The code herein is quite similar to that in o_instance.c, the
15 * chief differences being the custom triangle intersection routines
16 * and the fact that an "OBJECT" in the mesh octree is not an index
17 * into the Radiance OBJREC list, but a mesh triangle index. We still
18 * utilize the standard octree traversal code by setting the hitf
19 * function pointer in the RAY struct to our custom mesh_hit() call.
20 */
21
22 #include "copyright.h"
23
24 #include <string.h>
25
26 #include "ray.h"
27 #include "mesh.h"
28 #include "tmesh.h"
29 #include "rtotypes.h"
30
31
32 #define EDGE_CACHE_SIZ 251 /* length of mesh edge cache */
33
34 #define curmi (edge_cache.mi)
35 #define curmsh (curmi->msh)
36
37
38 /* Cache of signed volumes for this ray and this mesh */
39 struct EdgeCache {
40 OBJREC *o; /* mesh object */
41 MESHINST *mi; /* current mesh instance */
42 struct EdgeSide {
43 int32 v1i, v2i; /* vertex indices (lowest first) */
44 short signum; /* signed volume */
45 } cache[EDGE_CACHE_SIZ];
46 } edge_cache;
47
48
49 static void
50 prep_edge_cache(o) /* get instance and clear edge cache */
51 OBJREC *o;
52 {
53 /* get mesh instance */
54 edge_cache.mi = getmeshinst(edge_cache.o = o, IO_ALL);
55 /* clear edge cache */
56 memset((void *)edge_cache.cache, '\0', sizeof(edge_cache.cache));
57 }
58
59
60 static int
61 volume_sign(r, v1, v2) /* get signed volume for ray and edge */
62 RAY *r;
63 int32 v1, v2;
64 {
65 int reversed = 0;
66 struct EdgeSide *ecp;
67
68 if (v1 > v2) {
69 int32 t = v2; v2 = v1; v1 = t;
70 reversed = 1;
71 }
72 ecp = &edge_cache.cache[((v2<<11 ^ v1) & 0x7fffffff) % EDGE_CACHE_SIZ];
73 if ((ecp->v1i != v1) | (ecp->v2i != v2)) {
74 MESHVERT tv1, tv2; /* compute signed volume */
75 FVECT v2d;
76 double vol;
77 if (!getmeshvert(&tv1, edge_cache.mi->msh, v1, MT_V) |
78 !getmeshvert(&tv2, edge_cache.mi->msh, v2, MT_V))
79 objerror(edge_cache.o, INTERNAL,
80 "missing mesh vertex in volume_sign");
81 VSUB(v2d, tv2.v, r->rorg);
82 vol = (tv1.v[0] - r->rorg[0]) *
83 (v2d[1]*r->rdir[2] - v2d[2]*r->rdir[1]);
84 vol += (tv1.v[1] - r->rorg[1]) *
85 (v2d[2]*r->rdir[0] - v2d[0]*r->rdir[2]);
86 vol += (tv1.v[2] - r->rorg[2]) *
87 (v2d[0]*r->rdir[1] - v2d[1]*r->rdir[0]);
88 /* don't generate 0 */
89 ecp->signum = vol > .0 ? 1 : -1;
90 ecp->v1i = v1;
91 ecp->v2i = v2;
92 }
93 return(reversed ? -ecp->signum : ecp->signum);
94 }
95
96
97 static void
98 mesh_hit(oset, r) /* intersect ray with mesh triangle(s) */
99 OBJECT *oset;
100 RAY *r;
101 {
102 int32 tvi[3];
103 int sv1, sv2, sv3;
104 MESHVERT tv[3];
105 OBJECT tmod;
106 FVECT va, vb, nrm;
107 double d;
108 int i;
109 /* check each triangle */
110 for (i = oset[0]; i > 0; i--) {
111 if (!getmeshtrivid(tvi, &tmod, curmsh, oset[i]))
112 objerror(edge_cache.o, INTERNAL,
113 "missing triangle vertices in mesh_hit");
114 sv1 = volume_sign(r, tvi[0], tvi[1]);
115 sv2 = volume_sign(r, tvi[1], tvi[2]);
116 if (sv1 != sv2) /* compare volume signs */
117 continue;
118 sv3 = volume_sign(r, tvi[2], tvi[0]);
119 if (sv2 != sv3)
120 continue;
121 /* compute intersection */
122 getmeshvert(&tv[0], curmsh, tvi[0], MT_V);
123 getmeshvert(&tv[1], curmsh, tvi[1], MT_V);
124 getmeshvert(&tv[2], curmsh, tvi[2], MT_V);
125 VSUB(va, tv[0].v, tv[2].v);
126 VSUB(vb, tv[1].v, tv[0].v);
127 VCROSS(nrm, va, vb);
128 d = DOT(r->rdir, nrm);
129 if (d == 0.0)
130 continue; /* ray is tangent */
131 VSUB(va, tv[0].v, r->rorg);
132 d = DOT(va, nrm) / d;
133 if ((d <= FTINY) | (d >= r->rot))
134 continue; /* not good enough */
135 r->robj = oset[i]; /* else record hit */
136 r->ro = edge_cache.o;
137 r->rot = d;
138 VSUM(r->rop, r->rorg, r->rdir, d);
139 VCOPY(r->ron, nrm);
140 /* normalize(r->ron) called & r->rod set in o_mesh() */
141 }
142 }
143
144
145 int
146 o_mesh( /* compute ray intersection with a mesh */
147 OBJREC *o,
148 RAY *r
149 )
150 {
151 RAY rcont;
152 int flags;
153 MESHVERT tv[3];
154 OBJECT tmod;
155 RREAL wt[3];
156 int i;
157 /* get the mesh instance */
158 prep_edge_cache(o);
159 /* copy and transform ray */
160 rcont = *r;
161 multp3(rcont.rorg, r->rorg, curmi->x.b.xfm);
162 multv3(rcont.rdir, r->rdir, curmi->x.b.xfm);
163 for (i = 0; i < 3; i++)
164 rcont.rdir[i] /= curmi->x.b.sca;
165 rcont.rmax *= curmi->x.b.sca;
166 /* clear and trace ray */
167 rayclear(&rcont);
168 rcont.hitf = mesh_hit;
169 if (!localhit(&rcont, &curmi->msh->mcube))
170 return(0); /* missed */
171 if (rcont.rot * curmi->x.f.sca >= r->rot)
172 return(0); /* not close enough */
173 /* transform ray back */
174 r->rot = rcont.rot * curmi->x.f.sca;
175 multp3(r->rop, rcont.rop, curmi->x.f.xfm);
176 multv3(r->ron, rcont.ron, curmi->x.f.xfm);
177 normalize(r->ron);
178 r->rod = -DOT(r->rdir, r->ron);
179 /* get triangle */
180 flags = getmeshtri(tv, &tmod, curmsh, rcont.robj, MT_ALL);
181 if (!(flags & MT_V))
182 objerror(o, INTERNAL, "missing mesh vertices in o_mesh");
183 r->robj = objndx(o); /* set object and material */
184 if ((o->omod == OVOID) & (tmod != OVOID)) {
185 r->ro = getmeshpseudo(curmsh, tmod);
186 r->rox = &curmi->x;
187 } else {
188 r->ro = o;
189 r->rox = NULL;
190 }
191 /* compute barycentric weights */
192 if (flags & (MT_N|MT_UV))
193 if (get_baryc(wt, rcont.rop, tv[0].v, tv[1].v, tv[2].v) < 0) {
194 objerror(o, WARNING, "bad triangle in o_mesh");
195 flags &= ~(MT_N|MT_UV);
196 }
197 if (flags & MT_N) { /* interpolate normal */
198 for (i = 0; i < 3; i++)
199 rcont.pert[i] = wt[0]*tv[0].n[i] +
200 wt[1]*tv[1].n[i] +
201 wt[2]*tv[2].n[i];
202 multv3(r->pert, rcont.pert, curmi->x.f.xfm);
203 if (normalize(r->pert) != 0.0)
204 VSUB(r->pert, r->pert, r->ron);
205 } else
206 r->pert[0] = r->pert[1] = r->pert[2] = .0;
207
208 if (flags & MT_UV) /* interpolate uv coordinates */
209 for (i = 0; i < 2; i++)
210 r->uv[i] = wt[0]*tv[0].uv[i] +
211 wt[1]*tv[1].uv[i] +
212 wt[2]*tv[2].uv[i];
213 else
214 r->uv[0] = r->uv[1] = .0;
215
216 return(1); /* return hit */
217 }
