--- ray/src/rt/o_mesh.c 2012/10/23 05:03:52 2.13 +++ ray/src/rt/o_mesh.c 2019/03/01 02:03:33 2.15 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: o_mesh.c,v 2.13 2012/10/23 05:03:52 greg Exp $"; +static const char RCSid[] = "$Id: o_mesh.c,v 2.15 2019/03/01 02:03:33 greg Exp $"; #endif /* * Routines for computing ray intersections with meshes. @@ -59,11 +59,11 @@ OBJREC *o; static int volume_sign(r, v1, v2) /* get signed volume for ray and edge */ -register RAY *r; +RAY *r; int32 v1, v2; { - int reversed = 0; - register struct EdgeSide *ecp; + int reversed = 0; + struct EdgeSide *ecp; if (v1 > v2) { int32 t = v2; v2 = v1; v1 = t; @@ -130,7 +130,7 @@ RAY *r; continue; /* ray is tangent */ VSUB(va, tv[0].v, r->rorg); d = DOT(va, nrm) / d; - if (d <= FTINY || d >= r->rot) + if ((d <= FTINY) | (d >= r->rot)) continue; /* not good enough */ r->robj = oset[i]; /* else record hit */ r->ro = edge_cache.o; @@ -142,10 +142,10 @@ RAY *r; } -extern int +int o_mesh( /* compute ray intersection with a mesh */ OBJREC *o, - register RAY *r + RAY *r ) { RAY rcont; @@ -181,7 +181,7 @@ o_mesh( /* compute ray intersection with a mesh */ if (!(flags & MT_V)) objerror(o, INTERNAL, "missing mesh vertices in o_mesh"); r->robj = objndx(o); /* set object and material */ - if (o->omod == OVOID && tmod != OVOID) { + if ((o->omod == OVOID) & (tmod != OVOID)) { r->ro = getmeshpseudo(curmsh, tmod); r->rox = &curmi->x; } else @@ -210,7 +210,6 @@ o_mesh( /* compute ray intersection with a mesh */ wt[2]*tv[2].uv[i]; else r->uv[0] = r->uv[1] = .0; - - /* return hit */ - return(1); + + return(1); /* return hit */ }
