| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: o_mesh.c,v 2.14 2014/07/08 18:25:00 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* Routines for computing ray intersections with meshes.
| 6 |
| 7 |
* Intersection with a triangle mesh is based on Segura and Feito's
| 8 |
* WSCG 2001 paper, "Algorithms to Test Ray-Triangle Intersection,
| 9 |
* Comparative Study." This method avoids additional storage
| 10 |
* requirements, floating divides, and allows some savings by
| 11 |
* caching ray-edge comparisons that are otherwise repeated locally
| 12 |
* in typical mesh geometries. (This is our own optimization.)
| 13 |
| 14 |
* The code herein is quite similar to that in o_instance.c, the
| 15 |
* chief differences being the custom triangle intersection routines
| 16 |
* and the fact that an "OBJECT" in the mesh octree is not an index
| 17 |
* into the Radiance OBJREC list, but a mesh triangle index. We still
| 18 |
* utilize the standard octree traversal code by setting the hitf
| 19 |
* function pointer in the RAY struct to our custom mesh_hit() call.
| 20 |
| 21 |
| 22 |
#include "copyright.h"
| 23 |
| 24 |
#include <string.h>
| 25 |
| 26 |
#include "ray.h"
| 27 |
#include "mesh.h"
| 28 |
#include "tmesh.h"
| 29 |
#include "rtotypes.h"
| 30 |
| 31 |
| 32 |
#define EDGE_CACHE_SIZ 251 /* length of mesh edge cache */
| 33 |
| 34 |
#define curmi (edge_cache.mi)
| 35 |
#define curmsh (curmi->msh)
| 36 |
| 37 |
| 38 |
/* Cache of signed volumes for this ray and this mesh */
| 39 |
struct EdgeCache {
| 40 |
OBJREC *o; /* mesh object */
| 41 |
MESHINST *mi; /* current mesh instance */
| 42 |
struct EdgeSide {
| 43 |
int32 v1i, v2i; /* vertex indices (lowest first) */
| 44 |
short signum; /* signed volume */
| 45 |
} cache[EDGE_CACHE_SIZ];
| 46 |
} edge_cache;
| 47 |
| 48 |
| 49 |
static void
| 50 |
prep_edge_cache(o) /* get instance and clear edge cache */
| 51 |
OBJREC *o;
| 52 |
| 53 |
/* get mesh instance */
| 54 |
edge_cache.mi = getmeshinst(edge_cache.o = o, IO_ALL);
| 55 |
/* clear edge cache */
| 56 |
memset((void *)edge_cache.cache, '\0', sizeof(edge_cache.cache));
| 57 |
| 58 |
| 59 |
| 60 |
static int
| 61 |
volume_sign(r, v1, v2) /* get signed volume for ray and edge */
| 62 |
RAY *r;
| 63 |
int32 v1, v2;
| 64 |
| 65 |
int reversed = 0;
| 66 |
struct EdgeSide *ecp;
| 67 |
| 68 |
if (v1 > v2) {
| 69 |
int32 t = v2; v2 = v1; v1 = t;
| 70 |
reversed = 1;
| 71 |
| 72 |
ecp = &edge_cache.cache[((v2<<11 ^ v1) & 0x7fffffff) % EDGE_CACHE_SIZ];
| 73 |
if ((ecp->v1i != v1) | (ecp->v2i != v2)) {
| 74 |
MESHVERT tv1, tv2; /* compute signed volume */
| 75 |
FVECT v2d;
| 76 |
double vol;
| 77 |
if (!getmeshvert(&tv1, edge_cache.mi->msh, v1, MT_V) |
| 78 |
!getmeshvert(&tv2, edge_cache.mi->msh, v2, MT_V))
| 79 |
objerror(edge_cache.o, INTERNAL,
| 80 |
"missing mesh vertex in volume_sign");
| 81 |
VSUB(v2d, tv2.v, r->rorg);
| 82 |
vol = (tv1.v[0] - r->rorg[0]) *
| 83 |
(v2d[1]*r->rdir[2] - v2d[2]*r->rdir[1]);
| 84 |
vol += (tv1.v[1] - r->rorg[1]) *
| 85 |
(v2d[2]*r->rdir[0] - v2d[0]*r->rdir[2]);
| 86 |
vol += (tv1.v[2] - r->rorg[2]) *
| 87 |
(v2d[0]*r->rdir[1] - v2d[1]*r->rdir[0]);
| 88 |
/* don't generate 0 */
| 89 |
ecp->signum = vol > .0 ? 1 : -1;
| 90 |
ecp->v1i = v1;
| 91 |
ecp->v2i = v2;
| 92 |
| 93 |
return(reversed ? -ecp->signum : ecp->signum);
| 94 |
| 95 |
| 96 |
| 97 |
static void
| 98 |
mesh_hit(oset, r) /* intersect ray with mesh triangle(s) */
| 99 |
OBJECT *oset;
| 100 |
RAY *r;
| 101 |
| 102 |
int32 tvi[3];
| 103 |
int sv1, sv2, sv3;
| 104 |
MESHVERT tv[3];
| 105 |
OBJECT tmod;
| 106 |
FVECT va, vb, nrm;
| 107 |
double d;
| 108 |
int i;
| 109 |
/* check each triangle */
| 110 |
for (i = oset[0]; i > 0; i--) {
| 111 |
if (!getmeshtrivid(tvi, &tmod, curmsh, oset[i]))
| 112 |
| 113 |
"missing triangle vertices in mesh_hit");
| 114 |
sv1 = volume_sign(r, tvi[0], tvi[1]);
| 115 |
sv2 = volume_sign(r, tvi[1], tvi[2]);
| 116 |
if (sv1 != sv2) /* compare volume signs */
| 117 |
continue;
| 118 |
sv3 = volume_sign(r, tvi[2], tvi[0]);
| 119 |
if (sv2 != sv3)
| 120 |
continue;
| 121 |
/* compute intersection */
| 122 |
getmeshvert(&tv[0], curmsh, tvi[0], MT_V);
| 123 |
getmeshvert(&tv[1], curmsh, tvi[1], MT_V);
| 124 |
getmeshvert(&tv[2], curmsh, tvi[2], MT_V);
| 125 |
VSUB(va, tv[0].v, tv[2].v);
| 126 |
VSUB(vb, tv[1].v, tv[0].v);
| 127 |
VCROSS(nrm, va, vb);
| 128 |
d = DOT(r->rdir, nrm);
| 129 |
if (d == 0.0)
| 130 |
continue; /* ray is tangent */
| 131 |
VSUB(va, tv[0].v, r->rorg);
| 132 |
d = DOT(va, nrm) / d;
| 133 |
if ((d <= FTINY) | (d >= r->rot))
| 134 |
continue; /* not good enough */
| 135 |
r->robj = oset[i]; /* else record hit */
| 136 |
r->ro = edge_cache.o;
| 137 |
r->rot = d;
| 138 |
VSUM(r->rop, r->rorg, r->rdir, d);
| 139 |
VCOPY(r->ron, nrm);
| 140 |
/* normalize(r->ron) called & r->rod set in o_mesh() */
| 141 |
| 142 |
| 143 |
| 144 |
| 145 |
int
| 146 |
o_mesh( /* compute ray intersection with a mesh */
| 147 |
OBJREC *o,
| 148 |
RAY *r
| 149 |
| 150 |
| 151 |
RAY rcont;
| 152 |
int flags;
| 153 |
MESHVERT tv[3];
| 154 |
OBJECT tmod;
| 155 |
RREAL wt[3];
| 156 |
int i;
| 157 |
/* get the mesh instance */
| 158 |
prep_edge_cache(o);
| 159 |
/* copy and transform ray */
| 160 |
rcont = *r;
| 161 |
multp3(rcont.rorg, r->rorg, curmi->x.b.xfm);
| 162 |
multv3(rcont.rdir, r->rdir, curmi->x.b.xfm);
| 163 |
for (i = 0; i < 3; i++)
| 164 |
rcont.rdir[i] /= curmi->x.b.sca;
| 165 |
rcont.rmax *= curmi->x.b.sca;
| 166 |
/* clear and trace ray */
| 167 |
rayclear(&rcont);
| 168 |
rcont.hitf = mesh_hit;
| 169 |
if (!localhit(&rcont, &curmi->msh->mcube))
| 170 |
return(0); /* missed */
| 171 |
if (rcont.rot * curmi->x.f.sca >= r->rot)
| 172 |
return(0); /* not close enough */
| 173 |
/* transform ray back */
| 174 |
r->rot = rcont.rot * curmi->x.f.sca;
| 175 |
multp3(r->rop, rcont.rop, curmi->x.f.xfm);
| 176 |
multv3(r->ron, rcont.ron, curmi->x.f.xfm);
| 177 |
normalize(r->ron);
| 178 |
r->rod = -DOT(r->rdir, r->ron);
| 179 |
/* get triangle */
| 180 |
flags = getmeshtri(tv, &tmod, curmsh, rcont.robj, MT_ALL);
| 181 |
if (!(flags & MT_V))
| 182 |
objerror(o, INTERNAL, "missing mesh vertices in o_mesh");
| 183 |
r->robj = objndx(o); /* set object and material */
| 184 |
if ((o->omod == OVOID) & (tmod != OVOID)) {
| 185 |
r->ro = getmeshpseudo(curmsh, tmod);
| 186 |
r->rox = &curmi->x;
| 187 |
} else
| 188 |
r->ro = o;
| 189 |
/* compute barycentric weights */
| 190 |
if (flags & (MT_N|MT_UV))
| 191 |
if (get_baryc(wt, rcont.rop, tv[0].v, tv[1].v, tv[2].v) < 0) {
| 192 |
objerror(o, WARNING, "bad triangle in o_mesh");
| 193 |
flags &= ~(MT_N|MT_UV);
| 194 |
| 195 |
if (flags & MT_N) { /* interpolate normal */
| 196 |
| 197 |
rcont.pert[i] = wt[0]*tv[0].n[i] +
| 198 |
wt[1]*tv[1].n[i] +
| 199 |
wt[2]*tv[2].n[i];
| 200 |
multv3(r->pert, rcont.pert, curmi->x.f.xfm);
| 201 |
if (normalize(r->pert) != 0.0)
| 202 |
VSUB(r->pert, r->pert, r->ron);
| 203 |
} else
| 204 |
r->pert[0] = r->pert[1] = r->pert[2] = .0;
| 205 |
| 206 |
if (flags & MT_UV) /* interpolate uv coordinates */
| 207 |
for (i = 0; i < 2; i++)
| 208 |
r->uv[i] = wt[0]*tv[0].uv[i] +
| 209 |
wt[1]*tv[1].uv[i] +
| 210 |
wt[2]*tv[2].uv[i];
| 211 |
else
| 212 |
r->uv[0] = r->uv[1] = .0;
| 213 |
| 214 |
return(1); /* return hit */
| 215 |
