root/radiance/ray/src/rt/o_mesh.c
Sat Feb 25 19:49:16 2006 UTC (18 years, 2 months ago) by greg
Changes since 2.10: +13 -17 lines
Diff to previous 2.10 , to selected 2.3
Minor optimizations in ray-triangle intersection test
Changes since 2.9: +7 -5 lines
Diff to previous 2.9 , to selected 2.3
Fri Jun 20 00:25:50 2003 UTC (20 years, 10 months ago) by greg
Fri Mar 14 21:27:46 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.4: +12 -6 lines
Wed Mar 12 17:26:58 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.3: +5 -6 lines
Wed Mar 12 04:59:05 2003 UTC (21 years, 1 month ago) by greg
Tue Mar 11 22:48:20 2003 UTC (21 years, 1 month ago) by greg
Tue Mar 11 17:08:55 2003 UTC (21 years, 1 month ago) by greg
Diff to selected 2.3
