root/radiance/ray/src/rt/o_mesh.c
Revision: 2.11
Committed: Sat Feb 25 19:49:16 2006 UTC (18 years, 3 months ago) by greg
CVS Tags: rad4R0, rad3R8, rad3R9
Changes since 2.10: +13 -17 lines
Minor optimizations in ray-triangle intersection test
# User Rev Content
1 greg 2.1 #ifndef lint
2 greg 2.11 static const char RCSid[] = "$Id: o_mesh.c,v 2.10 2004/03/30 16:13:01 schorsch Exp $";
3 greg 2.1 #endif
4     /*
5     * Routines for computing ray intersections with meshes.
6     *
7     * Intersection with a triangle mesh is based on Segura and Feito's
8     * WSCG 2001 paper, "Algorithms to Test Ray-Triangle Intersection,
9     * Comparative Study." This method avoids additional storage
10     * requirements, floating divides, and allows some savings by
11     * caching ray-edge comparisons that are otherwise repeated locally
12     * in typical mesh geometries. (This is our own optimization.)
13     *
14     * The code herein is quite similar to that in o_instance.c, the
15     * chief differences being the custom triangle intersection routines
16     * and the fact that an "OBJECT" in the mesh octree is not an index
17     * into the Radiance OBJREC list, but a mesh triangle index. We still
18     * utilize the standard octree traversal code by setting the hitf
19     * function pointer in the RAY struct to our custom mesh_hit() call.
20     */
21
22     #include "copyright.h"
23
24 schorsch 2.8 #include <string.h>
25
26 greg 2.1 #include "ray.h"
27     #include "mesh.h"
28     #include "tmesh.h"
29 schorsch 2.10 #include "rtotypes.h"
30 greg 2.1
31
32 greg 2.2 #define EDGE_CACHE_SIZ 251 /* length of mesh edge cache */
33 greg 2.1
34     #define curmi (edge_cache.mi)
35     #define curmsh (curmi->msh)
36
37
38     /* Cache of signed volumes for this ray and this mesh */
39     struct EdgeCache {
40     OBJREC *o; /* mesh object */
41     MESHINST *mi; /* current mesh instance */
42     struct EdgeSide {
43 greg 2.6 int32 v1i, v2i; /* vertex indices (lowest first) */
44 greg 2.1 short signum; /* signed volume */
45     } cache[EDGE_CACHE_SIZ];
46     } edge_cache;
47
48
49     static void
50     prep_edge_cache(o) /* get instance and clear edge cache */
51     OBJREC *o;
52     {
53     /* get mesh instance */
54     edge_cache.mi = getmeshinst(edge_cache.o = o, IO_ALL);
55     /* clear edge cache */
56 schorsch 2.8 memset((void *)edge_cache.cache, '\0', sizeof(edge_cache.cache));
57 greg 2.1 }
58
59
60     static int
61 greg 2.11 volume_sign(r, v1, v2) /* get signed volume for ray and edge */
62 greg 2.1 register RAY *r;
63 greg 2.6 int32 v1, v2;
64 greg 2.1 {
65     int reversed = 0;
66     register struct EdgeSide *ecp;
67
68     if (v1 > v2) {
69 greg 2.6 int32 t = v2; v2 = v1; v1 = t;
70 greg 2.1 reversed = 1;
71     }
72 greg 2.2 ecp = &edge_cache.cache[((v2<<11 ^ v1) & 0x7fffffff) % EDGE_CACHE_SIZ];
73 greg 2.11 if ((ecp->v1i != v1) | (ecp->v2i != v2)) {
74 greg 2.1 MESHVERT tv1, tv2; /* compute signed volume */
75 greg 2.4 FVECT v2d;
76 greg 2.1 double vol;
77 greg 2.11 if (!getmeshvert(&tv1, edge_cache.mi->msh, v1, MT_V) |
78 greg 2.2 !getmeshvert(&tv2, edge_cache.mi->msh, v2, MT_V))
79 greg 2.1 objerror(edge_cache.o, INTERNAL,
80 greg 2.11 "missing mesh vertex in volume_sign");
81 greg 2.4 VSUB(v2d, tv2.v, r->rorg);
82 greg 2.1 vol = (tv1.v[0] - r->rorg[0]) *
83 greg 2.4 (v2d[1]*r->rdir[2] - v2d[2]*r->rdir[1]);
84 greg 2.1 vol += (tv1.v[1] - r->rorg[1]) *
85 greg 2.4 (v2d[2]*r->rdir[0] - v2d[0]*r->rdir[2]);
86 greg 2.1 vol += (tv1.v[2] - r->rorg[2]) *
87 greg 2.4 (v2d[0]*r->rdir[1] - v2d[1]*r->rdir[0]);
88 greg 2.11 /* don't generate 0 */
89     ecp->signum = vol > .0 ? 1 : -1;
90 greg 2.1 ecp->v1i = v1;
91     ecp->v2i = v2;
92     }
93     return(reversed ? -ecp->signum : ecp->signum);
94     }
95
96
97     static void
98     mesh_hit(oset, r) /* intersect ray with mesh triangle(s) */
99     OBJECT *oset;
100     RAY *r;
101     {
102 greg 2.6 int32 tvi[3];
103 greg 2.1 int sv1, sv2, sv3;
104     MESHVERT tv[3];
105 greg 2.5 OBJECT tmod;
106 greg 2.1 FVECT va, vb, nrm;
107     double d;
108     int i;
109     /* check each triangle */
110     for (i = oset[0]; i > 0; i--) {
111 greg 2.5 if (!getmeshtrivid(tvi, &tmod, curmsh, oset[i]))
112 greg 2.1 objerror(edge_cache.o, INTERNAL,
113 greg 2.2 "missing triangle vertices in mesh_hit");
114 greg 2.11 sv1 = volume_sign(r, tvi[0], tvi[1]);
115     sv2 = volume_sign(r, tvi[1], tvi[2]);
116     sv3 = volume_sign(r, tvi[2], tvi[0]);
117     /* compare volume signs */
118     if ((sv1 != sv2) | (sv2 != sv3))
119     continue;
120 greg 2.1 /* compute intersection */
121     getmeshvert(&tv[0], curmsh, tvi[0], MT_V);
122     getmeshvert(&tv[1], curmsh, tvi[1], MT_V);
123     getmeshvert(&tv[2], curmsh, tvi[2], MT_V);
124     VSUB(va, tv[0].v, tv[2].v);
125     VSUB(vb, tv[1].v, tv[0].v);
126     VCROSS(nrm, va, vb);
127     d = DOT(r->rdir, nrm);
128     if (d == 0.0)
129     continue; /* ray is tangent */
130     VSUB(va, tv[0].v, r->rorg);
131     d = DOT(va, nrm) / d;
132     if (d <= FTINY || d >= r->rot)
133     continue; /* not good enough */
134     r->robj = oset[i]; /* else record hit */
135     r->ro = edge_cache.o;
136     r->rot = d;
137     VSUM(r->rop, r->rorg, r->rdir, d);
138     VCOPY(r->ron, nrm);
139 greg 2.2 /* normalize(r->ron) called & r->rod set in o_mesh() */
140 greg 2.1 }
141     }
142
143
144 schorsch 2.10 extern int
145     o_mesh( /* compute ray intersection with a mesh */
146     OBJREC *o,
147     register RAY *r
148     )
149 greg 2.1 {
150     RAY rcont;
151     int flags;
152     MESHVERT tv[3];
153 greg 2.5 OBJECT tmod;
154 schorsch 2.7 RREAL wt[3];
155 greg 2.1 int i;
156     /* get the mesh instance */
157     prep_edge_cache(o);
158     /* copy and transform ray */
159 schorsch 2.9 rcont = *r;
160 greg 2.1 multp3(rcont.rorg, r->rorg, curmi->x.b.xfm);
161     multv3(rcont.rdir, r->rdir, curmi->x.b.xfm);
162     for (i = 0; i < 3; i++)
163     rcont.rdir[i] /= curmi->x.b.sca;
164     rcont.rmax *= curmi->x.b.sca;
165     /* clear and trace ray */
166     rayclear(&rcont);
167     rcont.hitf = mesh_hit;
168     if (!localhit(&rcont, &curmi->msh->mcube))
169     return(0); /* missed */
170     if (rcont.rot * curmi->x.f.sca >= r->rot)
171     return(0); /* not close enough */
172     /* transform ray back */
173     r->rot = rcont.rot * curmi->x.f.sca;
174     multp3(r->rop, rcont.rop, curmi->x.f.xfm);
175     multv3(r->ron, rcont.ron, curmi->x.f.xfm);
176     normalize(r->ron);
177     r->rod = -DOT(r->rdir, r->ron);
178 greg 2.5 /* get triangle */
179     flags = getmeshtri(tv, &tmod, curmsh, rcont.robj, MT_ALL);
180 greg 2.1 if (!(flags & MT_V))
181     objerror(o, INTERNAL, "missing mesh vertices in o_mesh");
182 greg 2.5 r->robj = objndx(o); /* set object and material */
183     if (o->omod == OVOID && tmod != OVOID) {
184     r->ro = getmeshpseudo(curmsh, tmod);
185     r->rox = &curmi->x;
186     } else
187     r->ro = o;
188     /* compute barycentric weights */
189 greg 2.1 if (flags & (MT_N|MT_UV))
190     if (get_baryc(wt, rcont.rop, tv[0].v, tv[1].v, tv[2].v) < 0) {
191     objerror(o, WARNING, "bad triangle in o_mesh");
192     flags &= ~(MT_N|MT_UV);
193     }
194     if (flags & MT_N) { /* interpolate normal */
195     for (i = 0; i < 3; i++)
196     rcont.pert[i] = wt[0]*tv[0].n[i] +
197     wt[1]*tv[1].n[i] +
198     wt[2]*tv[2].n[i];
199     multv3(r->pert, rcont.pert, curmi->x.f.xfm);
200     if (normalize(r->pert) != 0.0)
201     for (i = 0; i < 3; i++)
202     r->pert[i] -= r->ron[i];
203 greg 2.3 } else
204     r->pert[0] = r->pert[1] = r->pert[2] = .0;
205
206 greg 2.1 if (flags & MT_UV) /* interpolate uv coordinates */
207     for (i = 0; i < 2; i++)
208     r->uv[i] = wt[0]*tv[0].uv[i] +
209     wt[1]*tv[1].uv[i] +
210     wt[2]*tv[2].uv[i];
211 greg 2.3 else
212     r->uv[0] = r->uv[1] = .0;
213 greg 2.1
214     /* return hit */
215     return(1);
216     }
