--- ray/src/rt/o_mesh.c 2003/03/12 17:26:58 2.4 +++ ray/src/rt/o_mesh.c 2003/06/26 00:58:10 2.7 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: o_mesh.c,v 2.4 2003/03/12 17:26:58 greg Exp $"; +static const char RCSid[] = "$Id: o_mesh.c,v 2.7 2003/06/26 00:58:10 schorsch Exp $"; #endif /* * Routines for computing ray intersections with meshes. @@ -39,7 +39,7 @@ struct EdgeCache { OBJREC *o; /* mesh object */ MESHINST *mi; /* current mesh instance */ struct EdgeSide { - int4 v1i, v2i; /* vertex indices (lowest first) */ + int32 v1i, v2i; /* vertex indices (lowest first) */ short signum; /* signed volume */ } cache[EDGE_CACHE_SIZ]; } edge_cache; @@ -59,13 +59,13 @@ OBJREC *o; static int signed_volume(r, v1, v2) /* get signed volume for ray and edge */ register RAY *r; -int4 v1, v2; +int32 v1, v2; { int reversed = 0; register struct EdgeSide *ecp; if (v1 > v2) { - int4 t = v2; v2 = v1; v1 = t; + int32 t = v2; v2 = v1; v1 = t; reversed = 1; } ecp = &edge_cache.cache[((v2<<11 ^ v1) & 0x7fffffff) % EDGE_CACHE_SIZ]; @@ -102,15 +102,16 @@ mesh_hit(oset, r) /* intersect ray with mesh triangle OBJECT *oset; RAY *r; { - int4 tvi[3]; + int32 tvi[3]; int sv1, sv2, sv3; MESHVERT tv[3]; + OBJECT tmod; FVECT va, vb, nrm; double d; int i; /* check each triangle */ for (i = oset[0]; i > 0; i--) { - if (!getmeshtrivid(tvi, curmsh, oset[i])) + if (!getmeshtrivid(tvi, &tmod, curmsh, oset[i])) objerror(edge_cache.o, INTERNAL, "missing triangle vertices in mesh_hit"); sv1 = signed_volume(r, tvi[0], tvi[1]); @@ -151,7 +152,8 @@ register RAY *r; RAY rcont; int flags; MESHVERT tv[3]; - FLOAT wt[3]; + OBJECT tmod; + RREAL wt[3]; int i; /* get the mesh instance */ prep_edge_cache(o); @@ -169,19 +171,23 @@ register RAY *r; return(0); /* missed */ if (rcont.rot * curmi->x.f.sca >= r->rot) return(0); /* not close enough */ - - r->robj = objndx(o); /* record new hit */ - r->ro = o; /* transform ray back */ r->rot = rcont.rot * curmi->x.f.sca; multp3(r->rop, rcont.rop, curmi->x.f.xfm); multv3(r->ron, rcont.ron, curmi->x.f.xfm); normalize(r->ron); r->rod = -DOT(r->rdir, r->ron); - /* compute barycentric weights */ - flags = getmeshtri(tv, curmsh, rcont.robj, MT_ALL); + /* get triangle */ + flags = getmeshtri(tv, &tmod, curmsh, rcont.robj, MT_ALL); if (!(flags & MT_V)) objerror(o, INTERNAL, "missing mesh vertices in o_mesh"); + r->robj = objndx(o); /* set object and material */ + if (o->omod == OVOID && tmod != OVOID) { + r->ro = getmeshpseudo(curmsh, tmod); + r->rox = &curmi->x; + } else + r->ro = o; + /* compute barycentric weights */ if (flags & (MT_N|MT_UV)) if (get_baryc(wt, rcont.rop, tv[0].v, tv[1].v, tv[2].v) < 0) { objerror(o, WARNING, "bad triangle in o_mesh");
