--- ray/src/rt/o_mesh.c 2003/03/11 22:48:20 2.2 +++ ray/src/rt/o_mesh.c 2003/03/14 21:27:46 2.5 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: o_mesh.c,v 2.2 2003/03/11 22:48:20 greg Exp $"; +static const char RCSid[] = "$Id: o_mesh.c,v 2.5 2003/03/14 21:27:46 greg Exp $"; #endif /* * Routines for computing ray intersections with meshes. @@ -71,20 +71,19 @@ int4 v1, v2; ecp = &edge_cache.cache[((v2<<11 ^ v1) & 0x7fffffff) % EDGE_CACHE_SIZ]; if (ecp->v1i != v1 || ecp->v2i != v2) { MESHVERT tv1, tv2; /* compute signed volume */ + FVECT v2d; double vol; if (!getmeshvert(&tv1, edge_cache.mi->msh, v1, MT_V) || !getmeshvert(&tv2, edge_cache.mi->msh, v2, MT_V)) objerror(edge_cache.o, INTERNAL, "missing mesh vertex in signed_volume"); + VSUB(v2d, tv2.v, r->rorg); vol = (tv1.v[0] - r->rorg[0]) * - ( (tv2.v[1] - r->rorg[1])*r->rdir[2] - - (tv2.v[2] - r->rorg[2])*r->rdir[1] ); + (v2d[1]*r->rdir[2] - v2d[2]*r->rdir[1]); vol += (tv1.v[1] - r->rorg[1]) * - ( (tv2.v[2] - r->rorg[2])*r->rdir[0] - - (tv2.v[0] - r->rorg[0])*r->rdir[2] ); + (v2d[2]*r->rdir[0] - v2d[0]*r->rdir[2]); vol += (tv1.v[2] - r->rorg[2]) * - ( (tv2.v[0] - r->rorg[0])*r->rdir[1] - - (tv2.v[1] - r->rorg[1])*r->rdir[0] ); + (v2d[0]*r->rdir[1] - v2d[1]*r->rdir[0]); if (vol > .0) ecp->signum = 1; else if (vol < .0) @@ -106,12 +105,13 @@ RAY *r; int4 tvi[3]; int sv1, sv2, sv3; MESHVERT tv[3]; + OBJECT tmod; FVECT va, vb, nrm; double d; int i; /* check each triangle */ for (i = oset[0]; i > 0; i--) { - if (!getmeshtrivid(tvi, curmsh, oset[i])) + if (!getmeshtrivid(tvi, &tmod, curmsh, oset[i])) objerror(edge_cache.o, INTERNAL, "missing triangle vertices in mesh_hit"); sv1 = signed_volume(r, tvi[0], tvi[1]); @@ -152,6 +152,7 @@ register RAY *r; RAY rcont; int flags; MESHVERT tv[3]; + OBJECT tmod; FLOAT wt[3]; int i; /* get the mesh instance */ @@ -170,19 +171,23 @@ register RAY *r; return(0); /* missed */ if (rcont.rot * curmi->x.f.sca >= r->rot) return(0); /* not close enough */ - - r->robj = objndx(o); /* record new hit */ - r->ro = o; /* transform ray back */ r->rot = rcont.rot * curmi->x.f.sca; multp3(r->rop, rcont.rop, curmi->x.f.xfm); multv3(r->ron, rcont.ron, curmi->x.f.xfm); normalize(r->ron); r->rod = -DOT(r->rdir, r->ron); - /* compute barycentric weights */ - flags = getmeshtri(tv, curmsh, rcont.robj, MT_ALL); + /* get triangle */ + flags = getmeshtri(tv, &tmod, curmsh, rcont.robj, MT_ALL); if (!(flags & MT_V)) objerror(o, INTERNAL, "missing mesh vertices in o_mesh"); + r->robj = objndx(o); /* set object and material */ + if (o->omod == OVOID && tmod != OVOID) { + r->ro = getmeshpseudo(curmsh, tmod); + r->rox = &curmi->x; + } else + r->ro = o; + /* compute barycentric weights */ if (flags & (MT_N|MT_UV)) if (get_baryc(wt, rcont.rop, tv[0].v, tv[1].v, tv[2].v) < 0) { objerror(o, WARNING, "bad triangle in o_mesh"); @@ -197,12 +202,16 @@ register RAY *r; if (normalize(r->pert) != 0.0) for (i = 0; i < 3; i++) r->pert[i] -= r->ron[i]; - } + } else + r->pert[0] = r->pert[1] = r->pert[2] = .0; + if (flags & MT_UV) /* interpolate uv coordinates */ for (i = 0; i < 2; i++) r->uv[i] = wt[0]*tv[0].uv[i] + wt[1]*tv[1].uv[i] + wt[2]*tv[2].uv[i]; + else + r->uv[0] = r->uv[1] = .0; /* return hit */ return(1);
