root/radiance/ray/src/rt/o_mesh.c
Revision: 2.1
Committed: Tue Mar 11 17:08:55 2003 UTC (22 years, 3 months ago) by greg
5 * Routines for computing ray intersections with meshes.
6 *
7 * Intersection with a triangle mesh is based on Segura and Feito's
8 * WSCG 2001 paper, "Algorithms to Test Ray-Triangle Intersection,
9 * Comparative Study." This method avoids additional storage
10 * requirements, floating divides, and allows some savings by
11 * caching ray-edge comparisons that are otherwise repeated locally
12 * in typical mesh geometries. (This is our own optimization.)
13 *
14 * The code herein is quite similar to that in o_instance.c, the
15 * chief differences being the custom triangle intersection routines
16 * and the fact that an "OBJECT" in the mesh octree is not an index
17 * into the Radiance OBJREC list, but a mesh triangle index. We still
18 * utilize the standard octree traversal code by setting the hitf
19 * function pointer in the RAY struct to our custom mesh_hit() call.
20 */
21
22 #include "copyright.h"
23
24 #include "ray.h"
25
26 #include "mesh.h"
27
28 #include "tmesh.h"
29
30
31 #define EDGE_CACHE_SIZ 109 /* length of mesh edge cache */
32
33 #define curmi (edge_cache.mi)
34 #define curmsh (curmi->msh)
35
36
37 /* Cache of signed volumes for this ray and this mesh */
38 struct EdgeCache {
39 OBJREC *o; /* mesh object */
40 MESHINST *mi; /* current mesh instance */
41 struct EdgeSide {
42 int4 v1i, v2i; /* vertex indices (lowest first) */
43 short signum; /* signed volume */
44 } cache[EDGE_CACHE_SIZ];
45 } edge_cache;
46
47
48 static void
49 prep_edge_cache(o) /* get instance and clear edge cache */
50 OBJREC *o;
51 {
52 /* get mesh instance */
53 edge_cache.mi = getmeshinst(edge_cache.o = o, IO_ALL);
54 /* clear edge cache */
55 bzero((void *)edge_cache.cache, sizeof(edge_cache.cache));
56 }
57
58
59 static int
60 signed_volume(r, v1, v2) /* get signed volume for ray and edge */
61 register RAY *r;
62 int4 v1, v2;
63 {
64 int reversed = 0;
65 register struct EdgeSide *ecp;
66
67 if (v1 > v2) {
68 int4 t = v2; v2 = v1; v1 = t;
69 reversed = 1;
70 }
71 ecp = &edge_cache.cache[(v2<<11 ^ v1) % EDGE_CACHE_SIZ];
72 if (ecp->v1i != v1 || ecp->v2i != v2) {
73 MESHVERT tv1, tv2; /* compute signed volume */
74 double vol;
75 if (!getmeshvert(&tv1, edge_cache.mi->msh, v1, MT_V) ||
76 !getmeshvert(&tv2, edge_cache.mi->msh, v2, MT_V))
77 objerror(edge_cache.o, INTERNAL,
78 "missing mesh vertex in signed_volume");
79 vol = (tv1.v[0] - r->rorg[0]) *
80 ( (tv2.v[1] - r->rorg[1])*r->rdir[2] -
81 (tv2.v[2] - r->rorg[2])*r->rdir[1] );
82 vol += (tv1.v[1] - r->rorg[1]) *
83 ( (tv2.v[2] - r->rorg[2])*r->rdir[0] -
84 (tv2.v[0] - r->rorg[0])*r->rdir[2] );
85 vol += (tv1.v[2] - r->rorg[2]) *
86 ( (tv2.v[0] - r->rorg[0])*r->rdir[1] -
87 (tv2.v[1] - r->rorg[1])*r->rdir[0] );
88 if (vol > .0)
89 ecp->signum = 1;
90 else if (vol < .0)
91 ecp->signum = -1;
92 else
93 ecp->signum = 0;
94 ecp->v1i = v1;
95 ecp->v2i = v2;
96 }
97 return(reversed ? -ecp->signum : ecp->signum);
98 }
99
100
101 static void
102 mesh_hit(oset, r) /* intersect ray with mesh triangle(s) */
103 OBJECT *oset;
104 RAY *r;
105 {
106 int4 tvi[3];
107 int sv1, sv2, sv3;
108 MESHVERT tv[3];
109 FVECT va, vb, nrm;
110 double d;
111 int i;
112 /* check each triangle */
113 for (i = oset[0]; i > 0; i--) {
114 if (!getmeshtrivid(tvi, curmsh, oset[i]))
115 objerror(edge_cache.o, INTERNAL,
116 "missing triangle vertices in mesh_hit");
117 sv1 = signed_volume(r, tvi[0], tvi[1]);
118 sv2 = signed_volume(r, tvi[1], tvi[2]);
119 sv3 = signed_volume(r, tvi[2], tvi[0]);
120 if (sv1 != sv2 || sv2 != sv3) /* compare volume signs */
121 if (sv1 && sv2 && sv3)
122 continue;
123 /* compute intersection */
124 getmeshvert(&tv[0], curmsh, tvi[0], MT_V);
125 getmeshvert(&tv[1], curmsh, tvi[1], MT_V);
126 getmeshvert(&tv[2], curmsh, tvi[2], MT_V);
127 VSUB(va, tv[0].v, tv[2].v);
128 VSUB(vb, tv[1].v, tv[0].v);
129 VCROSS(nrm, va, vb);
130 d = DOT(r->rdir, nrm);
131 if (d == 0.0)
132 continue; /* ray is tangent */
133 VSUB(va, tv[0].v, r->rorg);
134 d = DOT(va, nrm) / d;
135 if (d <= FTINY || d >= r->rot)
136 continue; /* not good enough */
137 r->robj = oset[i]; /* else record hit */
138 r->ro = edge_cache.o;
139 r->rot = d;
140 VSUM(r->rop, r->rorg, r->rdir, d);
141 VCOPY(r->ron, nrm);
142 /* normalize(r->ron) called in o_mesh() & rod set */
143 }
144 }
145
146
147 int
148 o_mesh(o, r) /* compute ray intersection with a mesh */
149 OBJREC *o;
150 register RAY *r;
151 {
152 RAY rcont;
153 int flags;
154 MESHVERT tv[3];
155 FLOAT wt[3];
156 int i;
157 /* get the mesh instance */
158 prep_edge_cache(o);
159 /* copy and transform ray */
160 copystruct(&rcont, r);
161 multp3(rcont.rorg, r->rorg, curmi->x.b.xfm);
162 multv3(rcont.rdir, r->rdir, curmi->x.b.xfm);
163 for (i = 0; i < 3; i++)
164 rcont.rdir[i] /= curmi->x.b.sca;
165 rcont.rmax *= curmi->x.b.sca;
166 /* clear and trace ray */
167 rayclear(&rcont);
168 rcont.hitf = mesh_hit;
169 if (!localhit(&rcont, &curmi->msh->mcube))
170 return(0); /* missed */
171 if (rcont.rot * curmi->x.f.sca >= r->rot)
172 return(0); /* not close enough */
173
174 r->robj = objndx(o); /* record new hit */
175 r->ro = o;
176 /* transform ray back */
177 r->rot = rcont.rot * curmi->x.f.sca;
178 multp3(r->rop, rcont.rop, curmi->x.f.xfm);
179 multv3(r->ron, rcont.ron, curmi->x.f.xfm);
180 normalize(r->ron);
181 r->rod = -DOT(r->rdir, r->ron);
182 /* compute barycentric weights */
183 flags = getmeshtri(tv, curmsh, rcont.robj, MT_ALL);
184 if (!(flags & MT_V))
185 objerror(o, INTERNAL, "missing mesh vertices in o_mesh");
186 if (flags & (MT_N|MT_UV))
187 if (get_baryc(wt, rcont.rop, tv[0].v, tv[1].v, tv[2].v) < 0) {
188 objerror(o, WARNING, "bad triangle in o_mesh");
189 flags &= ~(MT_N|MT_UV);
190 }
191 if (flags & MT_N) { /* interpolate normal */
192 for (i = 0; i < 3; i++)
193 rcont.pert[i] = wt[0]*tv[0].n[i] +
194 wt[1]*tv[1].n[i] +
195 wt[2]*tv[2].n[i];
196 multv3(r->pert, rcont.pert, curmi->x.f.xfm);
197 if (normalize(r->pert) != 0.0)
198 for (i = 0; i < 3; i++)
199 r->pert[i] -= r->ron[i];
200 }
201 if (flags & MT_UV) /* interpolate uv coordinates */
202 for (i = 0; i < 2; i++)
203 r->uv[i] = wt[0]*tv[0].uv[i] +
204 wt[1]*tv[1].uv[i] +
205 wt[2]*tv[2].uv[i];
206
207 /* return hit */
208 return(1);
209 }
