root/radiance/ray/src/rt/o_mesh.c
Fri Mar 1 02:03:33 2019 UTC (6 years, 2 months ago) by greg
Minor changes should not affect function
Tue Jul 8 18:25:00 2014 UTC (10 years, 9 months ago) by greg
Changes since 2.13: +6 -6 lines
Tue Oct 23 05:03:52 2012 UTC (12 years, 6 months ago) by greg
Minor optimization
Mon Oct 25 22:57:45 2010 UTC (14 years, 6 months ago) by greg
Changes since 2.11: +2 -3 lines
Sat Feb 25 19:49:16 2006 UTC (19 years, 2 months ago) by greg
Changes since 2.10: +13 -17 lines
Minor optimizations in ray-triangle intersection test
Changes since 2.9: +7 -5 lines
Mon Jul 21 22:30:19 2003 UTC (21 years, 9 months ago) by schorsch
Mon Jun 30 14:59:12 2003 UTC (21 years, 10 months ago) by schorsch
Thu Jun 26 00:58:10 2003 UTC (21 years, 10 months ago) by schorsch
Fri Jun 20 00:25:50 2003 UTC (21 years, 10 months ago) by greg
Fri Mar 14 21:27:46 2003 UTC (22 years, 1 month ago) by greg
Changes since 2.4: +12 -6 lines
Wed Mar 12 17:26:58 2003 UTC (22 years, 1 month ago) by greg
Changes since 2.3: +5 -6 lines
Wed Mar 12 04:59:05 2003 UTC (22 years, 1 month ago) by greg
Tue Mar 11 22:48:20 2003 UTC (22 years, 1 month ago) by greg
Tue Mar 11 17:08:55 2003 UTC (22 years, 1 month ago) by greg
Diff to selected 2.6
