root/radiance/ray/src/rt/o_instance.c
Changes since 2.7: +7 -5 lines
Diff to previous 2.7 , to selected 1.9
Diff to previous 2.6 , to selected 1.9
Changes since 2.5: +26 -19 lines
Diff to previous 2.5 , to selected 1.9
Diff to previous 2.4 , to selected 1.9
Changes since 2.3: +57 -5 lines
Diff to previous 2.3 , to selected 1.9
Tue Dec 20 20:18:19 1994 UTC (29 years, 4 months ago) by greg
Diff to previous 2.2 , to selected 1.9
Sun Dec 20 10:11:53 1992 UTC (31 years, 4 months ago) by greg
Diff to previous 2.1 , to selected 1.9
removed spurious reference
Tue Nov 12 17:10:10 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.11 , to selected 1.9
Wed Jul 17 12:38:51 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.10: +5 -7 lines
Diff to previous 1.10 , to selected 1.9
added rayclear() function
Mon Jun 17 08:26:20 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.9
added raynum counter and reinstated repeat call test in setfunc()
Revision 1.9 - (view) (download) (annotate) - [selected]
Sat Dec 15 16:43:58 1990 UTC (33 years, 4 months ago) by greg
Diff to previous 1.8
changed r->rox to use pointer to instance transform when possible
Sat Dec 15 15:03:30 1990 UTC (33 years, 4 months ago) by greg
Changes since 1.7: +19 -15 lines
Diff to previous 1.7 , to selected 1.9
Fri Jan 19 00:00:17 1990 UTC (34 years, 3 months ago) by greg
Diff to previous 1.6 , to selected 1.9
Tue Oct 24 13:58:45 1989 UTC (34 years, 6 months ago) by greg
Diff to previous 1.5 , to selected 1.9
changed GET_ macro to IO_
Sun Apr 23 19:33:59 1989 UTC (35 years ago) by greg
Changes since 1.4: +0 -1 lines
Diff to previous 1.4 , to selected 1.9
eliminated redundant assignment
Thu Apr 20 08:25:22 1989 UTC (35 years ago) by greg
Diff to previous 1.3 , to selected 1.9
moved setting of ray transformation to intersection routines (bug)
Wed Apr 19 21:35:57 1989 UTC (35 years ago) by greg
Diff to previous 1.2 , to selected 1.9
fixed forward transformation order
Tue Apr 11 13:30:30 1989 UTC (35 years, 1 month ago) by greg
Changes since 1.1: +4 -2 lines
Diff to previous 1.1 , to selected 1.9
Thu Feb 2 10:41:32 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 1.9
