root/Development/ray/src/rt/o_instance.c
Tue Jul 8 18:25:00 2014 UTC (11 years, 5 months ago) by greg
CVS Tags: HEAD, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3, rad5R4, rad6R0
Diff to previous 2.8 , to selected 1.4
Tue Mar 30 16:13:01 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 2.7: +7 -5 lines
Diff to previous 2.7 , to selected 1.4
Mon Jul 21 22:30:19 2003 UTC (22 years, 5 months ago) by schorsch
Diff to previous 2.6 , to selected 1.4
Tue Mar 11 17:08:55 2003 UTC (22 years, 9 months ago) by greg
Changes since 2.5: +26 -19 lines
Diff to previous 2.5 , to selected 1.4
Tue Feb 25 02:47:23 2003 UTC (22 years, 10 months ago) by greg
Diff to previous 2.4 , to selected 1.4
Sat Feb 22 02:07:29 2003 UTC (22 years, 10 months ago) by greg
Changes since 2.3: +57 -5 lines
Diff to previous 2.3 , to selected 1.4
Tue Dec 20 20:18:19 1994 UTC (31 years ago) by greg
Diff to previous 2.2 , to selected 1.4
Sun Dec 20 10:11:53 1992 UTC (33 years ago) by greg
Diff to previous 2.1 , to selected 1.4
removed spurious reference
Tue Nov 12 17:10:10 1991 UTC (34 years, 1 month ago) by greg
Diff to previous 1.11 , to selected 1.4
Wed Jul 17 12:38:51 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.10: +5 -7 lines
Diff to previous 1.10 , to selected 1.4
added rayclear() function
Mon Jun 17 08:26:20 1991 UTC (34 years, 6 months ago) by greg
Diff to previous 1.9 , to selected 1.4
added raynum counter and reinstated repeat call test in setfunc()
Sat Dec 15 16:43:58 1990 UTC (35 years ago) by greg
Diff to previous 1.8 , to selected 1.4
changed r->rox to use pointer to instance transform when possible
Sat Dec 15 15:03:30 1990 UTC (35 years ago) by greg
Changes since 1.7: +19 -15 lines
Diff to previous 1.7 , to selected 1.4
Fri Jan 19 00:00:17 1990 UTC (35 years, 11 months ago) by greg
Diff to previous 1.6 , to selected 1.4
Tue Oct 24 13:58:45 1989 UTC (36 years, 2 months ago) by greg
Diff to previous 1.5 , to selected 1.4
changed GET_ macro to IO_
Sun Apr 23 19:33:59 1989 UTC (36 years, 8 months ago) by greg
Changes since 1.4: +0 -1 lines
Diff to previous 1.4
eliminated redundant assignment
Revision 1.4 - (view) (download) (annotate) - [selected]
Thu Apr 20 08:25:22 1989 UTC (36 years, 8 months ago) by greg
Diff to previous 1.3
moved setting of ray transformation to intersection routines (bug)
Wed Apr 19 21:35:57 1989 UTC (36 years, 8 months ago) by greg
Diff to previous 1.2 , to selected 1.4
fixed forward transformation order
Tue Apr 11 13:30:30 1989 UTC (36 years, 9 months ago) by greg
Changes since 1.1: +4 -2 lines
Diff to previous 1.1 , to selected 1.4
Thu Feb 2 10:41:32 1989 UTC (36 years, 11 months ago) by greg
Diff to selected 1.4
