root/radiance/ray/src/rt/o_face.c
Thu Mar 16 00:25:24 2023 UTC (14 months ago) by greg
CVS Tags: HEAD, rad5R4
feat: Added test for which side of flat surface is seen in case of coincident surfaces
Sun Jan 31 18:08:04 2021 UTC (3 years, 3 months ago) by greg
Changes since 2.7: +8 -8 lines
feat: added consistent handling of coincident surfaces, thanks to Peter A-B
Tue Jul 8 18:25:00 2014 UTC (9 years, 10 months ago) by greg
Thu Mar 2 16:51:55 2006 UTC (18 years, 2 months ago) by greg
Changes since 2.5: +2 -4 lines
Made some minor optimizations in face intersection code
Changes since 2.4: +7 -5 lines
Changes since 2.2: +1 -56 lines
Changes since 2.1: +57 -5 lines
Tue Nov 12 17:09:17 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.4 , to selected 2.3
Sat Dec 15 15:03:29 1990 UTC (33 years, 5 months ago) by greg
Changes since 1.3: +2 -3 lines
Diff to previous 1.3 , to selected 2.3
Wed Apr 19 22:24:26 1989 UTC (35 years, 1 month ago) by greg
Changes since 1.2: +10 -7 lines
Diff to previous 1.2 , to selected 2.3
moved setting of ray transformation to intersection routines (bug)
Tue Feb 21 14:56:20 1989 UTC (35 years, 3 months ago) by greg
Diff to previous 1.1 , to selected 2.3
portability fixes
Thu Feb 2 10:41:32 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.3
