root/radiance/ray/src/rt/o_face.c
Revision: 2.9
Committed: Thu Mar 16 00:25:24 2023 UTC (2 years, 2 months ago) by greg
CVS Tags: rad5R4, HEAD
feat: Added test for which side of flat surface is seen in case of coincident surfaces
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.9 static const char RCSid[] = "$Id: o_face.c,v 2.8 2021/01/31 18:08:04 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * o_face.c - compute ray intersection with faces.
6 greg 2.2 */
7
8 greg 2.3 #include "copyright.h"
9 greg 1.1
10     #include "ray.h"
11     #include "face.h"
12 schorsch 2.5 #include "rtotypes.h"
13 greg 1.1
14
15 greg 2.7 int
16 schorsch 2.5 o_face( /* compute intersection with polygonal face */
17     OBJREC *o,
18 greg 2.7 RAY *r
19 schorsch 2.5 )
20 greg 1.1 {
21     double rdot; /* direction . normal */
22     double t; /* distance to intersection */
23     FVECT pisect; /* intersection point */
24 greg 2.7 FACE *f; /* face record */
25 greg 1.1
26     f = getface(o);
27
28     /*
29     * First, we find the distance to the plane containing the
30 greg 2.8 * face. If the plane is parallel to our ray, or the
31     * previous hit was better, we return. Otherwise,
32 greg 1.1 * we determine whether in fact the ray intersects the
33     * face. The ray intersects the face if the
34     * point of intersection with the plane of the face
35     * is inside the face.
36     */
37     /* compute dist. to plane */
38     rdot = -DOT(r->rdir, f->norm);
39 greg 2.8 if ((rdot <= FTINY) & (rdot >= -FTINY)) /* ray parallels plane */
40     return(0);
41
42     t = (DOT(r->rorg, f->norm) - f->offset) / rdot;
43 greg 1.1
44 greg 2.9 if (rayreject(o, r, t, rdot)) /* previous hit is better? */
45 greg 1.1 return(0);
46     /* compute intersection */
47 greg 2.6 VSUM(pisect, r->rorg, r->rdir, t);
48 greg 1.1
49 greg 1.3 if (!inface(pisect, f)) /* ray intersects face? */
50     return(0);
51 greg 1.1
52 greg 1.3 r->ro = o;
53     r->rot = t;
54     VCOPY(r->rop, pisect);
55     VCOPY(r->ron, f->norm);
56     r->rod = rdot;
57 greg 2.4 r->pert[0] = r->pert[1] = r->pert[2] = 0.0;
58     r->uv[0] = r->uv[1] = 0.0;
59 greg 1.4 r->rox = NULL;
60 greg 1.3
61 greg 1.1 return(1); /* hit */
62     }
