#ifndef lint static const char RCSid[] = "$Id: o_cone.c,v 2.14 2025/12/20 02:09:11 greg Exp $"; #endif /* * o_cone.c - routine to determine ray intersection with cones. */ #include "copyright.h" #include "ray.h" #include "otypes.h" #include "rtotypes.h" #include "cone.h" int o_cone( /* intersect ray with cone */ OBJREC *o, RAY *r ) { FVECT rox, rdx; double a, b, c; double root[2]; int nroots, rn; CONE *co; int i; /* get cone structure */ co = getcone(o, 1); if (co == NULL) objerror(o, INTERNAL, "unexpected illegal"); /* * To intersect a ray with a cone, we transform the * ray into the cone's normalized space. This greatly * simplifies the computation. * For a cone or cup, normalization results in the * equation: * * x*x + y*y - z*z == 0 * * For a cylinder or tube, the normalized equation is: * * x*x + y*y - r*r == 0 * * A normalized ring obeys the following set of equations: * * z == 0 && * x*x + y*y >= r0*r0 && * x*x + y*y <= r1*r1 */ /* transform ray */ multp3(rox, r->rorg, co->tm); multv3(rdx, r->rdir, co->tm); /* compute intersection */ if ((o->otype == OBJ_CONE) | (o->otype == OBJ_CUP)) { a = rdx[0]*rdx[0] + rdx[1]*rdx[1] - rdx[2]*rdx[2]; b = 2.0*(rdx[0]*rox[0] + rdx[1]*rox[1] - rdx[2]*rox[2]); c = rox[0]*rox[0] + rox[1]*rox[1] - rox[2]*rox[2]; } else if ((o->otype == OBJ_CYLINDER) | (o->otype == OBJ_TUBE)) { a = rdx[0]*rdx[0] + rdx[1]*rdx[1]; b = 2.0*(rdx[0]*rox[0] + rdx[1]*rox[1]); c = rox[0]*rox[0] + rox[1]*rox[1] - CO_R0(co)*CO_R0(co); } else { /* OBJ_RING */ if ((rdx[2] <= FTINY) & (rdx[2] >= -FTINY)) return(0); /* parallel */ root[0] = -rox[2]/rdx[2]; if (rayreject(o, r, root[0], -rdx[2])) return(0); /* have better */ b = root[0]*rdx[0] + rox[0]; c = root[0]*rdx[1] + rox[1]; a = b*b + c*c; if (a > CO_R1(co)*CO_R1(co) || a < CO_R0(co)*CO_R0(co)) return(0); /* outside radii */ r->ro = o; r->rot = root[0]; VSUM(r->rop, r->rorg, r->rdir, r->rot); VCOPY(r->ron, co->ad); r->rod = -rdx[2]; r->pert[0] = r->pert[1] = r->pert[2] = 0.0; r->uv[0] = r->uv[1] = 0.0; r->rox = NULL; return(1); /* good */ } /* roots for cone, cup, cyl., tube */ nroots = quadratic(root, a, b, c); for (rn = 0; rn < nroots; rn++) { /* check real roots */ if (root[rn] <= FTINY) continue; /* too small */ if (root[rn] > r->rot + FTINY) break; /* too big */ /* check endpoints */ VSUM(rox, r->rorg, r->rdir, root[rn]); VSUB(rdx, rox, CO_P0(co)); b = DOT(rdx, co->ad); if (b < 0.0) continue; /* before p0 */ if (b > co->al) continue; /* after p1 */ if (rayreject(o, r, root[rn], 1 - 2*((rn>0)^(o->otype==OBJ_CUP|o->otype==OBJ_TUBE)))) break; /* previous hit better */ r->ro = o; r->rot = root[rn]; VCOPY(r->rop, rox); /* get normal */ if (o->otype == OBJ_CYLINDER) a = CO_R0(co); else if (o->otype == OBJ_TUBE) a = -CO_R0(co); else { /* OBJ_CONE || OBJ_CUP */ c = CO_R1(co) - CO_R0(co); a = CO_R0(co) + b*c/co->al; if (o->otype == OBJ_CUP) { c = -c; a = -a; } } for (i = 0; i < 3; i++) r->ron[i] = (rdx[i] - b*co->ad[i])/a; if ((o->otype == OBJ_CONE) | (o->otype == OBJ_CUP)) for (i = 0; i < 3; i++) r->ron[i] = (co->al*r->ron[i] - c*co->ad[i]) / co->sl; a = DOT(r->ron, r->ron); if ((a > 1.+FTINY) | (a < 1.-FTINY)) { c = 1./(.5 + .5*a); /* avoid numerical error */ r->ron[0] *= c; r->ron[1] *= c; r->ron[2] *= c; } r->rod = -DOT(r->rdir, r->ron); r->pert[0] = r->pert[1] = r->pert[2] = 0.0; r->uv[0] = r->uv[1] = 0.0; r->rox = NULL; return(1); /* good */ } return(0); }
