root/radiance/ray/src/rt/o_cone.c
Revision: 1.2
Committed: Wed Apr 19 22:24:25 1989 UTC (35 years, 2 months ago) by greg
Changes since 1.1: +4 -0 lines
moved setting of ray transformation to intersection routines (bug)
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * o_cone.c - routine to determine ray intersection with cones.
9 *
10 * 2/13/86
11 */
12
13 #include "ray.h"
14
15 #include "otypes.h"
16
17 #include "cone.h"
18
19
20 o_cone(o, r) /* intersect ray with cone */
21 OBJREC *o;
22 register RAY *r;
23 {
24 FVECT rox, rdx;
25 double a, b, c;
26 double root[2];
27 int nroots, rn;
28 register CONE *co;
29 register int i;
30
31 /* get cone structure */
32 co = getcone(o, 1);
33
34 /*
35 * To intersect a ray with a cone, we transform the
36 * ray into the cone's normalized space. This greatly
37 * simplifies the computation.
38 * For a cone or cup, normalization results in the
39 * equation:
40 *
41 * x*x + y*y - z*z == 0
42 *
43 * For a cylinder or tube, the normalized equation is:
44 *
45 * x*x + y*y - r*r == 0
46 *
47 * A normalized ring obeys the following set of equations:
48 *
49 * z == 0 &&
50 * x*x + y*y >= r0*r0 &&
51 * x*x + y*y <= r1*r1
52 */
53
54 /* transform ray */
55 multp3(rox, r->rorg, co->tm);
56 multv3(rdx, r->rdir, co->tm);
57 /* compute intersection */
58
59 if (o->otype == OBJ_CONE || o->otype == OBJ_CUP) {
60
61 a = rdx[0]*rdx[0] + rdx[1]*rdx[1] - rdx[2]*rdx[2];
62 b = 2.0*(rdx[0]*rox[0] + rdx[1]*rox[1] - rdx[2]*rox[2]);
63 c = rox[0]*rox[0] + rox[1]*rox[1] - rox[2]*rox[2];
64
65 } else if (o->otype == OBJ_CYLINDER || o->otype == OBJ_TUBE) {
66
67 a = rdx[0]*rdx[0] + rdx[1]*rdx[1];
68 b = 2.0*(rdx[0]*rox[0] + rdx[1]*rox[1]);
69 c = rox[0]*rox[0] + rox[1]*rox[1] - CO_R0(co)*CO_R0(co);
70
71 } else { /* OBJ_RING */
72
73 if (rdx[2] <= FTINY && rdx[2] >= -FTINY)
74 return(0); /* parallel */
75 root[0] = -rox[2]/rdx[2];
76 if (root[0] <= FTINY || root[0] >= r->rot)
77 return(0); /* distance check */
78 b = root[0]*rdx[0] + rox[0];
79 c = root[0]*rdx[1] + rox[1];
80 a = b*b + c*c;
81 if (a < CO_R0(co)*CO_R0(co) || a > CO_R1(co)*CO_R1(co))
82 return(0); /* outside radii */
83 r->ro = o;
84 r->rot = root[0];
85 for (i = 0; i < 3; i++)
86 r->rop[i] = r->rorg[i] + r->rdir[i]*r->rot;
87 VCOPY(r->ron, co->ad);
88 r->rod = -rdx[2];
89 r->rofs = 1.0; setident4(r->rofx);
90 r->robs = 1.0; setident4(r->robx);
91 return(1); /* good */
92 }
93 /* roots for cone, cup, cyl., tube */
94 nroots = quadratic(root, a, b, c);
95
96 for (rn = 0; rn < nroots; rn++) { /* check real roots */
97 if (root[rn] <= FTINY)
98 continue; /* too small */
99 if (root[rn] >= r->rot)
100 break; /* too big */
101 /* check endpoints */
102 for (i = 0; i < 3; i++) {
103 rox[i] = r->rorg[i] + root[rn]*r->rdir[i];
104 rdx[i] = rox[i] - CO_P0(co)[i];
105 }
106 b = DOT(rdx, co->ad);
107 if (b < 0.0)
108 continue; /* before p0 */
109 if (b > co->al)
110 continue; /* after p1 */
111 r->ro = o;
112 r->rot = root[rn];
113 VCOPY(r->rop, rox);
114 /* get normal */
115 if (o->otype == OBJ_CYLINDER)
116 a = CO_R0(co);
117 else if (o->otype == OBJ_TUBE)
118 a = -CO_R0(co);
119 else { /* OBJ_CONE || OBJ_CUP */
120 c = CO_R1(co) - CO_R0(co);
121 a = CO_R0(co) + b*c/co->al;
122 if (o->otype == OBJ_CUP) {
123 c = -c;
124 a = -a;
125 }
126 }
127 for (i = 0; i < 3; i++)
128 r->ron[i] = (rdx[i] - b*co->ad[i])/a;
129 if (o->otype == OBJ_CONE || o->otype == OBJ_CUP)
130 for (i = 0; i < 3; i++)
131 r->ron[i] = (co->al*r->ron[i] - c*co->ad[i])
132 /co->sl;
133 r->rod = -DOT(r->rdir, r->ron);
134 r->rofs = 1.0; setident4(r->rofx);
135 r->robs = 1.0; setident4(r->robx);
136 return(1); /* good */
137 }
138 return(0);
139 }
