1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: o_cone.c,v 2.4 2003/03/11 17:08:55 greg Exp $"; |
3 |
#endif |
4 |
5 |
* o_cone.c - routine to determine ray intersection with cones. |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include "ray.h" |
11 |
#include "otypes.h" |
12 |
#include "rtotypes.h" |
13 |
#include "cone.h" |
14 |
15 |
16 |
extern int |
17 |
o_cone( /* intersect ray with cone */ |
18 |
OBJREC *o, |
19 |
register RAY *r |
20 |
21 |
22 |
FVECT rox, rdx; |
23 |
double a, b, c; |
24 |
double root[2]; |
25 |
int nroots, rn; |
26 |
register CONE *co; |
27 |
register int i; |
28 |
29 |
/* get cone structure */ |
30 |
co = getcone(o, 1); |
31 |
32 |
33 |
* To intersect a ray with a cone, we transform the |
34 |
* ray into the cone's normalized space. This greatly |
35 |
* simplifies the computation. |
36 |
* For a cone or cup, normalization results in the |
37 |
* equation: |
38 |
39 |
* x*x + y*y - z*z == 0 |
40 |
41 |
* For a cylinder or tube, the normalized equation is: |
42 |
43 |
* x*x + y*y - r*r == 0 |
44 |
45 |
* A normalized ring obeys the following set of equations: |
46 |
47 |
* z == 0 && |
48 |
* x*x + y*y >= r0*r0 && |
49 |
* x*x + y*y <= r1*r1 |
50 |
51 |
52 |
/* transform ray */ |
53 |
multp3(rox, r->rorg, co->tm); |
54 |
multv3(rdx, r->rdir, co->tm); |
55 |
/* compute intersection */ |
56 |
57 |
if (o->otype == OBJ_CONE || o->otype == OBJ_CUP) { |
58 |
59 |
a = rdx[0]*rdx[0] + rdx[1]*rdx[1] - rdx[2]*rdx[2]; |
60 |
b = 2.0*(rdx[0]*rox[0] + rdx[1]*rox[1] - rdx[2]*rox[2]); |
61 |
c = rox[0]*rox[0] + rox[1]*rox[1] - rox[2]*rox[2]; |
62 |
63 |
} else if (o->otype == OBJ_CYLINDER || o->otype == OBJ_TUBE) { |
64 |
65 |
a = rdx[0]*rdx[0] + rdx[1]*rdx[1]; |
66 |
b = 2.0*(rdx[0]*rox[0] + rdx[1]*rox[1]); |
67 |
c = rox[0]*rox[0] + rox[1]*rox[1] - CO_R0(co)*CO_R0(co); |
68 |
69 |
} else { /* OBJ_RING */ |
70 |
71 |
if (rdx[2] <= FTINY && rdx[2] >= -FTINY) |
72 |
return(0); /* parallel */ |
73 |
root[0] = -rox[2]/rdx[2]; |
74 |
if (root[0] <= FTINY || root[0] >= r->rot) |
75 |
return(0); /* distance check */ |
76 |
b = root[0]*rdx[0] + rox[0]; |
77 |
c = root[0]*rdx[1] + rox[1]; |
78 |
a = b*b + c*c; |
79 |
if (a < CO_R0(co)*CO_R0(co) || a > CO_R1(co)*CO_R1(co)) |
80 |
return(0); /* outside radii */ |
81 |
r->ro = o; |
82 |
r->rot = root[0]; |
83 |
for (i = 0; i < 3; i++) |
84 |
r->rop[i] = r->rorg[i] + r->rdir[i]*r->rot; |
85 |
VCOPY(r->ron, co->ad); |
86 |
r->rod = -rdx[2]; |
87 |
r->rox = NULL; |
88 |
return(1); /* good */ |
89 |
90 |
/* roots for cone, cup, cyl., tube */ |
91 |
nroots = quadratic(root, a, b, c); |
92 |
93 |
for (rn = 0; rn < nroots; rn++) { /* check real roots */ |
94 |
if (root[rn] <= FTINY) |
95 |
continue; /* too small */ |
96 |
if (root[rn] >= r->rot) |
97 |
break; /* too big */ |
98 |
/* check endpoints */ |
99 |
for (i = 0; i < 3; i++) { |
100 |
rox[i] = r->rorg[i] + root[rn]*r->rdir[i]; |
101 |
rdx[i] = rox[i] - CO_P0(co)[i]; |
102 |
103 |
b = DOT(rdx, co->ad); |
104 |
if (b < 0.0) |
105 |
continue; /* before p0 */ |
106 |
if (b > co->al) |
107 |
continue; /* after p1 */ |
108 |
r->ro = o; |
109 |
r->rot = root[rn]; |
110 |
VCOPY(r->rop, rox); |
111 |
/* get normal */ |
112 |
if (o->otype == OBJ_CYLINDER) |
113 |
a = CO_R0(co); |
114 |
else if (o->otype == OBJ_TUBE) |
115 |
a = -CO_R0(co); |
116 |
else { /* OBJ_CONE || OBJ_CUP */ |
117 |
c = CO_R1(co) - CO_R0(co); |
118 |
a = CO_R0(co) + b*c/co->al; |
119 |
if (o->otype == OBJ_CUP) { |
120 |
c = -c; |
121 |
a = -a; |
122 |
123 |
124 |
125 |
r->ron[i] = (rdx[i] - b*co->ad[i])/a; |
126 |
if (o->otype == OBJ_CONE || o->otype == OBJ_CUP) |
127 |
128 |
r->ron[i] = (co->al*r->ron[i] - c*co->ad[i]) |
129 |
/co->sl; |
130 |
r->rod = -DOT(r->rdir, r->ron); |
131 |
r->pert[0] = r->pert[1] = r->pert[2] = 0.0; |
132 |
r->uv[0] = r->uv[1] = 0.0; |
133 |
r->rox = NULL; |
134 |
135 |
136 |
return(0); |
137 |
