root/radiance/ray/src/rt/o_cone.c
Thu Mar 16 00:25:24 2023 UTC (14 months, 2 weeks ago) by greg
CVS Tags: HEAD, rad5R4
feat: Added test for which side of flat surface is seen in case of coincident surfaces
Thu Dec 16 21:37:21 2021 UTC (2 years, 5 months ago) by greg
fix: added missing ray settings for ring primitive
Sun Jan 31 18:08:04 2021 UTC (3 years, 4 months ago) by greg
Changes since 2.9: +7 -5 lines
feat: added consistent handling of coincident surfaces, thanks to Peter A-B
Thu Apr 21 00:40:35 2016 UTC (8 years, 1 month ago) by greg
Made zero cone and ring radii non-fatal (degenerate -> ignore)
Tue Jul 8 18:25:00 2014 UTC (9 years, 10 months ago) by greg
Mon Oct 25 22:57:45 2010 UTC (13 years, 7 months ago) by greg
Changes since 2.6: +5 -8 lines
Mon Jun 28 10:07:17 2004 UTC (19 years, 11 months ago) by greg
Changes since 2.5: +6 -1 lines
Added numerical correction for needle-like cones
Changes since 2.2: +1 -56 lines
Changes since 2.1: +57 -5 lines
Tue Nov 12 17:09:26 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.3 , to selected 2.12
Sat Dec 15 15:03:28 1990 UTC (33 years, 5 months ago) by greg
Changes since 1.2: +3 -5 lines
Diff to previous 1.2 , to selected 2.12
Wed Apr 19 22:24:25 1989 UTC (35 years, 1 month ago) by greg
Changes since 1.1: +4 -0 lines
Diff to previous 1.1 , to selected 2.12
moved setting of ray transformation to intersection routines (bug)
Thu Feb 2 10:41:31 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.12
