root/radiance/ray/src/rt/nwsdev.cps
Revision: 1.1
Committed: Tue Jul 10 15:22:26 1990 UTC (34 years, 10 months ago) by greg
1 # SCCSid "$SunId$ LBL"
2
3 %
4 % By Isaac Kuo
5 %
6
7 #include "newsconstants.h"
8 cdef cps_clear()
9 textbackground setcolor clippath fill
10 cdef initcanvas(x,y,width,height,mb1key,mb2key,mb3key)
11 /Can framebuffer width height createcanvas def
12 Can /Retained true put
13 Can setcanvas x y movecanvas currentcanvas mapcanvas
14 clippath pathbbox pop pop translate
15 1.0 .75 .3 setrgbcolor clippath fill
16 /scrollheight textareaheight fontheight sub def
17 thefont findfont fontheight scalefont setfont
18 /textbackground textbackgroundRED textbackgroundGREEN
19 textbackgroundBLUE rgbcolor def
20 /MB1key mb1key def
21 /MB2key mb2key def
22 /MB3key mb3key def
23
24 % scroll scrolls the text area
25 /scroll
26 {
27 newpath
28 0 0 width scrollheight points2rect rectpath
29 0 fontheight copyarea % Scroll the text area
30 newpath textbackground setcolor
31 0 0 width fontheight points2rect rectpath
32 fill
33 /textcursorposition 0 def
34 } def
35 scroll scroll
36
37 % myshow takes a string and prints it at the current cursor location
38 /myshow
39 {
40 textshadowgray setgray
41 textcursorposition 1 sub textbottom 1 sub moveto dup show
42 0 setgray
43 textcursorposition textbottom moveto show
44 /textcursorposition currentpoint pop def
45 } def
46
47 % mydel takes a string and deletes it from the current cursor location
48 /mydel
49 {
50 textbackground setcolor
51 dup stringwidth pop textcursorposition exch sub
52 dup /textcursorposition exch def
53 1 sub textbottom 1 sub moveto dup show textcursorposition %
54 textbottom moveto show
55 } def
56
57 /normalcursor
58 {
59 /xcurs /xcurs_m Can setstandardcursor
60 } def
61 normalcursor
62
63 % get this canvas ready for input
64 /buttonevent createevent def
65 buttonevent /Name [/LeftMouseButton /MiddleMouseButton /RightMouseButton] put
66 buttonevent /Action /UpTransition put
67 buttonevent /Canvas Can put
68 /keyevent Can addkbdinterests aload /EVENTS exch
69 def revokeinterest revokeinterest def
70 /dumevent createevent def % dumevent is used by the input checker
71 dumevent /Name 32 put % to insure awaitevent returns an answer
72 dumevent /Action 13 put % immediately; if it is the first one
73 dumevent /Canvas Can put % returned, then no keyboard events
74 dumevent expressinterest % were waiting.
75 /kdevent createevent def % kdevent is used by the input checker
76 kdevent /Action 666 put % to replace waiting keyboard events with
77 kdevent /Canvas Can put % something which acts interchangably with
78 kdevent expressinterest % a normal keyboard event.
79
80 cdef box(x1,y1,x2,y2,float r,float g,float b)
81 % Draw a filled box at x,y in pixels with color r,g,b
82 r g b setrgbcolor newpath
83 x1 y1 x2 y2 points2rect rectpath fill
84 #define tag 1990
85 cdef cps_cleanup() => tag()
86 % Clean up just enough stuff so the window will die quietly
87 keyevent revokeinterest
88 kdevent revokeinterest
89 EVENTS Can revokekbdinterests
90 dumevent revokeinterest
91 /Can currentcanvas def
92 Can /EventsConsumed /NoEvents put
93 Can /Transparent true put
94 Can /Mapped false put
95 Can /Retained false put
96 tag tagprint
97 cdef getthebox(X,Y,W,H) => tag(X,Y,W,H)
98 % Get the coordinates of the box from the user
99 currentcanvas createoverlay setcanvas getwholerect waitprocess
100 aload pop /y1 exch def /x1 exch def /y0 exch def /x0 exch def
101 x0 x1 gt { /x x1 def /w x0 x1 sub def }
102 { /x x0 def /w x1 x0 sub def } ifelse
103 y0 y1 gt { /y y1 def /h y0 y1 sub def }
104 { /y y0 def /h y1 y0 sub def } ifelse
105 h w y x tag tagprint typedprint typedprint typedprint typedprint
106 cdef printout(string message)
107 % print message without scrolling the text "window" up
108 message myshow
109 cdef linefeed(string message)
110 % print message and scroll
111 message myshow scroll
112 cdef getclick(x,y,key) => tag(key,y,x)
113 % get a cursor position marked by click or key
114 buttonevent expressinterest
115 /beye_m /xhair_m Can setstandardcursor
116 /theclick awaitevent def
117 currentcursorlocation textareaheight sub
118 normalcursor
119 buttonevent revokeinterest
120
121 theclick /Name get
122 % Translate mouse clicks if necessary
123 dup /LeftMouseButton eq
124 {pop MB1key} if
125 dup /MiddleMouseButton eq
126 {pop MB2key} if
127 dup /RightMouseButton eq
128 {pop MB3key} if
129 cvi
130 tag tagprint typedprint typedprint typedprint
131 cdef isready(keyread) => tag(keyread)
132 % tells whether character input is ready
133 0 % default output
134 dumevent createevent copy sendevent
135 {
136 /theevent awaitevent def
137 theevent /Action get 13 eq
138 { exit } if
139 pop 1
140 /newevent kdevent createevent copy def
141 newevent /Name theevent /Name get put
142 newevent sendevent
143 } loop
144 tag tagprint typedprint
145 cdef startcomin()
146 % get ready for execution of comin
147 /nouse /nouse_m Can setstandardcursor
148 cdef endcomin()
149 % get ready for normal execution
150 normalcursor
151 cdef getkey(key) => tag(key)
152 % get a keypress
153 textcursor myshow awaitevent /Name get cvi
154 textcursor mydel tag tagprint typedprint
155 cdef delete(string s)
156 % delete the string s
157 s mydel
