root/radiance/ray/src/rt/nwsdev.c
Revision: 2.3
Committed: Sat Feb 22 02:07:29 2003 UTC (22 years, 2 months ago) by greg
Changes since 2.2: +0 -0 lines
State: FILE REMOVED
2 static char SCCSid[] = "$SunId$ LBL";
4
5 /*
6 * NeWS driver, by Isaac Kwo
7 *
8 * July 1990
9 */
10
11 #include "standard.h"
12 #include "newsconstants.h"
13 #include "driver.h"
14 #include "nwsdev.h"
15 #include "color.h"
16 char inputbuffer[256];
17 int pos;
18 int gamma[257];
19
20 static int nws_close(),nws_clear(),nws_painter(),nws_getclick(),
21 nws_printer(),nws_getinput(),nws_flush(),nws_errout(),
22 nws_gpainter();
23 static struct driver nws_driver =
24 {
25 nws_close,nws_clear,nws_gpainter,nws_getclick,
26 nws_printer,nws_getinput,nws_flush,1.0
27 };
28
29 static int
30 nws_clear()
31 {
32 cps_clear();
33 }
34
35 static int
36 nws_getclick(xp,yp)
37 int *xp,*yp;
38 {
39 int key;
40 cps_getclick(xp,yp,&key);
41 nws_driver.inpready=0;
42 return(key);
43 }
44
45 struct driver *
46 nws_init(name,id) /* initialize driver */
47 char *name,*id;
48 {
49 int wX,wY,wW,wH,i;
50 gamma[256]=1;
51 for(i=0;i<256;i++)
52 gamma[i]=500*pow(i/256.,1./gammacorrection);
53 ps_open_PostScript();
54 sgicheck(&i);
55 if(i)nws_driver.paintr=nws_painter;
56 getthebox(&wX,&wY,&wW,&wH);
57 if(wW<100)wW=100;
58 if(wH<100+textareaheight)wH=100+textareaheight;
59 cps_initcanvas
60 (wX,wY,wW,wH,(int)MB1,(int)MB2,(int)MB3);
61 nws_driver.xsiz=wW;
62 nws_driver.ysiz=wH-textareaheight;
63 nws_driver.inpready=0;
64 erract[COMMAND].pf=nws_printer;
65 if(erract[WARNING].pf!=NULL)erract[WARNING].pf=nws_errout;
66 return(&nws_driver);
67 }
68
69 static int
70 nws_close() /* close the display */
71 {
72 erract[COMMAND].pf=NULL;
73 if(erract[WARNING].pf!=NULL)erract[WARNING].pf=wputs;
74 cps_cleanup();
75 ps_flush_PostScript();
76 ps_close_PostScript();
77 }
78
79 static int
80 nws_flush() /* flush output and check for keyboard input */
81 {
82 ps_flush_PostScript();
83 isready(&(nws_driver.inpready));
84 }
85
86 static int
87 nws_errout(msg) /* output an error message */
88 char *msg; /* my comments are so bogus */
89 {
90 eputs(msg);
91 nws_printer(msg);
92 }
93
94 static int
95 nws_painter(col,xmin,ymin,xmax,ymax)
96 COLOR col;
97 int xmin,ymin,xmax,ymax;
98 {
99 box(xmin,ymin+textareaheight,xmax,ymax+textareaheight
100 ,(int)(500*col[RED]),(int)(500*col[GRN]),(int)(500*col[BLU]));
101 }
102 static int
103 nws_gpainter(col,xmin,ymin,xmax,ymax)
104 COLOR col;
105 int xmin,ymin,xmax,ymax;
106 {
107 int i;
108 int col2[3];
109 for(i=0;i<3;i++)
110 {
111 col2[i]=256.*col[i];
112 if(col2[i]>255)col2[i]=255;
113 col2[i]=gamma[col2[i]];
114 }
115 box(xmin,ymin+textareaheight,xmax,ymax+textareaheight
116 ,col2[0],col2[1],col2[2]);
117 }
118 static int
119 nws_printer(orig) /* printer recognises \n as a linefeed */
120 char *orig;
121 {
122 char *m,*s,string[BUFSIZ]; /* s is for string and m is for message */
123 m=s=string;
124 while((*(s++))=(*(orig++)));
125 s=string;
126 while(*s)
127 if(*s++=='\n')
128 {
129 *(s-1)=0;
130 linefeed(m);
131 m=s;
132 }
133 printout(m);
134 }
135
136 static int
137 mygetc()
138 {
139 int key;
140 getkey(&key);
141 return(key);
142 }
143 static int
144 myputs(str)
145 char *str;
146 {
147 char buf[2]; buf[1]=0;
148 for(;*str;str++)
149 switch(*str)
150 {
151 case '\n': pos=0; linefeed(""); break;
152 case '\b':
153 buf[0]=inputbuffer[--pos];
154 delete(buf);
155 break;
156 default:
157 buf[0]=inputbuffer[pos++]=(*str);
158 printout(buf);
159 break;
160 }
161 return(0);
162 }
163 static int
164 nws_getinput(s,prompt)
165 char s[BUFSIZ];
166 {
167 if(prompt)nws_printer(prompt);
168 startcomin();
169 pos=0;
170 editline(s,mygetc,myputs);
171 endcomin();
172 nws_driver.inpready=0;
173 }
