1 |
/* Copyright (c) 1991 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* normal.c - shading function for normal materials. |
9 |
10 |
* 8/19/85 |
11 |
* 12/19/85 - added stuff for metals. |
12 |
* 6/26/87 - improved specular model. |
13 |
* 9/28/87 - added model for translucent materials. |
14 |
15 |
16 |
#include "ray.h" |
17 |
18 |
#include "otypes.h" |
19 |
20 |
21 |
* This routine uses portions of the reflection |
22 |
* model described by Cook and Torrance. |
23 |
* The computation of specular components has been simplified by |
24 |
* numerous approximations and ommisions to improve speed. |
25 |
* We orient the surface towards the incoming ray, so a single |
26 |
* surface can be used to represent an infinitely thin object. |
27 |
28 |
* Arguments for MAT_PLASTIC and MAT_METAL are: |
29 |
* red grn blu specular-frac. facet-slope |
30 |
31 |
* Arguments for MAT_TRANS are: |
32 |
* red grn blu rspec rough trans tspec |
33 |
34 |
35 |
#define BSPEC(m) (6.0) /* specularity parameter b */ |
36 |
37 |
extern double exp(); |
38 |
39 |
typedef struct { |
40 |
OBJREC *mp; /* material pointer */ |
41 |
RAY *pr; /* intersected ray */ |
42 |
COLOR mcolor; /* color of this material */ |
43 |
COLOR scolor; /* color of specular component */ |
44 |
FVECT vrefl; /* vector in direction of reflected ray */ |
45 |
double alpha2; /* roughness squared times 2 */ |
46 |
double rdiff, rspec; /* reflected specular, diffuse */ |
47 |
double trans; /* transmissivity */ |
48 |
double tdiff, tspec; /* transmitted specular, diffuse */ |
49 |
FVECT pnorm; /* perturbed surface normal */ |
50 |
double pdot; /* perturbed dot product */ |
51 |
} NORMDAT; /* normal material data */ |
52 |
53 |
54 |
dirnorm(cval, np, ldir, omega) /* compute source contribution */ |
55 |
COLOR cval; /* returned coefficient */ |
56 |
register NORMDAT *np; /* material data */ |
57 |
FVECT ldir; /* light source direction */ |
58 |
double omega; /* light source size */ |
59 |
60 |
double ldot; |
61 |
double dtmp; |
62 |
COLOR ctmp; |
63 |
64 |
setcolor(cval, 0.0, 0.0, 0.0); |
65 |
66 |
ldot = DOT(np->pnorm, ldir); |
67 |
68 |
if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY) |
69 |
return; /* wrong side */ |
70 |
71 |
if (ldot > FTINY && np->rdiff > FTINY) { |
72 |
73 |
* Compute and add diffuse reflected component to returned |
74 |
* color. The diffuse reflected component will always be |
75 |
* modified by the color of the material. |
76 |
77 |
copycolor(ctmp, np->mcolor); |
78 |
dtmp = ldot * omega * np->rdiff / PI; |
79 |
scalecolor(ctmp, dtmp); |
80 |
addcolor(cval, ctmp); |
81 |
82 |
if (ldot > FTINY && np->rspec > FTINY && np->alpha2 > FTINY) { |
83 |
84 |
* Compute specular reflection coefficient using |
85 |
* gaussian distribution model. |
86 |
87 |
/* roughness + source */ |
88 |
dtmp = np->alpha2 + omega/(2.0*PI); |
89 |
/* gaussian */ |
90 |
dtmp = exp((DOT(np->vrefl,ldir)-1.)/dtmp)/(2.*PI)/dtmp; |
91 |
/* worth using? */ |
92 |
if (dtmp > FTINY) { |
93 |
copycolor(ctmp, np->scolor); |
94 |
dtmp *= omega; |
95 |
96 |
97 |
98 |
99 |
if (ldot < -FTINY && np->tdiff > FTINY) { |
100 |
101 |
* Compute diffuse transmission. |
102 |
103 |
104 |
dtmp = -ldot * omega * np->tdiff / PI; |
105 |
106 |
107 |
108 |
if (ldot < -FTINY && np->tspec > FTINY && np->alpha2 > FTINY) { |
109 |
110 |
* Compute specular transmission. Specular transmission |
111 |
* is unaffected by material color. |
112 |
113 |
114 |
115 |
/* gaussian */ |
116 |
dtmp = exp((DOT(np->pr->rdir,ldir)-1.)/dtmp)/(2.*PI)/dtmp; |
117 |
118 |
119 |
dtmp *= np->tspec * omega; |
120 |
setcolor(ctmp, dtmp, dtmp, dtmp); |
121 |
122 |
123 |
124 |
125 |
126 |
127 |
m_normal(m, r) /* color a ray which hit something normal */ |
128 |
register OBJREC *m; |
129 |
register RAY *r; |
130 |
131 |
NORMDAT nd; |
132 |
double transtest, transdist; |
133 |
double dtmp; |
134 |
COLOR ctmp; |
135 |
register int i; |
136 |
137 |
if (m->oargs.nfargs != (m->otype == MAT_TRANS ? 7 : 5)) |
138 |
objerror(m, USER, "bad # arguments"); |
139 |
/* easy shadow test */ |
140 |
if (r->crtype & SHADOW && m->otype != MAT_TRANS) |
141 |
return; |
142 |
nd.mp = m; |
143 |
nd.pr = r; |
144 |
/* get material color */ |
145 |
setcolor(nd.mcolor, m->oargs.farg[0], |
146 |
m->oargs.farg[1], |
147 |
m->oargs.farg[2]); |
148 |
/* get roughness */ |
149 |
nd.alpha2 = m->oargs.farg[4]; |
150 |
nd.alpha2 *= 2.0 * nd.alpha2; |
151 |
/* reorient if necessary */ |
152 |
if (r->rod < 0.0) |
153 |
flipsurface(r); |
154 |
/* get modifiers */ |
155 |
raytexture(r, m->omod); |
156 |
nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */ |
157 |
multcolor(nd.mcolor, r->pcol); /* modify material color */ |
158 |
transtest = 0; |
159 |
/* get specular component */ |
160 |
nd.rspec = m->oargs.farg[3]; |
161 |
162 |
if (nd.rspec > FTINY) { /* has specular component */ |
163 |
/* compute specular color */ |
164 |
if (m->otype == MAT_METAL) |
165 |
copycolor(nd.scolor, nd.mcolor); |
166 |
else |
167 |
setcolor(nd.scolor, 1.0, 1.0, 1.0); |
168 |
scalecolor(nd.scolor, nd.rspec); |
169 |
/* improved model */ |
170 |
dtmp = exp(-BSPEC(m)*nd.pdot); |
171 |
for (i = 0; i < 3; i++) |
172 |
colval(nd.scolor,i) += (1.0-colval(nd.scolor,i))*dtmp; |
173 |
nd.rspec += (1.0-nd.rspec)*dtmp; |
174 |
/* compute reflected ray */ |
175 |
176 |
nd.vrefl[i] = r->rdir[i] + 2.0*nd.pdot*nd.pnorm[i]; |
177 |
178 |
if (nd.alpha2 <= FTINY && !(r->crtype & SHADOW)) { |
179 |
RAY lr; |
180 |
if (rayorigin(&lr, r, REFLECTED, nd.rspec) == 0) { |
181 |
VCOPY(lr.rdir, nd.vrefl); |
182 |
rayvalue(&lr); |
183 |
multcolor(lr.rcol, nd.scolor); |
184 |
addcolor(r->rcol, lr.rcol); |
185 |
186 |
187 |
188 |
/* compute transmission */ |
189 |
if (m->otype == MAT_TRANS) { |
190 |
nd.trans = m->oargs.farg[5]*(1.0 - nd.rspec); |
191 |
nd.tspec = nd.trans * m->oargs.farg[6]; |
192 |
nd.tdiff = nd.trans - nd.tspec; |
193 |
} else |
194 |
nd.tdiff = nd.tspec = nd.trans = 0.0; |
195 |
/* transmitted ray */ |
196 |
if (nd.tspec > FTINY && nd.alpha2 <= FTINY) { |
197 |
RAY lr; |
198 |
if (rayorigin(&lr, r, TRANS, nd.tspec) == 0) { |
199 |
if (!(r->crtype & SHADOW) && |
200 |
DOT(r->pert,r->pert) > FTINY*FTINY) { |
201 |
for (i = 0; i < 3; i++) /* perturb direction */ |
202 |
lr.rdir[i] = r->rdir[i] - |
203 |
.75*r->pert[i]; |
204 |
normalize(lr.rdir); |
205 |
} else { |
206 |
VCOPY(lr.rdir, r->rdir); |
207 |
transtest = 2; |
208 |
209 |
rayvalue(&lr); |
210 |
scalecolor(lr.rcol, nd.tspec); |
211 |
multcolor(lr.rcol, nd.mcolor); /* modified by color */ |
212 |
213 |
transtest *= bright(lr.rcol); |
214 |
transdist = r->rot + lr.rt; |
215 |
216 |
217 |
if (r->crtype & SHADOW) /* the rest is shadow */ |
218 |
return; |
219 |
/* diffuse reflection */ |
220 |
nd.rdiff = 1.0 - nd.trans - nd.rspec; |
221 |
222 |
if (nd.rdiff <= FTINY && nd.tdiff <= FTINY && nd.alpha2 <= FTINY) |
223 |
return; /* purely specular */ |
224 |
225 |
if (nd.rdiff > FTINY) { /* ambient from this side */ |
226 |
ambient(ctmp, r); |
227 |
if (nd.alpha2 <= FTINY) |
228 |
scalecolor(ctmp, nd.rdiff); |
229 |
else |
230 |
scalecolor(ctmp, 1.0-nd.trans); |
231 |
multcolor(ctmp, nd.mcolor); /* modified by material color */ |
232 |
addcolor(r->rcol, ctmp); /* add to returned color */ |
233 |
234 |
if (nd.tdiff > FTINY) { /* ambient from other side */ |
235 |
flipsurface(r); |
236 |
ambient(ctmp, r); |
237 |
238 |
scalecolor(ctmp, nd.tdiff); |
239 |
else |
240 |
scalecolor(ctmp, nd.trans); |
241 |
multcolor(ctmp, nd.mcolor); |
242 |
addcolor(r->rcol, ctmp); |
243 |
flipsurface(r); |
244 |
245 |
/* add direct component */ |
246 |
direct(r, dirnorm, &nd); |
247 |
/* check distance */ |
248 |
if (transtest > bright(r->rcol)) |
249 |
r->rt = transdist; |
250 |
