root/radiance/ray/src/rt/normal.c
Revision: 2.75
Committed: Thu Aug 3 16:41:52 2017 UTC (8 years ago) by greg
Changes since 2.74: +7 -3 lines
Fixed error in effective ray length for purely specular materials
2 static const char RCSid[] = "$Id: normal.c,v 2.74 2016/02/23 12:42:41 rschregle Exp $";
5 * normal.c - shading function for normal materials.
6 *
7 * 8/19/85
8 * 12/19/85 - added stuff for metals.
9 * 6/26/87 - improved specular model.
10 * 9/28/87 - added model for translucent materials.
11 * Later changes described in delta comments.
12 */
13
14 #include "copyright.h"
15
16 #include "ray.h"
17 #include "ambient.h"
18 #include "source.h"
19 #include "otypes.h"
20 #include "rtotypes.h"
21 #include "random.h"
22 #include "pmapmat.h"
23
24 #ifndef MAXITER
25 #define MAXITER 10 /* maximum # specular ray attempts */
26 #endif
27 /* estimate of Fresnel function */
28 #define FRESNE(ci) (exp(-5.85*(ci)) - 0.00287989916)
29 #define FRESTHRESH 0.017999 /* minimum specularity for approx. */
30
31
32 /*
33 * This routine implements the isotropic Gaussian
34 * model described by Ward in Siggraph `92 article.
35 * We orient the surface towards the incoming ray, so a single
36 * surface can be used to represent an infinitely thin object.
37 *
38 * Arguments for MAT_PLASTIC and MAT_METAL are:
39 * red grn blu specular-frac. facet-slope
40 *
41 * Arguments for MAT_TRANS are:
42 * red grn blu rspec rough trans tspec
43 */
44
45 /* specularity flags */
46 #define SP_REFL 01 /* has reflected specular component */
47 #define SP_TRAN 02 /* has transmitted specular */
48 #define SP_PURE 04 /* purely specular (zero roughness) */
49 #define SP_FLAT 010 /* flat reflecting surface */
50 #define SP_RBLT 020 /* reflection below sample threshold */
51 #define SP_TBLT 040 /* transmission below threshold */
52
53 typedef struct {
54 OBJREC *mp; /* material pointer */
55 RAY *rp; /* ray pointer */
56 short specfl; /* specularity flags, defined above */
57 COLOR mcolor; /* color of this material */
58 COLOR scolor; /* color of specular component */
59 FVECT vrefl; /* vector in direction of reflected ray */
60 FVECT prdir; /* vector in transmitted direction */
61 double alpha2; /* roughness squared */
62 double rdiff, rspec; /* reflected specular, diffuse */
63 double trans; /* transmissivity */
64 double tdiff, tspec; /* transmitted specular, diffuse */
65 FVECT pnorm; /* perturbed surface normal */
66 double pdot; /* perturbed dot product */
67 } NORMDAT; /* normal material data */
68
69 static void gaussamp(NORMDAT *np);
70
71
72 static void
73 dirnorm( /* compute source contribution */
74 COLOR cval, /* returned coefficient */
75 void *nnp, /* material data */
76 FVECT ldir, /* light source direction */
77 double omega /* light source size */
78 )
79 {
80 NORMDAT *np = nnp;
81 double ldot;
82 double lrdiff, ltdiff;
83 double dtmp, d2, d3, d4;
84 FVECT vtmp;
85 COLOR ctmp;
86
87 setcolor(cval, 0.0, 0.0, 0.0);
88
89 ldot = DOT(np->pnorm, ldir);
90
91 if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY)
92 return; /* wrong side */
93
94 /* Fresnel estimate */
95 lrdiff = np->rdiff;
96 ltdiff = np->tdiff;
97 if (np->specfl & SP_PURE && np->rspec >= FRESTHRESH &&
98 (lrdiff > FTINY) | (ltdiff > FTINY)) {
99 dtmp = 1. - FRESNE(fabs(ldot));
100 lrdiff *= dtmp;
101 ltdiff *= dtmp;
102 }
103
104 if (ldot > FTINY && lrdiff > FTINY) {
105 /*
106 * Compute and add diffuse reflected component to returned
107 * color. The diffuse reflected component will always be
108 * modified by the color of the material.
109 */
110 copycolor(ctmp, np->mcolor);
111 dtmp = ldot * omega * lrdiff * (1.0/PI);
112 scalecolor(ctmp, dtmp);
113 addcolor(cval, ctmp);
114 }
115
116 if (ldot < -FTINY && ltdiff > FTINY) {
117 /*
118 * Compute diffuse transmission.
119 */
120 copycolor(ctmp, np->mcolor);
121 dtmp = -ldot * omega * ltdiff * (1.0/PI);
122 scalecolor(ctmp, dtmp);
123 addcolor(cval, ctmp);
124 }
125
126 if (ambRayInPmap(np->rp))
127 return; /* specular already in photon map */
128
129 if (ldot > FTINY && (np->specfl&(SP_REFL|SP_PURE)) == SP_REFL) {
130 /*
131 * Compute specular reflection coefficient using
132 * Gaussian distribution model.
133 */
134 /* roughness */
135 dtmp = np->alpha2;
136 /* + source if flat */
137 if (np->specfl & SP_FLAT)
138 dtmp += omega * (0.25/PI);
139 /* half vector */
140 VSUB(vtmp, ldir, np->rp->rdir);
141 d2 = DOT(vtmp, np->pnorm);
142 d2 *= d2;
143 d3 = DOT(vtmp,vtmp);
144 d4 = (d3 - d2) / d2;
145 /* new W-G-M-D model */
146 dtmp = exp(-d4/dtmp) * d3 / (PI * d2*d2 * dtmp);
147 /* worth using? */
148 if (dtmp > FTINY) {
149 copycolor(ctmp, np->scolor);
150 dtmp *= ldot * omega;
151 scalecolor(ctmp, dtmp);
152 addcolor(cval, ctmp);
153 }
154 }
155
156
157 if (ldot < -FTINY && (np->specfl&(SP_TRAN|SP_PURE)) == SP_TRAN) {
158 /*
159 * Compute specular transmission. Specular transmission
160 * is always modified by material color.
161 */
162 /* roughness + source */
163 dtmp = np->alpha2 + omega*(1.0/PI);
164 /* Gaussian */
165 dtmp = exp((2.*DOT(np->prdir,ldir)-2.)/dtmp)/(PI*dtmp);
166 /* worth using? */
167 if (dtmp > FTINY) {
168 copycolor(ctmp, np->mcolor);
169 dtmp *= np->tspec * omega * sqrt(-ldot/np->pdot);
170 scalecolor(ctmp, dtmp);
171 addcolor(cval, ctmp);
172 }
173 }
174 }
175
176
177 int
178 m_normal( /* color a ray that hit something normal */
179 OBJREC *m,
180 RAY *r
181 )
182 {
183 NORMDAT nd;
184 double fest;
185 double transtest, transdist;
186 double mirtest, mirdist;
187 int hastexture;
188 double d;
189 COLOR ctmp;
190 int i;
191
192 /* PMAP: skip transmitted shadow ray if accounted for in photon map */
193 /* No longer needed?
194 if (shadowRayInPmap(r) || ambRayInPmap(r))
195 return(1); */
196
197 /* easy shadow test */
198 if (r->crtype & SHADOW && m->otype != MAT_TRANS)
199 return(1);
200
201 if (m->oargs.nfargs != (m->otype == MAT_TRANS ? 7 : 5))
202 objerror(m, USER, "bad number of arguments");
203 /* check for back side */
204 if (r->rod < 0.0) {
205 if (!backvis) {
206 raytrans(r);
207 return(1);
208 }
209 raytexture(r, m->omod);
210 flipsurface(r); /* reorient if backvis */
211 } else
212 raytexture(r, m->omod);
213 nd.mp = m;
214 nd.rp = r;
215 /* get material color */
216 setcolor(nd.mcolor, m->oargs.farg[0],
217 m->oargs.farg[1],
218 m->oargs.farg[2]);
219 /* get roughness */
220 nd.specfl = 0;
221 nd.alpha2 = m->oargs.farg[4];
222 if ((nd.alpha2 *= nd.alpha2) <= FTINY)
223 nd.specfl |= SP_PURE;
224
225 if ( (hastexture = (DOT(r->pert,r->pert) > FTINY*FTINY)) ) {
226 nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */
227 } else {
228 VCOPY(nd.pnorm, r->ron);
229 nd.pdot = r->rod;
230 }
231 if (r->ro != NULL && isflat(r->ro->otype))
232 nd.specfl |= SP_FLAT;
233 if (nd.pdot < .001)
234 nd.pdot = .001; /* non-zero for dirnorm() */
235 multcolor(nd.mcolor, r->pcol); /* modify material color */
236 mirtest = transtest = 0;
237 mirdist = transdist = r->rot;
238 nd.rspec = m->oargs.farg[3];
239 /* compute Fresnel approx. */
240 if (nd.specfl & SP_PURE && nd.rspec >= FRESTHRESH) {
241 fest = FRESNE(nd.pdot);
242 nd.rspec += fest*(1. - nd.rspec);
243 } else
244 fest = 0.;
245 /* compute transmission */
246 if (m->otype == MAT_TRANS) {
247 nd.trans = m->oargs.farg[5]*(1.0 - nd.rspec);
248 nd.tspec = nd.trans * m->oargs.farg[6];
249 nd.tdiff = nd.trans - nd.tspec;
250 if (nd.tspec > FTINY) {
251 nd.specfl |= SP_TRAN;
252 /* check threshold */
253 if (!(nd.specfl & SP_PURE) &&
254 specthresh >= nd.tspec-FTINY)
255 nd.specfl |= SP_TBLT;
256 if (!hastexture || r->crtype & (SHADOW|AMBIENT)) {
257 VCOPY(nd.prdir, r->rdir);
258 transtest = 2;
259 } else {
260 for (i = 0; i < 3; i++) /* perturb */
261 nd.prdir[i] = r->rdir[i] - r->pert[i];
262 if (DOT(nd.prdir, r->ron) < -FTINY)
263 normalize(nd.prdir); /* OK */
264 else
265 VCOPY(nd.prdir, r->rdir);
266 }
267 }
268 } else
269 nd.tdiff = nd.tspec = nd.trans = 0.0;
270 /* transmitted ray */
271
272 if ((nd.specfl&(SP_TRAN|SP_PURE|SP_TBLT)) == (SP_TRAN|SP_PURE)) {
273 RAY lr;
274 copycolor(lr.rcoef, nd.mcolor); /* modified by color */
275 scalecolor(lr.rcoef, nd.tspec);
276 if (rayorigin(&lr, TRANS, r, lr.rcoef) == 0) {
277 VCOPY(lr.rdir, nd.prdir);
278 rayvalue(&lr);
279 multcolor(lr.rcol, lr.rcoef);
280 addcolor(r->rcol, lr.rcol);
281 transtest *= bright(lr.rcol);
282 transdist = r->rot + lr.rt;
283 }
284 } else
285 transtest = 0;
286
287 if (r->crtype & SHADOW) { /* the rest is shadow */
288 r->rt = transdist;
289 return(1);
290 }
291 /* get specular reflection */
292 if (nd.rspec > FTINY) {
293 nd.specfl |= SP_REFL;
294 /* compute specular color */
295 if (m->otype != MAT_METAL) {
296 setcolor(nd.scolor, nd.rspec, nd.rspec, nd.rspec);
297 } else if (fest > FTINY) {
298 d = m->oargs.farg[3]*(1. - fest);
299 for (i = 0; i < 3; i++)
300 colval(nd.scolor,i) = fest +
301 colval(nd.mcolor,i)*d;
302 } else {
303 copycolor(nd.scolor, nd.mcolor);
304 scalecolor(nd.scolor, nd.rspec);
305 }
306 /* check threshold */
307 if (!(nd.specfl & SP_PURE) && specthresh >= nd.rspec-FTINY)
308 nd.specfl |= SP_RBLT;
309 /* compute reflected ray */
310 VSUM(nd.vrefl, r->rdir, nd.pnorm, 2.*nd.pdot);
311 /* penetration? */
312 if (hastexture && DOT(nd.vrefl, r->ron) <= FTINY)
313 VSUM(nd.vrefl, r->rdir, r->ron, 2.*r->rod);
314 checknorm(nd.vrefl);
315 }
316 /* reflected ray */
317 if ((nd.specfl&(SP_REFL|SP_PURE|SP_RBLT)) == (SP_REFL|SP_PURE)) {
318 RAY lr;
319 if (rayorigin(&lr, REFLECTED, r, nd.scolor) == 0) {
320 VCOPY(lr.rdir, nd.vrefl);
321 rayvalue(&lr);
322 multcolor(lr.rcol, lr.rcoef);
323 addcolor(r->rcol, lr.rcol);
324 if (nd.specfl & SP_FLAT &&
325 !hastexture | (r->crtype & AMBIENT)) {
326 mirtest = 2.*bright(lr.rcol);
327 mirdist = r->rot + lr.rt;
328 }
329 }
330 }
331 /* diffuse reflection */
332 nd.rdiff = 1.0 - nd.trans - nd.rspec;
333
334 if (nd.specfl & SP_PURE && nd.rdiff <= FTINY && nd.tdiff <= FTINY) {
335 if (mirtest > transtest+FTINY)
336 r->rt = mirdist;
337 else if (transtest > FTINY)
338 r->rt = transdist;
339 return(1); /* 100% pure specular */
340 }
341 if (!(nd.specfl & SP_PURE))
342 gaussamp(&nd); /* checks *BLT flags */
343
344 if (nd.rdiff > FTINY) { /* ambient from this side */
345 copycolor(ctmp, nd.mcolor); /* modified by material color */
346 scalecolor(ctmp, nd.rdiff);
347 if (nd.specfl & SP_RBLT) /* add in specular as well? */
348 addcolor(ctmp, nd.scolor);
349 multambient(ctmp, r, hastexture ? nd.pnorm : r->ron);
350 addcolor(r->rcol, ctmp); /* add to returned color */
351 }
352 if (nd.tdiff > FTINY) { /* ambient from other side */
353 copycolor(ctmp, nd.mcolor); /* modified by color */
354 if (nd.specfl & SP_TBLT)
355 scalecolor(ctmp, nd.trans);
356 else
357 scalecolor(ctmp, nd.tdiff);
358 flipsurface(r);
359 if (hastexture) {
360 FVECT bnorm;
361 bnorm[0] = -nd.pnorm[0];
362 bnorm[1] = -nd.pnorm[1];
363 bnorm[2] = -nd.pnorm[2];
364 multambient(ctmp, r, bnorm);
365 } else
366 multambient(ctmp, r, r->ron);
367 addcolor(r->rcol, ctmp);
368 flipsurface(r);
369 }
370 /* add direct component */
371 direct(r, dirnorm, &nd);
372 /* check distance */
373 d = bright(r->rcol);
374 if (transtest > d)
375 r->rt = transdist;
376 else if (mirtest > d)
377 r->rt = mirdist;
378
379 return(1);
380 }
381
382
383 static void
384 gaussamp( /* sample Gaussian specular */
385 NORMDAT *np
386 )
387 {
388 RAY sr;
389 FVECT u, v, h;
390 double rv[2];
391 double d, sinp, cosp;
392 COLOR scol;
393 int maxiter, ntrials, nstarget, nstaken;
394 int i;
395 /* quick test */
396 if ((np->specfl & (SP_REFL|SP_RBLT)) != SP_REFL &&
397 (np->specfl & (SP_TRAN|SP_TBLT)) != SP_TRAN)
398 return;
399 /* set up sample coordinates */
400 getperpendicular(u, np->pnorm, rand_samp);
401 fcross(v, np->pnorm, u);
402 /* compute reflection */
403 if ((np->specfl & (SP_REFL|SP_RBLT)) == SP_REFL &&
404 rayorigin(&sr, SPECULAR, np->rp, np->scolor) == 0) {
405 nstarget = 1;
406 if (specjitter > 1.5) { /* multiple samples? */
407 nstarget = specjitter*np->rp->rweight + .5;
408 if (sr.rweight <= minweight*nstarget)
409 nstarget = sr.rweight/minweight;
410 if (nstarget > 1) {
411 d = 1./nstarget;
412 scalecolor(sr.rcoef, d);
413 sr.rweight *= d;
414 } else
415 nstarget = 1;
416 }
417 setcolor(scol, 0., 0., 0.);
418 dimlist[ndims++] = (int)(size_t)np->mp;
419 maxiter = MAXITER*nstarget;
420 for (nstaken = ntrials = 0; nstaken < nstarget &&
421 ntrials < maxiter; ntrials++) {
422 if (ntrials)
423 d = frandom();
424 else
425 d = urand(ilhash(dimlist,ndims)+samplendx);
426 multisamp(rv, 2, d);
427 d = 2.0*PI * rv[0];
428 cosp = tcos(d);
429 sinp = tsin(d);
430 if ((0. <= specjitter) & (specjitter < 1.))
431 rv[1] = 1.0 - specjitter*rv[1];
432 if (rv[1] <= FTINY)
433 d = 1.0;
434 else
435 d = sqrt( np->alpha2 * -log(rv[1]) );
436 for (i = 0; i < 3; i++)
437 h[i] = np->pnorm[i] + d*(cosp*u[i] + sinp*v[i]);
438 d = -2.0 * DOT(h, np->rp->rdir) / (1.0 + d*d);
439 VSUM(sr.rdir, np->rp->rdir, h, d);
440 /* sample rejection test */
441 if ((d = DOT(sr.rdir, np->rp->ron)) <= FTINY)
442 continue;
443 checknorm(sr.rdir);
444 if (nstarget > 1) { /* W-G-M-D adjustment */
445 if (nstaken) rayclear(&sr);
446 rayvalue(&sr);
447 d = 2./(1. + np->rp->rod/d);
448 scalecolor(sr.rcol, d);
449 addcolor(scol, sr.rcol);
450 } else {
451 rayvalue(&sr);
452 multcolor(sr.rcol, sr.rcoef);
453 addcolor(np->rp->rcol, sr.rcol);
454 }
455 ++nstaken;
456 }
457 if (nstarget > 1) { /* final W-G-M-D weighting */
458 multcolor(scol, sr.rcoef);
459 d = (double)nstarget/ntrials;
460 scalecolor(scol, d);
461 addcolor(np->rp->rcol, scol);
462 }
463 ndims--;
464 }
465 /* compute transmission */
466 copycolor(sr.rcoef, np->mcolor); /* modified by color */
467 scalecolor(sr.rcoef, np->tspec);
468 if ((np->specfl & (SP_TRAN|SP_TBLT)) == SP_TRAN &&
469 rayorigin(&sr, SPECULAR, np->rp, sr.rcoef) == 0) {
470 nstarget = 1;
471 if (specjitter > 1.5) { /* multiple samples? */
472 nstarget = specjitter*np->rp->rweight + .5;
473 if (sr.rweight <= minweight*nstarget)
474 nstarget = sr.rweight/minweight;
475 if (nstarget > 1) {
476 d = 1./nstarget;
477 scalecolor(sr.rcoef, d);
478 sr.rweight *= d;
479 } else
480 nstarget = 1;
481 }
482 dimlist[ndims++] = (int)(size_t)np->mp;
483 maxiter = MAXITER*nstarget;
484 for (nstaken = ntrials = 0; nstaken < nstarget &&
485 ntrials < maxiter; ntrials++) {
486 if (ntrials)
487 d = frandom();
488 else
489 d = urand(ilhash(dimlist,ndims)+samplendx);
490 multisamp(rv, 2, d);
491 d = 2.0*PI * rv[0];
492 cosp = tcos(d);
493 sinp = tsin(d);
494 if ((0. <= specjitter) & (specjitter < 1.))
495 rv[1] = 1.0 - specjitter*rv[1];
496 if (rv[1] <= FTINY)
497 d = 1.0;
498 else
499 d = sqrt( np->alpha2 * -log(rv[1]) );
500 for (i = 0; i < 3; i++)
501 sr.rdir[i] = np->prdir[i] + d*(cosp*u[i] + sinp*v[i]);
502 /* sample rejection test */
503 if (DOT(sr.rdir, np->rp->ron) >= -FTINY)
504 continue;
505 normalize(sr.rdir); /* OK, normalize */
506 if (nstaken) /* multi-sampling */
507 rayclear(&sr);
508 rayvalue(&sr);
509 multcolor(sr.rcol, sr.rcoef);
510 addcolor(np->rp->rcol, sr.rcol);
511 ++nstaken;
512 }
513 ndims--;
514 }
515 }
