| 1 |
/* Copyright (c) 1995 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* normal.c - shading function for normal materials.
| 9 |
| 10 |
* 8/19/85
| 11 |
* 12/19/85 - added stuff for metals.
| 12 |
* 6/26/87 - improved specular model.
| 13 |
* 9/28/87 - added model for translucent materials.
| 14 |
* Later changes described in delta comments.
| 15 |
| 16 |
| 17 |
#include "ray.h"
| 18 |
| 19 |
#include "otypes.h"
| 20 |
| 21 |
#include "random.h"
| 22 |
| 23 |
extern double specthresh; /* specular sampling threshold */
| 24 |
extern double specjitter; /* specular sampling jitter */
| 25 |
| 26 |
extern int backvis; /* back faces visible? */
| 27 |
| 28 |
static gaussamp();
| 29 |
| 30 |
| 31 |
* This routine implements the isotropic Gaussian
| 32 |
* model described by Ward in Siggraph `92 article.
| 33 |
* We orient the surface towards the incoming ray, so a single
| 34 |
* surface can be used to represent an infinitely thin object.
| 35 |
| 36 |
* Arguments for MAT_PLASTIC and MAT_METAL are:
| 37 |
* red grn blu specular-frac. facet-slope
| 38 |
| 39 |
* Arguments for MAT_TRANS are:
| 40 |
* red grn blu rspec rough trans tspec
| 41 |
| 42 |
| 43 |
/* specularity flags */
| 44 |
#define SP_REFL 01 /* has reflected specular component */
| 45 |
#define SP_TRAN 02 /* has transmitted specular */
| 46 |
#define SP_PURE 04 /* purely specular (zero roughness) */
| 47 |
#define SP_FLAT 010 /* flat reflecting surface */
| 48 |
#define SP_RBLT 020 /* reflection below sample threshold */
| 49 |
#define SP_TBLT 040 /* transmission below threshold */
| 50 |
| 51 |
typedef struct {
| 52 |
OBJREC *mp; /* material pointer */
| 53 |
RAY *rp; /* ray pointer */
| 54 |
short specfl; /* specularity flags, defined above */
| 55 |
COLOR mcolor; /* color of this material */
| 56 |
COLOR scolor; /* color of specular component */
| 57 |
FVECT vrefl; /* vector in direction of reflected ray */
| 58 |
FVECT prdir; /* vector in transmitted direction */
| 59 |
double alpha2; /* roughness squared */
| 60 |
double rdiff, rspec; /* reflected specular, diffuse */
| 61 |
double trans; /* transmissivity */
| 62 |
double tdiff, tspec; /* transmitted specular, diffuse */
| 63 |
FVECT pnorm; /* perturbed surface normal */
| 64 |
double pdot; /* perturbed dot product */
| 65 |
} NORMDAT; /* normal material data */
| 66 |
| 67 |
| 68 |
dirnorm(cval, np, ldir, omega) /* compute source contribution */
| 69 |
COLOR cval; /* returned coefficient */
| 70 |
register NORMDAT *np; /* material data */
| 71 |
FVECT ldir; /* light source direction */
| 72 |
double omega; /* light source size */
| 73 |
| 74 |
double ldot;
| 75 |
double dtmp, d2;
| 76 |
FVECT vtmp;
| 77 |
COLOR ctmp;
| 78 |
| 79 |
setcolor(cval, 0.0, 0.0, 0.0);
| 80 |
| 81 |
ldot = DOT(np->pnorm, ldir);
| 82 |
| 83 |
if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY)
| 84 |
return; /* wrong side */
| 85 |
| 86 |
if (ldot > FTINY && np->rdiff > FTINY) {
| 87 |
| 88 |
* Compute and add diffuse reflected component to returned
| 89 |
* color. The diffuse reflected component will always be
| 90 |
* modified by the color of the material.
| 91 |
| 92 |
copycolor(ctmp, np->mcolor);
| 93 |
dtmp = ldot * omega * np->rdiff / PI;
| 94 |
scalecolor(ctmp, dtmp);
| 95 |
addcolor(cval, ctmp);
| 96 |
| 97 |
if (ldot > FTINY && (np->specfl&(SP_REFL|SP_PURE)) == SP_REFL) {
| 98 |
| 99 |
* Compute specular reflection coefficient using
| 100 |
* gaussian distribution model.
| 101 |
| 102 |
/* roughness */
| 103 |
dtmp = np->alpha2;
| 104 |
/* + source if flat */
| 105 |
if (np->specfl & SP_FLAT)
| 106 |
dtmp += omega/(4.0*PI);
| 107 |
/* half vector */
| 108 |
vtmp[0] = ldir[0] - np->rp->rdir[0];
| 109 |
vtmp[1] = ldir[1] - np->rp->rdir[1];
| 110 |
vtmp[2] = ldir[2] - np->rp->rdir[2];
| 111 |
d2 = DOT(vtmp, np->pnorm);
| 112 |
d2 *= d2;
| 113 |
d2 = (DOT(vtmp,vtmp) - d2) / d2;
| 114 |
/* gaussian */
| 115 |
dtmp = exp(-d2/dtmp)/(4.*PI*dtmp);
| 116 |
/* worth using? */
| 117 |
if (dtmp > FTINY) {
| 118 |
copycolor(ctmp, np->scolor);
| 119 |
dtmp *= omega * sqrt(ldot/np->pdot);
| 120 |
| 121 |
| 122 |
| 123 |
| 124 |
if (ldot < -FTINY && np->tdiff > FTINY) {
| 125 |
| 126 |
* Compute diffuse transmission.
| 127 |
| 128 |
| 129 |
dtmp = -ldot * omega * np->tdiff / PI;
| 130 |
| 131 |
| 132 |
| 133 |
if (ldot < -FTINY && (np->specfl&(SP_TRAN|SP_PURE)) == SP_TRAN) {
| 134 |
| 135 |
* Compute specular transmission. Specular transmission
| 136 |
* is always modified by material color.
| 137 |
| 138 |
/* roughness + source */
| 139 |
dtmp = np->alpha2 + omega/PI;
| 140 |
/* gaussian */
| 141 |
dtmp = exp((2.*DOT(np->prdir,ldir)-2.)/dtmp)/(PI*dtmp);
| 142 |
/* worth using? */
| 143 |
if (dtmp > FTINY) {
| 144 |
| 145 |
dtmp *= np->tspec * omega * sqrt(-ldot/np->pdot);
| 146 |
| 147 |
| 148 |
| 149 |
| 150 |
| 151 |
| 152 |
| 153 |
m_normal(m, r) /* color a ray that hit something normal */
| 154 |
register OBJREC *m;
| 155 |
register RAY *r;
| 156 |
| 157 |
NORMDAT nd;
| 158 |
double transtest, transdist;
| 159 |
double mirtest, mirdist;
| 160 |
int hastexture;
| 161 |
double d;
| 162 |
COLOR ctmp;
| 163 |
register int i;
| 164 |
/* easy shadow test */
| 165 |
if (r->crtype & SHADOW && m->otype != MAT_TRANS)
| 166 |
return(1);
| 167 |
| 168 |
if (m->oargs.nfargs != (m->otype == MAT_TRANS ? 7 : 5))
| 169 |
objerror(m, USER, "bad number of arguments");
| 170 |
/* check for back side */
| 171 |
if (r->rod < 0.0) {
| 172 |
if (!backvis && m->otype != MAT_TRANS) {
| 173 |
raytrans(r);
| 174 |
return(1);
| 175 |
| 176 |
flipsurface(r); /* reorient if backvis */
| 177 |
| 178 |
nd.mp = m;
| 179 |
nd.rp = r;
| 180 |
/* get material color */
| 181 |
setcolor(nd.mcolor, m->oargs.farg[0],
| 182 |
m->oargs.farg[1],
| 183 |
m->oargs.farg[2]);
| 184 |
/* get roughness */
| 185 |
nd.specfl = 0;
| 186 |
nd.alpha2 = m->oargs.farg[4];
| 187 |
if ((nd.alpha2 *= nd.alpha2) <= FTINY)
| 188 |
nd.specfl |= SP_PURE;
| 189 |
if (r->ro != NULL && isflat(r->ro->otype))
| 190 |
nd.specfl |= SP_FLAT;
| 191 |
/* get modifiers */
| 192 |
raytexture(r, m->omod);
| 193 |
if (hastexture = DOT(r->pert,r->pert) > FTINY*FTINY)
| 194 |
nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */
| 195 |
else {
| 196 |
VCOPY(nd.pnorm, r->ron);
| 197 |
nd.pdot = r->rod;
| 198 |
| 199 |
if (nd.pdot < .001)
| 200 |
nd.pdot = .001; /* non-zero for dirnorm() */
| 201 |
multcolor(nd.mcolor, r->pcol); /* modify material color */
| 202 |
mirtest = transtest = 0;
| 203 |
mirdist = transdist = r->rot;
| 204 |
nd.rspec = m->oargs.farg[3];
| 205 |
/* compute transmission */
| 206 |
if (m->otype == MAT_TRANS) {
| 207 |
nd.trans = m->oargs.farg[5]*(1.0 - nd.rspec);
| 208 |
nd.tspec = nd.trans * m->oargs.farg[6];
| 209 |
nd.tdiff = nd.trans - nd.tspec;
| 210 |
if (nd.tspec > FTINY) {
| 211 |
nd.specfl |= SP_TRAN;
| 212 |
/* check threshold */
| 213 |
if (!(nd.specfl & SP_PURE) &&
| 214 |
specthresh >= nd.tspec-FTINY)
| 215 |
nd.specfl |= SP_TBLT;
| 216 |
if (!hastexture || r->crtype & SHADOW) {
| 217 |
VCOPY(nd.prdir, r->rdir);
| 218 |
transtest = 2;
| 219 |
} else {
| 220 |
for (i = 0; i < 3; i++) /* perturb */
| 221 |
nd.prdir[i] = r->rdir[i] - r->pert[i];
| 222 |
if (DOT(nd.prdir, r->ron) < -FTINY)
| 223 |
normalize(nd.prdir); /* OK */
| 224 |
else
| 225 |
| 226 |
| 227 |
| 228 |
} else
| 229 |
nd.tdiff = nd.tspec = nd.trans = 0.0;
| 230 |
/* transmitted ray */
| 231 |
if ((nd.specfl&(SP_TRAN|SP_PURE)) == (SP_TRAN|SP_PURE)) {
| 232 |
RAY lr;
| 233 |
if (rayorigin(&lr, r, TRANS, nd.tspec) == 0) {
| 234 |
VCOPY(lr.rdir, nd.prdir);
| 235 |
rayvalue(&lr);
| 236 |
scalecolor(lr.rcol, nd.tspec);
| 237 |
multcolor(lr.rcol, nd.mcolor); /* modified by color */
| 238 |
addcolor(r->rcol, lr.rcol);
| 239 |
transtest *= bright(lr.rcol);
| 240 |
transdist = r->rot + lr.rt;
| 241 |
| 242 |
} else
| 243 |
transtest = 0;
| 244 |
| 245 |
if (r->crtype & SHADOW) { /* the rest is shadow */
| 246 |
r->rt = transdist;
| 247 |
return(1);
| 248 |
| 249 |
/* get specular reflection */
| 250 |
if (nd.rspec > FTINY) {
| 251 |
nd.specfl |= SP_REFL;
| 252 |
/* compute specular color */
| 253 |
if (m->otype == MAT_METAL)
| 254 |
copycolor(nd.scolor, nd.mcolor);
| 255 |
else
| 256 |
setcolor(nd.scolor, 1.0, 1.0, 1.0);
| 257 |
scalecolor(nd.scolor, nd.rspec);
| 258 |
| 259 |
if (!(nd.specfl & SP_PURE) && specthresh >= nd.rspec-FTINY)
| 260 |
nd.specfl |= SP_RBLT;
| 261 |
/* compute reflected ray */
| 262 |
| 263 |
nd.vrefl[i] = r->rdir[i] + 2.*nd.pdot*nd.pnorm[i];
| 264 |
/* penetration? */
| 265 |
if (hastexture && DOT(nd.vrefl, r->ron) <= FTINY)
| 266 |
for (i = 0; i < 3; i++) /* safety measure */
| 267 |
nd.vrefl[i] = r->rdir[i] + 2.*r->rod*r->ron[i];
| 268 |
| 269 |
if (!(r->crtype & SHADOW) && nd.specfl & SP_PURE) {
| 270 |
RAY lr;
| 271 |
if (rayorigin(&lr, r, REFLECTED, nd.rspec) == 0) {
| 272 |
VCOPY(lr.rdir, nd.vrefl);
| 273 |
rayvalue(&lr);
| 274 |
multcolor(lr.rcol, nd.scolor);
| 275 |
| 276 |
if (!hastexture && nd.specfl & SP_FLAT) {
| 277 |
mirtest = 2.*bright(lr.rcol);
| 278 |
mirdist = r->rot + lr.rt;
| 279 |
| 280 |
| 281 |
| 282 |
| 283 |
/* diffuse reflection */
| 284 |
nd.rdiff = 1.0 - nd.trans - nd.rspec;
| 285 |
| 286 |
if (nd.specfl & SP_PURE && nd.rdiff <= FTINY && nd.tdiff <= FTINY)
| 287 |
return(1); /* 100% pure specular */
| 288 |
| 289 |
if (nd.specfl & (SP_REFL|SP_TRAN) && !(nd.specfl & SP_PURE))
| 290 |
gaussamp(r, &nd);
| 291 |
| 292 |
if (nd.rdiff > FTINY) { /* ambient from this side */
| 293 |
ambient(ctmp, r);
| 294 |
if (nd.specfl & SP_RBLT)
| 295 |
scalecolor(ctmp, 1.0-nd.trans);
| 296 |
else
| 297 |
scalecolor(ctmp, nd.rdiff);
| 298 |
multcolor(ctmp, nd.mcolor); /* modified by material color */
| 299 |
addcolor(r->rcol, ctmp); /* add to returned color */
| 300 |
| 301 |
if (nd.tdiff > FTINY) { /* ambient from other side */
| 302 |
flipsurface(r);
| 303 |
ambient(ctmp, r);
| 304 |
if (nd.specfl & SP_TBLT)
| 305 |
scalecolor(ctmp, nd.trans);
| 306 |
else
| 307 |
scalecolor(ctmp, nd.tdiff);
| 308 |
multcolor(ctmp, nd.mcolor); /* modified by color */
| 309 |
| 310 |
flipsurface(r);
| 311 |
| 312 |
/* add direct component */
| 313 |
direct(r, dirnorm, &nd);
| 314 |
/* check distance */
| 315 |
d = bright(r->rcol);
| 316 |
if (transtest > d)
| 317 |
r->rt = transdist;
| 318 |
else if (mirtest > d)
| 319 |
r->rt = mirdist;
| 320 |
| 321 |
return(1);
| 322 |
| 323 |
| 324 |
| 325 |
static
| 326 |
gaussamp(r, np) /* sample gaussian specular */
| 327 |
RAY *r;
| 328 |
| 329 |
| 330 |
RAY sr;
| 331 |
FVECT u, v, h;
| 332 |
double rv[2];
| 333 |
double d, sinp, cosp;
| 334 |
register int i;
| 335 |
/* quick test */
| 336 |
if ((np->specfl & (SP_REFL|SP_RBLT)) != SP_REFL &&
| 337 |
(np->specfl & (SP_TRAN|SP_TBLT)) != SP_TRAN)
| 338 |
return;
| 339 |
/* set up sample coordinates */
| 340 |
v[0] = v[1] = v[2] = 0.0;
| 341 |
| 342 |
if (np->pnorm[i] < 0.6 && np->pnorm[i] > -0.6)
| 343 |
break;
| 344 |
v[i] = 1.0;
| 345 |
fcross(u, v, np->pnorm);
| 346 |
normalize(u);
| 347 |
fcross(v, np->pnorm, u);
| 348 |
/* compute reflection */
| 349 |
if ((np->specfl & (SP_REFL|SP_RBLT)) == SP_REFL &&
| 350 |
rayorigin(&sr, r, SPECULAR, np->rspec) == 0) {
| 351 |
dimlist[ndims++] = (int)np->mp;
| 352 |
d = urand(ilhash(dimlist,ndims)+samplendx);
| 353 |
multisamp(rv, 2, d);
| 354 |
d = 2.0*PI * rv[0];
| 355 |
cosp = cos(d);
| 356 |
sinp = sin(d);
| 357 |
rv[1] = 1.0 - specjitter*rv[1];
| 358 |
if (rv[1] <= FTINY)
| 359 |
d = 1.0;
| 360 |
else
| 361 |
d = sqrt( np->alpha2 * -log(rv[1]) );
| 362 |
| 363 |
h[i] = np->pnorm[i] + d*(cosp*u[i] + sinp*v[i]);
| 364 |
d = -2.0 * DOT(h, r->rdir) / (1.0 + d*d);
| 365 |
| 366 |
sr.rdir[i] = r->rdir[i] + d*h[i];
| 367 |
if (DOT(sr.rdir, r->ron) <= FTINY)
| 368 |
VCOPY(sr.rdir, np->vrefl); /* jitter no good */
| 369 |
rayvalue(&sr);
| 370 |
multcolor(sr.rcol, np->scolor);
| 371 |
addcolor(r->rcol, sr.rcol);
| 372 |
ndims--;
| 373 |
| 374 |
| 375 |
if ((np->specfl & (SP_TRAN|SP_TBLT)) == SP_TRAN &&
| 376 |
rayorigin(&sr, r, SPECULAR, np->tspec) == 0) {
| 377 |
| 378 |
d = urand(ilhash(dimlist,ndims)+1823+samplendx);
| 379 |
| 380 |
d = 2.0*PI * rv[0];
| 381 |
cosp = cos(d);
| 382 |
sinp = sin(d);
| 383 |
| 384 |
if (rv[1] <= FTINY)
| 385 |
d = 1.0;
| 386 |
else
| 387 |
d = sqrt( -log(rv[1]) * np->alpha2 );
| 388 |
| 389 |
sr.rdir[i] = np->prdir[i] + d*(cosp*u[i] + sinp*v[i]);
| 390 |
if (DOT(sr.rdir, r->ron) < -FTINY)
| 391 |
normalize(sr.rdir); /* OK, normalize */
| 392 |
else
| 393 |
VCOPY(sr.rdir, np->prdir); /* else no jitter */
| 394 |
rayvalue(&sr);
| 395 |
scalecolor(sr.rcol, np->tspec);
| 396 |
multcolor(sr.rcol, np->mcolor); /* modified by color */
| 397 |
| 398 |
ndims--;
| 399 |
| 400 |
