--- ray/src/rt/normal.c 2003/03/03 00:10:51 2.40 +++ ray/src/rt/normal.c 2010/09/26 15:51:15 2.53 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: normal.c,v 2.40 2003/03/03 00:10:51 greg Exp $"; +static const char RCSid[] = "$Id: normal.c,v 2.53 2010/09/26 15:51:15 greg Exp $"; #endif /* * normal.c - shading function for normal materials. @@ -14,18 +14,19 @@ static const char RCSid[] = "$Id: normal.c,v 2.40 2003 #include "copyright.h" #include "ray.h" - +#include "ambient.h" +#include "source.h" #include "otypes.h" - +#include "rtotypes.h" #include "random.h" #ifndef MAXITER #define MAXITER 10 /* maximum # specular ray attempts */ #endif /* estimate of Fresnel function */ -#define FRESNE(ci) (exp(-6.0*(ci)) - 0.00247875217) +#define FRESNE(ci) (exp(-5.85*(ci)) - 0.00287989916) +#define FRESTHRESH 0.017999 /* minimum specularity for approx. */ -static void gaussamp(); /* * This routine implements the isotropic Gaussian @@ -64,16 +65,21 @@ typedef struct { double pdot; /* perturbed dot product */ } NORMDAT; /* normal material data */ +static srcdirf_t dirnorm; +static void gaussamp(RAY *r, NORMDAT *np); + static void -dirnorm(cval, np, ldir, omega) /* compute source contribution */ -COLOR cval; /* returned coefficient */ -register NORMDAT *np; /* material data */ -FVECT ldir; /* light source direction */ -double omega; /* light source size */ +dirnorm( /* compute source contribution */ + COLOR cval, /* returned coefficient */ + void *nnp, /* material data */ + FVECT ldir, /* light source direction */ + double omega /* light source size */ +) { + register NORMDAT *np = nnp; double ldot; - double ldiff; + double lrdiff, ltdiff; double dtmp, d2; FVECT vtmp; COLOR ctmp; @@ -86,18 +92,23 @@ double omega; /* light source size */ return; /* wrong side */ /* Fresnel estimate */ - ldiff = np->rdiff; - if (np->specfl & SP_PURE && (np->rspec > FTINY & ldiff > FTINY)) - ldiff *= 1. - FRESNE(fabs(ldot)); + lrdiff = np->rdiff; + ltdiff = np->tdiff; + if (np->specfl & SP_PURE && np->rspec >= FRESTHRESH && + (lrdiff > FTINY) | (ltdiff > FTINY)) { + dtmp = 1. - FRESNE(fabs(ldot)); + lrdiff *= dtmp; + ltdiff *= dtmp; + } - if (ldot > FTINY && ldiff > FTINY) { + if (ldot > FTINY && lrdiff > FTINY) { /* * Compute and add diffuse reflected component to returned * color. The diffuse reflected component will always be * modified by the color of the material. */ copycolor(ctmp, np->mcolor); - dtmp = ldot * omega * ldiff / PI; + dtmp = ldot * omega * lrdiff * (1.0/PI); scalecolor(ctmp, dtmp); addcolor(cval, ctmp); } @@ -110,7 +121,7 @@ double omega; /* light source size */ dtmp = np->alpha2; /* + source if flat */ if (np->specfl & SP_FLAT) - dtmp += omega/(4.0*PI); + dtmp += omega * (0.25/PI); /* half vector */ vtmp[0] = ldir[0] - np->rp->rdir[0]; vtmp[1] = ldir[1] - np->rp->rdir[1]; @@ -119,21 +130,21 @@ double omega; /* light source size */ d2 *= d2; d2 = (DOT(vtmp,vtmp) - d2) / d2; /* gaussian */ - dtmp = exp(-d2/dtmp)/(4.*PI*dtmp); + dtmp = exp(-d2/dtmp)/(4.*PI * np->pdot * dtmp); /* worth using? */ if (dtmp > FTINY) { copycolor(ctmp, np->scolor); - dtmp *= omega * sqrt(ldot/np->pdot); + dtmp *= omega; scalecolor(ctmp, dtmp); addcolor(cval, ctmp); } } - if (ldot < -FTINY && np->tdiff > FTINY) { + if (ldot < -FTINY && ltdiff > FTINY) { /* * Compute diffuse transmission. */ copycolor(ctmp, np->mcolor); - dtmp = -ldot * omega * np->tdiff / PI; + dtmp = -ldot * omega * ltdiff * (1.0/PI); scalecolor(ctmp, dtmp); addcolor(cval, ctmp); } @@ -143,7 +154,7 @@ double omega; /* light source size */ * is always modified by material color. */ /* roughness + source */ - dtmp = np->alpha2 + omega/PI; + dtmp = np->alpha2 + omega*(1.0/PI); /* gaussian */ dtmp = exp((2.*DOT(np->prdir,ldir)-2.)/dtmp)/(PI*dtmp); /* worth using? */ @@ -157,10 +168,11 @@ double omega; /* light source size */ } -int -m_normal(m, r) /* color a ray that hit something normal */ -register OBJREC *m; -register RAY *r; +extern int +m_normal( /* color a ray that hit something normal */ + register OBJREC *m, + register RAY *r +) { NORMDAT nd; double fest; @@ -197,15 +209,15 @@ register RAY *r; nd.alpha2 = m->oargs.farg[4]; if ((nd.alpha2 *= nd.alpha2) <= FTINY) nd.specfl |= SP_PURE; - if (r->ro != NULL && isflat(r->ro->otype)) - nd.specfl |= SP_FLAT; - if (hastexture = DOT(r->pert,r->pert) > FTINY*FTINY) + if ( (hastexture = (DOT(r->pert,r->pert) > FTINY*FTINY)) ) { nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */ - else { + } else { VCOPY(nd.pnorm, r->ron); nd.pdot = r->rod; } + if (r->ro != NULL && isflat(r->ro->otype)) + nd.specfl |= SP_FLAT; if (nd.pdot < .001) nd.pdot = .001; /* non-zero for dirnorm() */ multcolor(nd.mcolor, r->pcol); /* modify material color */ @@ -213,7 +225,7 @@ register RAY *r; mirdist = transdist = r->rot; nd.rspec = m->oargs.farg[3]; /* compute Fresnel approx. */ - if (nd.specfl & SP_PURE && nd.rspec > FTINY) { + if (nd.specfl & SP_PURE && nd.rspec >= FRESTHRESH) { fest = FRESNE(r->rod); nd.rspec += fest*(1. - nd.rspec); } else @@ -246,11 +258,12 @@ register RAY *r; /* transmitted ray */ if ((nd.specfl&(SP_TRAN|SP_PURE|SP_TBLT)) == (SP_TRAN|SP_PURE)) { RAY lr; - if (rayorigin(&lr, r, TRANS, nd.tspec) == 0) { + copycolor(lr.rcoef, nd.mcolor); /* modified by color */ + scalecolor(lr.rcoef, nd.tspec); + if (rayorigin(&lr, TRANS, r, lr.rcoef) == 0) { VCOPY(lr.rdir, nd.prdir); rayvalue(&lr); - scalecolor(lr.rcol, nd.tspec); - multcolor(lr.rcol, nd.mcolor); /* modified by color */ + multcolor(lr.rcol, lr.rcoef); addcolor(r->rcol, lr.rcol); transtest *= bright(lr.rcol); transdist = r->rot + lr.rt; @@ -286,14 +299,15 @@ register RAY *r; if (hastexture && DOT(nd.vrefl, r->ron) <= FTINY) for (i = 0; i < 3; i++) /* safety measure */ nd.vrefl[i] = r->rdir[i] + 2.*r->rod*r->ron[i]; + checknorm(nd.vrefl); } /* reflected ray */ if ((nd.specfl&(SP_REFL|SP_PURE|SP_RBLT)) == (SP_REFL|SP_PURE)) { RAY lr; - if (rayorigin(&lr, r, REFLECTED, nd.rspec) == 0) { + if (rayorigin(&lr, REFLECTED, r, nd.scolor) == 0) { VCOPY(lr.rdir, nd.vrefl); rayvalue(&lr); - multcolor(lr.rcol, nd.scolor); + multcolor(lr.rcol, lr.rcoef); addcolor(r->rcol, lr.rcol); if (!hastexture && nd.specfl & SP_FLAT) { mirtest = 2.*bright(lr.rcol); @@ -311,29 +325,29 @@ register RAY *r; gaussamp(r, &nd); /* checks *BLT flags */ if (nd.rdiff > FTINY) { /* ambient from this side */ - ambient(ctmp, r, hastexture?nd.pnorm:r->ron); + copycolor(ctmp, nd.mcolor); /* modified by material color */ if (nd.specfl & SP_RBLT) scalecolor(ctmp, 1.0-nd.trans); else scalecolor(ctmp, nd.rdiff); - multcolor(ctmp, nd.mcolor); /* modified by material color */ + multambient(ctmp, r, hastexture ? nd.pnorm : r->ron); addcolor(r->rcol, ctmp); /* add to returned color */ } if (nd.tdiff > FTINY) { /* ambient from other side */ + copycolor(ctmp, nd.mcolor); /* modified by color */ + if (nd.specfl & SP_TBLT) + scalecolor(ctmp, nd.trans); + else + scalecolor(ctmp, nd.tdiff); flipsurface(r); if (hastexture) { FVECT bnorm; bnorm[0] = -nd.pnorm[0]; bnorm[1] = -nd.pnorm[1]; bnorm[2] = -nd.pnorm[2]; - ambient(ctmp, r, bnorm); + multambient(ctmp, r, bnorm); } else - ambient(ctmp, r, r->ron); - if (nd.specfl & SP_TBLT) - scalecolor(ctmp, nd.trans); - else - scalecolor(ctmp, nd.tdiff); - multcolor(ctmp, nd.mcolor); /* modified by color */ + multambient(ctmp, r, r->ron); addcolor(r->rcol, ctmp); flipsurface(r); } @@ -351,9 +365,10 @@ register RAY *r; static void -gaussamp(r, np) /* sample gaussian specular */ -RAY *r; -register NORMDAT *np; +gaussamp( /* sample gaussian specular */ + RAY *r, + register NORMDAT *np +) { RAY sr; FVECT u, v, h; @@ -376,7 +391,7 @@ register NORMDAT *np; fcross(v, np->pnorm, u); /* compute reflection */ if ((np->specfl & (SP_REFL|SP_RBLT)) == SP_REFL && - rayorigin(&sr, r, SPECULAR, np->rspec) == 0) { + rayorigin(&sr, SPECULAR, r, np->scolor) == 0) { dimlist[ndims++] = (int)np->mp; for (niter = 0; niter < MAXITER; niter++) { if (niter) @@ -399,7 +414,7 @@ register NORMDAT *np; sr.rdir[i] = r->rdir[i] + d*h[i]; if (DOT(sr.rdir, r->ron) > FTINY) { rayvalue(&sr); - multcolor(sr.rcol, np->scolor); + multcolor(sr.rcol, sr.rcoef); addcolor(r->rcol, sr.rcol); break; } @@ -407,8 +422,10 @@ register NORMDAT *np; ndims--; } /* compute transmission */ + copycolor(sr.rcoef, np->mcolor); /* modified by color */ + scalecolor(sr.rcoef, np->tspec); if ((np->specfl & (SP_TRAN|SP_TBLT)) == SP_TRAN && - rayorigin(&sr, r, SPECULAR, np->tspec) == 0) { + rayorigin(&sr, SPECULAR, r, sr.rcoef) == 0) { dimlist[ndims++] = (int)np->mp; for (niter = 0; niter < MAXITER; niter++) { if (niter) @@ -429,8 +446,7 @@ register NORMDAT *np; if (DOT(sr.rdir, r->ron) < -FTINY) { normalize(sr.rdir); /* OK, normalize */ rayvalue(&sr); - scalecolor(sr.rcol, np->tspec); - multcolor(sr.rcol, np->mcolor); /* modified */ + multcolor(sr.rcol, sr.rcoef); addcolor(r->rcol, sr.rcol); break; }
