--- ray/src/rt/normal.c 1993/08/24 12:59:28 2.26 +++ ray/src/rt/normal.c 1995/09/15 15:47:30 2.29 @@ -23,6 +23,8 @@ static char SCCSid[] = "$SunId$ LBL"; extern double specthresh; /* specular sampling threshold */ extern double specjitter; /* specular sampling jitter */ +extern int backvis; /* back faces visible? */ + static gaussamp(); /* @@ -154,14 +156,25 @@ register RAY *r; { NORMDAT nd; double transtest, transdist; + double mirtest, mirdist; + int hastexture; + double d; COLOR ctmp; register int i; /* easy shadow test */ if (r->crtype & SHADOW && m->otype != MAT_TRANS) - return; + return(1); if (m->oargs.nfargs != (m->otype == MAT_TRANS ? 7 : 5)) objerror(m, USER, "bad number of arguments"); + /* check for back side */ + if (r->rod < 0.0) { + if (!backvis && m->otype != MAT_TRANS) { + raytrans(r); + return(1); + } + flipsurface(r); /* reorient if backvis */ + } nd.mp = m; nd.rp = r; /* get material color */ @@ -173,17 +186,21 @@ register RAY *r; nd.alpha2 = m->oargs.farg[4]; if ((nd.alpha2 *= nd.alpha2) <= FTINY) nd.specfl |= SP_PURE; - /* reorient if necessary */ - if (r->rod < 0.0) - flipsurface(r); + if (r->ro != NULL && isflat(r->ro->otype)) + nd.specfl |= SP_FLAT; /* get modifiers */ raytexture(r, m->omod); - nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */ + if (hastexture = DOT(r->pert,r->pert) > FTINY*FTINY) + nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */ + else { + VCOPY(nd.pnorm, r->ron); + nd.pdot = r->rod; + } if (nd.pdot < .001) nd.pdot = .001; /* non-zero for dirnorm() */ multcolor(nd.mcolor, r->pcol); /* modify material color */ - transtest = 0; - transdist = r->rot; + mirtest = transtest = 0; + mirdist = transdist = r->rot; /* get specular component */ if ((nd.rspec = m->oargs.farg[3]) > FTINY) { nd.specfl |= SP_REFL; @@ -198,8 +215,9 @@ register RAY *r; nd.specfl |= SP_RBLT; /* compute reflected ray */ for (i = 0; i < 3; i++) - nd.vrefl[i] = r->rdir[i] + 2.0*nd.pdot*nd.pnorm[i]; - if (DOT(nd.vrefl, r->ron) <= FTINY) /* penetration? */ + nd.vrefl[i] = r->rdir[i] + 2.*nd.pdot*nd.pnorm[i]; + /* penetration? */ + if (hastexture && DOT(nd.vrefl, r->ron) <= FTINY) for (i = 0; i < 3; i++) /* safety measure */ nd.vrefl[i] = r->rdir[i] + 2.*r->rod*r->ron[i]; @@ -210,6 +228,10 @@ register RAY *r; rayvalue(&lr); multcolor(lr.rcol, nd.scolor); addcolor(r->rcol, lr.rcol); + if (!hastexture && nd.specfl & SP_FLAT) { + mirtest = 2.*bright(lr.rcol); + mirdist = r->rot + lr.rt; + } } } } @@ -224,8 +246,7 @@ register RAY *r; if (!(nd.specfl & SP_PURE) && specthresh >= nd.tspec-FTINY) nd.specfl |= SP_TBLT; - if (r->crtype & SHADOW || - DOT(r->pert,r->pert) <= FTINY*FTINY) { + if (!hastexture || r->crtype & SHADOW) { VCOPY(nd.prdir, r->rdir); transtest = 2; } else { @@ -254,18 +275,16 @@ register RAY *r; } else transtest = 0; - if (r->crtype & SHADOW) /* the rest is shadow */ - return; + if (r->crtype & SHADOW) { /* the rest is shadow */ + r->rt = transdist; + return(1); + } /* diffuse reflection */ nd.rdiff = 1.0 - nd.trans - nd.rspec; if (nd.specfl & SP_PURE && nd.rdiff <= FTINY && nd.tdiff <= FTINY) - return; /* 100% pure specular */ + return(1); /* 100% pure specular */ - if (r->ro != NULL && (r->ro->otype == OBJ_FACE || - r->ro->otype == OBJ_RING)) - nd.specfl |= SP_FLAT; - if (nd.specfl & (SP_REFL|SP_TRAN) && !(nd.specfl & SP_PURE)) gaussamp(r, &nd); @@ -292,8 +311,13 @@ register RAY *r; /* add direct component */ direct(r, dirnorm, &nd); /* check distance */ - if (transtest > bright(r->rcol)) + d = bright(r->rcol); + if (transtest > d) r->rt = transdist; + else if (mirtest > d) + r->rt = mirdist; + + return(1); }
