--- ray/src/rt/normal.c 1989/02/02 10:41:30 1.1 +++ ray/src/rt/normal.c 1998/12/16 18:14:58 2.37 @@ -1,7 +1,7 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1998 Silicon Graphics, Inc. */ #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static char SCCSid[] = "$SunId$ SGI"; #endif /* @@ -11,19 +11,29 @@ static char SCCSid[] = "$SunId$ LBL"; * 12/19/85 - added stuff for metals. * 6/26/87 - improved specular model. * 9/28/87 - added model for translucent materials. + * Later changes described in delta comments. */ #include "ray.h" -#include "source.h" - #include "otypes.h" +#include "random.h" + +extern double specthresh; /* specular sampling threshold */ +extern double specjitter; /* specular sampling jitter */ + +extern int backvis; /* back faces visible? */ + +#ifndef MAXITER +#define MAXITER 10 /* maximum # specular ray attempts */ +#endif + +static gaussamp(); + /* - * This routine uses portions of the reflection - * model described by Cook and Torrance. - * The computation of specular components has been simplified by - * numerous approximations and ommisions to improve speed. + * This routine implements the isotropic Gaussian + * model described by Ward in Siggraph `92 article. * We orient the surface towards the incoming ray, so a single * surface can be used to represent an infinitely thin object. * @@ -34,182 +44,380 @@ static char SCCSid[] = "$SunId$ LBL"; * red grn blu rspec rough trans tspec */ -#define BSPEC(m) (6.0) /* specularity parameter b */ + /* specularity flags */ +#define SP_REFL 01 /* has reflected specular component */ +#define SP_TRAN 02 /* has transmitted specular */ +#define SP_PURE 04 /* purely specular (zero roughness) */ +#define SP_FLAT 010 /* flat reflecting surface */ +#define SP_RBLT 020 /* reflection below sample threshold */ +#define SP_TBLT 040 /* transmission below threshold */ - -m_normal(m, r) /* color a ray which hit something normal */ -register OBJREC *m; -register RAY *r; -{ - double exp(); +typedef struct { + OBJREC *mp; /* material pointer */ + RAY *rp; /* ray pointer */ + short specfl; /* specularity flags, defined above */ COLOR mcolor; /* color of this material */ COLOR scolor; /* color of specular component */ FVECT vrefl; /* vector in direction of reflected ray */ - double alpha2; /* roughness squared times 2 */ - RAY lr; /* ray to illumination source */ + FVECT prdir; /* vector in transmitted direction */ + double alpha2; /* roughness squared */ double rdiff, rspec; /* reflected specular, diffuse */ double trans; /* transmissivity */ double tdiff, tspec; /* transmitted specular, diffuse */ FVECT pnorm; /* perturbed surface normal */ double pdot; /* perturbed dot product */ +} NORMDAT; /* normal material data */ + + +dirnorm(cval, np, ldir, omega) /* compute source contribution */ +COLOR cval; /* returned coefficient */ +register NORMDAT *np; /* material data */ +FVECT ldir; /* light source direction */ +double omega; /* light source size */ +{ double ldot; - double omega; - double dtmp; + double dtmp, d2; + FVECT vtmp; COLOR ctmp; - register int i; - if (m->oargs.nfargs != (m->otype == MAT_TRANS ? 7 : 5)) - objerror(m, USER, "bad # arguments"); + setcolor(cval, 0.0, 0.0, 0.0); + + ldot = DOT(np->pnorm, ldir); + + if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY) + return; /* wrong side */ + + if (ldot > FTINY && np->rdiff > FTINY) { + /* + * Compute and add diffuse reflected component to returned + * color. The diffuse reflected component will always be + * modified by the color of the material. + */ + copycolor(ctmp, np->mcolor); + dtmp = ldot * omega * np->rdiff / PI; + scalecolor(ctmp, dtmp); + addcolor(cval, ctmp); + } + if (ldot > FTINY && (np->specfl&(SP_REFL|SP_PURE)) == SP_REFL) { + /* + * Compute specular reflection coefficient using + * gaussian distribution model. + */ + /* roughness */ + dtmp = np->alpha2; + /* + source if flat */ + if (np->specfl & SP_FLAT) + dtmp += omega/(4.0*PI); + /* half vector */ + vtmp[0] = ldir[0] - np->rp->rdir[0]; + vtmp[1] = ldir[1] - np->rp->rdir[1]; + vtmp[2] = ldir[2] - np->rp->rdir[2]; + d2 = DOT(vtmp, np->pnorm); + d2 *= d2; + d2 = (DOT(vtmp,vtmp) - d2) / d2; + /* gaussian */ + dtmp = exp(-d2/dtmp)/(4.*PI*dtmp); + /* worth using? */ + if (dtmp > FTINY) { + copycolor(ctmp, np->scolor); + dtmp *= omega * sqrt(ldot/np->pdot); + scalecolor(ctmp, dtmp); + addcolor(cval, ctmp); + } + } + if (ldot < -FTINY && np->tdiff > FTINY) { + /* + * Compute diffuse transmission. + */ + copycolor(ctmp, np->mcolor); + dtmp = -ldot * omega * np->tdiff / PI; + scalecolor(ctmp, dtmp); + addcolor(cval, ctmp); + } + if (ldot < -FTINY && (np->specfl&(SP_TRAN|SP_PURE)) == SP_TRAN) { + /* + * Compute specular transmission. Specular transmission + * is always modified by material color. + */ + /* roughness + source */ + dtmp = np->alpha2 + omega/PI; + /* gaussian */ + dtmp = exp((2.*DOT(np->prdir,ldir)-2.)/dtmp)/(PI*dtmp); + /* worth using? */ + if (dtmp > FTINY) { + copycolor(ctmp, np->mcolor); + dtmp *= np->tspec * omega * sqrt(-ldot/np->pdot); + scalecolor(ctmp, dtmp); + addcolor(cval, ctmp); + } + } +} + + +m_normal(m, r) /* color a ray that hit something normal */ +register OBJREC *m; +register RAY *r; +{ + NORMDAT nd; + double transtest, transdist; + double mirtest, mirdist; + int hastexture; + double d; + COLOR ctmp; + register int i; /* easy shadow test */ if (r->crtype & SHADOW && m->otype != MAT_TRANS) - return; + return(1); + + if (m->oargs.nfargs != (m->otype == MAT_TRANS ? 7 : 5)) + objerror(m, USER, "bad number of arguments"); + /* check for back side */ + if (r->rod < 0.0) { + if (!backvis && m->otype != MAT_TRANS) { + raytrans(r); + return(1); + } + flipsurface(r); /* reorient if backvis */ + } + nd.mp = m; + nd.rp = r; /* get material color */ - setcolor(mcolor, m->oargs.farg[0], + setcolor(nd.mcolor, m->oargs.farg[0], m->oargs.farg[1], m->oargs.farg[2]); /* get roughness */ - alpha2 = m->oargs.farg[4]; - alpha2 *= 2.0 * alpha2; - /* reorient if necessary */ - if (r->rod < 0.0) - flipsurface(r); + nd.specfl = 0; + nd.alpha2 = m->oargs.farg[4]; + if ((nd.alpha2 *= nd.alpha2) <= FTINY) + nd.specfl |= SP_PURE; + if (r->ro != NULL && isflat(r->ro->otype)) + nd.specfl |= SP_FLAT; /* get modifiers */ raytexture(r, m->omod); - pdot = raynormal(pnorm, r); /* perturb normal */ - multcolor(mcolor, r->pcol); /* modify material color */ - /* get specular component */ - rspec = m->oargs.farg[3]; + if (hastexture = DOT(r->pert,r->pert) > FTINY*FTINY) + nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */ + else { + VCOPY(nd.pnorm, r->ron); + nd.pdot = r->rod; + } + if (nd.pdot < .001) + nd.pdot = .001; /* non-zero for dirnorm() */ + multcolor(nd.mcolor, r->pcol); /* modify material color */ + mirtest = transtest = 0; + mirdist = transdist = r->rot; + nd.rspec = m->oargs.farg[3]; + /* compute transmission */ + if (m->otype == MAT_TRANS) { + nd.trans = m->oargs.farg[5]*(1.0 - nd.rspec); + nd.tspec = nd.trans * m->oargs.farg[6]; + nd.tdiff = nd.trans - nd.tspec; + if (nd.tspec > FTINY) { + nd.specfl |= SP_TRAN; + /* check threshold */ + if (!(nd.specfl & SP_PURE) && + specthresh >= nd.tspec-FTINY) + nd.specfl |= SP_TBLT; + if (!hastexture || r->crtype & SHADOW) { + VCOPY(nd.prdir, r->rdir); + transtest = 2; + } else { + for (i = 0; i < 3; i++) /* perturb */ + nd.prdir[i] = r->rdir[i] - r->pert[i]; + if (DOT(nd.prdir, r->ron) < -FTINY) + normalize(nd.prdir); /* OK */ + else + VCOPY(nd.prdir, r->rdir); + } + } + } else + nd.tdiff = nd.tspec = nd.trans = 0.0; + /* transmitted ray */ + if ((nd.specfl&(SP_TRAN|SP_PURE|SP_TBLT)) == (SP_TRAN|SP_PURE)) { + RAY lr; + if (rayorigin(&lr, r, TRANS, nd.tspec) == 0) { + VCOPY(lr.rdir, nd.prdir); + rayvalue(&lr); + scalecolor(lr.rcol, nd.tspec); + multcolor(lr.rcol, nd.mcolor); /* modified by color */ + addcolor(r->rcol, lr.rcol); + transtest *= bright(lr.rcol); + transdist = r->rot + lr.rt; + } + } else + transtest = 0; - if (rspec > FTINY) { /* has specular component */ + if (r->crtype & SHADOW) { /* the rest is shadow */ + r->rt = transdist; + return(1); + } + /* get specular reflection */ + if (nd.rspec > FTINY) { + nd.specfl |= SP_REFL; /* compute specular color */ if (m->otype == MAT_METAL) - copycolor(scolor, mcolor); + copycolor(nd.scolor, nd.mcolor); else - setcolor(scolor, 1.0, 1.0, 1.0); - scalecolor(scolor, rspec); - /* improved model */ - dtmp = exp(-BSPEC(m)*pdot); - for (i = 0; i < 3; i++) - colval(scolor,i) += (1.0-colval(scolor,i))*dtmp; - rspec += (1.0-rspec)*dtmp; + setcolor(nd.scolor, 1.0, 1.0, 1.0); + scalecolor(nd.scolor, nd.rspec); + /* check threshold */ + if (!(nd.specfl & SP_PURE) && specthresh >= nd.rspec-FTINY) + nd.specfl |= SP_RBLT; /* compute reflected ray */ for (i = 0; i < 3; i++) - vrefl[i] = r->rdir[i] + 2.0*pdot*pnorm[i]; - - if (alpha2 <= FTINY && !(r->crtype & SHADOW)) - if (rayorigin(&lr, r, REFLECTED, rspec) == 0) { - VCOPY(lr.rdir, vrefl); - rayvalue(&lr); - multcolor(lr.rcol, scolor); - addcolor(r->rcol, lr.rcol); - } + nd.vrefl[i] = r->rdir[i] + 2.*nd.pdot*nd.pnorm[i]; + /* penetration? */ + if (hastexture && DOT(nd.vrefl, r->ron) <= FTINY) + for (i = 0; i < 3; i++) /* safety measure */ + nd.vrefl[i] = r->rdir[i] + 2.*r->rod*r->ron[i]; } - - if (m->otype == MAT_TRANS) { - trans = m->oargs.farg[5]*(1.0 - rspec); - tspec = trans * m->oargs.farg[6]; - tdiff = trans - tspec; - } else - tdiff = tspec = trans = 0.0; - /* transmitted ray */ - if (tspec > FTINY && alpha2 <= FTINY) - if (rayorigin(&lr, r, TRANS, tspec) == 0) { - VCOPY(lr.rdir, r->rdir); + /* reflected ray */ + if ((nd.specfl&(SP_REFL|SP_PURE|SP_RBLT)) == (SP_REFL|SP_PURE)) { + RAY lr; + if (rayorigin(&lr, r, REFLECTED, nd.rspec) == 0) { + VCOPY(lr.rdir, nd.vrefl); rayvalue(&lr); - scalecolor(lr.rcol, tspec); + multcolor(lr.rcol, nd.scolor); addcolor(r->rcol, lr.rcol); + if (!hastexture && nd.specfl & SP_FLAT) { + mirtest = 2.*bright(lr.rcol); + mirdist = r->rot + lr.rt; + } } - if (r->crtype & SHADOW) /* the rest is shadow */ - return; + } /* diffuse reflection */ - rdiff = 1.0 - trans - rspec; + nd.rdiff = 1.0 - nd.trans - nd.rspec; - if (rdiff <= FTINY && tdiff <= FTINY && alpha2 <= FTINY) - return; /* purely specular */ + if (nd.specfl & SP_PURE && nd.rdiff <= FTINY && nd.tdiff <= FTINY) + return(1); /* 100% pure specular */ - ambient(ctmp, r); /* compute ambient component */ - scalecolor(ctmp, 1.0-trans); /* from this side */ - multcolor(ctmp, mcolor); /* modified by material color */ - addcolor(r->rcol, ctmp); /* add to returned color */ + if (!(nd.specfl & SP_PURE)) + gaussamp(r, &nd); /* checks *BLT flags */ - if (trans > FTINY) { /* ambient from other side */ + if (nd.rdiff > FTINY) { /* ambient from this side */ + ambient(ctmp, r, hastexture?nd.pnorm:r->ron); + if (nd.specfl & SP_RBLT) + scalecolor(ctmp, 1.0-nd.trans); + else + scalecolor(ctmp, nd.rdiff); + multcolor(ctmp, nd.mcolor); /* modified by material color */ + addcolor(r->rcol, ctmp); /* add to returned color */ + } + if (nd.tdiff > FTINY) { /* ambient from other side */ flipsurface(r); - scalecolor(ctmp, trans); - multcolor(ctmp, mcolor); + if (hastexture) { + FVECT bnorm; + bnorm[0] = -nd.pnorm[0]; + bnorm[1] = -nd.pnorm[1]; + bnorm[2] = -nd.pnorm[2]; + ambient(ctmp, r, bnorm); + } else + ambient(ctmp, r, r->ron); + if (nd.specfl & SP_TBLT) + scalecolor(ctmp, nd.trans); + else + scalecolor(ctmp, nd.tdiff); + multcolor(ctmp, nd.mcolor); /* modified by color */ addcolor(r->rcol, ctmp); flipsurface(r); } - - for (i = 0; i < nsources; i++) { /* add specular and diffuse */ + /* add direct component */ + direct(r, dirnorm, &nd); + /* check distance */ + d = bright(r->rcol); + if (transtest > d) + r->rt = transdist; + else if (mirtest > d) + r->rt = mirdist; - if ((omega = srcray(&lr, r, i)) == 0.0) - continue; /* bad source */ + return(1); +} - ldot = DOT(pnorm, lr.rdir); - - if (ldot < 0.0 ? trans <= FTINY : trans >= 1.0-FTINY) - continue; /* wrong side */ - - rayvalue(&lr); /* compute light ray value */ - - if (intens(lr.rcol) <= FTINY) - continue; /* didn't hit light source */ - if (ldot > FTINY && rdiff > FTINY) { - /* - * Compute and add diffuse component to returned color. - * The diffuse component will always be modified by the - * color of the material. - */ - copycolor(ctmp, lr.rcol); - dtmp = ldot * omega * rdiff / PI; - scalecolor(ctmp, dtmp); - multcolor(ctmp, mcolor); - addcolor(r->rcol, ctmp); - } - if (ldot > FTINY && rspec > FTINY && alpha2 > FTINY) { - /* - * Compute specular reflection coefficient using - * gaussian distribution model. - */ - /* roughness + source */ - dtmp = alpha2 + omega/(2.0*PI); - /* gaussian */ - dtmp = exp((DOT(vrefl,lr.rdir)-1.)/dtmp)/(2.*PI)/dtmp; - /* worth using? */ - if (dtmp > FTINY) { - copycolor(ctmp, lr.rcol); - dtmp *= omega; - scalecolor(ctmp, dtmp); - multcolor(ctmp, scolor); - addcolor(r->rcol, ctmp); +static +gaussamp(r, np) /* sample gaussian specular */ +RAY *r; +register NORMDAT *np; +{ + RAY sr; + FVECT u, v, h; + double rv[2]; + double d, sinp, cosp; + int niter; + register int i; + /* quick test */ + if ((np->specfl & (SP_REFL|SP_RBLT)) != SP_REFL && + (np->specfl & (SP_TRAN|SP_TBLT)) != SP_TRAN) + return; + /* set up sample coordinates */ + v[0] = v[1] = v[2] = 0.0; + for (i = 0; i < 3; i++) + if (np->pnorm[i] < 0.6 && np->pnorm[i] > -0.6) + break; + v[i] = 1.0; + fcross(u, v, np->pnorm); + normalize(u); + fcross(v, np->pnorm, u); + /* compute reflection */ + if ((np->specfl & (SP_REFL|SP_RBLT)) == SP_REFL && + rayorigin(&sr, r, SPECULAR, np->rspec) == 0) { + dimlist[ndims++] = (int)np->mp; + for (niter = 0; niter < MAXITER; niter++) { + if (niter) + d = frandom(); + else + d = urand(ilhash(dimlist,ndims)+samplendx); + multisamp(rv, 2, d); + d = 2.0*PI * rv[0]; + cosp = tcos(d); + sinp = tsin(d); + rv[1] = 1.0 - specjitter*rv[1]; + if (rv[1] <= FTINY) + d = 1.0; + else + d = sqrt( np->alpha2 * -log(rv[1]) ); + for (i = 0; i < 3; i++) + h[i] = np->pnorm[i] + d*(cosp*u[i] + sinp*v[i]); + d = -2.0 * DOT(h, r->rdir) / (1.0 + d*d); + for (i = 0; i < 3; i++) + sr.rdir[i] = r->rdir[i] + d*h[i]; + if (DOT(sr.rdir, r->ron) > FTINY) { + rayvalue(&sr); + multcolor(sr.rcol, np->scolor); + addcolor(r->rcol, sr.rcol); + break; } } - if (ldot < -FTINY && tdiff > FTINY) { - /* - * Compute diffuse transmission. - */ - copycolor(ctmp, lr.rcol); - dtmp = -ldot * omega * tdiff / PI; - scalecolor(ctmp, dtmp); - multcolor(ctmp, mcolor); - addcolor(r->rcol, ctmp); - } - if (ldot < -FTINY && tspec > FTINY && alpha2 > FTINY) { - /* - * Compute specular transmission. - */ - /* roughness + source */ - dtmp = alpha2 + omega/(2.0*PI); - /* gaussian */ - dtmp = exp((DOT(r->rdir,lr.rdir)-1.)/dtmp)/(2.*PI)/dtmp; - /* worth using? */ - if (dtmp > FTINY) { - copycolor(ctmp, lr.rcol); - dtmp *= tspec * omega; - scalecolor(ctmp, dtmp); - addcolor(r->rcol, ctmp); + ndims--; + } + /* compute transmission */ + if ((np->specfl & (SP_TRAN|SP_TBLT)) == SP_TRAN && + rayorigin(&sr, r, SPECULAR, np->tspec) == 0) { + dimlist[ndims++] = (int)np->mp; + for (niter = 0; niter < MAXITER; niter++) { + if (niter) + d = frandom(); + else + d = urand(ilhash(dimlist,ndims)+1823+samplendx); + multisamp(rv, 2, d); + d = 2.0*PI * rv[0]; + cosp = tcos(d); + sinp = tsin(d); + rv[1] = 1.0 - specjitter*rv[1]; + if (rv[1] <= FTINY) + d = 1.0; + else + d = sqrt( np->alpha2 * -log(rv[1]) ); + for (i = 0; i < 3; i++) + sr.rdir[i] = np->prdir[i] + d*(cosp*u[i] + sinp*v[i]); + if (DOT(sr.rdir, r->ron) < -FTINY) { + normalize(sr.rdir); /* OK, normalize */ + rayvalue(&sr); + scalecolor(sr.rcol, np->tspec); + multcolor(sr.rcol, np->mcolor); /* modified */ + addcolor(r->rcol, sr.rcol); + break; } } + ndims--; } }
