1 |
/* Copyright (c) 1986 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* normal.c - shading function for normal materials. |
9 |
10 |
* 8/19/85 |
11 |
* 12/19/85 - added stuff for metals. |
12 |
* 6/26/87 - improved specular model. |
13 |
* 9/28/87 - added model for translucent materials. |
14 |
15 |
16 |
#include "ray.h" |
17 |
18 |
#include "source.h" |
19 |
20 |
#include "otypes.h" |
21 |
22 |
23 |
* This routine uses portions of the reflection |
24 |
* model described by Cook and Torrance. |
25 |
* The computation of specular components has been simplified by |
26 |
* numerous approximations and ommisions to improve speed. |
27 |
* We orient the surface towards the incoming ray, so a single |
28 |
* surface can be used to represent an infinitely thin object. |
29 |
30 |
* Arguments for MAT_PLASTIC and MAT_METAL are: |
31 |
* red grn blu specular-frac. facet-slope |
32 |
33 |
* Arguments for MAT_TRANS are: |
34 |
* red grn blu rspec rough trans tspec |
35 |
36 |
37 |
#define BSPEC(m) (6.0) /* specularity parameter b */ |
38 |
39 |
40 |
m_normal(m, r) /* color a ray which hit something normal */ |
41 |
register OBJREC *m; |
42 |
register RAY *r; |
43 |
44 |
double exp(); |
45 |
COLOR mcolor; /* color of this material */ |
46 |
COLOR scolor; /* color of specular component */ |
47 |
FVECT vrefl; /* vector in direction of reflected ray */ |
48 |
double alpha2; /* roughness squared times 2 */ |
49 |
RAY lr; /* ray to illumination source */ |
50 |
double rdiff, rspec; /* reflected specular, diffuse */ |
51 |
double trans; /* transmissivity */ |
52 |
double tdiff, tspec; /* transmitted specular, diffuse */ |
53 |
FVECT pnorm; /* perturbed surface normal */ |
54 |
double pdot; /* perturbed dot product */ |
55 |
double ldot; |
56 |
double omega; |
57 |
double dtmp; |
58 |
COLOR ctmp; |
59 |
register int i; |
60 |
61 |
if (m->oargs.nfargs != (m->otype == MAT_TRANS ? 7 : 5)) |
62 |
objerror(m, USER, "bad # arguments"); |
63 |
/* easy shadow test */ |
64 |
if (r->crtype & SHADOW && m->otype != MAT_TRANS) |
65 |
return; |
66 |
/* get material color */ |
67 |
setcolor(mcolor, m->oargs.farg[0], |
68 |
m->oargs.farg[1], |
69 |
m->oargs.farg[2]); |
70 |
/* get roughness */ |
71 |
alpha2 = m->oargs.farg[4]; |
72 |
alpha2 *= 2.0 * alpha2; |
73 |
/* reorient if necessary */ |
74 |
if (r->rod < 0.0) |
75 |
flipsurface(r); |
76 |
/* get modifiers */ |
77 |
raytexture(r, m->omod); |
78 |
pdot = raynormal(pnorm, r); /* perturb normal */ |
79 |
multcolor(mcolor, r->pcol); /* modify material color */ |
80 |
/* get specular component */ |
81 |
rspec = m->oargs.farg[3]; |
82 |
83 |
if (rspec > FTINY) { /* has specular component */ |
84 |
/* compute specular color */ |
85 |
if (m->otype == MAT_METAL) |
86 |
copycolor(scolor, mcolor); |
87 |
else |
88 |
setcolor(scolor, 1.0, 1.0, 1.0); |
89 |
scalecolor(scolor, rspec); |
90 |
/* improved model */ |
91 |
dtmp = exp(-BSPEC(m)*pdot); |
92 |
for (i = 0; i < 3; i++) |
93 |
colval(scolor,i) += (1.0-colval(scolor,i))*dtmp; |
94 |
rspec += (1.0-rspec)*dtmp; |
95 |
/* compute reflected ray */ |
96 |
97 |
vrefl[i] = r->rdir[i] + 2.0*pdot*pnorm[i]; |
98 |
99 |
if (alpha2 <= FTINY && !(r->crtype & SHADOW)) |
100 |
if (rayorigin(&lr, r, REFLECTED, rspec) == 0) { |
101 |
VCOPY(lr.rdir, vrefl); |
102 |
rayvalue(&lr); |
103 |
multcolor(lr.rcol, scolor); |
104 |
addcolor(r->rcol, lr.rcol); |
105 |
106 |
107 |
108 |
if (m->otype == MAT_TRANS) { |
109 |
trans = m->oargs.farg[5]*(1.0 - rspec); |
110 |
tspec = trans * m->oargs.farg[6]; |
111 |
tdiff = trans - tspec; |
112 |
} else |
113 |
tdiff = tspec = trans = 0.0; |
114 |
/* transmitted ray */ |
115 |
if (tspec > FTINY && alpha2 <= FTINY) |
116 |
if (rayorigin(&lr, r, TRANS, tspec) == 0) { |
117 |
VCOPY(lr.rdir, r->rdir); |
118 |
rayvalue(&lr); |
119 |
scalecolor(lr.rcol, tspec); |
120 |
121 |
122 |
if (r->crtype & SHADOW) /* the rest is shadow */ |
123 |
return; |
124 |
/* diffuse reflection */ |
125 |
rdiff = 1.0 - trans - rspec; |
126 |
127 |
if (rdiff <= FTINY && tdiff <= FTINY && alpha2 <= FTINY) |
128 |
return; /* purely specular */ |
129 |
130 |
if (rdiff > FTINY) { /* ambient from this side */ |
131 |
ambient(ctmp, r); |
132 |
if (alpha2 <= FTINY) |
133 |
scalecolor(ctmp, rdiff); |
134 |
else |
135 |
scalecolor(ctmp, 1.0-trans); |
136 |
multcolor(ctmp, mcolor); /* modified by material color */ |
137 |
addcolor(r->rcol, ctmp); /* add to returned color */ |
138 |
139 |
if (tdiff > FTINY) { /* ambient from other side */ |
140 |
flipsurface(r); |
141 |
ambient(ctmp, r); |
142 |
143 |
scalecolor(ctmp, tdiff); |
144 |
else |
145 |
scalecolor(ctmp, trans); |
146 |
multcolor(ctmp, mcolor); |
147 |
addcolor(r->rcol, ctmp); |
148 |
flipsurface(r); |
149 |
150 |
151 |
for (i = 0; i < nsources; i++) { /* add specular and diffuse */ |
152 |
153 |
if ((omega = srcray(&lr, r, i)) == 0.0) |
154 |
continue; /* bad source */ |
155 |
156 |
ldot = DOT(pnorm, lr.rdir); |
157 |
158 |
if (ldot < 0.0 ? trans <= FTINY : trans >= 1.0-FTINY) |
159 |
continue; /* wrong side */ |
160 |
161 |
rayvalue(&lr); /* compute light ray value */ |
162 |
163 |
if (intens(lr.rcol) <= FTINY) |
164 |
continue; /* didn't hit light source */ |
165 |
166 |
if (ldot > FTINY && rdiff > FTINY) { |
167 |
168 |
* Compute and add diffuse component to returned color. |
169 |
* The diffuse component will always be modified by the |
170 |
* color of the material. |
171 |
172 |
copycolor(ctmp, lr.rcol); |
173 |
dtmp = ldot * omega * rdiff / PI; |
174 |
scalecolor(ctmp, dtmp); |
175 |
176 |
177 |
178 |
if (ldot > FTINY && rspec > FTINY && alpha2 > FTINY) { |
179 |
180 |
* Compute specular reflection coefficient using |
181 |
* gaussian distribution model. |
182 |
183 |
/* roughness + source */ |
184 |
dtmp = alpha2 + omega/(2.0*PI); |
185 |
/* gaussian */ |
186 |
dtmp = exp((DOT(vrefl,lr.rdir)-1.)/dtmp)/(2.*PI)/dtmp; |
187 |
/* worth using? */ |
188 |
if (dtmp > FTINY) { |
189 |
190 |
dtmp *= omega; |
191 |
192 |
multcolor(ctmp, scolor); |
193 |
194 |
195 |
196 |
if (ldot < -FTINY && tdiff > FTINY) { |
197 |
198 |
* Compute diffuse transmission. |
199 |
200 |
201 |
dtmp = -ldot * omega * tdiff / PI; |
202 |
203 |
204 |
205 |
206 |
if (ldot < -FTINY && tspec > FTINY && alpha2 > FTINY) { |
207 |
208 |
* Compute specular transmission. |
209 |
210 |
211 |
212 |
/* gaussian */ |
213 |
dtmp = exp((DOT(r->rdir,lr.rdir)-1.)/dtmp)/(2.*PI)/dtmp; |
214 |
215 |
216 |
217 |
dtmp *= tspec * omega; |
218 |
219 |
220 |
221 |
222 |
223 |
