--- ray/src/rt/normal.c 1989/04/15 12:23:22 1.2 +++ ray/src/rt/normal.c 1991/08/12 08:20:55 1.12 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1991 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -15,8 +15,6 @@ static char SCCSid[] = "$SunId$ LBL"; #include "ray.h" -#include "source.h" - #include "otypes.h" /* @@ -36,26 +34,104 @@ static char SCCSid[] = "$SunId$ LBL"; #define BSPEC(m) (6.0) /* specularity parameter b */ +extern double exp(); -m_normal(m, r) /* color a ray which hit something normal */ -register OBJREC *m; -register RAY *r; -{ - double exp(); +typedef struct { + OBJREC *mp; /* material pointer */ + RAY *pr; /* intersected ray */ COLOR mcolor; /* color of this material */ COLOR scolor; /* color of specular component */ FVECT vrefl; /* vector in direction of reflected ray */ double alpha2; /* roughness squared times 2 */ - RAY lr; /* ray to illumination source */ double rdiff, rspec; /* reflected specular, diffuse */ double trans; /* transmissivity */ double tdiff, tspec; /* transmitted specular, diffuse */ FVECT pnorm; /* perturbed surface normal */ double pdot; /* perturbed dot product */ +} NORMDAT; /* normal material data */ + + +dirnorm(cval, np, ldir, omega) /* compute source contribution */ +COLOR cval; /* returned coefficient */ +register NORMDAT *np; /* material data */ +FVECT ldir; /* light source direction */ +double omega; /* light source size */ +{ double ldot; - double omega; double dtmp; COLOR ctmp; + + setcolor(cval, 0.0, 0.0, 0.0); + + ldot = DOT(np->pnorm, ldir); + + if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY) + return; /* wrong side */ + + if (ldot > FTINY && np->rdiff > FTINY) { + /* + * Compute and add diffuse reflected component to returned + * color. The diffuse reflected component will always be + * modified by the color of the material. + */ + copycolor(ctmp, np->mcolor); + dtmp = ldot * omega * np->rdiff / PI; + scalecolor(ctmp, dtmp); + addcolor(cval, ctmp); + } + if (ldot > FTINY && np->rspec > FTINY && np->alpha2 > FTINY) { + /* + * Compute specular reflection coefficient using + * gaussian distribution model. + */ + /* roughness + source */ + dtmp = np->alpha2 + omega/(2.0*PI); + /* gaussian */ + dtmp = exp((DOT(np->vrefl,ldir)-1.)/dtmp)/(2.*PI)/dtmp; + /* worth using? */ + if (dtmp > FTINY) { + copycolor(ctmp, np->scolor); + dtmp *= omega; + scalecolor(ctmp, dtmp); + addcolor(cval, ctmp); + } + } + if (ldot < -FTINY && np->tdiff > FTINY) { + /* + * Compute diffuse transmission. + */ + copycolor(ctmp, np->mcolor); + dtmp = -ldot * omega * np->tdiff / PI; + scalecolor(ctmp, dtmp); + addcolor(cval, ctmp); + } + if (ldot < -FTINY && np->tspec > FTINY && np->alpha2 > FTINY) { + /* + * Compute specular transmission. Specular transmission + * is unaffected by material color. + */ + /* roughness + source */ + dtmp = np->alpha2 + omega/(2.0*PI); + /* gaussian */ + dtmp = exp((DOT(np->pr->rdir,ldir)-1.)/dtmp)/(2.*PI)/dtmp; + /* worth using? */ + if (dtmp > FTINY) { + dtmp *= np->tspec * omega; + setcolor(ctmp, dtmp, dtmp, dtmp); + addcolor(cval, ctmp); + } + } +} + + +m_normal(m, r) /* color a ray which hit something normal */ +register OBJREC *m; +register RAY *r; +{ + NORMDAT nd; + double transtest, transdist; + double dtmp; + COLOR ctmp; register int i; if (m->oargs.nfargs != (m->otype == MAT_TRANS ? 7 : 5)) @@ -63,161 +139,112 @@ register RAY *r; /* easy shadow test */ if (r->crtype & SHADOW && m->otype != MAT_TRANS) return; + nd.mp = m; + nd.pr = r; /* get material color */ - setcolor(mcolor, m->oargs.farg[0], + setcolor(nd.mcolor, m->oargs.farg[0], m->oargs.farg[1], m->oargs.farg[2]); /* get roughness */ - alpha2 = m->oargs.farg[4]; - alpha2 *= 2.0 * alpha2; + nd.alpha2 = m->oargs.farg[4]; + nd.alpha2 *= 2.0 * nd.alpha2; /* reorient if necessary */ if (r->rod < 0.0) flipsurface(r); /* get modifiers */ raytexture(r, m->omod); - pdot = raynormal(pnorm, r); /* perturb normal */ - multcolor(mcolor, r->pcol); /* modify material color */ + nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */ + multcolor(nd.mcolor, r->pcol); /* modify material color */ + transtest = 0; /* get specular component */ - rspec = m->oargs.farg[3]; + nd.rspec = m->oargs.farg[3]; - if (rspec > FTINY) { /* has specular component */ + if (nd.rspec > FTINY) { /* has specular component */ /* compute specular color */ if (m->otype == MAT_METAL) - copycolor(scolor, mcolor); + copycolor(nd.scolor, nd.mcolor); else - setcolor(scolor, 1.0, 1.0, 1.0); - scalecolor(scolor, rspec); + setcolor(nd.scolor, 1.0, 1.0, 1.0); + scalecolor(nd.scolor, nd.rspec); /* improved model */ - dtmp = exp(-BSPEC(m)*pdot); + dtmp = exp(-BSPEC(m)*nd.pdot); for (i = 0; i < 3; i++) - colval(scolor,i) += (1.0-colval(scolor,i))*dtmp; - rspec += (1.0-rspec)*dtmp; + colval(nd.scolor,i) += (1.0-colval(nd.scolor,i))*dtmp; + nd.rspec += (1.0-nd.rspec)*dtmp; /* compute reflected ray */ for (i = 0; i < 3; i++) - vrefl[i] = r->rdir[i] + 2.0*pdot*pnorm[i]; + nd.vrefl[i] = r->rdir[i] + 2.0*nd.pdot*nd.pnorm[i]; - if (alpha2 <= FTINY && !(r->crtype & SHADOW)) - if (rayorigin(&lr, r, REFLECTED, rspec) == 0) { - VCOPY(lr.rdir, vrefl); + if (nd.alpha2 <= FTINY && !(r->crtype & SHADOW)) { + RAY lr; + if (rayorigin(&lr, r, REFLECTED, nd.rspec) == 0) { + VCOPY(lr.rdir, nd.vrefl); rayvalue(&lr); - multcolor(lr.rcol, scolor); + multcolor(lr.rcol, nd.scolor); addcolor(r->rcol, lr.rcol); } + } } - + /* compute transmission */ if (m->otype == MAT_TRANS) { - trans = m->oargs.farg[5]*(1.0 - rspec); - tspec = trans * m->oargs.farg[6]; - tdiff = trans - tspec; + nd.trans = m->oargs.farg[5]*(1.0 - nd.rspec); + nd.tspec = nd.trans * m->oargs.farg[6]; + nd.tdiff = nd.trans - nd.tspec; } else - tdiff = tspec = trans = 0.0; + nd.tdiff = nd.tspec = nd.trans = 0.0; /* transmitted ray */ - if (tspec > FTINY && alpha2 <= FTINY) - if (rayorigin(&lr, r, TRANS, tspec) == 0) { - VCOPY(lr.rdir, r->rdir); + if (nd.tspec > FTINY && nd.alpha2 <= FTINY) { + RAY lr; + if (rayorigin(&lr, r, TRANS, nd.tspec) == 0) { + if (!(r->crtype & SHADOW) && + DOT(r->pert,r->pert) > FTINY*FTINY) { + for (i = 0; i < 3; i++) /* perturb direction */ + lr.rdir[i] = r->rdir[i] - + .75*r->pert[i]; + normalize(lr.rdir); + } else { + VCOPY(lr.rdir, r->rdir); + transtest = 2; + } rayvalue(&lr); - scalecolor(lr.rcol, tspec); + scalecolor(lr.rcol, nd.tspec); + multcolor(lr.rcol, nd.mcolor); /* modified by color */ addcolor(r->rcol, lr.rcol); + transtest *= bright(lr.rcol); + transdist = r->rot + lr.rt; } + } if (r->crtype & SHADOW) /* the rest is shadow */ return; /* diffuse reflection */ - rdiff = 1.0 - trans - rspec; + nd.rdiff = 1.0 - nd.trans - nd.rspec; - if (rdiff <= FTINY && tdiff <= FTINY && alpha2 <= FTINY) + if (nd.rdiff <= FTINY && nd.tdiff <= FTINY && nd.alpha2 <= FTINY) return; /* purely specular */ - if (rdiff > FTINY) { /* ambient from this side */ + if (nd.rdiff > FTINY) { /* ambient from this side */ ambient(ctmp, r); - if (alpha2 <= FTINY) - scalecolor(ctmp, rdiff); + if (nd.alpha2 <= FTINY) + scalecolor(ctmp, nd.rdiff); else - scalecolor(ctmp, 1.0-trans); - multcolor(ctmp, mcolor); /* modified by material color */ + scalecolor(ctmp, 1.0-nd.trans); + multcolor(ctmp, nd.mcolor); /* modified by material color */ addcolor(r->rcol, ctmp); /* add to returned color */ } - if (tdiff > FTINY) { /* ambient from other side */ + if (nd.tdiff > FTINY) { /* ambient from other side */ flipsurface(r); ambient(ctmp, r); - if (alpha2 <= FTINY) - scalecolor(ctmp, tdiff); + if (nd.alpha2 <= FTINY) + scalecolor(ctmp, nd.tdiff); else - scalecolor(ctmp, trans); - multcolor(ctmp, mcolor); + scalecolor(ctmp, nd.trans); + multcolor(ctmp, nd.mcolor); addcolor(r->rcol, ctmp); flipsurface(r); } - - for (i = 0; i < nsources; i++) { /* add specular and diffuse */ - - if ((omega = srcray(&lr, r, i)) == 0.0) - continue; /* bad source */ - - ldot = DOT(pnorm, lr.rdir); - - if (ldot < 0.0 ? trans <= FTINY : trans >= 1.0-FTINY) - continue; /* wrong side */ - - rayvalue(&lr); /* compute light ray value */ - - if (intens(lr.rcol) <= FTINY) - continue; /* didn't hit light source */ - - if (ldot > FTINY && rdiff > FTINY) { - /* - * Compute and add diffuse component to returned color. - * The diffuse component will always be modified by the - * color of the material. - */ - copycolor(ctmp, lr.rcol); - dtmp = ldot * omega * rdiff / PI; - scalecolor(ctmp, dtmp); - multcolor(ctmp, mcolor); - addcolor(r->rcol, ctmp); - } - if (ldot > FTINY && rspec > FTINY && alpha2 > FTINY) { - /* - * Compute specular reflection coefficient using - * gaussian distribution model. - */ - /* roughness + source */ - dtmp = alpha2 + omega/(2.0*PI); - /* gaussian */ - dtmp = exp((DOT(vrefl,lr.rdir)-1.)/dtmp)/(2.*PI)/dtmp; - /* worth using? */ - if (dtmp > FTINY) { - copycolor(ctmp, lr.rcol); - dtmp *= omega; - scalecolor(ctmp, dtmp); - multcolor(ctmp, scolor); - addcolor(r->rcol, ctmp); - } - } - if (ldot < -FTINY && tdiff > FTINY) { - /* - * Compute diffuse transmission. - */ - copycolor(ctmp, lr.rcol); - dtmp = -ldot * omega * tdiff / PI; - scalecolor(ctmp, dtmp); - multcolor(ctmp, mcolor); - addcolor(r->rcol, ctmp); - } - if (ldot < -FTINY && tspec > FTINY && alpha2 > FTINY) { - /* - * Compute specular transmission. - */ - /* roughness + source */ - dtmp = alpha2 + omega/(2.0*PI); - /* gaussian */ - dtmp = exp((DOT(r->rdir,lr.rdir)-1.)/dtmp)/(2.*PI)/dtmp; - /* worth using? */ - if (dtmp > FTINY) { - copycolor(ctmp, lr.rcol); - dtmp *= tspec * omega; - scalecolor(ctmp, dtmp); - addcolor(r->rcol, ctmp); - } - } - } + /* add direct component */ + direct(r, dirnorm, &nd); + /* check distance */ + if (transtest > bright(r->rcol)) + r->rt = transdist; }
