Fixed bug in calculation of diffuse transmission on polished "trans" surfaces
Corrected Gaussian reflectance model normalization (cosine factor)
Created proper prototypes for function pointers and included missing headers
Improved last Fresnel approx. improvement, which was wrong
Improved Fresnel reflection approximation
Changed call order for proper function of two-sided, textured surfaces
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
switched to faster table-lookup for sin() and cos() functions
simplified logic slightly
fixed double-counting bug in calculation of specular transmission
changed code to iterate until specular sample succeeds (MAXITER)
bug fix in shadows through trans materials
fixed problem with back side normal computation for ambient()
added texturing to ambient value computation using extambient()
made shadow testing slightly more efficient for trans type
added isflat() macro and effective ray distance for mirror reflection
added -bv option for back face visibility (normally on)
fixed potential use of unassigned transdist when bright(r->rcol)<0
removed approximation to Fresnel reflection, since the direct component was not being calculated accordingly (BRDF not bidirectional) changed BRDTfunc arguments and operation, fixed one or two bugs there also
improved specular component calculation
fixed comments in header
fixed normalization of transmitted direct component
fixed screwed-up normalization in sample generation
changed effect of perturbation and roughness on transmission
bug fixes in specular transmission
reinstated random testing of specular threshold
brought isotropic Gaussian model into line using half-vector
reinstated Fresnel factors for roughened surfaces
corrected normalization of light source highlights
fixed bug that caused ambient to be overcounted for polished surf's changed use of Fresnel correction so it will only affect polished surf's
precautionary test before accessing r->ro member
bug fix in distance setting code and transmitted color
changed urand() call to frandom() for specular threshold testing
changed default values and handling of specthresh
finally added sampling of transmitted specular
improved safety measures for grazing angles
added jittering to specular threshold test
added specular jitter and threshold controls
fixed bug in sampling code
changed direct calculation only to widen hightlight for flat surfaces
added specular sampling
changed gaussian transmission to account for texture
made gaussian component bidirectional with addition of cosine term
fixed source tracing
fixed bug introduced by better trans distance comp.
fixed code for determining when to use trans distance
changed trans types to modify transmitted color and added perturbation to transmitted ray direction
improved setting of rt RAY parameter
fixed inconsistency in treatment of specular transmission
Efficient approximation to direct component with many sources Glow type changed Spot type eliminated
repaired and improved ambient calculation
