root/radiance/ray/src/rt/normal.c
Revision: 2.25
Committed: Thu May 27 15:28:03 1993 UTC (32 years, 1 month ago) by greg
Changes since 2.24: +3 -15 lines
removed approximation to Fresnel reflection, since the direct
component was not being calculated accordingly (BRDF not bidirectional)
changed BRDTfunc arguments and operation, fixed one or two bugs there also
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * normal.c - shading function for normal materials.
9 *
10 * 8/19/85
11 * 12/19/85 - added stuff for metals.
12 * 6/26/87 - improved specular model.
13 * 9/28/87 - added model for translucent materials.
14 * Later changes described in delta comments.
15 */
16
17 #include "ray.h"
18
19 #include "otypes.h"
20
21 #include "random.h"
22
23 extern double specthresh; /* specular sampling threshold */
24 extern double specjitter; /* specular sampling jitter */
25
26 static gaussamp();
27
28 /*
29 * This routine implements the isotropic Gaussian
30 * model described by Ward in Siggraph `92 article.
31 * We orient the surface towards the incoming ray, so a single
32 * surface can be used to represent an infinitely thin object.
33 *
34 * Arguments for MAT_PLASTIC and MAT_METAL are:
35 * red grn blu specular-frac. facet-slope
36 *
37 * Arguments for MAT_TRANS are:
38 * red grn blu rspec rough trans tspec
39 */
40
41 /* specularity flags */
42 #define SP_REFL 01 /* has reflected specular component */
43 #define SP_TRAN 02 /* has transmitted specular */
44 #define SP_PURE 04 /* purely specular (zero roughness) */
45 #define SP_FLAT 010 /* flat reflecting surface */
46 #define SP_RBLT 020 /* reflection below sample threshold */
47 #define SP_TBLT 040 /* transmission below threshold */
48
49 typedef struct {
50 OBJREC *mp; /* material pointer */
51 RAY *rp; /* ray pointer */
52 short specfl; /* specularity flags, defined above */
53 COLOR mcolor; /* color of this material */
54 COLOR scolor; /* color of specular component */
55 FVECT vrefl; /* vector in direction of reflected ray */
56 FVECT prdir; /* vector in transmitted direction */
57 double alpha2; /* roughness squared */
58 double rdiff, rspec; /* reflected specular, diffuse */
59 double trans; /* transmissivity */
60 double tdiff, tspec; /* transmitted specular, diffuse */
61 FVECT pnorm; /* perturbed surface normal */
62 double pdot; /* perturbed dot product */
63 } NORMDAT; /* normal material data */
64
65
66 dirnorm(cval, np, ldir, omega) /* compute source contribution */
67 COLOR cval; /* returned coefficient */
68 register NORMDAT *np; /* material data */
69 FVECT ldir; /* light source direction */
70 double omega; /* light source size */
71 {
72 double ldot;
73 double dtmp, d2;
74 FVECT vtmp;
75 COLOR ctmp;
76
77 setcolor(cval, 0.0, 0.0, 0.0);
78
79 ldot = DOT(np->pnorm, ldir);
80
81 if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY)
82 return; /* wrong side */
83
84 if (ldot > FTINY && np->rdiff > FTINY) {
85 /*
86 * Compute and add diffuse reflected component to returned
87 * color. The diffuse reflected component will always be
88 * modified by the color of the material.
89 */
90 copycolor(ctmp, np->mcolor);
91 dtmp = ldot * omega * np->rdiff / PI;
92 scalecolor(ctmp, dtmp);
93 addcolor(cval, ctmp);
94 }
95 if (ldot > FTINY && (np->specfl&(SP_REFL|SP_PURE)) == SP_REFL) {
96 /*
97 * Compute specular reflection coefficient using
98 * gaussian distribution model.
99 */
100 /* roughness */
101 dtmp = np->alpha2;
102 /* + source if flat */
103 if (np->specfl & SP_FLAT)
104 dtmp += omega/(4.0*PI);
105 /* half vector */
106 vtmp[0] = ldir[0] - np->rp->rdir[0];
107 vtmp[1] = ldir[1] - np->rp->rdir[1];
108 vtmp[2] = ldir[2] - np->rp->rdir[2];
109 d2 = DOT(vtmp, np->pnorm);
110 d2 *= d2;
111 d2 = (DOT(vtmp,vtmp) - d2) / d2;
112 /* gaussian */
113 dtmp = exp(-d2/dtmp)/(4.*PI*dtmp);
114 /* worth using? */
115 if (dtmp > FTINY) {
116 copycolor(ctmp, np->scolor);
117 dtmp *= omega * sqrt(ldot/np->pdot);
118 scalecolor(ctmp, dtmp);
119 addcolor(cval, ctmp);
120 }
121 }
122 if (ldot < -FTINY && np->tdiff > FTINY) {
123 /*
124 * Compute diffuse transmission.
125 */
126 copycolor(ctmp, np->mcolor);
127 dtmp = -ldot * omega * np->tdiff / PI;
128 scalecolor(ctmp, dtmp);
129 addcolor(cval, ctmp);
130 }
131 if (ldot < -FTINY && (np->specfl&(SP_TRAN|SP_PURE)) == SP_TRAN) {
132 /*
133 * Compute specular transmission. Specular transmission
134 * is always modified by material color.
135 */
136 /* roughness + source */
137 dtmp = np->alpha2 + omega/PI;
138 /* gaussian */
139 dtmp = exp((2.*DOT(np->prdir,ldir)-2.)/dtmp)/(PI*dtmp);
140 /* worth using? */
141 if (dtmp > FTINY) {
142 copycolor(ctmp, np->mcolor);
143 dtmp *= np->tspec * omega * sqrt(-ldot/np->pdot);
144 scalecolor(ctmp, dtmp);
145 addcolor(cval, ctmp);
146 }
147 }
148 }
149
150
151 m_normal(m, r) /* color a ray that hit something normal */
152 register OBJREC *m;
153 register RAY *r;
154 {
155 NORMDAT nd;
156 double transtest, transdist;
157 COLOR ctmp;
158 register int i;
159 /* easy shadow test */
160 if (r->crtype & SHADOW && m->otype != MAT_TRANS)
161 return;
162
163 if (m->oargs.nfargs != (m->otype == MAT_TRANS ? 7 : 5))
164 objerror(m, USER, "bad number of arguments");
165 nd.mp = m;
166 nd.rp = r;
167 /* get material color */
168 setcolor(nd.mcolor, m->oargs.farg[0],
169 m->oargs.farg[1],
170 m->oargs.farg[2]);
171 /* get roughness */
172 nd.specfl = 0;
173 nd.alpha2 = m->oargs.farg[4];
174 if ((nd.alpha2 *= nd.alpha2) <= FTINY)
175 nd.specfl |= SP_PURE;
176 /* reorient if necessary */
177 if (r->rod < 0.0)
178 flipsurface(r);
179 /* get modifiers */
180 raytexture(r, m->omod);
181 nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */
182 if (nd.pdot < .001)
183 nd.pdot = .001; /* non-zero for dirnorm() */
184 multcolor(nd.mcolor, r->pcol); /* modify material color */
185 transtest = 0;
186 /* get specular component */
187 if ((nd.rspec = m->oargs.farg[3]) > FTINY) {
188 nd.specfl |= SP_REFL;
189 /* compute specular color */
190 if (m->otype == MAT_METAL)
191 copycolor(nd.scolor, nd.mcolor);
192 else
193 setcolor(nd.scolor, 1.0, 1.0, 1.0);
194 scalecolor(nd.scolor, nd.rspec);
195 /* check threshold */
196 if (!(nd.specfl & SP_PURE) && specthresh >= nd.rspec-FTINY)
197 nd.specfl |= SP_RBLT;
198 /* compute reflected ray */
199 for (i = 0; i < 3; i++)
200 nd.vrefl[i] = r->rdir[i] + 2.0*nd.pdot*nd.pnorm[i];
201 if (DOT(nd.vrefl, r->ron) <= FTINY) /* penetration? */
202 for (i = 0; i < 3; i++) /* safety measure */
203 nd.vrefl[i] = r->rdir[i] + 2.*r->rod*r->ron[i];
204
205 if (!(r->crtype & SHADOW) && nd.specfl & SP_PURE) {
206 RAY lr;
207 if (rayorigin(&lr, r, REFLECTED, nd.rspec) == 0) {
208 VCOPY(lr.rdir, nd.vrefl);
209 rayvalue(&lr);
210 multcolor(lr.rcol, nd.scolor);
211 addcolor(r->rcol, lr.rcol);
212 }
213 }
214 }
215 /* compute transmission */
216 if (m->otype == MAT_TRANS) {
217 nd.trans = m->oargs.farg[5]*(1.0 - nd.rspec);
218 nd.tspec = nd.trans * m->oargs.farg[6];
219 nd.tdiff = nd.trans - nd.tspec;
220 if (nd.tspec > FTINY) {
221 nd.specfl |= SP_TRAN;
222 /* check threshold */
223 if (!(nd.specfl & SP_PURE) &&
224 specthresh >= nd.tspec-FTINY)
225 nd.specfl |= SP_TBLT;
226 if (r->crtype & SHADOW ||
227 DOT(r->pert,r->pert) <= FTINY*FTINY) {
228 VCOPY(nd.prdir, r->rdir);
229 transtest = 2;
230 } else {
231 for (i = 0; i < 3; i++) /* perturb */
232 nd.prdir[i] = r->rdir[i] - r->pert[i];
233 if (DOT(nd.prdir, r->ron) < -FTINY)
234 normalize(nd.prdir); /* OK */
235 else
236 VCOPY(nd.prdir, r->rdir);
237 }
238 }
239 } else
240 nd.tdiff = nd.tspec = nd.trans = 0.0;
241 /* transmitted ray */
242 if ((nd.specfl&(SP_TRAN|SP_PURE)) == (SP_TRAN|SP_PURE)) {
243 RAY lr;
244 if (rayorigin(&lr, r, TRANS, nd.tspec) == 0) {
245 VCOPY(lr.rdir, nd.prdir);
246 rayvalue(&lr);
247 scalecolor(lr.rcol, nd.tspec);
248 multcolor(lr.rcol, nd.mcolor); /* modified by color */
249 addcolor(r->rcol, lr.rcol);
250 transtest *= bright(lr.rcol);
251 transdist = r->rot + lr.rt;
252 }
253 } else
254 transtest = 0;
255
256 if (r->crtype & SHADOW) /* the rest is shadow */
257 return;
258 /* diffuse reflection */
259 nd.rdiff = 1.0 - nd.trans - nd.rspec;
260
261 if (nd.specfl & SP_PURE && nd.rdiff <= FTINY && nd.tdiff <= FTINY)
262 return; /* 100% pure specular */
263
264 if (r->ro != NULL && (r->ro->otype == OBJ_FACE ||
265 r->ro->otype == OBJ_RING))
266 nd.specfl |= SP_FLAT;
267
268 if (nd.specfl & (SP_REFL|SP_TRAN) && !(nd.specfl & SP_PURE))
269 gaussamp(r, &nd);
270
271 if (nd.rdiff > FTINY) { /* ambient from this side */
272 ambient(ctmp, r);
273 if (nd.specfl & SP_RBLT)
274 scalecolor(ctmp, 1.0-nd.trans);
275 else
276 scalecolor(ctmp, nd.rdiff);
277 multcolor(ctmp, nd.mcolor); /* modified by material color */
278 addcolor(r->rcol, ctmp); /* add to returned color */
279 }
280 if (nd.tdiff > FTINY) { /* ambient from other side */
281 flipsurface(r);
282 ambient(ctmp, r);
283 if (nd.specfl & SP_TBLT)
284 scalecolor(ctmp, nd.trans);
285 else
286 scalecolor(ctmp, nd.tdiff);
287 multcolor(ctmp, nd.mcolor); /* modified by color */
288 addcolor(r->rcol, ctmp);
289 flipsurface(r);
290 }
291 /* add direct component */
292 direct(r, dirnorm, &nd);
293 /* check distance */
294 if (transtest > bright(r->rcol))
295 r->rt = transdist;
296 }
297
298
299 static
300 gaussamp(r, np) /* sample gaussian specular */
301 RAY *r;
302 register NORMDAT *np;
303 {
304 RAY sr;
305 FVECT u, v, h;
306 double rv[2];
307 double d, sinp, cosp;
308 register int i;
309 /* quick test */
310 if ((np->specfl & (SP_REFL|SP_RBLT)) != SP_REFL &&
311 (np->specfl & (SP_TRAN|SP_TBLT)) != SP_TRAN)
312 return;
313 /* set up sample coordinates */
314 v[0] = v[1] = v[2] = 0.0;
315 for (i = 0; i < 3; i++)
316 if (np->pnorm[i] < 0.6 && np->pnorm[i] > -0.6)
317 break;
318 v[i] = 1.0;
319 fcross(u, v, np->pnorm);
320 normalize(u);
321 fcross(v, np->pnorm, u);
322 /* compute reflection */
323 if ((np->specfl & (SP_REFL|SP_RBLT)) == SP_REFL &&
324 rayorigin(&sr, r, SPECULAR, np->rspec) == 0) {
325 dimlist[ndims++] = (int)np->mp;
326 d = urand(ilhash(dimlist,ndims)+samplendx);
327 multisamp(rv, 2, d);
328 d = 2.0*PI * rv[0];
329 cosp = cos(d);
330 sinp = sin(d);
331 rv[1] = 1.0 - specjitter*rv[1];
332 if (rv[1] <= FTINY)
333 d = 1.0;
334 else
335 d = sqrt( np->alpha2 * -log(rv[1]) );
336 for (i = 0; i < 3; i++)
337 h[i] = np->pnorm[i] + d*(cosp*u[i] + sinp*v[i]);
338 d = -2.0 * DOT(h, r->rdir) / (1.0 + d*d);
339 for (i = 0; i < 3; i++)
340 sr.rdir[i] = r->rdir[i] + d*h[i];
341 if (DOT(sr.rdir, r->ron) <= FTINY)
342 VCOPY(sr.rdir, np->vrefl); /* jitter no good */
343 rayvalue(&sr);
344 multcolor(sr.rcol, np->scolor);
345 addcolor(r->rcol, sr.rcol);
346 ndims--;
347 }
348 /* compute transmission */
349 if ((np->specfl & (SP_TRAN|SP_TBLT)) == SP_TRAN &&
350 rayorigin(&sr, r, SPECULAR, np->tspec) == 0) {
351 dimlist[ndims++] = (int)np->mp;
352 d = urand(ilhash(dimlist,ndims)+1823+samplendx);
353 multisamp(rv, 2, d);
354 d = 2.0*PI * rv[0];
355 cosp = cos(d);
356 sinp = sin(d);
357 rv[1] = 1.0 - specjitter*rv[1];
358 if (rv[1] <= FTINY)
359 d = 1.0;
360 else
361 d = sqrt( -log(rv[1]) * np->alpha2 );
362 for (i = 0; i < 3; i++)
363 sr.rdir[i] = np->prdir[i] + d*(cosp*u[i] + sinp*v[i]);
364 if (DOT(sr.rdir, r->ron) < -FTINY)
365 normalize(sr.rdir); /* OK, normalize */
366 else
367 VCOPY(sr.rdir, np->prdir); /* else no jitter */
368 rayvalue(&sr);
369 scalecolor(sr.rcol, np->tspec);
370 multcolor(sr.rcol, np->mcolor); /* modified by color */
371 addcolor(r->rcol, sr.rcol);
372 ndims--;
373 }
374 }
