root/radiance/ray/src/rt/normal.c
Wed Mar 12 17:26:58 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.41: +2 -2 lines
Diff to previous 2.41 , to selected 2.19
Wed Mar 12 04:59:05 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.40: +5 -5 lines
Diff to previous 2.40 , to selected 2.19
Mon Mar 3 00:10:51 2003 UTC (21 years, 2 months ago) by greg
Changes since 2.39: +4 -3 lines
Diff to previous 2.39 , to selected 2.19
Changed call order for proper function of two-sided, textured surfaces
Changes since 2.38: +1 -56 lines
Diff to previous 2.38 , to selected 2.19
Changes since 2.37: +88 -17 lines
Diff to previous 2.37 , to selected 2.19
Wed Dec 16 18:14:58 1998 UTC (25 years, 5 months ago) by gwlarson
Changes since 2.36: +7 -7 lines
Diff to previous 2.36 , to selected 2.19
switched to faster table-lookup for sin() and cos() functions
Sun Nov 30 12:32:45 1997 UTC (26 years, 5 months ago) by gregl
Changes since 2.35: +15 -15 lines
Diff to previous 2.35 , to selected 2.19
simplified logic slightly
Tue Jan 7 16:44:04 1997 UTC (27 years, 4 months ago) by greg
Changes since 2.34: +1 -1 lines
Diff to previous 2.34 , to selected 2.19
fixed double-counting bug in calculation of specular transmission
Wed Apr 24 15:47:27 1996 UTC (28 years ago) by greg
Changes since 2.33: +57 -41 lines
Diff to previous 2.33 , to selected 2.19
changed code to iterate until specular sample succeeds (MAXITER)
Wed Jan 3 11:33:56 1996 UTC (28 years, 4 months ago) by greg
Changes since 2.32: +1 -1 lines
Diff to previous 2.32 , to selected 2.19
bug fix in shadows through trans materials
Wed Nov 22 09:27:55 1995 UTC (28 years, 6 months ago) by greg
Changes since 2.31: +8 -1 lines
Diff to previous 2.31 , to selected 2.19
fixed problem with back side normal computation for ambient()
Mon Nov 6 12:03:17 1995 UTC (28 years, 6 months ago) by greg
Diff to previous 2.30 , to selected 2.19
added texturing to ambient value computation using extambient()
Tue Sep 26 15:05:32 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.29: +36 -35 lines
Diff to previous 2.29 , to selected 2.19
made shadow testing slightly more efficient for trans type
Fri Sep 15 15:47:30 1995 UTC (28 years, 8 months ago) by greg
Changes since 2.28: +36 -21 lines
Diff to previous 2.28 , to selected 2.19
added isflat() macro and effective ray distance for mirror reflection
Wed Dec 21 09:51:49 1994 UTC (29 years, 5 months ago) by greg
Changes since 2.27: +10 -3 lines
Diff to previous 2.27 , to selected 2.19
added -bv option for back face visibility (normally on)
Wed Jan 12 16:46:45 1994 UTC (30 years, 4 months ago) by greg
Changes since 2.26: +5 -3 lines
Diff to previous 2.26 , to selected 2.19
Tue Aug 24 12:59:28 1993 UTC (30 years, 9 months ago) by greg
Changes since 2.25: +1 -0 lines
Diff to previous 2.25 , to selected 2.19
fixed potential use of unassigned transdist when bright(r->rcol)<0
Thu May 27 15:28:03 1993 UTC (30 years, 11 months ago) by greg
Changes since 2.24: +3 -15 lines
Diff to previous 2.24 , to selected 2.19
removed approximation to Fresnel reflection, since the direct
component was not being calculated accordingly (BRDF not bidirectional)
changed BRDTfunc arguments and operation, fixed one or two bugs there also
Mon Mar 8 12:37:27 1993 UTC (31 years, 2 months ago) by greg
Changes since 2.23: +2 -0 lines
Diff to previous 2.23 , to selected 2.19
Fri Feb 12 10:41:02 1993 UTC (31 years, 3 months ago) by greg
Changes since 2.22: +3 -2 lines
Diff to previous 2.22 , to selected 2.19
improved specular component calculation
Fri Oct 16 10:20:29 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.21: +2 -4 lines
Diff to previous 2.21 , to selected 2.19
fixed comments in header
Wed May 20 14:23:47 1992 UTC (32 years ago) by greg
Diff to previous 2.20 , to selected 2.19
fixed normalization of transmitted direct component
Tue May 19 17:09:03 1992 UTC (32 years ago) by greg
Diff to previous 2.19
fixed screwed-up normalization in sample generation
Revision 2.19 - (view) (download) (annotate) - [selected]
Sat May 16 08:37:06 1992 UTC (32 years ago) by greg
Diff to previous 2.18
changed effect of perturbation and roughness on transmission
Fri May 15 13:07:55 1992 UTC (32 years ago) by greg
Diff to previous 2.17 , to selected 2.19
bug fixes in specular transmission
Thu May 14 11:32:07 1992 UTC (32 years ago) by greg
Diff to previous 2.16 , to selected 2.19
reinstated random testing of specular threshold
Wed May 6 17:36:00 1992 UTC (32 years ago) by greg
Changes since 2.15: +13 -5 lines
Diff to previous 2.15 , to selected 2.19
brought isotropic Gaussian model into line using half-vector
Wed Apr 22 09:05:30 1992 UTC (32 years, 1 month ago) by greg
Changes since 2.14: +8 -7 lines
Diff to previous 2.14 , to selected 2.19
reinstated Fresnel factors for roughened surfaces
Mon Apr 20 09:25:50 1992 UTC (32 years, 1 month ago) by greg
Diff to previous 2.13 , to selected 2.19
corrected normalization of light source highlights
Thu Apr 16 13:31:28 1992 UTC (32 years, 1 month ago) by greg
Changes since 2.12: +16 -13 lines
Diff to previous 2.12 , to selected 2.19
fixed bug that caused ambient to be overcounted for polished surf's
changed use of Fresnel correction so it will only affect polished surf's
Tue Mar 3 16:20:02 1992 UTC (32 years, 2 months ago) by greg
Diff to previous 2.11 , to selected 2.19
precautionary test before accessing r->ro member
Fri Feb 21 14:53:16 1992 UTC (32 years, 3 months ago) by greg
Changes since 2.10: +8 -6 lines
Diff to previous 2.10 , to selected 2.19
bug fix in distance setting code and transmitted color
Thu Jan 30 11:37:00 1992 UTC (32 years, 3 months ago) by greg
Changes since 2.9: +2 -4 lines
Diff to previous 2.9 , to selected 2.19
changed urand() call to frandom() for specular threshold testing
Thu Jan 16 12:05:29 1992 UTC (32 years, 4 months ago) by greg
Diff to previous 2.8 , to selected 2.19
changed default values and handling of specthresh
Wed Jan 15 16:59:52 1992 UTC (32 years, 4 months ago) by greg
Changes since 2.7: +26 -2 lines
Diff to previous 2.7 , to selected 2.19
finally added sampling of transmitted specular
Wed Jan 15 11:41:44 1992 UTC (32 years, 4 months ago) by greg
Changes since 2.6: +27 -26 lines
Diff to previous 2.6 , to selected 2.19
improved safety measures for grazing angles
Wed Jan 15 11:02:40 1992 UTC (32 years, 4 months ago) by greg
Changes since 2.5: +9 -2 lines
Diff to previous 2.5 , to selected 2.19
added jittering to specular threshold test
Tue Jan 14 16:16:45 1992 UTC (32 years, 4 months ago) by greg
Changes since 2.4: +21 -3 lines
Diff to previous 2.4 , to selected 2.19
added specular jitter and threshold controls
Tue Jan 14 15:33:08 1992 UTC (32 years, 4 months ago) by greg
Changes since 2.3: +24 -23 lines
Diff to previous 2.3 , to selected 2.19
fixed bug in sampling code
Sat Jan 4 23:36:42 1992 UTC (32 years, 4 months ago) by greg
Changes since 2.2: +10 -2 lines
Diff to previous 2.2 , to selected 2.19
changed direct calculation only to widen hightlight for flat surfaces
Sat Jan 4 19:53:53 1992 UTC (32 years, 4 months ago) by greg
Changes since 2.1: +96 -33 lines
Diff to previous 2.1 , to selected 2.19
added specular sampling
Tue Nov 12 17:09:11 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.14 , to selected 2.19
Wed Oct 30 14:53:55 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.13: +11 -13 lines
Diff to previous 1.13 , to selected 2.19
changed gaussian transmission to account for texture
Wed Oct 30 10:59:42 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.12: +8 -5 lines
Diff to previous 1.12 , to selected 2.19
made gaussian component bidirectional with addition of cosine term
Mon Aug 12 08:20:55 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.11: +2 -1 lines
Diff to previous 1.11 , to selected 2.19
fixed source tracing
Thu Jun 13 13:58:18 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.10: +0 -1 lines
Diff to previous 1.10 , to selected 2.19
Fri May 10 08:51:04 1991 UTC (33 years ago) by greg
Changes since 1.9: +3 -1 lines
Diff to previous 1.9 , to selected 2.19
fixed bug introduced by better trans distance comp.
Wed May 8 08:27:48 1991 UTC (33 years ago) by greg
Changes since 1.8: +15 -6 lines
Diff to previous 1.8 , to selected 2.19
fixed code for determining when to use trans distance
Tue May 7 17:45:49 1991 UTC (33 years ago) by greg
Changes since 1.7: +4 -1 lines
Diff to previous 1.7 , to selected 2.19
changed trans types to modify transmitted color
and added perturbation to transmitted ray direction
Mon Oct 15 20:39:35 1990 UTC (33 years, 7 months ago) by greg
Changes since 1.6: +0 -2 lines
Diff to previous 1.6 , to selected 2.19
improved setting of rt RAY parameter
Tue Jun 26 09:00:10 1990 UTC (33 years, 10 months ago) by greg
Changes since 1.5: +0 -2 lines
Diff to previous 1.5 , to selected 2.19
Tue Mar 27 11:40:02 1990 UTC (34 years, 1 month ago) by greg
Changes since 1.4: +5 -0 lines
Diff to previous 1.4 , to selected 2.19
Wed Oct 18 09:01:36 1989 UTC (34 years, 7 months ago) by greg
Changes since 1.3: +6 -6 lines
Diff to previous 1.3 , to selected 2.19
fixed inconsistency in treatment of specular transmission
Wed Jun 7 08:35:14 1989 UTC (34 years, 11 months ago) by greg
Changes since 1.2: +131 -119 lines
Diff to previous 1.2 , to selected 2.19
Glow type changed
Spot type eliminated
Sat Apr 15 12:23:22 1989 UTC (35 years, 1 month ago) by greg
Changes since 1.1: +15 -7 lines
Diff to previous 1.1 , to selected 2.19
repaired and improved ambient calculation
Thu Feb 2 10:41:30 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.19
