root/radiance/ray/src/rt/noise3.c
Wed Nov 21 20:23:15 2018 UTC (5 years, 6 months ago) by greg
Changes since 2.13: +9 -9 lines
Diff to previous 2.13 , to selected 1.3
Fixed bug in calculation of noise{x,y,z}
Tue Oct 8 18:59:44 2013 UTC (10 years, 8 months ago) by greg
Changes since 2.12: +128 -107 lines
Diff to previous 2.12 , to selected 1.3
Tue Feb 22 16:45:12 2011 UTC (13 years, 3 months ago) by greg
Changes since 2.11: +2 -4 lines
Diff to previous 2.11 , to selected 1.3
Fixed a few compile errors due to code reorg
Fri Sep 3 21:16:50 2010 UTC (13 years, 9 months ago) by greg
Changes since 2.10: +1 -4 lines
Diff to previous 2.10 , to selected 1.3
Removed '//' comment lines that shouldn't be in C code
Thu Mar 2 17:16:56 2006 UTC (18 years, 3 months ago) by greg
Changes since 2.9: +5 -5 lines
Diff to previous 2.9 , to selected 1.3
Replaced % operations with if statements (hopefully faster)
Changes since 2.8: +38 -22 lines
Diff to previous 2.8 , to selected 1.3
Mon Aug 4 22:37:53 2003 UTC (20 years, 10 months ago) by greg
Changes since 2.7: +5 -3 lines
Diff to previous 2.7 , to selected 1.3
Diff to previous 2.6 , to selected 1.3
Changes since 2.5: +57 -6 lines
Diff to previous 2.5 , to selected 1.3
Thu Oct 31 10:58:36 1996 UTC (27 years, 7 months ago) by greg
Diff to previous 2.4 , to selected 1.3
renamed noise3{a,b,c} to noise3{x,y,z}
Mon Aug 9 10:03:45 1993 UTC (30 years, 10 months ago) by greg
Diff to previous 2.3 , to selected 1.3
relaxed error on fractal noise function -- wasn't helping
Mon Mar 8 12:37:25 1993 UTC (31 years, 3 months ago) by greg
Diff to previous 2.2 , to selected 1.3
Fri Oct 2 16:18:50 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.1: +1 -2 lines
Diff to previous 2.1 , to selected 1.3
Tue Nov 12 17:09:23 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.7 , to selected 1.3
Thu Oct 10 16:43:40 1991 UTC (32 years, 8 months ago) by greg
Changes since 1.6: +16 -9 lines
Diff to previous 1.6 , to selected 1.3
made interpolation of noise3() function smoother
Fri Aug 2 13:57:09 1991 UTC (32 years, 10 months ago) by greg
Diff to previous 1.5 , to selected 1.3
minor changes
Fri May 24 14:23:33 1991 UTC (33 years ago) by greg
Changes since 1.4: +36 -55 lines
Diff to previous 1.4 , to selected 1.3
changed noise3 initialization
Wed May 22 08:56:21 1991 UTC (33 years ago) by greg
Changes since 1.3: +8 -8 lines
Diff to previous 1.3
moved test in fnoise3() (optimization)
Revision 1.3 - (view) (download) (annotate) - [selected]
Tue Oct 30 21:03:49 1990 UTC (33 years, 7 months ago) by greg
Changes since 1.2: +19 -19 lines
Diff to previous 1.2
improved speed of fnoise3() with integer math
Fri Mar 3 12:25:34 1989 UTC (35 years, 3 months ago) by greg
Diff to previous 1.1 , to selected 1.3
smaller EPSILON for fnoise3
Thu Feb 2 10:41:29 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 1.3
