root/radiance/ray/src/rt/mx_data.c
Revision: 1.1
Committed: Thu Feb 2 10:41:28 1989 UTC (35 years, 3 months ago) by greg
1 /* Copyright (c) 1988 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * mx_data.c - routine for stored mixtures.
9 *
10 * 11/2/88
11 */
12
13 #include "ray.h"
14
15 #include "data.h"
16
17 /*
18 * A stored mixture is specified:
19 *
20 * modifier mixdata name
21 * 6+ foremod backmod func dfname vfname v0 v1 .. xf
22 * 0
23 * n A1 A2 ..
24 *
25 * Vfname is the name of the file where the variable definitions
26 * can be found. The list of real arguments can be accessed by
27 * definitions in the file. Dfname is the data file.
28 * The dimensions of the data files and the number
29 * of variables must match. The func is a single argument
30 * function which returns the corrected data value given the
31 * interpolated value from the file. The xf is a transformation
32 * to get from the original coordinates to the current coordinates.
33 */
34
35
36 mx_data(m, r) /* interpolate mixture data */
37 register OBJREC *m;
38 RAY *r;
39 {
40 extern double varvalue(), funvalue(), datavalue();
41 extern int errno;
42 register int i;
43 double coef;
44 double pt[MAXDIM];
45 DATARRAY *dp;
46 OBJECT mod[2];
47 register char **sa;
48
49 setfunc(m, r);
50
51 sa = m->oargs.sarg;
52
53 if (m->oargs.nsargs < 6)
54 objerror(m, USER, "bad # arguments");
55 for (i = 0; i < 2; i++)
56 if (!strcmp(sa[i], VOIDID))
57 mod[i] = OVOID;
58 else if ((mod[i] = modifier(sa[i])) == OVOID) {
59 sprintf(errmsg, "undefined modifier \"%s\"", sa[i]);
60 objerror(m, USER, errmsg);
61 }
62 if (!vardefined(sa[5]))
63 loadfunc(sa[4]);
64 for (i = 0; i+5 < m->oargs.nsargs &&
65 sa[i+5][0] != '-'; i++) {
66 if (i >= MAXDIM)
67 objerror(m, USER, "dimension error");
68 errno = 0;
69 pt[i] = varvalue(sa[i+5]);
70 if (errno)
71 goto computerr;
72 }
73 dp = getdata(sa[3]);
74 if (dp->nd != i)
75 objerror(m, USER, "dimension error");
76 coef = datavalue(dp, pt);
77 errno = 0;
78 coef = funvalue(sa[2], 1, &coef);
79 if (errno)
80 goto computerr;
81 raymixture(r, mod[0], mod[1], coef);
82 return;
83
84 computerr:
85 objerror(m, WARNING, "compute error");
86 }
