--- ray/src/rt/mx_data.c 1998/08/10 18:35:14 2.4 +++ ray/src/rt/mx_data.c 1999/01/20 14:10:06 2.5 @@ -17,19 +17,29 @@ static char SCCSid[] = "$SunId$ SGI"; #include "func.h" /* - * A stored mixture is specified: + * A stored mixture is specified: * * modifier mixdata name * 6+ foremod backmod func dfname vfname v0 v1 .. xf * 0 * n A1 A2 .. * + * A picture mixture is specified as: + * + * modifier mixpict name + * 7+ foremod backmod func pfname vfname vx vy xf + * 0 + * n A1 A2 .. + * + * * Vfname is the name of the file where the variable definitions * can be found. The list of real arguments can be accessed by * definitions in the file. Dfname is the data file. + * (Pfname is a picture file.) * The dimensions of the data files and the number * of variables must match. The func is a single argument - * function which returns the corrected data value given the + * function in the case of mixdata (three argument in the case + * of mixpict), which returns the corrected data value given the * interpolated value from the file. The xf is a transformation * to get from the original coordinates to the current coordinates. */ @@ -71,6 +81,55 @@ RAY *r; coef = datavalue(dp, pt); errno = 0; coef = funvalue(m->oargs.sarg[2], 1, &coef); + if (errno) + goto computerr; + if (raymixture(r, mod[0], mod[1], coef)) { + if (m->omod != OVOID) + objerror(m, USER, "inappropriate modifier"); + return(1); + } + return(0); +computerr: + objerror(m, WARNING, "compute error"); + return(0); +} + + +mx_pdata(m, r) /* interpolate mixture picture */ +register OBJREC *m; +RAY *r; +{ + OBJECT obj; + double col[3], coef; + double pt[MAXDIM]; + DATARRAY *dp; + OBJECT mod[2]; + register MFUNC *mf; + register int i; + + if (m->oargs.nsargs < 7) + objerror(m, USER, "bad # arguments"); + obj = objndx(m); + for (i = 0; i < 2; i++) + if (!strcmp(m->oargs.sarg[i], VOIDID)) + mod[i] = OVOID; + else if ((mod[i] = lastmod(obj, m->oargs.sarg[i])) == OVOID) { + sprintf(errmsg, "undefined modifier \"%s\"", + m->oargs.sarg[i]); + objerror(m, USER, errmsg); + } + dp = getpict(m->oargs.sarg[3]); + mf = getfunc(m, 4, 0x3<<5, 0); + setfunc(m, r); + errno = 0; + pt[1] = evalue(mf->ep[0]); /* y major ordering */ + pt[0] = evalue(mf->ep[1]); + if (errno) + goto computerr; + for (i = 0; i < 3; i++) /* get pixel from picture */ + col[i] = datavalue(dp+i, pt); + errno = 0; /* evaluate function on pixel */ + coef = funvalue(m->oargs.sarg[2], 3, col); if (errno) goto computerr; if (raymixture(r, mod[0], mod[1], coef)) {
