--- ray/src/rt/mx_data.c 1989/02/02 10:41:28 1.1 +++ ray/src/rt/mx_data.c 2004/03/30 16:13:01 2.9 @@ -1,86 +1,144 @@ -/* Copyright (c) 1988 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: mx_data.c,v 2.9 2004/03/30 16:13:01 schorsch Exp $"; #endif - /* * mx_data.c - routine for stored mixtures. - * - * 11/2/88 */ -#include "ray.h" +#include "copyright.h" +#include "ray.h" #include "data.h" +#include "func.h" +#include "rtotypes.h" /* - * A stored mixture is specified: + * A stored mixture is specified: * * modifier mixdata name * 6+ foremod backmod func dfname vfname v0 v1 .. xf * 0 * n A1 A2 .. * + * A picture mixture is specified as: + * + * modifier mixpict name + * 7+ foremod backmod func pfname vfname vx vy xf + * 0 + * n A1 A2 .. + * + * * Vfname is the name of the file where the variable definitions * can be found. The list of real arguments can be accessed by * definitions in the file. Dfname is the data file. + * (Pfname is a picture file.) * The dimensions of the data files and the number * of variables must match. The func is a single argument - * function which returns the corrected data value given the + * function in the case of mixdata (three argument in the case + * of mixpict), which returns the corrected data value given the * interpolated value from the file. The xf is a transformation * to get from the original coordinates to the current coordinates. */ -mx_data(m, r) /* interpolate mixture data */ -register OBJREC *m; -RAY *r; +extern int +mx_data( /* interpolate mixture data */ + register OBJREC *m, + RAY *r +) { - extern double varvalue(), funvalue(), datavalue(); - extern int errno; - register int i; + OBJECT obj; double coef; double pt[MAXDIM]; DATARRAY *dp; OBJECT mod[2]; - register char **sa; + register MFUNC *mf; + register int i; - setfunc(m, r); - - sa = m->oargs.sarg; - if (m->oargs.nsargs < 6) objerror(m, USER, "bad # arguments"); + obj = objndx(m); for (i = 0; i < 2; i++) - if (!strcmp(sa[i], VOIDID)) + if (!strcmp(m->oargs.sarg[i], VOIDID)) mod[i] = OVOID; - else if ((mod[i] = modifier(sa[i])) == OVOID) { - sprintf(errmsg, "undefined modifier \"%s\"", sa[i]); + else if ((mod[i] = lastmod(obj, m->oargs.sarg[i])) == OVOID) { + sprintf(errmsg, "undefined modifier \"%s\"", + m->oargs.sarg[i]); objerror(m, USER, errmsg); } - if (!vardefined(sa[5])) - loadfunc(sa[4]); - for (i = 0; i+5 < m->oargs.nsargs && - sa[i+5][0] != '-'; i++) { - if (i >= MAXDIM) - objerror(m, USER, "dimension error"); - errno = 0; - pt[i] = varvalue(sa[i+5]); - if (errno) + dp = getdata(m->oargs.sarg[3]); + i = (1 << dp->nd) - 1; + mf = getfunc(m, 4, i<<5, 0); + setfunc(m, r); + errno = 0; + for (i = 0; i < dp->nd; i++) { + pt[i] = evalue(mf->ep[i]); + if (errno == EDOM || errno == ERANGE) goto computerr; } - dp = getdata(sa[3]); - if (dp->nd != i) - objerror(m, USER, "dimension error"); coef = datavalue(dp, pt); errno = 0; - coef = funvalue(sa[2], 1, &coef); - if (errno) + coef = funvalue(m->oargs.sarg[2], 1, &coef); + if (errno == EDOM || errno == ERANGE) goto computerr; - raymixture(r, mod[0], mod[1], coef); - return; + if (raymixture(r, mod[0], mod[1], coef)) { + if (m->omod != OVOID) + objerror(m, USER, "inappropriate modifier"); + return(1); + } + return(0); +computerr: + objerror(m, WARNING, "compute error"); + return(0); +} + +extern int +mx_pdata( /* interpolate mixture picture */ + register OBJREC *m, + RAY *r +) +{ + OBJECT obj; + double col[3], coef; + double pt[MAXDIM]; + DATARRAY *dp; + OBJECT mod[2]; + register MFUNC *mf; + register int i; + + if (m->oargs.nsargs < 7) + objerror(m, USER, "bad # arguments"); + obj = objndx(m); + for (i = 0; i < 2; i++) + if (!strcmp(m->oargs.sarg[i], VOIDID)) + mod[i] = OVOID; + else if ((mod[i] = lastmod(obj, m->oargs.sarg[i])) == OVOID) { + sprintf(errmsg, "undefined modifier \"%s\"", + m->oargs.sarg[i]); + objerror(m, USER, errmsg); + } + dp = getpict(m->oargs.sarg[3]); + mf = getfunc(m, 4, 0x3<<5, 0); + setfunc(m, r); + errno = 0; + pt[1] = evalue(mf->ep[0]); /* y major ordering */ + pt[0] = evalue(mf->ep[1]); + if (errno == EDOM || errno == ERANGE) + goto computerr; + for (i = 0; i < 3; i++) /* get pixel from picture */ + col[i] = datavalue(dp+i, pt); + errno = 0; /* evaluate function on pixel */ + coef = funvalue(m->oargs.sarg[2], 3, col); + if (errno == EDOM || errno == ERANGE) + goto computerr; + if (raymixture(r, mod[0], mod[1], coef)) { + if (m->omod != OVOID) + objerror(m, USER, "inappropriate modifier"); + return(1); + } + return(0); computerr: objerror(m, WARNING, "compute error"); + return(0); }
