root/radiance/ray/src/rt/mx_data.c
Revision: 2.8
Committed: Wed Mar 5 16:16:53 2003 UTC (21 years, 3 months ago) by greg
5 * mx_data.c - routine for stored mixtures.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11
12 #include "data.h"
13
14 #include "func.h"
15
16 /*
17 * A stored mixture is specified:
18 *
19 * modifier mixdata name
20 * 6+ foremod backmod func dfname vfname v0 v1 .. xf
21 * 0
22 * n A1 A2 ..
23 *
24 * A picture mixture is specified as:
25 *
26 * modifier mixpict name
27 * 7+ foremod backmod func pfname vfname vx vy xf
28 * 0
29 * n A1 A2 ..
30 *
31 *
32 * Vfname is the name of the file where the variable definitions
33 * can be found. The list of real arguments can be accessed by
34 * definitions in the file. Dfname is the data file.
35 * (Pfname is a picture file.)
36 * The dimensions of the data files and the number
37 * of variables must match. The func is a single argument
38 * function in the case of mixdata (three argument in the case
39 * of mixpict), which returns the corrected data value given the
40 * interpolated value from the file. The xf is a transformation
41 * to get from the original coordinates to the current coordinates.
42 */
43
44
45 mx_data(m, r) /* interpolate mixture data */
46 register OBJREC *m;
47 RAY *r;
48 {
49 OBJECT obj;
50 double coef;
51 double pt[MAXDIM];
52 DATARRAY *dp;
53 OBJECT mod[2];
54 register MFUNC *mf;
55 register int i;
56
57 if (m->oargs.nsargs < 6)
58 objerror(m, USER, "bad # arguments");
59 obj = objndx(m);
60 for (i = 0; i < 2; i++)
61 if (!strcmp(m->oargs.sarg[i], VOIDID))
62 mod[i] = OVOID;
63 else if ((mod[i] = lastmod(obj, m->oargs.sarg[i])) == OVOID) {
64 sprintf(errmsg, "undefined modifier \"%s\"",
65 m->oargs.sarg[i]);
66 objerror(m, USER, errmsg);
67 }
68 dp = getdata(m->oargs.sarg[3]);
69 i = (1 << dp->nd) - 1;
70 mf = getfunc(m, 4, i<<5, 0);
71 setfunc(m, r);
72 errno = 0;
73 for (i = 0; i < dp->nd; i++) {
74 pt[i] = evalue(mf->ep[i]);
75 if (errno == EDOM || errno == ERANGE)
76 goto computerr;
77 }
78 coef = datavalue(dp, pt);
79 errno = 0;
80 coef = funvalue(m->oargs.sarg[2], 1, &coef);
81 if (errno == EDOM || errno == ERANGE)
82 goto computerr;
83 if (raymixture(r, mod[0], mod[1], coef)) {
84 if (m->omod != OVOID)
85 objerror(m, USER, "inappropriate modifier");
86 return(1);
87 }
88 return(0);
89 computerr:
90 objerror(m, WARNING, "compute error");
91 return(0);
92 }
93
94
95 mx_pdata(m, r) /* interpolate mixture picture */
96 register OBJREC *m;
97 RAY *r;
98 {
99 OBJECT obj;
100 double col[3], coef;
101 double pt[MAXDIM];
102 DATARRAY *dp;
103 OBJECT mod[2];
104 register MFUNC *mf;
105 register int i;
106
107 if (m->oargs.nsargs < 7)
108 objerror(m, USER, "bad # arguments");
109 obj = objndx(m);
110 for (i = 0; i < 2; i++)
111 if (!strcmp(m->oargs.sarg[i], VOIDID))
112 mod[i] = OVOID;
113 else if ((mod[i] = lastmod(obj, m->oargs.sarg[i])) == OVOID) {
114 sprintf(errmsg, "undefined modifier \"%s\"",
115 m->oargs.sarg[i]);
116 objerror(m, USER, errmsg);
117 }
118 dp = getpict(m->oargs.sarg[3]);
119 mf = getfunc(m, 4, 0x3<<5, 0);
120 setfunc(m, r);
121 errno = 0;
122 pt[1] = evalue(mf->ep[0]); /* y major ordering */
123 pt[0] = evalue(mf->ep[1]);
124 if (errno == EDOM || errno == ERANGE)
125 goto computerr;
126 for (i = 0; i < 3; i++) /* get pixel from picture */
127 col[i] = datavalue(dp+i, pt);
128 errno = 0; /* evaluate function on pixel */
129 coef = funvalue(m->oargs.sarg[2], 3, col);
130 if (errno == EDOM || errno == ERANGE)
131 goto computerr;
132 if (raymixture(r, mod[0], mod[1], coef)) {
133 if (m->omod != OVOID)
134 objerror(m, USER, "inappropriate modifier");
135 return(1);
136 }
137 return(0);
138 computerr:
139 objerror(m, WARNING, "compute error");
140 return(0);
141 }
