--- ray/src/rt/mkpmap.c 2018/02/02 19:47:55 2.8 +++ ray/src/rt/mkpmap.c 2020/08/07 01:21:13 2.10 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mkpmap.c,v 2.8 2018/02/02 19:47:55 rschregle Exp $"; +static const char RCSid[] = "$Id: mkpmap.c,v 2.10 2020/08/07 01:21:13 rschregle Exp $"; #endif @@ -9,17 +9,21 @@ static const char RCSid[] = "$Id: mkpmap.c,v 2.8 2018/ Roland Schregle (roland.schregle@{hslu.ch, gmail.com}) (c) Fraunhofer Institute for Solar Energy Systems, - Lucerne University of Applied Sciences & Arts + supported by the German Research Foundation (DFG) + under the FARESYS project. (c) Lucerne University of Applied Sciences and Arts, - supported by the Swiss National Science Foundation (SNSF, #147053) + supported by the Swiss National Science Foundation (SNSF #147053). + (c) Tokyo University of Science, + supported by the JSPS KAKENHI Grant Number JP19KK0115. ====================================================================== - $Id: mkpmap.c,v 2.8 2018/02/02 19:47:55 rschregle Exp $ + $Id: mkpmap.c,v 2.10 2020/08/07 01:21:13 rschregle Exp $ */ #include "pmap.h" #include "pmapmat.h" +#include "pmapsrc.h" #include "pmapcontrib.h" #include "pmaprand.h" #include "paths.h" @@ -49,8 +53,8 @@ int clobber = 0; /* overwrite outpu COLOR cextinction = BLKCOLOR; /* global extinction coefficient */ COLOR salbedo = BLKCOLOR; /* global scattering albedo */ double seccg = 0; /* global scattering eccentricity */ -int ambincl = -1; /* photon port flag */ -char *amblist [AMBLLEN + 1]; /* photon port list */ +char *amblist [AMBLLEN + 1]; /* ambient include/exclude list */ +int ambincl = -1; /* include == 1, exclude == 0 */ char *diagFile = NULL; /* diagnostics output file */ int rand_samp = 1; /* uncorrelated random sampling */ unsigned nproc = 1; /* number of parallel processes */ @@ -80,6 +84,10 @@ void printdefaults() /* EvalDRC support */ puts("-A\t\t\t\t# angular source file"); #endif + puts("-ae mod\t\t\t\t# exclude modifier"); + puts("-aE file\t\t\t\t# exclude modifiers from file"); + puts("-ai mod\t\t\t\t# include modifier"); + puts("-aI file\t\t\t\t# include modifiers from file"); #ifdef PMAP_EKSPERTZ puts("-api xmin ymin zmin xmax ymax zmax\t# region of interest"); #endif @@ -92,15 +100,15 @@ void printdefaults() printf("-apD %f\t\t\t\t# predistribution factor\n", preDistrib); printf("-apM %d\t\t\t\t\t# max predistrib passes\n", maxPreDistrib); #if 1 - /* Kept for backwards compat, will be gradually phased out by -lD, -lr */ + /* Kept for backwards compat, will be gradually phased out by -ld, -lr */ printf("-apm %ld\t\t\t\t# limit photon bounces\n", photonMaxBounce); #endif - puts("-apo mod\t\t\t\t# photon port modifier"); - puts("-apO file\t\t\t\t# photon port file"); + puts("-apo+ mod\t\t\t\t# photon port modifier"); + puts("-apO+ file\t\t\t\t# photon ports from file"); printf("-apP %f\t\t\t\t# precomputation factor\n", finalGather); printf("-apr %d\t\t\t\t\t# random seed\n", randSeed); puts("-aps mod\t\t\t\t# antimatter sensor modifier"); - puts("-apS file\t\t\t\t# antimatter sensor file"); + puts("-apS file\t\t\t\t# antimatter sensors from file"); printf(backvis ? "-bv+\t\t\t\t\t# back face visibility on\n" : "-bv-\t\t\t\t\t# back face visibility off\n"); @@ -110,7 +118,7 @@ void printdefaults() printf(clobber ? "-fo+\t\t\t\t\t# force overwrite\n" : "-fo-\t\t\t\t\t# do not overwrite\n"); #ifdef PMAP_EKSPERTZ - /* NU STUFF for Ze Exspertz! */ + /* (Formerly) NU STUFF for Ze Exspertz! */ printf("-ld %.1f\t\t\t\t\t# limit photon distance\n", photonMaxDist); printf("-lr %ld\t\t\t\t# limit photon bounces\n", photonMaxBounce); #endif @@ -121,7 +129,7 @@ void printdefaults() colval(cextinction,BLU)); printf("-mg %.2f\t\t\t\t# scattering eccentricity\n", seccg); #if NIX - /* Multiprocessing on NIX only */ + /* Multiprocessing on NIX only; so tuff luck, Windoze Weenies! */ printf("-n %d\t\t\t\t\t# number of parallel processes\n", nproc); #endif printf("-t %-9d\t\t\t\t# time between reports\n", photonRepTime); @@ -132,22 +140,39 @@ void printdefaults() int main (int argc, char* argv []) { - #define check(ol, al) if (argv [i][ol] || \ - badarg(argc - i - 1,argv + i + 1, al)) \ - goto badopt - + #define check(ol, al) if ( \ + argv [i][ol] || badarg(argc - i - 1,argv + i + 1, al) \ + ) goto badopt + + /* Evaluate boolean option, setting var accordingly */ #define check_bool(olen, var) switch (argv [i][olen]) { \ - case '\0': var = !var; break; \ - case 'y': case 'Y': case 't': case 'T': \ - case '+': case '1': var = 1; break; \ - case 'n': case 'N': case 'f': case 'F': \ - case '-': case '0': var = 0; break; \ - default: goto badopt; \ - } + case '\0': \ + var = !var; break; \ + case 'y': case 'Y': case 't': case 'T': case '+': case '1': \ + var = 1; break; \ + case 'n': case 'N': case 'f': case 'F': case '-': case '0': \ + var = 0; break; \ + default: \ + goto badopt; \ + } + + /* Evaluate trinary option, setting bits v1 and v2 in var accordingly */ + #define check_tri(olen, v1, v2, var) switch (argv [i][olen]) { \ + case '\0': case '+': \ + var = v1; break; \ + case '-': \ + var = v2; break;\ + case '0': \ + var = v1 | v2; break; \ + default: \ + goto badopt; \ + } - int loadflags = IO_CHECK | IO_SCENE | IO_TREE | IO_BOUNDS, rval, i; - char **portLp = NULL, **sensLp = photonSensorList; - struct stat pmstat; + int loadflags = IO_CHECK | IO_SCENE | IO_TREE | IO_BOUNDS, + rval, i, j, n; + char **portLp = photonPortList, **sensLp = photonSensorList, + **amblp = NULL, sbuf [MAXSTR], portFlags [2] = "\0\0"; + struct stat pmstat; /* Global program name */ progname = fixargv0(argv [0]); @@ -183,202 +208,268 @@ int main (int argc, char* argv []) } switch (argv [i][1]) { - case 'a': - if (!strcmp(argv [i] + 2, "pg")) { - /* Global photon map */ - check(4, "ss"); - globalPmapParams.fileName = argv [++i]; - globalPmapParams.distribTarget = - parseMultiplier(argv [++i]); - if (!globalPmapParams.distribTarget) - goto badopt; - globalPmapParams.minGather = globalPmapParams.maxGather = 0; - } + case 'a': /* Ambient */ + switch (argv [i][2]) { + case 'i': /* Ambient include */ + case 'I': + check(3, "s"); + if (ambincl != 1) { + ambincl = 1; + amblp = amblist; + } + if (argv [i][2] == 'I') { + /* Add modifiers from file */ + rval = wordfile(amblp, AMBLLEN - (amblp - amblist), + getpath(argv [++i], + getrlibpath(), R_OK)); + if (rval < 0) { + sprintf(errmsg, + "cannot open ambient include file \"%s\"", + argv [i]); + error(SYSTEM, errmsg); + } + amblp += rval; + } + else { + /* Add modifier from next arg */ + *amblp++ = savqstr(argv [++i]); + *amblp = NULL; + } + break; + + case 'e': /* Ambient exclude */ + case 'E': + check(3, "s"); + if (ambincl != 0) { + ambincl = 0; + amblp = amblist; + } + if (argv [i][2] == 'E') { + /* Add modifiers from file */ + rval = wordfile(amblp, AMBLLEN - (amblp - amblist), + getpath(argv [++i], + getrlibpath(), R_OK)); + if (rval < 0) { + sprintf(errmsg, + "cannot open ambient exclude file \"%s\"", + argv [i]); + error(SYSTEM, errmsg); + } + amblp += rval; + } + else { + /* Add modifier from next arg */ + *amblp++ = savqstr(argv [++i]); + *amblp = NULL; + } + break; - else if (!strcmp(argv [i] + 2, "pp")) { - /* Precomputed global photon map */ - check(4, "ssi"); - preCompPmapParams.fileName = argv [++i]; - preCompPmapParams.distribTarget = - parseMultiplier(argv [++i]); - if (!preCompPmapParams.distribTarget) - goto badopt; - preCompPmapParams.minGather = preCompPmapParams.maxGather = - atoi(argv [++i]); - if (!preCompPmapParams.maxGather) - goto badopt; - } + case 'p': /* Pmap-specific */ + switch (argv [i][3]) { + case 'g': /* Global photon map */ + check(4, "ss"); + globalPmapParams.fileName = argv [++i]; + globalPmapParams.distribTarget = + parseMultiplier(argv [++i]); + if (!globalPmapParams.distribTarget) + goto badopt; + globalPmapParams.minGather = + globalPmapParams.maxGather = 0; + break; - else if (!strcmp(argv [i] + 2, "pc")) { - /* Caustic photon map */ - check(4, "ss"); - causticPmapParams.fileName = argv [++i]; - causticPmapParams.distribTarget = - parseMultiplier(argv [++i]); - if (!causticPmapParams.distribTarget) - goto badopt; - } + case 'p': /* Precomputed global photon map */ + check(4, "ssi"); + preCompPmapParams.fileName = argv [++i]; + preCompPmapParams.distribTarget = + parseMultiplier(argv [++i]); + if (!preCompPmapParams.distribTarget) + goto badopt; + preCompPmapParams.minGather = + preCompPmapParams.maxGather = atoi(argv [++i]); + if (!preCompPmapParams.maxGather) + goto badopt; + break; - else if (!strcmp(argv [i] + 2, "pv")) { - /* Volume photon map */ - check(4, "ss"); - volumePmapParams.fileName = argv [++i]; - volumePmapParams.distribTarget = - parseMultiplier(argv [++i]); - if (!volumePmapParams.distribTarget) - goto badopt; - } - - else if (!strcmp(argv [i] + 2, "pd")) { - /* Direct photon map */ - check(4, "ss"); - directPmapParams.fileName = argv [++i]; - directPmapParams.distribTarget = - parseMultiplier(argv [++i]); - if (!directPmapParams.distribTarget) - goto badopt; - } - - else if (!strcmp(argv [i] + 2, "pC")) { - /* Light source contribution photon map */ - check(4, "ss"); - contribPmapParams.fileName = argv [++i]; - contribPmapParams.distribTarget = - parseMultiplier(argv [++i]); - if (!contribPmapParams.distribTarget) - goto badopt; - } + case 'c': /* Caustic photon map */ + check(4, "ss"); + causticPmapParams.fileName = argv [++i]; + causticPmapParams.distribTarget = + parseMultiplier(argv [++i]); + if (!causticPmapParams.distribTarget) + goto badopt; + break; + + case 'v': /* Volume photon map */ + check(4, "ss"); + volumePmapParams.fileName = argv [++i]; + volumePmapParams.distribTarget = + parseMultiplier(argv [++i]); + if (!volumePmapParams.distribTarget) + goto badopt; + break; + + case 'd': /* Direct photon map */ + check(4, "ss"); + directPmapParams.fileName = argv [++i]; + directPmapParams.distribTarget = + parseMultiplier(argv [++i]); + if (!directPmapParams.distribTarget) + goto badopt; + break; + + case 'C': /* Contribution photon map */ + check(4, "ss"); + contribPmapParams.fileName = argv [++i]; + contribPmapParams.distribTarget = + parseMultiplier(argv [++i]); + if (!contribPmapParams.distribTarget) + goto badopt; + break; - else if (!strcmp(argv [i] + 2, "pD")) { - /* Predistribution factor */ - check(4, "f"); - preDistrib = atof(argv [++i]); - if (preDistrib <= 0) - error(USER, "predistribution factor must be > 0"); - } + case 'D': /* Predistribution factor */ + check(4, "f"); + preDistrib = atof(argv [++i]); + if (preDistrib <= 0) + error(USER, "predistrib factor must be > 0"); + break; - else if (!strcmp(argv [i] + 2, "pM")) { - /* Max predistribution passes */ - check(4, "i"); - maxPreDistrib = atoi(argv [++i]); - if (maxPreDistrib <= 0) - error(USER, "max predistribution passes must be > 0"); - } + case 'M': /* Max predistribution passes */ + check(4, "i"); + maxPreDistrib = atoi(argv [++i]); + if (maxPreDistrib <= 0) + error(USER, "max predistrib passes must be > 0"); + break; + #if 1 - /* Kept for backwards compat, to be phased out by -lr */ - else if (!strcmp(argv [i] + 2, "pm")) { - /* Max photon bounces */ - check(4, "i"); - photonMaxBounce = atol(argv [++i]); - if (photonMaxBounce <= 0) - error(USER, "max photon bounces must be > 0"); - } + /* Kept for backwards compat, to be phased out by -lr */ + case 'm': /* Max photon bounces */ + check(4, "i"); + photonMaxBounce = atol(argv [++i]); + if (photonMaxBounce <= 0) + error(USER, "max photon bounces must be > 0"); + break; #endif -#ifdef PMAP_EKSPERTZ - /* Add region of interest; for Ze Ekspertz only! */ - else if (!strcmp(argv [i] + 2, "pi")) { - unsigned j, n = pmapNumROI; - check(4, "ffffff"); - - pmapROI = realloc(pmapROI, - ++pmapNumROI * sizeof(PhotonMapROI)); - if (!pmapROI) - error(SYSTEM, "failed to allocate ROI"); - - pmapROI [n].min [0] = atof(argv [++i]); - pmapROI [n].min [1] = atof(argv [++i]); - pmapROI [n].min [2] = atof(argv [++i]); - pmapROI [n].max [0] = atof(argv [++i]); - pmapROI [n].max [1] = atof(argv [++i]); - pmapROI [n].max [2] = atof(argv [++i]); - - for (j = 0; j < 3; j++) - if (pmapROI [n].min [j] >= pmapROI [n].max [j]) - error(USER, - "invalid region of interest (swapped min/max?)"); - } + +#ifdef PMAP_EKSPERTZ + case 'i': /* Add region of interest */ + check(4, "ffffff"); + n = pmapNumROI; + pmapROI = realloc(pmapROI, + ++pmapNumROI * sizeof(PhotonMapROI)); + if (!pmapROI) + error(SYSTEM, "failed to allocate ROI"); + pmapROI [n].min [0] = atof(argv [++i]); + pmapROI [n].min [1] = atof(argv [++i]); + pmapROI [n].min [2] = atof(argv [++i]); + pmapROI [n].max [0] = atof(argv [++i]); + pmapROI [n].max [1] = atof(argv [++i]); + pmapROI [n].max [2] = atof(argv [++i]); + for (j = 0; j < 3; j++) + if (pmapROI [n].min [j] >= pmapROI [n].max [j]) + error(USER, "invalid region of interest " + "(swapped min/max?)"); + break; #endif - else if (!strcmp(argv [i] + 2, "pP")) { - /* Global photon precomputation factor */ - check(4, "f"); - finalGather = atof(argv [++i]); - if (finalGather <= 0 || finalGather > 1) - error(USER, "global photon precomputation factor " - "must be in range ]0, 1]"); - } - - else if (!strcmp(argv [i] + 2, "po") || - !strcmp(argv [i] + 2, "pO")) { - /* Photon port */ - check(4, "s"); - - if (ambincl != 1) { - ambincl = 1; - portLp = amblist; - } - - if (argv[i][3] == 'O') { - /* Get port modifiers from file */ - rval = wordfile(portLp, AMBLLEN-(portLp-amblist), - getpath(argv [++i], getrlibpath(), R_OK)); - - if (rval < 0) { - sprintf(errmsg, "cannot open photon port file %s", - argv [i]); - error(SYSTEM, errmsg); - } - - portLp += rval; - } - - else { - /* Append modifier to port list */ - *portLp++ = argv [++i]; - *portLp = NULL; - } - } - - else if (!strcmp(argv [i] + 2, "pr")) { - /* Random seed */ - check(4, "i"); - randSeed = atoi(argv [++i]); - } - else if (!strcmp(argv [i] + 2, "ps") || - !strcmp(argv [i] + 2, "pS")) { - /* Antimatter sensor */ - check(4, "s"); - - if (argv[i][3] == 'S') { - /* Get sensor modifiers from file */ - rval = wordfile(sensLp, MAXSET-(sensLp-photonSensorList), - getpath(argv [++i], getrlibpath(), R_OK)); - - if (rval < 0) { - sprintf(errmsg, "cannot open antimatter sensor file %s", - argv [i]); - error(SYSTEM, errmsg); + case 'P': /* Global photon precomp ratio */ + check(4, "f"); + finalGather = atof(argv [++i]); + if (finalGather <= 0 || finalGather > 1) + error(USER, "global photon precomputation ratio " + "must be in range ]0, 1]"); + break; + + case 'o': /* Photon port */ + case 'O': + /* Check for bad arg and length, taking into account + * default forward orientation if none specified, in + * order to maintain previous behaviour */ + check(argv [i][4] ? 5 : 4, "s"); + /* Get port orientation flags */ + check_tri( + 4, PMAP_PORTFWD, PMAP_PORTBWD, portFlags [0] + ); + + if (argv [i][3] == 'O') { + /* Add port modifiers from file */ + rval = wordfile( + portLp, MAXSET - (portLp - photonPortList), + getpath(argv [++i], getrlibpath(), R_OK) + ); + if (rval < 0) { + sprintf( + errmsg, "cannot open photon port file %s", + argv [i] + ); + error(SYSTEM, errmsg); + } + /* HACK: append port orientation flags to every + * modifier; note this requires reallocation */ + for (; rval--; portLp++) { + j = strlen(*portLp); + if (!(*portLp = realloc(*portLp, j + 2))) { + sprintf( + errmsg, + "cannot allocate photon port modifiers" + " from file %s", argv [i] + ); + error(SYSTEM, errmsg); + } + strcat(*portLp, portFlags); + } + } + else { + /* Append port flags to port modifier, add to + * port list and mark of end list with NULL */ + strcpy(sbuf, argv [++i]); + strcat(sbuf, portFlags); + *portLp++ = savqstr(sbuf); + *portLp = NULL; + } + break; + + case 'r': /* Random seed */ + check(4, "i"); + randSeed = atoi(argv [++i]); + break; + + case 's': /* Antimatter sensor */ + case 'S': + check(4, "s"); + if (argv[i][3] == 'S') { + /* Add sensor modifiers from file */ + rval = wordfile(sensLp, + MAXSET - (sensLp - photonSensorList), + getpath(argv [++i], + getrlibpath(), R_OK)); + if (rval < 0) { + sprintf(errmsg, + "cannot open antimatter sensor file %s", + argv [i]); + error(SYSTEM, errmsg); + } + sensLp += rval; + } + else { + /* Append modifier to sensor list, mark end with + * NULL */ + *sensLp++ = savqstr(argv [++i]); + *sensLp = NULL; + } + break; + + default: goto badopt; } + break; - sensLp += rval; - } - - else { - /* Append modifier to sensor list */ - *sensLp++ = argv [++i]; - *sensLp = NULL; - } + default: goto badopt; } - - else goto badopt; break; - - case 'b': + + case 'b': /* Back face visibility */ if (argv [i][2] == 'v') { - /* Back face visibility */ check_bool(3, backvis); } - else goto badopt; break; @@ -403,14 +494,13 @@ int main (int argc, char* argv []) diagFile = argv [++i]; break; - case 'f': + case 'f': /* Force overwrite */ if (argv [i][2] == 'o') { - /* Force overwrite */ check_bool(3, clobber); } - else goto badopt; break; + #ifdef PMAP_EKSPERTZ case 'l': /* Limits */ switch (argv [i][2]) { @@ -432,6 +522,7 @@ int main (int argc, char* argv []) } break; #endif + case 'm': /* Medium */ switch (argv[i][2]) { case 'e': /* Eggs-tinction coefficient */ @@ -456,6 +547,7 @@ int main (int argc, char* argv []) default: goto badopt; } break; + #if NIX case 'n': /* Num parallel processes (NIX only) */ check(2, "i"); @@ -468,7 +560,8 @@ int main (int argc, char* argv []) error(WARNING, errmsg); } break; -#endif +#endif + case 't': /* Timer */ check(2, "i"); photonRepTime = atoi(argv [++i]); @@ -476,14 +569,16 @@ int main (int argc, char* argv []) case 'v': /* Verbosity */ check_bool(2, verbose); - break; + break; + #ifdef EVALDRC_HACK case 'A': /* Angular source file */ check(2,"s"); angsrcfile = argv[++i]; break; -#endif - default: goto badopt; +#endif + + default: goto badopt; } }
