root/radiance/ray/src/rt/mkpmap.c
Fri Aug 7 01:21:13 2020 UTC (4 years, 8 months ago) by rschregle
Changes since 2.9: +80 -37 lines
feat(mkpmap): Extended -apo option to reorient photon ports.
Tue Mar 20 19:55:33 2018 UTC (7 years, 1 month ago) by rschregle
Changes since 2.8: +248 -196 lines
Added -ae/-ai ambient exclude options to mkpmap, cleaned up opt parsing.
Fri Feb 2 19:47:55 2018 UTC (7 years, 3 months ago) by rschregle
Changes since 2.7: +89 -58 lines
Added -lr, -ld options to mkpmap, enabled -api
Sat Dec 9 18:38:57 2017 UTC (7 years, 4 months ago) by rschregle
Fixed typo in ROI option parsing
Mon Aug 14 21:12:10 2017 UTC (7 years, 8 months ago) by rschregle
Changes since 2.5: +53 -71 lines
Updated photon map code for Windows; no multproc or ooC for now
Tue May 17 17:39:47 2016 UTC (8 years, 11 months ago) by rschregle
Changes since 2.4: +76 -25 lines
Mon Mar 21 19:06:08 2016 UTC (9 years, 1 month ago) by greg
Changes since 2.3: +5 -5 lines
Thu Mar 10 18:25:46 2016 UTC (9 years, 1 month ago) by schorsch
newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Thu May 21 05:54:54 2015 UTC (9 years, 11 months ago) by greg
Tue Feb 24 19:39:26 2015 UTC (10 years, 2 months ago) by greg
Diff to selected 2.5
