--- ray/src/rt/mkpmap.c 2017/12/09 18:38:57 2.7 +++ ray/src/rt/mkpmap.c 2018/02/02 19:47:55 2.8 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: mkpmap.c,v 2.7 2017/12/09 18:38:57 rschregle Exp $"; +static const char RCSid[] = "$Id: mkpmap.c,v 2.8 2018/02/02 19:47:55 rschregle Exp $"; #endif @@ -14,7 +14,7 @@ static const char RCSid[] = "$Id: mkpmap.c,v 2.7 2017/ supported by the Swiss National Science Foundation (SNSF, #147053) ====================================================================== - $Id: mkpmap.c,v 2.7 2017/12/09 18:38:57 rschregle Exp $ + $Id: mkpmap.c,v 2.8 2018/02/02 19:47:55 rschregle Exp $ */ @@ -30,6 +30,10 @@ static const char RCSid[] = "$Id: mkpmap.c,v 2.7 2017/ #include +/* Enable options for Ze Ekspertz only! */ +#define PMAP_EKSPERTZ + + extern char VersionID []; @@ -71,51 +75,58 @@ void (*trace)() = NULL, (*addobjnotify [])() = {ambnot void printdefaults() /* print default values to stdout */ { - puts("-apg file nPhotons\t\t# global photon map"); - puts("-apc file nPhotons\t\t# caustic photon map"); - puts("-apd file nPhotons\t\t# direct photon map"); - puts("-app file nPhotons bwidth\t# precomputed global photon map"); - puts("-apv file nPhotons\t\t# volume photon map"); - puts("-apC file nPhotons\t\t# contribution photon map"); - - printf("-apD %f\t\t\t# predistribution factor\n", preDistrib); - printf("-apM %d\t\t\t\t# max predistrib passes\n", maxPreDistrib); - printf("-apm %ld\t\t\t# max photon bounces\n", photonMaxBounce); - puts("-apo mod\t\t\t# photon port modifier"); - puts("-apO file\t\t\t# photon port file"); - printf("-apP %f\t\t\t# precomputation factor\n", finalGather); - printf("-apr %d\t\t\t\t# random seed\n", randSeed); - puts("-aps mod\t\t\t# antimatter sensor modifier"); - puts("-apS file\t\t\t# antimatter sensor file"); - printf(backvis ? "-bv+\t\t\t\t# back face visibility on\n" - : "-bv-\t\t\t\t# back face visibility off\n"); - printf("-dp %.1f\t\t\t# PDF samples / sr\n", pdfSamples); - printf("-ds %f\t\t\t# source partition size ratio\n", srcsizerat); - printf("-e %s\t\t\t# diagnostics output file\n", diagFile); - printf(clobber ? "-fo+\t\t\t\t# force overwrite\n" - : "-fo-\t\t\t\t# do not overwrite\n"); - printf("-ma %.2f %.2f %.2f\t\t# scattering albedo\n", +#ifdef EVALDRC_HACK + /* EvalDRC support */ + puts("-A\t\t\t\t# angular source file"); +#endif +#ifdef PMAP_EKSPERTZ + puts("-api xmin ymin zmin xmax ymax zmax\t# region of interest"); +#endif + puts("-apg file nPhotons\t\t\t# global photon map"); + puts("-apc file nPhotons\t\t\t# caustic photon map"); + puts("-apd file nPhotons\t\t\t# direct photon map"); + puts("-app file nPhotons bwidth\t\t# precomputed global photon map"); + puts("-apv file nPhotons\t\t\t# volume photon map"); + puts("-apC file nPhotons\t\t\t# contribution photon map"); + printf("-apD %f\t\t\t\t# predistribution factor\n", preDistrib); + printf("-apM %d\t\t\t\t\t# max predistrib passes\n", maxPreDistrib); +#if 1 + /* Kept for backwards compat, will be gradually phased out by -lD, -lr */ + printf("-apm %ld\t\t\t\t# limit photon bounces\n", photonMaxBounce); +#endif + puts("-apo mod\t\t\t\t# photon port modifier"); + puts("-apO file\t\t\t\t# photon port file"); + printf("-apP %f\t\t\t\t# precomputation factor\n", finalGather); + printf("-apr %d\t\t\t\t\t# random seed\n", randSeed); + puts("-aps mod\t\t\t\t# antimatter sensor modifier"); + puts("-apS file\t\t\t\t# antimatter sensor file"); + + printf(backvis ? "-bv+\t\t\t\t\t# back face visibility on\n" + : "-bv-\t\t\t\t\t# back face visibility off\n"); + printf("-dp %.1f\t\t\t\t# PDF samples / sr\n", pdfSamples); + printf("-ds %f\t\t\t\t# source partition size ratio\n", srcsizerat); + printf("-e %s\t\t\t\t# diagnostics output file\n", diagFile); + printf(clobber ? "-fo+\t\t\t\t\t# force overwrite\n" + : "-fo-\t\t\t\t\t# do not overwrite\n"); +#ifdef PMAP_EKSPERTZ + /* NU STUFF for Ze Exspertz! */ + printf("-ld %.1f\t\t\t\t\t# limit photon distance\n", photonMaxDist); + printf("-lr %ld\t\t\t\t# limit photon bounces\n", photonMaxBounce); +#endif + printf("-ma %.2f %.2f %.2f\t\t\t# scattering albedo\n", colval(salbedo,RED), colval(salbedo,GRN), colval(salbedo,BLU)); - printf("-me %.2e %.2e %.2e\t# extinction coefficient\n", + printf("-me %.2e %.2e %.2e\t\t# extinction coefficient\n", colval(cextinction,RED), colval(cextinction,GRN), colval(cextinction,BLU)); - printf("-mg %.2f\t\t\t# scattering eccentricity\n", seccg); + printf("-mg %.2f\t\t\t\t# scattering eccentricity\n", seccg); #if NIX /* Multiprocessing on NIX only */ - printf("-n %d\t\t\t\t# number of parallel processes\n", nproc); + printf("-n %d\t\t\t\t\t# number of parallel processes\n", nproc); #endif - printf("-t %-9d\t\t\t# time between reports\n", photonRepTime); - printf(verbose ? "-v+\t\t\t\t# verbose console output\n" - : "-v-\t\t\t\t# terse console output\n"); -#ifdef PMAP_ROI - /* Ziss option for ze egg-spurtz only! */ - puts("-api xmin ymin zmin\n xmax ymax zmax\t\t# region of interest"); -#endif -#ifdef EVALDRC_HACK - /* ... and ziss one... */ - puts("-A\t\t\t\t# angular source file"); -#endif + printf("-t %-9d\t\t\t\t# time between reports\n", photonRepTime); + printf(verbose ? "-v+\t\t\t\t\t# verbose console output\n" + : "-v-\t\t\t\t\t# terse console output\n"); } @@ -182,15 +193,7 @@ int main (int argc, char* argv []) if (!globalPmapParams.distribTarget) goto badopt; globalPmapParams.minGather = globalPmapParams.maxGather = 0; - } - - else if (!strcmp(argv [i] + 2, "pm")) { - /* Max photon bounces */ - check(4, "i"); - photonMaxBounce = atol(argv [++i]); - if (photonMaxBounce <= 0) - error(USER, "max photon bounces must be > 0"); - } + } else if (!strcmp(argv [i] + 2, "pp")) { /* Precomputed global photon map */ @@ -245,7 +248,7 @@ int main (int argc, char* argv []) if (!contribPmapParams.distribTarget) goto badopt; } - + else if (!strcmp(argv [i] + 2, "pD")) { /* Predistribution factor */ check(4, "f"); @@ -253,7 +256,7 @@ int main (int argc, char* argv []) if (preDistrib <= 0) error(USER, "predistribution factor must be > 0"); } - + else if (!strcmp(argv [i] + 2, "pM")) { /* Max predistribution passes */ check(4, "i"); @@ -261,9 +264,18 @@ int main (int argc, char* argv []) if (maxPreDistrib <= 0) error(USER, "max predistribution passes must be > 0"); } - -#ifdef PMAP_ROI - /* Add region of interest; for ze egg-spurtz only! */ +#if 1 + /* Kept for backwards compat, to be phased out by -lr */ + else if (!strcmp(argv [i] + 2, "pm")) { + /* Max photon bounces */ + check(4, "i"); + photonMaxBounce = atol(argv [++i]); + if (photonMaxBounce <= 0) + error(USER, "max photon bounces must be > 0"); + } +#endif +#ifdef PMAP_EKSPERTZ + /* Add region of interest; for Ze Ekspertz only! */ else if (!strcmp(argv [i] + 2, "pi")) { unsigned j, n = pmapNumROI; check(4, "ffffff"); @@ -285,8 +297,7 @@ int main (int argc, char* argv []) error(USER, "invalid region of interest (swapped min/max?)"); } -#endif - +#endif else if (!strcmp(argv [i] + 2, "pP")) { /* Global photon precomputation factor */ check(4, "f"); @@ -400,7 +411,27 @@ int main (int argc, char* argv []) else goto badopt; break; - +#ifdef PMAP_EKSPERTZ + case 'l': /* Limits */ + switch (argv [i][2]) { + case 'd': /* Limit photon path distance */ + check(3, "f"); + photonMaxDist = atof(argv [++i]); + if (photonMaxDist <= 0) + error(USER, "max photon distance must be > 0"); + break; + + case 'r': /* Limit photon bounces */ + check(3, "i"); + photonMaxBounce = atol(argv [++i]); + if (photonMaxBounce <= 0) + error(USER, "max photon bounces must be > 0"); + break; + + default: goto badopt; + } + break; +#endif case 'm': /* Medium */ switch (argv[i][2]) { case 'e': /* Eggs-tinction coefficient */
