root/Development/ray/src/rt/mkpmap.c
Fri Jun 20 03:43:17 2025 UTC (4 months, 3 weeks ago) by greg
CVS Tags: HEAD, rad6R0
Changes since 2.14: +4 -3 lines
Diff to previous 2.14
fix(rvu): Issue with live reset of -u boolean and consistency improvements
Thu Jun 5 18:28:25 2025 UTC (5 months ago) by greg
Changes since 2.13: +2 -3 lines
Diff to previous 2.13
fix(mkpman): Removed redundant progname definition
Wed Apr 23 02:13:34 2025 UTC (6 months, 2 weeks ago) by greg
Changes since 2.12: +6 -3 lines
Diff to previous 2.12
fix(mkpmap): Added missing call to initialize functions
Wed Aug 21 20:42:20 2024 UTC (14 months, 2 weeks ago) by greg
refactor: moved memory sharing routines to preload.c with common call interface
Wed Apr 14 11:26:25 2021 UTC (4 years, 6 months ago) by rschregle
Changes since 2.10: +151 -89 lines
feat(mkpmap): Added -apI option for spherical ROI
Fri Aug 7 01:21:13 2020 UTC (5 years, 3 months ago) by rschregle
Changes since 2.9: +80 -37 lines
feat(mkpmap): Extended -apo option to reorient photon ports.
Tue Mar 20 19:55:33 2018 UTC (7 years, 7 months ago) by rschregle
Changes since 2.8: +248 -196 lines
Added -ae/-ai ambient exclude options to mkpmap, cleaned up opt parsing.
Fri Feb 2 19:47:55 2018 UTC (7 years, 9 months ago) by rschregle
Changes since 2.7: +89 -58 lines
Added -lr, -ld options to mkpmap, enabled -api
Sat Dec 9 18:38:57 2017 UTC (7 years, 11 months ago) by rschregle
Fixed typo in ROI option parsing
Mon Aug 14 21:12:10 2017 UTC (8 years, 2 months ago) by rschregle
Changes since 2.5: +53 -71 lines
Updated photon map code for Windows; no multproc or ooC for now
Tue May 17 17:39:47 2016 UTC (9 years, 5 months ago) by rschregle
Changes since 2.4: +76 -25 lines
Mon Mar 21 19:06:08 2016 UTC (9 years, 7 months ago) by greg
Changes since 2.3: +5 -5 lines
Thu Mar 10 18:25:46 2016 UTC (9 years, 8 months ago) by schorsch
newer C++ compilers have a standard type named "bool". rename macro to get rid of warnings.
Thu May 21 05:54:54 2015 UTC (10 years, 5 months ago) by greg
Tue Feb 24 19:39:26 2015 UTC (10 years, 8 months ago) by greg
