--- ray/src/rt/m_wgmdf.c 2024/12/09 00:44:29 2.1 +++ ray/src/rt/m_wgmdf.c 2024/12/19 23:25:28 2.8 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: m_wgmdf.c,v 2.1 2024/12/09 00:44:29 greg Exp $"; +static const char RCSid[] = "$Id: m_wgmdf.c,v 2.8 2024/12/19 23:25:28 greg Exp $"; #endif /* * Shading function for programmable Ward-Geisler-Moroder-Duer material. @@ -158,6 +158,29 @@ fill_modval(MODVAL *mp, const WGMDDAT *wp) return(set_modval(mp, lastmod(objndx(wp->mtp), mp->nam), wp->rp)); } +/* set calculation context for given component of MAT_WGMDF */ +static int +setWGMDfunc(MODVAL *mp, const WGMDDAT *wp) +{ + static char lastMod[MAXSTR]; + double sf; + FVECT vec; + + if (setfunc(wp->mtp, wp->rp) == 0 && + !strcmp(mp->nam, lastMod)) + return(0); /* already set */ + strcpy(lastMod, mp->nam); + /* else (re)assign special variables */ + sf = 1 - 2*(wp->rp->rod < 0); + varset("RdotP`", '=', mp->pdot*sf); + multv3(vec, mp->pnorm, funcxf.xfm); + sf /= funcxf.sca; + varset("NxP`", '=', vec[0]*sf); + varset("NyP`", '=', vec[1]*sf); + varset("NzP`", '=', vec[2]*sf); + return(1); +} + /* assign indicated diffuse component (do !trans first) */ static void set_dcomp(WGMDDAT *wp, int trans) @@ -190,50 +213,45 @@ set_dcomp(WGMDDAT *wp, int trans) static void set_scomp(WGMDDAT *wp, int trans) { - SCOMP *sp = trans ? &wp->ts : &wp->rs; - const int eoff = 3*(trans != 0); - double coef; - - setfunc(wp->mtp, wp->rp); /* get coefficient, first */ - errno = 0; - coef = evalue(wp->mf->ep[eoff]); - if ((errno == EDOM) | (errno == ERANGE)) { - objerror(wp->mtp, WARNING, "specular compute error"); - scolorblack(sp->scol); - return; - } - if (coef <= FTINY) { /* negligible value? */ - scolorblack(sp->scol); - return; - } /* else get modifier */ + SCOMP *sp = trans ? &wp->ts : &wp->rs; + EPNODE **exa = wp->mf->ep + 3*(trans != 0); + double coef; + /* constant zero check */ + if (exa[0]->type == NUM && exa[0]->v.num <= FTINY) + goto blackout; + /* need modifier */ sp->mo.nam = wp->mtp->oargs.sarg[4*(trans != 0)]; if (!fill_modval(&sp->mo, wp)) { sprintf(errmsg, "unknown specular %s modifier '%s'", trans ? "transmission" : "reflection", sp->mo.nam); objerror(wp->mtp, USER, errmsg); } + if (sintens(sp->mo.pcol) <= FTINY) + goto blackout; /* got black pattern */ + setWGMDfunc(&sp->mo, wp); /* else compute coefficient */ + errno = 0; + coef = evalue(exa[0]); + if ((errno == EDOM) | (errno == ERANGE)) { + objerror(wp->mtp, WARNING, "specular compute error"); + goto blackout; + } + if (coef <= FTINY) /* negligible value? */ + goto blackout; copyscolor(sp->scol, sp->mo.pcol); scalescolor(sp->scol, coef); - if (sintens(sp->scol) <= FTINY) { - scolorblack(sp->scol); - return; /* got black pattern */ - } - setfunc(wp->mtp, wp->rp); /* else get roughness */ - errno = 0; - sp->u_alpha = evalue(wp->mf->ep[eoff+1]); - sp->v_alpha = (sp->u_alpha > FTINY) ? evalue(wp->mf->ep[eoff+2]) : 0.0; + errno = 0; /* else get roughness */ + sp->u_alpha = evalue(exa[1]); + sp->v_alpha = (sp->u_alpha > FTINY) ? evalue(exa[2]) : 0.0; if ((errno == EDOM) | (errno == ERANGE)) { objerror(wp->mtp, WARNING, "roughness compute error"); - scolorblack(sp->scol); - return; + goto blackout; } /* we have something... */ wp->specfl |= trans ? SP_TRAN : SP_REFL; if (sp->v_alpha <= FTINY) { /* is it pure specular? */ wp->specfl |= trans ? SP_TPURE : SP_RPURE; sp->u_alpha = sp->v_alpha = 0.0; return; - } - /* get anisotropic coordinates */ + } /* else get aniso coordinates */ fcross(sp->v, sp->mo.pnorm, wp->ulocal); if (normalize(sp->v) == 0.0) { /* orientation vector==normal? */ if (fabs(sp->u_alpha - sp->v_alpha) > 0.001) @@ -244,6 +262,9 @@ set_scomp(WGMDDAT *wp, int trans) (sp->u_alpha*sp->u_alpha + sp->v_alpha*sp->v_alpha) ); } else fcross(sp->u, sp->v, sp->mo.pnorm); + return; +blackout: + scolorblack(sp->scol); /* zero out component */ } /* sample anisotropic Gaussian specular */ @@ -510,11 +531,15 @@ m_wgmdf(OBJREC *m, RAY *r) } if ((m->oargs.nsargs < 13) | (m->oargs.nfargs < 9)) objerror(m, USER, "bad number of arguments"); + + if (r->crtype & SHADOW && !strcmp(m->oargs.sarg[5], "0")) + return(1); /* first shadow test */ clr_comps(&wd); wd.rp = r; wd.mtp = m; wd.mf = getfunc(m, 12, 0xEEE, 1); - setfunc(m, r); /* get local u vector */ + set_dcomp(&wd, 0); /* gets main modifier */ + setWGMDfunc(&wd.rd.mo, &wd); /* get local u vector */ errno = 0; for (i = 0; i < 3; i++) wd.ulocal[i] = evalue(wd.mf->ep[6+i]); @@ -523,18 +548,19 @@ m_wgmdf(OBJREC *m, RAY *r) else if (wd.mf->fxp != &unitxf) multv3(wd.ulocal, wd.ulocal, wd.mf->fxp->xfm); - set_dcomp(&wd, 0); /* call this first */ - set_dcomp(&wd, 1); /* call this second */ set_scomp(&wd, 1); /* sets SP_TPURE */ if (r->crtype & SHADOW && !(wd.specfl & SP_TPURE)) - return(1); /* early shadow test */ + return(1); /* second shadow test */ + set_dcomp(&wd, 1); set_scomp(&wd, 0); - wd.specfl |= SP_FLAT*(r->ro != NULL && isflat(r->ro->otype)); + wd.specfl |= SP_FLAT*(!wd.rs.mo.hastexture && + r->ro != NULL && isflat(r->ro->otype)); /* apply Fresnel adjustments? */ if (wd.specfl & SP_RPURE && pbright(wd.rs.scol) >= FRESTHRESH) { const double fest = FRESNE(fabs(wd.rs.mo.pdot)); for (i = NCSAMP; i--; ) wd.rs.scol[i] += fest*(1. - wd.rs.scol[i]); + scalescolor(wd.rd.scol, 1.-fest); scalescolor(wd.ts.scol, 1.-fest); scalescolor(wd.td.scol, 1.-fest); } @@ -587,8 +613,7 @@ m_wgmdf(OBJREC *m, RAY *r) copyscolor(r->mcol, lr.rcol); saddscolor(r->rcol, lr.rcol); r->rmt = r->rot; - if (wd.specfl & SP_FLAT && - !wd.rs.mo.hastexture | (r->crtype & AMBIENT)) + if (wd.specfl & SP_FLAT && r->crtype & AMBIENT) r->rmt += raydistance(&lr); } if (wd.specfl & (SP_REFL|SP_TRAN)) /* specularly scattered rays */
