root/radiance/ray/src/rt/m_wgmdf.c
Revision: 2.1
Committed: Mon Dec 9 00:44:29 2024 UTC (7 months, 4 weeks ago) by greg
2 static const char RCSid[] = "$Id: normal.c,v 2.84 2024/04/05 01:10:26 greg Exp $";
5 * Shading function for programmable Ward-Geisler-Moroder-Duer material.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "ambient.h"
12 #include "otypes.h"
13 #include "rtotypes.h"
14 #include "source.h"
15 #include "func.h"
16 #include "random.h"
17 #include "pmapmat.h"
18
19 #ifndef MAXITER
20 #define MAXITER 10 /* maximum # specular ray attempts */
21 #endif
22 /* estimate of Fresnel function */
23 #define FRESNE(ci) (exp(-5.85*(ci)) - 0.00202943064)
24 #define FRESTHRESH 0.017999 /* minimum specularity for approx. */
25
26 /*
27 * This routine implements the anisotropic Gaussian
28 * model described by Ward in a 1992 Siggraph article and updated by
29 * Geisler-Moroder and Duer in a 2010 article in High Performance Graphics.
30 * We do not reorient incoming ray, using side in part to determine
31 * reflectance values. Most parameters are programmable with their own
32 * modifiers and/or value expressions.
33 *
34 * Arguments for MAT_WGMDF are:
35 * 13+ rs_mod rs rs_urough rs_vrough
36 * ts_mod ts ts_urough ts_vrough
37 * td_mod
38 * ux uy uz funcfile transform
39 * 0
40 * 9+ rfdif gfdif bfdif
41 * rbdif gbdif bbdif
42 * rtdif gtdif btdif
43 * A10 ..
44 *
45 * Where the rs_urough or rs_vrough expression yields zero, mirror-Fresnel
46 * effects are computed, similar to MAT_PLASTIC and MAT_METAL. The
47 * rs* expressions should not vary with incident angle, or the material
48 * will not be physically valid. Similarly, the ts* expressions should
49 * give the same value for coincident direction vectors from either side.
50 * There are independent modifiers for specular reflection,
51 * transmission, and diffuse transmission. Diffuse reflection
52 * applies the material's main modifier, which doesn't apply to
53 * anything else by default. However, any of the modifiers may be
54 * ALIASMOD, which will use the main material modifier, or VOIDID,
55 * which will just be white.
56 * Diffuse reflection and transmission colors and patterns add to
57 * the specular components, and are only adjusted with mirror-Fresnel
58 * reflection if specular reflection is greater than FRESHTHRESH. The
59 * specular transmission is likewise adjusted in such cases. Specified
60 * values for all components should sum to less than 1, but like other
61 * Radiance materials, this is not enforced, nor is a warning issued.
62 */
63 /* specularity flags */
64 #define SP_REFL 01 /* has reflected specular component */
65 #define SP_TRAN 02 /* has transmitted specular */
66 #define SP_RPURE 04 /* mirror reflection */
67 #define SP_TPURE 010 /* has view component */
68 #define SP_FLAT 020 /* flat reflecting surface */
69 #define SP_RBLT 040 /* reflection below sample threshold */
70 #define SP_TBLT 0100 /* transmission below threshold */
71
72 typedef struct {
73 char *nam; /* modifier name */
74 int hastexture; /* has a texture? */
75 FVECT pnorm; /* perturbed normal direction */
76 double pdot; /* perturbed dot product */
77 SCOLOR pcol; /* pattern color */
78 } MODVAL; /* modifier-derived values */
79
80 typedef struct {
81 MODVAL mo; /* modifier parameters */
82 SCOLOR scol; /* modified diffuse color */
83 } DCOMP; /* diffuse component parameters */
84
85 typedef struct {
86 MODVAL mo; /* modifier parameters */
87 SCOLOR scol; /* modified specular color */
88 FVECT u, v; /* u and v in-plane vectors */
89 double u_alpha; /* u roughness */
90 double v_alpha; /* v roughness */
91 } SCOMP; /* specular component parameters */
92
93 typedef struct {
94 RAY *rp; /* ray pointer */
95 OBJREC *mtp; /* material pointer */
96 MFUNC *mf; /* pointer to expression list */
97 int specfl; /* specularity flags, defined above */
98 FVECT ulocal; /* u-vector in local coordinates */
99 DCOMP rd, td; /* diffuse component params */
100 SCOMP rs, ts; /* specular component params */
101 FVECT prdir; /* vector in transmitted direction */
102 } WGMDDAT; /* WGMD material data */
103
104 #define clr_comps(wp) ((wp)->specfl = 0, \
105 (wp)->rd.mo.nam = (wp)->td.mo.nam = \
106 (wp)->rs.mo.nam = (wp)->ts.mo.nam = "")
107
108 /* assign modifier values */
109 static int
110 set_modval(MODVAL *mp, OBJECT omod, const RAY *r)
111 {
112 RAY tr;
113
114 if (!mp->nam[0])
115 mp->nam = (omod == OVOID) ? VOIDID : objptr(omod)->oname;
116 else if (!strcmp(mp->nam, VOIDID))
117 omod = OVOID;
118 else if (omod == OVOID)
119 return(0);
120 tr = *r; /* independent modifier */
121 raytexture(&tr, omod);
122 if (DOT(tr.pert,tr.pert) > FTINY*FTINY) {
123 mp->pdot = raynormal(mp->pnorm, &tr);
124 mp->hastexture = 1;
125 } else {
126 VCOPY(mp->pnorm, tr.ron);
127 mp->pdot = tr.rod;
128 mp->hastexture = 0;
129 }
130 copyscolor(mp->pcol, tr.pcol);
131 return(1);
132 }
133
134 /* fill modifier values, using previous setting if found */
135 static int
136 fill_modval(MODVAL *mp, const WGMDDAT *wp)
137 {
138 if (mp == &wp->rd.mo) { /* special case (should be first) */
139 set_modval(mp, wp->mtp->omod, wp->rp);
140 return(1);
141 } /* use main modifier? */
142 if (!strcmp(mp->nam, ALIASMOD) || !strcmp(mp->nam, wp->rd.mo.nam)) {
143 *mp = wp->rd.mo;
144 return(1);
145 } /* check others */
146 if (mp != &wp->td.mo && !strcmp(mp->nam, wp->td.mo.nam)) {
147 *mp = wp->td.mo;
148 return(1);
149 }
150 if (mp != &wp->rs.mo && !strcmp(mp->nam, wp->rs.mo.nam)) {
151 *mp = wp->rs.mo;
152 return(1);
153 }
154 if (mp != &wp->ts.mo && !strcmp(mp->nam, wp->ts.mo.nam)) {
155 *mp = wp->ts.mo;
156 return(1);
157 } /* new modifier */
158 return(set_modval(mp, lastmod(objndx(wp->mtp), mp->nam), wp->rp));
159 }
160
161 /* assign indicated diffuse component (do !trans first) */
162 static void
163 set_dcomp(WGMDDAT *wp, int trans)
164 {
165 DCOMP *dp = trans ? &wp->td : &wp->rd;
166 const int offs = trans ? 6 : 3*(wp->rp->rod < 0);
167
168 if (trans) { /* transmitted diffuse? */
169 if (intens(wp->mtp->oargs.farg+offs) <= FTINY) {
170 scolorblack(dp->scol);
171 return;
172 }
173 dp->mo.nam = wp->mtp->oargs.sarg[8];
174 if (!fill_modval(&dp->mo, wp)) {
175 sprintf(errmsg,
176 "unknown diffuse transmission modifier '%s'",
177 dp->mo.nam);
178 objerror(wp->mtp, USER, errmsg);
179 }
180 } else /* no priors for main mod */
181 fill_modval(&dp->mo, wp);
182
183 setscolor(dp->scol, wp->mtp->oargs.farg[offs],
184 wp->mtp->oargs.farg[offs+1],
185 wp->mtp->oargs.farg[offs+2]);
186 smultscolor(dp->scol, dp->mo.pcol);
187 }
188
189 /* assign indicated specular component */
190 static void
191 set_scomp(WGMDDAT *wp, int trans)
192 {
193 SCOMP *sp = trans ? &wp->ts : &wp->rs;
194 const int eoff = 3*(trans != 0);
195 double coef;
196
197 setfunc(wp->mtp, wp->rp); /* get coefficient, first */
198 errno = 0;
199 coef = evalue(wp->mf->ep[eoff]);
200 if ((errno == EDOM) | (errno == ERANGE)) {
201 objerror(wp->mtp, WARNING, "specular compute error");
202 scolorblack(sp->scol);
203 return;
204 }
205 if (coef <= FTINY) { /* negligible value? */
206 scolorblack(sp->scol);
207 return;
208 } /* else get modifier */
209 sp->mo.nam = wp->mtp->oargs.sarg[4*(trans != 0)];
210 if (!fill_modval(&sp->mo, wp)) {
211 sprintf(errmsg, "unknown specular %s modifier '%s'",
212 trans ? "transmission" : "reflection", sp->mo.nam);
213 objerror(wp->mtp, USER, errmsg);
214 }
215 copyscolor(sp->scol, sp->mo.pcol);
216 scalescolor(sp->scol, coef);
217 if (sintens(sp->scol) <= FTINY) {
218 scolorblack(sp->scol);
219 return; /* got black pattern */
220 }
221 setfunc(wp->mtp, wp->rp); /* else get roughness */
222 errno = 0;
223 sp->u_alpha = evalue(wp->mf->ep[eoff+1]);
224 sp->v_alpha = (sp->u_alpha > FTINY) ? evalue(wp->mf->ep[eoff+2]) : 0.0;
225 if ((errno == EDOM) | (errno == ERANGE)) {
226 objerror(wp->mtp, WARNING, "roughness compute error");
227 scolorblack(sp->scol);
228 return;
229 } /* we have something... */
230 wp->specfl |= trans ? SP_TRAN : SP_REFL;
231 if (sp->v_alpha <= FTINY) { /* is it pure specular? */
232 wp->specfl |= trans ? SP_TPURE : SP_RPURE;
233 sp->u_alpha = sp->v_alpha = 0.0;
234 return;
235 }
236 /* get anisotropic coordinates */
237 fcross(sp->v, sp->mo.pnorm, wp->ulocal);
238 if (normalize(sp->v) == 0.0) { /* orientation vector==normal? */
239 if (fabs(sp->u_alpha - sp->v_alpha) > 0.001)
240 objerror(wp->mtp, WARNING, "bad orientation vector");
241 getperpendicular(sp->u, sp->mo.pnorm, 1); /* punting */
242 fcross(sp->v, sp->mo.pnorm, sp->u);
243 sp->u_alpha = sp->v_alpha = sqrt( 0.5 *
244 (sp->u_alpha*sp->u_alpha + sp->v_alpha*sp->v_alpha) );
245 } else
246 fcross(sp->u, sp->v, sp->mo.pnorm);
247 }
248
249 /* sample anisotropic Gaussian specular */
250 static void
251 agaussamp(WGMDDAT *wp)
252 {
253 RAY sr;
254 FVECT h;
255 double rv[2];
256 double d, sinp, cosp;
257 int maxiter, ntrials, nstarget, nstaken;
258 int i;
259 /* compute reflection */
260 if ((wp->specfl & (SP_REFL|SP_RPURE|SP_RBLT)) == SP_REFL &&
261 rayorigin(&sr, RSPECULAR, wp->rp, wp->rs.scol) == 0) {
262 SCOLOR scol;
263 nstarget = 1;
264 if (specjitter > 1.5) { /* multiple samples? */
265 nstarget = specjitter*wp->rp->rweight + .5;
266 if (sr.rweight <= minweight*nstarget)
267 nstarget = sr.rweight/minweight;
268 if (nstarget > 1) {
269 d = 1./nstarget;
270 scalescolor(sr.rcoef, d);
271 sr.rweight *= d;
272 } else
273 nstarget = 1;
274 }
275 scolorblack(scol);
276 dimlist[ndims++] = (int)(size_t)wp->mtp;
277 maxiter = MAXITER*nstarget;
278 for (nstaken = ntrials = 0; (nstaken < nstarget) &
279 (ntrials < maxiter); ntrials++) {
280 if (ntrials)
281 d = frandom();
282 else
283 d = urand(ilhash(dimlist,ndims)+samplendx);
284 multisamp(rv, 2, d);
285 d = 2.0*PI * rv[0];
286 cosp = tcos(d) * wp->rs.u_alpha;
287 sinp = tsin(d) * wp->rs.v_alpha;
288 d = 1./sqrt(cosp*cosp + sinp*sinp);
289 cosp *= d;
290 sinp *= d;
291 if ((0. <= specjitter) & (specjitter < 1.))
292 rv[1] = 1.0 - specjitter*rv[1];
293 d = (rv[1] <= FTINY) ? 1.0 : sqrt( -log(rv[1]) /
294 (cosp*cosp/(wp->rs.u_alpha*wp->rs.u_alpha) +
295 sinp*sinp/(wp->rs.v_alpha*wp->rs.v_alpha)) );
296 for (i = 0; i < 3; i++)
297 h[i] = wp->rs.mo.pnorm[i] +
298 d*(cosp*wp->rs.u[i] + sinp*wp->rs.v[i]);
299 d = -2.0 * DOT(h, wp->rp->rdir) / (1.0 + d*d);
300 VSUM(sr.rdir, wp->rp->rdir, h, d);
301 /* sample rejection test */
302 d = DOT(sr.rdir, wp->rp->ron);
303 if ((d > 0) ^ (wp->rp->rod > 0))
304 continue;
305 checknorm(sr.rdir);
306 if (nstarget > 1) { /* W-G-M-D adjustment */
307 if (nstaken) rayclear(&sr);
308 rayvalue(&sr);
309 d = 2./(1. + wp->rp->rod/d);
310 scalescolor(sr.rcol, d);
311 saddscolor(scol, sr.rcol);
312 } else {
313 rayvalue(&sr);
314 smultscolor(sr.rcol, sr.rcoef);
315 saddscolor(wp->rp->rcol, sr.rcol);
316 }
317 ++nstaken;
318 }
319 if (nstarget > 1) { /* final W-G-M-D weighting */
320 smultscolor(scol, sr.rcoef);
321 d = (double)nstarget/ntrials;
322 scalescolor(scol, d);
323 saddscolor(wp->rp->rcol, scol);
324 }
325 ndims--;
326 }
327 /* compute transmission */
328 if ((wp->specfl & (SP_TRAN|SP_TPURE|SP_TBLT)) == SP_TRAN &&
329 rayorigin(&sr, TSPECULAR, wp->rp, wp->ts.scol) == 0) {
330 nstarget = 1;
331 if (specjitter > 1.5) { /* multiple samples? */
332 nstarget = specjitter*wp->rp->rweight + .5;
333 if (sr.rweight <= minweight*nstarget)
334 nstarget = sr.rweight/minweight;
335 if (nstarget > 1) {
336 d = 1./nstarget;
337 scalescolor(sr.rcoef, d);
338 sr.rweight *= d;
339 } else
340 nstarget = 1;
341 }
342 dimlist[ndims++] = (int)(size_t)wp->mtp;
343 maxiter = MAXITER*nstarget;
344 for (nstaken = ntrials = 0; (nstaken < nstarget) &
345 (ntrials < maxiter); ntrials++) {
346 if (ntrials)
347 d = frandom();
348 else
349 d = urand(ilhash(dimlist,ndims)+1823+samplendx);
350 multisamp(rv, 2, d);
351 d = 2.0*PI * rv[0];
352 cosp = tcos(d) * wp->ts.u_alpha;
353 sinp = tsin(d) * wp->ts.v_alpha;
354 d = 1./sqrt(cosp*cosp + sinp*sinp);
355 cosp *= d;
356 sinp *= d;
357 if ((0. <= specjitter) & (specjitter < 1.))
358 rv[1] = 1.0 - specjitter*rv[1];
359 if (rv[1] <= FTINY)
360 d = 1.0;
361 else
362 d = sqrt(-log(rv[1]) /
363 (cosp*cosp/(wp->ts.u_alpha*wp->ts.u_alpha) +
364 sinp*sinp/(wp->ts.v_alpha*wp->ts.v_alpha)));
365 for (i = 0; i < 3; i++)
366 sr.rdir[i] = wp->prdir[i] +
367 d*(cosp*wp->ts.u[i] + sinp*wp->ts.v[i]);
368 /* rejection test */
369 if ((DOT(sr.rdir,wp->rp->ron) > 0) == (wp->rp->rod > 0))
370 continue;
371 normalize(sr.rdir); /* OK, normalize */
372 if (nstaken) /* multi-sampling? */
373 rayclear(&sr);
374 rayvalue(&sr);
375 smultscolor(sr.rcol, sr.rcoef);
376 saddscolor(wp->rp->rcol, sr.rcol);
377 ++nstaken;
378 }
379 ndims--;
380 }
381 }
382
383 /* compute source contribution for MAT_WGMDF */
384 static void
385 dirwgmdf(SCOLOR scval, void *uwp, FVECT ldir, double omega)
386 {
387 WGMDDAT *wp = (WGMDDAT *)uwp;
388 const int hitfront = (wp->rp->rod > 0);
389 double fresadj = 1.;
390 double ldot;
391 double dtmp, dtmp1, dtmp2;
392 FVECT h;
393 double au2, av2;
394 SCOLOR sctmp;
395
396 scolorblack(scval); /* will add component coefficients */
397
398 /* XXX ignores which side is lit */
399 if (wp->specfl & SP_RPURE && pbright(wp->rs.scol) >= FRESTHRESH)
400 fresadj = 1. - FRESNE(fabs(DOT(wp->rs.mo.pnorm,ldir)));
401
402 if (sintens(wp->rd.scol) > FTINY &&
403 ((ldot = DOT(wp->rd.mo.pnorm,ldir)) > 0) == hitfront) {
404 /*
405 * Compute diffuse reflection coefficient for source.
406 */
407 copyscolor(sctmp, wp->rd.scol);
408 dtmp = fabs(ldot) * omega * (1.0/PI) * fresadj;
409 scalescolor(sctmp, dtmp);
410 saddscolor(scval, sctmp);
411 }
412 if (sintens(wp->td.scol) > FTINY &&
413 ((ldot = DOT(wp->td.mo.pnorm,ldir)) > 0) ^ hitfront) {
414 /*
415 * Compute diffuse transmission coefficient for source.
416 */
417 copyscolor(sctmp, wp->td.scol);
418 dtmp = fabs(ldot) * omega * (1.0/PI) * fresadj;
419 scalescolor(sctmp, dtmp);
420 saddscolor(scval, sctmp);
421 }
422 #if 0 /* XXX not yet implemented */
423 if (ambRayInPmap(wp->rp))
424 return; /* specular accounted for in photon map */
425 #endif
426 if ((wp->specfl & (SP_REFL|SP_RPURE)) == SP_REFL &&
427 ((ldot = DOT(wp->rs.mo.pnorm,ldir)) > 0) == hitfront) {
428 /*
429 * Compute specular reflection coefficient for source using
430 * anisotropic Gaussian distribution model.
431 */
432 /* add source width if flat */
433 if (wp->specfl & SP_FLAT)
434 au2 = av2 = omega * (0.25/PI);
435 else
436 au2 = av2 = 0.0;
437 au2 += wp->rs.u_alpha*wp->rs.u_alpha;
438 av2 += wp->rs.v_alpha*wp->rs.v_alpha;
439 /* half vector */
440 VSUB(h, ldir, wp->rp->rdir);
441 /* ellipse */
442 dtmp1 = DOT(wp->rs.u, h);
443 dtmp1 *= dtmp1 / au2;
444 dtmp2 = DOT(wp->rs.v, h);
445 dtmp2 *= dtmp2 / av2;
446 /* W-G-M-D model */
447 dtmp = DOT(wp->rs.mo.pnorm, h);
448 dtmp *= dtmp;
449 dtmp1 = (dtmp1 + dtmp2) / dtmp;
450 dtmp = exp(-dtmp1) * DOT(h,h) /
451 (PI * dtmp*dtmp * sqrt(au2*av2));
452
453 if (dtmp > FTINY) { /* worth using? */
454 copyscolor(sctmp, wp->rs.scol);
455 dtmp *= fabs(ldot) * omega;
456 scalescolor(sctmp, dtmp);
457 saddscolor(scval, sctmp);
458 }
459 }
460 if ((wp->specfl & (SP_TRAN|SP_TPURE)) == SP_TRAN &&
461 ((ldot = DOT(wp->ts.mo.pnorm,ldir)) > 0) ^ hitfront) {
462 /*
463 * Compute specular transmission coefficient for source.
464 */
465 /* roughness + source */
466 au2 = av2 = omega * (1.0/PI);
467 au2 += wp->ts.u_alpha*wp->ts.u_alpha;
468 av2 += wp->ts.v_alpha*wp->ts.v_alpha;
469 /* "half vector" */
470 VSUB(h, ldir, wp->prdir);
471 dtmp = DOT(h,h);
472 if (dtmp > FTINY*FTINY) {
473 dtmp1 = DOT(h,wp->ts.mo.pnorm);
474 dtmp = 1.0 - dtmp1*dtmp1/dtmp;
475 }
476 if (dtmp > FTINY*FTINY) {
477 dtmp1 = DOT(h,wp->ts.u);
478 dtmp1 *= dtmp1 / au2;
479 dtmp2 = DOT(h,wp->ts.v);
480 dtmp2 *= dtmp2 / av2;
481 dtmp = (dtmp1 + dtmp2) / dtmp;
482 dtmp = exp(-dtmp);
483 } else
484 dtmp = 1.0;
485 /* Gaussian */
486 dtmp *= (1.0/PI) * sqrt(-ldot/(wp->ts.mo.pdot*au2*av2));
487
488 if (dtmp > FTINY) { /* worth using? */
489 copyscolor(sctmp, wp->ts.scol);
490 dtmp *= omega;
491 scalescolor(sctmp, dtmp);
492 saddscolor(scval, sctmp);
493 }
494 }
495 }
496
497 /* color a ray that hit a programmable WGMD material */
498 int
499 m_wgmdf(OBJREC *m, RAY *r)
500 {
501 RAY lr;
502 WGMDDAT wd;
503 SCOLOR sctmp;
504 FVECT anorm;
505 int i;
506
507 if (!backvis & (r->rod < 0.0)) {
508 raytrans(r);
509 return(1); /* backside invisible */
510 }
511 if ((m->oargs.nsargs < 13) | (m->oargs.nfargs < 9))
512 objerror(m, USER, "bad number of arguments");
513 clr_comps(&wd);
514 wd.rp = r;
515 wd.mtp = m;
516 wd.mf = getfunc(m, 12, 0xEEE, 1);
517 setfunc(m, r); /* get local u vector */
518 errno = 0;
519 for (i = 0; i < 3; i++)
520 wd.ulocal[i] = evalue(wd.mf->ep[6+i]);
521 if ((errno == EDOM) | (errno == ERANGE))
522 wd.ulocal[0] = wd.ulocal[1] = wd.ulocal[2] = 0.0;
523 else if (wd.mf->fxp != &unitxf)
524 multv3(wd.ulocal, wd.ulocal, wd.mf->fxp->xfm);
525
526 set_dcomp(&wd, 0); /* call this first */
527 set_dcomp(&wd, 1); /* call this second */
528 set_scomp(&wd, 1); /* sets SP_TPURE */
529 if (r->crtype & SHADOW && !(wd.specfl & SP_TPURE))
530 return(1); /* early shadow test */
531 set_scomp(&wd, 0);
532 wd.specfl |= SP_FLAT*(r->ro != NULL && isflat(r->ro->otype));
533 /* apply Fresnel adjustments? */
534 if (wd.specfl & SP_RPURE && pbright(wd.rs.scol) >= FRESTHRESH) {
535 const double fest = FRESNE(fabs(wd.rs.mo.pdot));
536 for (i = NCSAMP; i--; )
537 wd.rs.scol[i] += fest*(1. - wd.rs.scol[i]);
538 scalescolor(wd.ts.scol, 1.-fest);
539 scalescolor(wd.td.scol, 1.-fest);
540 }
541 /* check specular thresholds */
542 wd.specfl |= SP_RBLT*((wd.specfl & (SP_REFL|SP_RPURE)) == SP_REFL &&
543 specthresh >= pbright(wd.rs.scol)-FTINY);
544 wd.specfl |= SP_TBLT*((wd.specfl & (SP_TRAN|SP_TPURE)) == SP_TRAN &&
545 specthresh >= pbright(wd.ts.scol)-FTINY);
546 /* get through direction */
547 if (wd.specfl & SP_TRAN && wd.ts.mo.hastexture &&
548 !(r->crtype & (SHADOW|AMBIENT))) {
549 for (i = 0; i < 3; i++) /* perturb */
550 wd.prdir[i] = r->rdir[i] - wd.ts.mo.pnorm[i] + r->ron[i];
551 if ((DOT(wd.prdir,r->ron) > 0) ^ (r->rod > 0))
552 normalize(wd.prdir); /* OK */
553 else /* too much */
554 VCOPY(wd.prdir, r->rdir);
555 } else
556 VCOPY(wd.prdir, r->rdir);
557 /* transmitted view ray? */
558 if ((wd.specfl & (SP_TRAN|SP_TPURE|SP_TBLT)) == (SP_TRAN|SP_TPURE) &&
559 rayorigin(&lr, TRANS, r, wd.ts.scol) == 0) {
560 VCOPY(lr.rdir, wd.prdir);
561 rayvalue(&lr);
562 smultscolor(lr.rcol, lr.rcoef);
563 saddscolor(r->rcol, lr.rcol);
564 if (scolor_mean(wd.ts.scol) >= 0.999) {
565 /* completely transparent */
566 smultscolor(lr.mcol, lr.rcoef);
567 copyscolor(r->mcol, lr.mcol);
568 r->rmt = r->rot + lr.rmt;
569 r->rxt = r->rot + lr.rxt;
570 } else if (pbright(wd.ts.scol) >
571 pbright(wd.td.scol) + pbright(wd.rd.scol))
572 r->rxt = r->rot + raydistance(&lr);
573 }
574 if (r->crtype & SHADOW)
575 return(1); /* the rest is shadow */
576 /* mirror ray? */
577 if ((wd.specfl & (SP_REFL|SP_RPURE|SP_RBLT)) == (SP_REFL|SP_RPURE) &&
578 rayorigin(&lr, REFLECTED, r, wd.rs.scol) == 0) {
579 VSUM(lr.rdir, r->rdir, wd.rs.mo.pnorm, 2.*wd.rs.mo.pdot);
580 /* fall back if would penetrate */
581 if (wd.rs.mo.hastexture &&
582 (DOT(lr.rdir,r->ron) > 0) ^ (r->rod > 0))
583 VSUM(lr.rdir, r->rdir, r->ron, 2.*r->rod);
584 checknorm(lr.rdir);
585 rayvalue(&lr);
586 smultscolor(lr.rcol, lr.rcoef);
587 copyscolor(r->mcol, lr.rcol);
588 saddscolor(r->rcol, lr.rcol);
589 r->rmt = r->rot;
590 if (wd.specfl & SP_FLAT &&
591 !wd.rs.mo.hastexture | (r->crtype & AMBIENT))
592 r->rmt += raydistance(&lr);
593 }
594 if (wd.specfl & (SP_REFL|SP_TRAN)) /* specularly scattered rays */
595 agaussamp(&wd); /* checks *BLT flags */
596
597 if (sintens(wd.rd.scol) > FTINY) { /* ambient from this side */
598 if (r->rod > 0) {
599 VCOPY(anorm, wd.rd.mo.pnorm);
600 } else {
601 anorm[0] = -wd.rd.mo.pnorm[0];
602 anorm[1] = -wd.rd.mo.pnorm[1];
603 anorm[2] = -wd.rd.mo.pnorm[2];
604 }
605 copyscolor(sctmp, wd.rd.scol);
606 if (wd.specfl & SP_RBLT) /* add in specular as well? */
607 saddscolor(sctmp, wd.rs.scol);
608 multambient(sctmp, r, anorm);
609 saddscolor(r->rcol, sctmp); /* add to returned color */
610 }
611 if (sintens(wd.td.scol) > FTINY) { /* ambient from other side */
612 if (r->rod > 0) {
613 anorm[0] = -wd.td.mo.pnorm[0];
614 anorm[1] = -wd.td.mo.pnorm[1];
615 anorm[2] = -wd.td.mo.pnorm[2];
616 } else {
617 VCOPY(anorm, wd.td.mo.pnorm);
618 }
619 copyscolor(sctmp, wd.td.scol);
620 if (wd.specfl & SP_TBLT) /* add in specular as well? */
621 saddscolor(sctmp, wd.ts.scol)
622 multambient(sctmp, r, anorm);
623 saddscolor(r->rcol, sctmp);
624 }
625 direct(r, dirwgmdf, &wd); /* add direct component last */
626 return(1);
627 }
