1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: m_wgmdf.c,v 2.7 2024/12/18 18:34:13 greg Exp $"; |
3 |
#endif |
4 |
5 |
* Shading function for programmable Ward-Geisler-Moroder-Duer material. |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include "ray.h" |
11 |
#include "ambient.h" |
12 |
#include "otypes.h" |
13 |
#include "rtotypes.h" |
14 |
#include "source.h" |
15 |
#include "func.h" |
16 |
#include "random.h" |
17 |
#include "pmapmat.h" |
18 |
19 |
#ifndef MAXITER |
20 |
#define MAXITER 10 /* maximum # specular ray attempts */ |
21 |
#endif |
22 |
/* estimate of Fresnel function */ |
23 |
#define FRESNE(ci) (exp(-5.85*(ci)) - 0.00202943064) |
24 |
#define FRESTHRESH 0.017999 /* minimum specularity for approx. */ |
25 |
26 |
27 |
* This routine implements the anisotropic Gaussian |
28 |
* model described by Ward in a 1992 Siggraph article and updated by |
29 |
* Geisler-Moroder and Duer in a 2010 article in High Performance Graphics. |
30 |
* We do not reorient incoming ray, using side in part to determine |
31 |
* reflectance values. Most parameters are programmable with their own |
32 |
* modifiers and/or value expressions. |
33 |
34 |
* Arguments for MAT_WGMDF are: |
35 |
* 13+ rs_mod rs rs_urough rs_vrough |
36 |
* ts_mod ts ts_urough ts_vrough |
37 |
* td_mod |
38 |
* ux uy uz funcfile transform |
39 |
* 0 |
40 |
* 9+ rfdif gfdif bfdif |
41 |
* rbdif gbdif bbdif |
42 |
* rtdif gtdif btdif |
43 |
* A10 .. |
44 |
45 |
* Where the rs_urough or rs_vrough expression yields zero, mirror-Fresnel |
46 |
* effects are computed, similar to MAT_PLASTIC and MAT_METAL. The |
47 |
* rs* expressions should not vary with incident angle, or the material |
48 |
* will not be physically valid. Similarly, the ts* expressions should |
49 |
* give the same value for coincident direction vectors from either side. |
50 |
* There are independent modifiers for specular reflection, |
51 |
* transmission, and diffuse transmission. Diffuse reflection |
52 |
* applies the material's main modifier, which doesn't apply to |
53 |
* anything else by default. However, any of the modifiers may be |
54 |
* ALIASMOD, which will use the main material modifier, or VOIDID, |
55 |
* which will just be white. |
56 |
* Diffuse reflection and transmission colors and patterns add to |
57 |
* the specular components, and are only adjusted with mirror-Fresnel |
58 |
* reflection if specular reflection is greater than FRESHTHRESH. The |
59 |
* specular transmission is likewise adjusted in such cases. Specified |
60 |
* values for all components should sum to less than 1, but like other |
61 |
* Radiance materials, this is not enforced, nor is a warning issued. |
62 |
63 |
/* specularity flags */ |
64 |
#define SP_REFL 01 /* has reflected specular component */ |
65 |
#define SP_TRAN 02 /* has transmitted specular */ |
66 |
#define SP_RPURE 04 /* mirror reflection */ |
67 |
#define SP_TPURE 010 /* has view component */ |
68 |
#define SP_FLAT 020 /* flat reflecting surface */ |
69 |
#define SP_RBLT 040 /* reflection below sample threshold */ |
70 |
#define SP_TBLT 0100 /* transmission below threshold */ |
71 |
72 |
typedef struct { |
73 |
char *nam; /* modifier name */ |
74 |
int hastexture; /* has a texture? */ |
75 |
FVECT pnorm; /* perturbed normal direction */ |
76 |
double pdot; /* perturbed dot product */ |
77 |
SCOLOR pcol; /* pattern color */ |
78 |
} MODVAL; /* modifier-derived values */ |
79 |
80 |
typedef struct { |
81 |
MODVAL mo; /* modifier parameters */ |
82 |
SCOLOR scol; /* modified diffuse color */ |
83 |
} DCOMP; /* diffuse component parameters */ |
84 |
85 |
typedef struct { |
86 |
87 |
SCOLOR scol; /* modified specular color */ |
88 |
FVECT u, v; /* u and v in-plane vectors */ |
89 |
double u_alpha; /* u roughness */ |
90 |
double v_alpha; /* v roughness */ |
91 |
} SCOMP; /* specular component parameters */ |
92 |
93 |
typedef struct { |
94 |
RAY *rp; /* ray pointer */ |
95 |
OBJREC *mtp; /* material pointer */ |
96 |
MFUNC *mf; /* pointer to expression list */ |
97 |
int specfl; /* specularity flags, defined above */ |
98 |
FVECT ulocal; /* u-vector in local coordinates */ |
99 |
DCOMP rd, td; /* diffuse component params */ |
100 |
SCOMP rs, ts; /* specular component params */ |
101 |
FVECT prdir; /* vector in transmitted direction */ |
102 |
} WGMDDAT; /* WGMD material data */ |
103 |
104 |
#define clr_comps(wp) ((wp)->specfl = 0, \ |
105 |
(wp)->rd.mo.nam = (wp)->td.mo.nam = \ |
106 |
(wp)->rs.mo.nam = (wp)->ts.mo.nam = "") |
107 |
108 |
/* assign modifier values */ |
109 |
static int |
110 |
set_modval(MODVAL *mp, OBJECT omod, const RAY *r) |
111 |
112 |
RAY tr; |
113 |
114 |
if (!mp->nam[0]) |
115 |
mp->nam = (omod == OVOID) ? VOIDID : objptr(omod)->oname; |
116 |
else if (!strcmp(mp->nam, VOIDID)) |
117 |
omod = OVOID; |
118 |
else if (omod == OVOID) |
119 |
return(0); |
120 |
tr = *r; /* independent modifier */ |
121 |
raytexture(&tr, omod); |
122 |
if (DOT(tr.pert,tr.pert) > FTINY*FTINY) { |
123 |
mp->pdot = raynormal(mp->pnorm, &tr); |
124 |
mp->hastexture = 1; |
125 |
} else { |
126 |
VCOPY(mp->pnorm, tr.ron); |
127 |
mp->pdot = tr.rod; |
128 |
mp->hastexture = 0; |
129 |
130 |
copyscolor(mp->pcol, tr.pcol); |
131 |
return(1); |
132 |
133 |
134 |
/* fill modifier values, using previous setting if found */ |
135 |
static int |
136 |
fill_modval(MODVAL *mp, const WGMDDAT *wp) |
137 |
138 |
if (mp == &wp->rd.mo) { /* special case (should be first) */ |
139 |
set_modval(mp, wp->mtp->omod, wp->rp); |
140 |
return(1); |
141 |
} /* use main modifier? */ |
142 |
if (!strcmp(mp->nam, ALIASMOD) || !strcmp(mp->nam, wp->rd.mo.nam)) { |
143 |
*mp = wp->rd.mo; |
144 |
return(1); |
145 |
} /* check others */ |
146 |
if (mp != &wp->td.mo && !strcmp(mp->nam, wp->td.mo.nam)) { |
147 |
*mp = wp->td.mo; |
148 |
return(1); |
149 |
150 |
if (mp != &wp->rs.mo && !strcmp(mp->nam, wp->rs.mo.nam)) { |
151 |
*mp = wp->rs.mo; |
152 |
return(1); |
153 |
154 |
if (mp != &wp->ts.mo && !strcmp(mp->nam, wp->ts.mo.nam)) { |
155 |
*mp = wp->ts.mo; |
156 |
return(1); |
157 |
} /* new modifier */ |
158 |
return(set_modval(mp, lastmod(objndx(wp->mtp), mp->nam), wp->rp)); |
159 |
160 |
161 |
/* set calculation context for given component of MAT_WGMDF */ |
162 |
static int |
163 |
setWGMDfunc(MODVAL *mp, const WGMDDAT *wp) |
164 |
165 |
static char lastMod[MAXSTR]; |
166 |
double sf; |
167 |
FVECT vec; |
168 |
169 |
if (setfunc(wp->mtp, wp->rp) == 0 && |
170 |
!strcmp(mp->nam, lastMod)) |
171 |
return(0); /* already set */ |
172 |
strcpy(lastMod, mp->nam); |
173 |
/* else (re)assign special variables */ |
174 |
sf = 1 - 2*(wp->rp->rod < 0); |
175 |
varset("RdotP`", '=', mp->pdot*sf); |
176 |
multv3(vec, mp->pnorm, funcxf.xfm); |
177 |
sf /= funcxf.sca; |
178 |
varset("NxP`", '=', vec[0]*sf); |
179 |
varset("NyP`", '=', vec[1]*sf); |
180 |
varset("NzP`", '=', vec[2]*sf); |
181 |
return(1); |
182 |
183 |
184 |
/* assign indicated diffuse component (do !trans first) */ |
185 |
static void |
186 |
set_dcomp(WGMDDAT *wp, int trans) |
187 |
188 |
DCOMP *dp = trans ? &wp->td : &wp->rd; |
189 |
const int offs = trans ? 6 : 3*(wp->rp->rod < 0); |
190 |
191 |
if (trans) { /* transmitted diffuse? */ |
192 |
if (intens(wp->mtp->oargs.farg+offs) <= FTINY) { |
193 |
scolorblack(dp->scol); |
194 |
return; |
195 |
196 |
dp->mo.nam = wp->mtp->oargs.sarg[8]; |
197 |
if (!fill_modval(&dp->mo, wp)) { |
198 |
sprintf(errmsg, |
199 |
"unknown diffuse transmission modifier '%s'", |
200 |
dp->mo.nam); |
201 |
objerror(wp->mtp, USER, errmsg); |
202 |
203 |
} else /* no priors for main mod */ |
204 |
fill_modval(&dp->mo, wp); |
205 |
206 |
setscolor(dp->scol, wp->mtp->oargs.farg[offs], |
207 |
wp->mtp->oargs.farg[offs+1], |
208 |
wp->mtp->oargs.farg[offs+2]); |
209 |
smultscolor(dp->scol, dp->mo.pcol); |
210 |
211 |
212 |
/* assign indicated specular component */ |
213 |
static void |
214 |
set_scomp(WGMDDAT *wp, int trans) |
215 |
216 |
SCOMP *sp = trans ? &wp->ts : &wp->rs; |
217 |
EPNODE **exa = wp->mf->ep + 3*(trans != 0); |
218 |
double coef; |
219 |
/* constant zero check */ |
220 |
if (exa[0]->type == NUM && exa[0]->v.num <= FTINY) |
221 |
goto blackout; |
222 |
/* need modifier */ |
223 |
sp->mo.nam = wp->mtp->oargs.sarg[4*(trans != 0)]; |
224 |
if (!fill_modval(&sp->mo, wp)) { |
225 |
sprintf(errmsg, "unknown specular %s modifier '%s'", |
226 |
trans ? "transmission" : "reflection", sp->mo.nam); |
227 |
228 |
229 |
if (sintens(sp->mo.pcol) <= FTINY) |
230 |
goto blackout; /* got black pattern */ |
231 |
setWGMDfunc(&sp->mo, wp); /* else compute coefficient */ |
232 |
errno = 0; |
233 |
coef = evalue(exa[0]); |
234 |
if ((errno == EDOM) | (errno == ERANGE)) { |
235 |
objerror(wp->mtp, WARNING, "specular compute error"); |
236 |
goto blackout; |
237 |
238 |
if (coef <= FTINY) /* negligible value? */ |
239 |
goto blackout; |
240 |
copyscolor(sp->scol, sp->mo.pcol); |
241 |
scalescolor(sp->scol, coef); |
242 |
errno = 0; /* else get roughness */ |
243 |
sp->u_alpha = evalue(exa[1]); |
244 |
sp->v_alpha = (sp->u_alpha > FTINY) ? evalue(exa[2]) : 0.0; |
245 |
246 |
objerror(wp->mtp, WARNING, "roughness compute error"); |
247 |
goto blackout; |
248 |
} /* we have something... */ |
249 |
wp->specfl |= trans ? SP_TRAN : SP_REFL; |
250 |
if (sp->v_alpha <= FTINY) { /* is it pure specular? */ |
251 |
wp->specfl |= trans ? SP_TPURE : SP_RPURE; |
252 |
sp->u_alpha = sp->v_alpha = 0.0; |
253 |
return; |
254 |
} /* else get aniso coordinates */ |
255 |
fcross(sp->v, sp->mo.pnorm, wp->ulocal); |
256 |
if (normalize(sp->v) == 0.0) { /* orientation vector==normal? */ |
257 |
if (fabs(sp->u_alpha - sp->v_alpha) > 0.001) |
258 |
objerror(wp->mtp, WARNING, "bad orientation vector"); |
259 |
getperpendicular(sp->u, sp->mo.pnorm, 1); /* punting */ |
260 |
fcross(sp->v, sp->mo.pnorm, sp->u); |
261 |
sp->u_alpha = sp->v_alpha = sqrt( 0.5 * |
262 |
(sp->u_alpha*sp->u_alpha + sp->v_alpha*sp->v_alpha) ); |
263 |
} else |
264 |
fcross(sp->u, sp->v, sp->mo.pnorm); |
265 |
return; |
266 |
blackout: |
267 |
scolorblack(sp->scol); /* zero out component */ |
268 |
269 |
270 |
/* sample anisotropic Gaussian specular */ |
271 |
static void |
272 |
agaussamp(WGMDDAT *wp) |
273 |
274 |
RAY sr; |
275 |
FVECT h; |
276 |
double rv[2]; |
277 |
double d, sinp, cosp; |
278 |
int maxiter, ntrials, nstarget, nstaken; |
279 |
int i; |
280 |
/* compute reflection */ |
281 |
if ((wp->specfl & (SP_REFL|SP_RPURE|SP_RBLT)) == SP_REFL && |
282 |
rayorigin(&sr, RSPECULAR, wp->rp, wp->rs.scol) == 0) { |
283 |
SCOLOR scol; |
284 |
nstarget = 1; |
285 |
if (specjitter > 1.5) { /* multiple samples? */ |
286 |
nstarget = specjitter*wp->rp->rweight + .5; |
287 |
if (sr.rweight <= minweight*nstarget) |
288 |
nstarget = sr.rweight/minweight; |
289 |
if (nstarget > 1) { |
290 |
d = 1./nstarget; |
291 |
scalescolor(sr.rcoef, d); |
292 |
sr.rweight *= d; |
293 |
} else |
294 |
nstarget = 1; |
295 |
296 |
scolorblack(scol); |
297 |
dimlist[ndims++] = (int)(size_t)wp->mtp; |
298 |
maxiter = MAXITER*nstarget; |
299 |
for (nstaken = ntrials = 0; (nstaken < nstarget) & |
300 |
(ntrials < maxiter); ntrials++) { |
301 |
if (ntrials) |
302 |
d = frandom(); |
303 |
else |
304 |
d = urand(ilhash(dimlist,ndims)+samplendx); |
305 |
multisamp(rv, 2, d); |
306 |
d = 2.0*PI * rv[0]; |
307 |
cosp = tcos(d) * wp->rs.u_alpha; |
308 |
sinp = tsin(d) * wp->rs.v_alpha; |
309 |
d = 1./sqrt(cosp*cosp + sinp*sinp); |
310 |
cosp *= d; |
311 |
sinp *= d; |
312 |
if ((0. <= specjitter) & (specjitter < 1.)) |
313 |
rv[1] = 1.0 - specjitter*rv[1]; |
314 |
d = (rv[1] <= FTINY) ? 1.0 : sqrt( -log(rv[1]) / |
315 |
(cosp*cosp/(wp->rs.u_alpha*wp->rs.u_alpha) + |
316 |
sinp*sinp/(wp->rs.v_alpha*wp->rs.v_alpha)) ); |
317 |
for (i = 0; i < 3; i++) |
318 |
h[i] = wp->rs.mo.pnorm[i] + |
319 |
d*(cosp*wp->rs.u[i] + sinp*wp->rs.v[i]); |
320 |
d = -2.0 * DOT(h, wp->rp->rdir) / (1.0 + d*d); |
321 |
VSUM(sr.rdir, wp->rp->rdir, h, d); |
322 |
/* sample rejection test */ |
323 |
d = DOT(sr.rdir, wp->rp->ron); |
324 |
if ((d > 0) ^ (wp->rp->rod > 0)) |
325 |
continue; |
326 |
checknorm(sr.rdir); |
327 |
if (nstarget > 1) { /* W-G-M-D adjustment */ |
328 |
if (nstaken) rayclear(&sr); |
329 |
rayvalue(&sr); |
330 |
d = 2./(1. + wp->rp->rod/d); |
331 |
scalescolor(sr.rcol, d); |
332 |
saddscolor(scol, sr.rcol); |
333 |
} else { |
334 |
rayvalue(&sr); |
335 |
smultscolor(sr.rcol, sr.rcoef); |
336 |
saddscolor(wp->rp->rcol, sr.rcol); |
337 |
338 |
++nstaken; |
339 |
340 |
if (nstarget > 1) { /* final W-G-M-D weighting */ |
341 |
smultscolor(scol, sr.rcoef); |
342 |
d = (double)nstarget/ntrials; |
343 |
scalescolor(scol, d); |
344 |
saddscolor(wp->rp->rcol, scol); |
345 |
346 |
ndims--; |
347 |
348 |
/* compute transmission */ |
349 |
if ((wp->specfl & (SP_TRAN|SP_TPURE|SP_TBLT)) == SP_TRAN && |
350 |
rayorigin(&sr, TSPECULAR, wp->rp, wp->ts.scol) == 0) { |
351 |
nstarget = 1; |
352 |
353 |
354 |
355 |
356 |
357 |
d = 1./nstarget; |
358 |
359 |
sr.rweight *= d; |
360 |
} else |
361 |
nstarget = 1; |
362 |
363 |
364 |
365 |
366 |
367 |
if (ntrials) |
368 |
d = frandom(); |
369 |
else |
370 |
d = urand(ilhash(dimlist,ndims)+1823+samplendx); |
371 |
372 |
373 |
cosp = tcos(d) * wp->ts.u_alpha; |
374 |
sinp = tsin(d) * wp->ts.v_alpha; |
375 |
376 |
cosp *= d; |
377 |
sinp *= d; |
378 |
379 |
380 |
if (rv[1] <= FTINY) |
381 |
d = 1.0; |
382 |
else |
383 |
d = sqrt(-log(rv[1]) / |
384 |
(cosp*cosp/(wp->ts.u_alpha*wp->ts.u_alpha) + |
385 |
sinp*sinp/(wp->ts.v_alpha*wp->ts.v_alpha))); |
386 |
387 |
sr.rdir[i] = wp->prdir[i] + |
388 |
d*(cosp*wp->ts.u[i] + sinp*wp->ts.v[i]); |
389 |
/* rejection test */ |
390 |
if ((DOT(sr.rdir,wp->rp->ron) > 0) == (wp->rp->rod > 0)) |
391 |
continue; |
392 |
normalize(sr.rdir); /* OK, normalize */ |
393 |
if (nstaken) /* multi-sampling? */ |
394 |
rayclear(&sr); |
395 |
rayvalue(&sr); |
396 |
397 |
398 |
++nstaken; |
399 |
400 |
ndims--; |
401 |
402 |
403 |
404 |
/* compute source contribution for MAT_WGMDF */ |
405 |
static void |
406 |
dirwgmdf(SCOLOR scval, void *uwp, FVECT ldir, double omega) |
407 |
408 |
WGMDDAT *wp = (WGMDDAT *)uwp; |
409 |
const int hitfront = (wp->rp->rod > 0); |
410 |
double fresadj = 1.; |
411 |
double ldot; |
412 |
double dtmp, dtmp1, dtmp2; |
413 |
FVECT h; |
414 |
double au2, av2; |
415 |
SCOLOR sctmp; |
416 |
417 |
scolorblack(scval); /* will add component coefficients */ |
418 |
419 |
/* XXX ignores which side is lit */ |
420 |
if (wp->specfl & SP_RPURE && pbright(wp->rs.scol) >= FRESTHRESH) |
421 |
fresadj = 1. - FRESNE(fabs(DOT(wp->rs.mo.pnorm,ldir))); |
422 |
423 |
if (sintens(wp->rd.scol) > FTINY && |
424 |
((ldot = DOT(wp->rd.mo.pnorm,ldir)) > 0) == hitfront) { |
425 |
426 |
* Compute diffuse reflection coefficient for source. |
427 |
428 |
copyscolor(sctmp, wp->rd.scol); |
429 |
dtmp = fabs(ldot) * omega * (1.0/PI) * fresadj; |
430 |
scalescolor(sctmp, dtmp); |
431 |
saddscolor(scval, sctmp); |
432 |
433 |
if (sintens(wp->td.scol) > FTINY && |
434 |
((ldot = DOT(wp->td.mo.pnorm,ldir)) > 0) ^ hitfront) { |
435 |
436 |
* Compute diffuse transmission coefficient for source. |
437 |
438 |
copyscolor(sctmp, wp->td.scol); |
439 |
440 |
441 |
442 |
443 |
#if 0 /* XXX not yet implemented */ |
444 |
if (ambRayInPmap(wp->rp)) |
445 |
return; /* specular accounted for in photon map */ |
446 |
#endif |
447 |
if ((wp->specfl & (SP_REFL|SP_RPURE)) == SP_REFL && |
448 |
((ldot = DOT(wp->rs.mo.pnorm,ldir)) > 0) == hitfront) { |
449 |
450 |
* Compute specular reflection coefficient for source using |
451 |
* anisotropic Gaussian distribution model. |
452 |
453 |
/* add source width if flat */ |
454 |
if (wp->specfl & SP_FLAT) |
455 |
au2 = av2 = omega * (0.25/PI); |
456 |
else |
457 |
au2 = av2 = 0.0; |
458 |
au2 += wp->rs.u_alpha*wp->rs.u_alpha; |
459 |
av2 += wp->rs.v_alpha*wp->rs.v_alpha; |
460 |
/* half vector */ |
461 |
VSUB(h, ldir, wp->rp->rdir); |
462 |
/* ellipse */ |
463 |
dtmp1 = DOT(wp->rs.u, h); |
464 |
dtmp1 *= dtmp1 / au2; |
465 |
dtmp2 = DOT(wp->rs.v, h); |
466 |
dtmp2 *= dtmp2 / av2; |
467 |
/* W-G-M-D model */ |
468 |
dtmp = DOT(wp->rs.mo.pnorm, h); |
469 |
dtmp *= dtmp; |
470 |
dtmp1 = (dtmp1 + dtmp2) / dtmp; |
471 |
dtmp = exp(-dtmp1) * DOT(h,h) / |
472 |
(PI * dtmp*dtmp * sqrt(au2*av2)); |
473 |
474 |
if (dtmp > FTINY) { /* worth using? */ |
475 |
copyscolor(sctmp, wp->rs.scol); |
476 |
dtmp *= fabs(ldot) * omega; |
477 |
478 |
479 |
480 |
481 |
if ((wp->specfl & (SP_TRAN|SP_TPURE)) == SP_TRAN && |
482 |
((ldot = DOT(wp->ts.mo.pnorm,ldir)) > 0) ^ hitfront) { |
483 |
484 |
* Compute specular transmission coefficient for source. |
485 |
486 |
/* roughness + source */ |
487 |
au2 = av2 = omega * (1.0/PI); |
488 |
au2 += wp->ts.u_alpha*wp->ts.u_alpha; |
489 |
av2 += wp->ts.v_alpha*wp->ts.v_alpha; |
490 |
/* "half vector" */ |
491 |
VSUB(h, ldir, wp->prdir); |
492 |
dtmp = DOT(h,h); |
493 |
if (dtmp > FTINY*FTINY) { |
494 |
dtmp1 = DOT(h,wp->ts.mo.pnorm); |
495 |
dtmp = 1.0 - dtmp1*dtmp1/dtmp; |
496 |
497 |
498 |
dtmp1 = DOT(h,wp->ts.u); |
499 |
500 |
dtmp2 = DOT(h,wp->ts.v); |
501 |
502 |
dtmp = (dtmp1 + dtmp2) / dtmp; |
503 |
dtmp = exp(-dtmp); |
504 |
} else |
505 |
dtmp = 1.0; |
506 |
/* Gaussian */ |
507 |
dtmp *= (1.0/PI) * sqrt(-ldot/(wp->ts.mo.pdot*au2*av2)); |
508 |
509 |
510 |
copyscolor(sctmp, wp->ts.scol); |
511 |
dtmp *= omega; |
512 |
513 |
514 |
515 |
516 |
517 |
518 |
/* color a ray that hit a programmable WGMD material */ |
519 |
int |
520 |
m_wgmdf(OBJREC *m, RAY *r) |
521 |
522 |
RAY lr; |
523 |
WGMDDAT wd; |
524 |
SCOLOR sctmp; |
525 |
FVECT anorm; |
526 |
int i; |
527 |
528 |
if (!backvis & (r->rod < 0.0)) { |
529 |
raytrans(r); |
530 |
return(1); /* backside invisible */ |
531 |
532 |
if ((m->oargs.nsargs < 13) | (m->oargs.nfargs < 9)) |
533 |
objerror(m, USER, "bad number of arguments"); |
534 |
535 |
if (r->crtype & SHADOW && !strcmp(m->oargs.sarg[5], "0")) |
536 |
return(1); /* first shadow test */ |
537 |
clr_comps(&wd); |
538 |
wd.rp = r; |
539 |
wd.mtp = m; |
540 |
wd.mf = getfunc(m, 12, 0xEEE, 1); |
541 |
set_dcomp(&wd, 0); /* gets main modifier */ |
542 |
setWGMDfunc(&wd.rd.mo, &wd); /* get local u vector */ |
543 |
errno = 0; |
544 |
545 |
wd.ulocal[i] = evalue(wd.mf->ep[6+i]); |
546 |
if ((errno == EDOM) | (errno == ERANGE)) |
547 |
wd.ulocal[0] = wd.ulocal[1] = wd.ulocal[2] = 0.0; |
548 |
else if (wd.mf->fxp != &unitxf) |
549 |
multv3(wd.ulocal, wd.ulocal, wd.mf->fxp->xfm); |
550 |
551 |
set_scomp(&wd, 1); /* sets SP_TPURE */ |
552 |
if (r->crtype & SHADOW && !(wd.specfl & SP_TPURE)) |
553 |
return(1); /* second shadow test */ |
554 |
set_dcomp(&wd, 1); |
555 |
set_scomp(&wd, 0); |
556 |
wd.specfl |= SP_FLAT*(!wd.rs.mo.hastexture && |
557 |
r->ro != NULL && isflat(r->ro->otype)); |
558 |
/* apply Fresnel adjustments? */ |
559 |
if (wd.specfl & SP_RPURE && pbright(wd.rs.scol) >= FRESTHRESH) { |
560 |
const double fest = FRESNE(fabs(wd.rs.mo.pdot)); |
561 |
for (i = NCSAMP; i--; ) |
562 |
wd.rs.scol[i] += fest*(1. - wd.rs.scol[i]); |
563 |
scalescolor(wd.rd.scol, 1.-fest); |
564 |
scalescolor(wd.ts.scol, 1.-fest); |
565 |
scalescolor(wd.td.scol, 1.-fest); |
566 |
567 |
/* check specular thresholds */ |
568 |
wd.specfl |= SP_RBLT*((wd.specfl & (SP_REFL|SP_RPURE)) == SP_REFL && |
569 |
specthresh >= pbright(wd.rs.scol)-FTINY); |
570 |
wd.specfl |= SP_TBLT*((wd.specfl & (SP_TRAN|SP_TPURE)) == SP_TRAN && |
571 |
specthresh >= pbright(wd.ts.scol)-FTINY); |
572 |
/* get through direction */ |
573 |
if (wd.specfl & SP_TRAN && wd.ts.mo.hastexture && |
574 |
!(r->crtype & (SHADOW|AMBIENT))) { |
575 |
for (i = 0; i < 3; i++) /* perturb */ |
576 |
wd.prdir[i] = r->rdir[i] - wd.ts.mo.pnorm[i] + r->ron[i]; |
577 |
if ((DOT(wd.prdir,r->ron) > 0) ^ (r->rod > 0)) |
578 |
normalize(wd.prdir); /* OK */ |
579 |
else /* too much */ |
580 |
VCOPY(wd.prdir, r->rdir); |
581 |
} else |
582 |
583 |
/* transmitted view ray? */ |
584 |
if ((wd.specfl & (SP_TRAN|SP_TPURE|SP_TBLT)) == (SP_TRAN|SP_TPURE) && |
585 |
rayorigin(&lr, TRANS, r, wd.ts.scol) == 0) { |
586 |
VCOPY(lr.rdir, wd.prdir); |
587 |
rayvalue(&lr); |
588 |
smultscolor(lr.rcol, lr.rcoef); |
589 |
saddscolor(r->rcol, lr.rcol); |
590 |
if (scolor_mean(wd.ts.scol) >= 0.999) { |
591 |
/* completely transparent */ |
592 |
smultscolor(lr.mcol, lr.rcoef); |
593 |
copyscolor(r->mcol, lr.mcol); |
594 |
r->rmt = r->rot + lr.rmt; |
595 |
r->rxt = r->rot + lr.rxt; |
596 |
} else if (pbright(wd.ts.scol) > |
597 |
pbright(wd.td.scol) + pbright(wd.rd.scol)) |
598 |
r->rxt = r->rot + raydistance(&lr); |
599 |
600 |
if (r->crtype & SHADOW) |
601 |
return(1); /* the rest is shadow */ |
602 |
/* mirror ray? */ |
603 |
if ((wd.specfl & (SP_REFL|SP_RPURE|SP_RBLT)) == (SP_REFL|SP_RPURE) && |
604 |
rayorigin(&lr, REFLECTED, r, wd.rs.scol) == 0) { |
605 |
VSUM(lr.rdir, r->rdir, wd.rs.mo.pnorm, 2.*wd.rs.mo.pdot); |
606 |
/* fall back if would penetrate */ |
607 |
if (wd.rs.mo.hastexture && |
608 |
(DOT(lr.rdir,r->ron) > 0) ^ (r->rod > 0)) |
609 |
VSUM(lr.rdir, r->rdir, r->ron, 2.*r->rod); |
610 |
checknorm(lr.rdir); |
611 |
rayvalue(&lr); |
612 |
613 |
copyscolor(r->mcol, lr.rcol); |
614 |
615 |
r->rmt = r->rot; |
616 |
if (wd.specfl & SP_FLAT && r->crtype & AMBIENT) |
617 |
r->rmt += raydistance(&lr); |
618 |
619 |
if (wd.specfl & (SP_REFL|SP_TRAN)) /* specularly scattered rays */ |
620 |
agaussamp(&wd); /* checks *BLT flags */ |
621 |
622 |
if (sintens(wd.rd.scol) > FTINY) { /* ambient from this side */ |
623 |
if (r->rod > 0) { |
624 |
VCOPY(anorm, wd.rd.mo.pnorm); |
625 |
} else { |
626 |
anorm[0] = -wd.rd.mo.pnorm[0]; |
627 |
anorm[1] = -wd.rd.mo.pnorm[1]; |
628 |
anorm[2] = -wd.rd.mo.pnorm[2]; |
629 |
630 |
copyscolor(sctmp, wd.rd.scol); |
631 |
if (wd.specfl & SP_RBLT) /* add in specular as well? */ |
632 |
saddscolor(sctmp, wd.rs.scol); |
633 |
multambient(sctmp, r, anorm); |
634 |
saddscolor(r->rcol, sctmp); /* add to returned color */ |
635 |
636 |
if (sintens(wd.td.scol) > FTINY) { /* ambient from other side */ |
637 |
if (r->rod > 0) { |
638 |
anorm[0] = -wd.td.mo.pnorm[0]; |
639 |
anorm[1] = -wd.td.mo.pnorm[1]; |
640 |
anorm[2] = -wd.td.mo.pnorm[2]; |
641 |
} else { |
642 |
VCOPY(anorm, wd.td.mo.pnorm); |
643 |
644 |
copyscolor(sctmp, wd.td.scol); |
645 |
if (wd.specfl & SP_TBLT) /* add in specular as well? */ |
646 |
saddscolor(sctmp, wd.ts.scol) |
647 |
648 |
saddscolor(r->rcol, sctmp); |
649 |
650 |
direct(r, dirwgmdf, &wd); /* add direct component last */ |
651 |
return(1); |
652 |
