root/radiance/ray/src/rt/m_mist.c
Tue Jul 8 18:25:00 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.17: +13 -13 lines
Diff to previous 2.17 , to selected 2.5
Tue Apr 19 01:15:06 2005 UTC (19 years, 5 months ago) by greg
Diff to previous 2.16 , to selected 2.5
Tue Sep 28 17:54:19 2004 UTC (19 years, 11 months ago) by greg
Changes since 2.15: +1 -1 lines
Diff to previous 2.15 , to selected 2.5
Tue Mar 30 16:13:01 2004 UTC (20 years, 5 months ago) by schorsch
Changes since 2.14: +23 -13 lines
Sun Jul 27 22:12:03 2003 UTC (21 years, 2 months ago) by schorsch
Mon Jun 30 14:59:12 2003 UTC (21 years, 2 months ago) by schorsch
Mon Mar 10 17:26:26 2003 UTC (21 years, 6 months ago) by greg
Changes since 2.11: +1 -2 lines
Compile fixes for Linux
Tue Feb 25 02:47:22 2003 UTC (21 years, 7 months ago) by greg
Sat Feb 22 02:07:28 2003 UTC (21 years, 7 months ago) by greg
Changes since 2.9: +60 -9 lines
Wed May 28 14:38:32 1997 UTC (27 years, 4 months ago) by gregl
Changes since 2.8: +3 -2 lines
made source list overflow an internal error
Tue Jul 16 09:21:10 1996 UTC (28 years, 2 months ago) by greg
fixed errant argument count check (bug in 3.0 release)
Wed Jun 5 11:27:33 1996 UTC (28 years, 3 months ago) by greg
Changes since 2.6: +4 -0 lines
moved MAXSLIST macro to m_mist.c routine
Wed Apr 17 14:10:23 1996 UTC (28 years, 5 months ago) by greg
Changes since 2.5: +15 -13 lines
Thu Mar 21 10:24:59 1996 UTC (28 years, 6 months ago) by greg
Changes since 2.4: +12 -7 lines
minor bug check fix in assigning leaving extinction coefficient
Sun Dec 17 11:51:47 1995 UTC (28 years, 9 months ago) by greg
Changes since 2.3: +1 -2 lines
bug fixes related to M_MIST type and source scattering
added MAXSSAMP macro to limit number of scatter samples
Mon Dec 11 11:19:33 1995 UTC (28 years, 9 months ago) by greg
subtle fix for virtual light sources
Sat Dec 9 09:40:42 1995 UTC (28 years, 9 months ago) by greg
Changes since 2.1: +62 -44 lines
bug fixes, especially for rays that never entered mist volume
Fri Dec 8 21:27:10 1995 UTC (28 years, 9 months ago) by greg
Diff to selected 2.5
