--- ray/src/rt/m_mist.c 2003/02/22 02:07:28 2.10
+++ ray/src/rt/m_mist.c 2004/03/30 16:13:01 2.15
@@ -1,70 +1,17 @@
#ifndef lint
-static const char RCSid[] = "$Id: m_mist.c,v 2.10 2003/02/22 02:07:28 greg Exp $";
+static const char RCSid[] = "$Id";
#endif
* Mist volumetric material.
- * The Radiance Software License, Version 1.0
- * Copyright (c) 1990 - 2002 The Regents of the University of California,
- * through Lawrence Berkeley National Laboratory. All rights reserved.
- * Redistribution and use in source and binary forms, with or without
- * modification, are permitted provided that the following conditions
- * are met:
- * 1. Redistributions of source code must retain the above copyright
- * notice, this list of conditions and the following disclaimer.
- * 2. Redistributions in binary form must reproduce the above copyright
- * notice, this list of conditions and the following disclaimer in
- * the documentation and/or other materials provided with the
- * distribution.
- * 3. The end-user documentation included with the redistribution,
- * if any, must include the following acknowledgment:
- * "This product includes Radiance software
- * (http://radsite.lbl.gov/)
- * developed by the Lawrence Berkeley National Laboratory
- * (http://www.lbl.gov/)."
- * Alternately, this acknowledgment may appear in the software itself,
- * if and wherever such third-party acknowledgments normally appear.
- * 4. The names "Radiance," "Lawrence Berkeley National Laboratory"
- * and "The Regents of the University of California" must
- * not be used to endorse or promote products derived from this
- * software without prior written permission. For written
- * permission, please contact radiance@radsite.lbl.gov.
- * 5. Products derived from this software may not be called "Radiance",
- * nor may "Radiance" appear in their name, without prior written
- * permission of Lawrence Berkeley National Laboratory.
- * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED
- * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES
- * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
- * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR
- * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
- * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
- * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF
- * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
- * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
- * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
- * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
- * SUCH DAMAGE.
- * This software consists of voluntary contributions made by many
- * individuals on behalf of Lawrence Berkeley National Laboratory. For more
- * information on Lawrence Berkeley National Laboratory, please see
+#include "copyright.h"
-#include "ray.h"
+#include
+#include "ray.h"
#include "source.h"
+#include "rtotypes.h"
* A mist volume is used to specify a region in the scene where a certain
@@ -104,11 +51,16 @@ static const char RCSid[] = "$Id: m_mist.c,v 2.10 2003
#define RELAYDELIM '>' /* relay delimiter character */
+static int inslist(int *sl, int n);
+static int srcmatch(SRCREC *sp, char *id);
+static void add2slist(RAY *r, int *sl);
static int
-inslist(sl, n) /* return index of source n if it's in list sl */
-register int *sl;
-register int n;
+inslist( /* return index of source n if it's in list sl */
+ register int *sl,
+ register int n
register int i;
@@ -120,14 +72,14 @@ register int n;
static int
-srcmatch(sp, id) /* check for an id match on a light source */
-register SRCREC *sp;
-register char *id;
+srcmatch( /* check for an id match on a light source */
+ register SRCREC *sp,
+ register char *id
- extern char *index();
register char *cp;
/* check for relay sources */
- while ((cp = index(id, RELAYDELIM)) != NULL) {
+ while ((cp = strchr(id, RELAYDELIM)) != NULL) {
if (!(sp->sflags & SVIRTUAL) || sp->so == NULL)
return(0);
if (strncmp(id, sp->so->oname, cp-id) || sp->so->oname[cp-id])
@@ -142,9 +94,10 @@ register char *id;
static void
-add2slist(r, sl) /* add source list to ray's */
-register RAY *r;
-register int *sl;
+add2slist( /* add source list to ray's */
+ register RAY *r,
+ register int *sl
static int slspare[MAXSLIST+1]; /* in case of emergence */
register int i;
@@ -163,10 +116,11 @@ register int *sl;
-int
-m_mist(m, r) /* process a ray entering or leaving some mist */
-OBJREC *m;
-register RAY *r;
+extern int
+m_mist( /* process a ray entering or leaving some mist */
+ OBJREC *m,
+ register RAY *r
RAY p;
int *myslist = NULL;
@@ -231,7 +185,7 @@ register RAY *r;
} else { /* leaving ray */
if (myslist != NULL) { /* delete from list */
for (j = myslist[0]; j > 0; j--)
- if (i = inslist(p.slights, myslist[j]))
+ if ( (i = inslist(p.slights, myslist[j])) )
p.slights[i] = -1;
for (i = 0, j = 1; j <= p.slights[0]; j++)
if (p.slights[j] != -1)
@@ -268,4 +222,5 @@ register RAY *r;
return(1);
memerr:
error(SYSTEM, "out of memory in m_mist");
+ return 0; /* pro forma return */
