1 |
/* Copyright (c) 1995 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* Mist volumetric material. |
9 |
10 |
11 |
#include "ray.h" |
12 |
13 |
#include "source.h" |
14 |
15 |
16 |
* A mist volume is used to specify a region in the scene where a certain |
17 |
* light source (or sources) is going to contribute to scattering. The |
18 |
* material can add to the existing global medium, and override any ray |
19 |
* settings for scattering albedo and eccentricity. Overlapping mist |
20 |
* regions should agree w.r.t. albedo and eccentricity, and |
21 |
* should have disjoint source lists. |
22 |
23 |
* A pattern, if used, should compute the line integral of extinction, |
24 |
* and will modify the first three arguments directly. This will tend |
25 |
* to invalidate results when there are other objects intersected within |
26 |
* the mist region. |
27 |
28 |
* The string arguments for MAT_MIST are the identifiers for the important |
29 |
* light sources, which will be looked up in the source array. The last |
30 |
* source found matching a name is the one used. A relayed light source |
31 |
* may be indicated by the relay surface name, followed by a '>' character, |
32 |
* followed by the relayed source name (which may be another relay). |
33 |
34 |
* Up to five real arguments may be given for MAT_MIST: |
35 |
36 |
* [ext_r ext_g ext_b [albedo [gecc]]] |
37 |
38 |
* The primaries indicate medium extinction per unit length (absorption |
39 |
* plus scattering). The albedo is the ratio of scattering to extinction, |
40 |
* and is set globally by the -ma option (salbedo) and overridden here. |
41 |
* The Heyney-Greenstein eccentricity parameter (-mg seccg) indicates how much |
42 |
* scattering favors the forward direction. A value of 0 means isotropic |
43 |
* scattering. A value approaching 1 indicates strong forward scattering. |
44 |
45 |
46 |
#define MAXSLIST 32 /* maximum sources to check */ |
47 |
#define RELAYDELIM '>' /* relay delimiter character */ |
48 |
49 |
extern COLOR cextinction; /* global coefficient of extinction */ |
50 |
extern double salbedo; /* global scattering albedo */ |
51 |
extern double seccg; /* global scattering eccentricity */ |
52 |
53 |
54 |
static int |
55 |
inslist(sl, n) /* return index of source n if it's in list sl */ |
56 |
register int *sl; |
57 |
register int n; |
58 |
59 |
register int i; |
60 |
61 |
for (i = sl[0]; i > 0; i--) |
62 |
if (sl[i] == n) |
63 |
return(i); |
64 |
return(0); |
65 |
66 |
67 |
68 |
static int |
69 |
srcmatch(sn, id) /* check for an id match on a light source */ |
70 |
register int sn; |
71 |
char *id; |
72 |
73 |
extern char *index(); |
74 |
register char *cp; |
75 |
again: |
76 |
if (source[sn].so == NULL) /* just in case */ |
77 |
return(0); |
78 |
if ((cp = index(id, RELAYDELIM)) != NULL) { /* relay source */ |
79 |
if (!(source[sn].sflags & SVIRTUAL)) |
80 |
return(0); |
81 |
*cp = '\0'; |
82 |
if (strcmp(id, source[sn].so->oname)) { |
83 |
*cp = RELAYDELIM; |
84 |
return(0); |
85 |
86 |
*cp = RELAYDELIM; |
87 |
id = cp + 1; /* recurse */ |
88 |
sn = source[sn].sa.sv.sn; |
89 |
goto again; |
90 |
91 |
if (source[sn].sflags & SVIRTUAL) |
92 |
return(0); |
93 |
return(!strcmp(id, source[sn].so->oname)); |
94 |
95 |
96 |
97 |
m_mist(m, r) /* process a ray entering or leaving some mist */ |
98 |
OBJREC *m; |
99 |
register RAY *r; |
100 |
101 |
RAY p; |
102 |
int *myslist = NULL; |
103 |
int newslist[MAXSLIST+1]; |
104 |
COLOR mext; |
105 |
double re, ge, be; |
106 |
register int i, j; |
107 |
/* check arguments */ |
108 |
if (m->oargs.nfargs > 5) |
109 |
objerror(m, USER, "bad arguments"); |
110 |
if (m->oargs.nsargs > MAXSLIST) |
111 |
objerror(m, USER, "too many sources in list"); |
112 |
/* get source indices */ |
113 |
if (m->oargs.nsargs > 0 && (myslist = (int *)m->os) == NULL) { |
114 |
myslist = (int *)malloc((m->oargs.nsargs+1)*sizeof(int)); |
115 |
if (myslist == NULL) |
116 |
goto memerr; |
117 |
myslist[0] = m->oargs.nsargs; /* size is first in set */ |
118 |
for (j = myslist[0]; j > 0; j--) { |
119 |
i = nsources; /* look up each source id */ |
120 |
while (i--) |
121 |
if (srcmatch(i, m->oargs.sarg[j-1])) |
122 |
break; |
123 |
if (i < 0) { |
124 |
sprintf(errmsg, "unknown source \"%s\"", |
125 |
m->oargs.sarg[j-1]); |
126 |
objerror(m, WARNING, errmsg); |
127 |
} else |
128 |
myslist[j] = i; |
129 |
130 |
m->os = (char *)myslist; |
131 |
132 |
if (m->oargs.nfargs > 2) { /* compute extinction */ |
133 |
setcolor(mext, m->oargs.farg[0], m->oargs.farg[1], |
134 |
m->oargs.farg[2]); |
135 |
raytexture(r, m->omod); /* get modifiers */ |
136 |
multcolor(mext, r->pcol); |
137 |
} else |
138 |
setcolor(mext, 0., 0., 0.); |
139 |
/* start transmitted ray */ |
140 |
if (rayorigin(&p, r, TRANS, 1.) < 0) |
141 |
return(1); |
142 |
VCOPY(p.rdir, r->rdir); |
143 |
p.slights = newslist; |
144 |
if (r->slights != NULL) |
145 |
for (j = r->slights[0]; j >= 0; j--) |
146 |
p.slights[j] = r->slights[j]; |
147 |
else |
148 |
p.slights[0] = 0; |
149 |
if (r->rod > 0.) { /* entering ray */ |
150 |
addcolor(p.cext, mext); |
151 |
if (m->oargs.nfargs > 3) |
152 |
p.albedo = m->oargs.farg[3]; |
153 |
if (m->oargs.nfargs > 4) |
154 |
p.gecc = m->oargs.farg[4]; |
155 |
if (myslist != NULL) /* add to list */ |
156 |
for (j = myslist[0]; j > 0; j--) |
157 |
if (!inslist(p.slights, myslist[j])) { |
158 |
if (p.slights[0] >= MAXSLIST) |
159 |
error(USER, |
160 |
"scattering source list overflow"); |
161 |
p.slights[++p.slights[0]] = myslist[j]; |
162 |
163 |
} else { /* leaving ray */ |
164 |
re = colval(r->cext,RED) - colval(mext,RED); |
165 |
ge = colval(r->cext,GRN) - colval(mext,GRN); |
166 |
be = colval(r->cext,BLU) - colval(mext,BLU); |
167 |
setcolor(p.cext, re<0. ? 0. : re, |
168 |
ge<0. ? 0. : ge, |
169 |
be<0. ? 0. : be); |
170 |
171 |
p.albedo = salbedo; |
172 |
173 |
p.gecc = seccg; |
174 |
if (myslist != NULL) { /* delete from list */ |
175 |
176 |
if (i = inslist(p.slights, myslist[j])) |
177 |
p.slights[i] = -1; |
178 |
for (i = 0, j = 1; j <= p.slights[0]; j++) |
179 |
if (p.slights[j] != -1) |
180 |
p.slights[++i] = p.slights[j]; |
181 |
p.slights[0] = i; |
182 |
183 |
184 |
rayvalue(&p); /* calls rayparticipate() */ |
185 |
copycolor(r->rcol, p.rcol); /* return value */ |
186 |
r->rt = r->rot + p.rt; |
187 |
return(1); |
188 |
memerr: |
189 |
error(SYSTEM, "out of memory in m_mist"); |
190 |
