root/radiance/ray/src/rt/m_mist.c
Revision: 2.3
Committed: Mon Dec 11 11:19:33 1995 UTC (29 years, 7 months ago) by greg
subtle fix for virtual light sources
1 /* Copyright (c) 1995 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Mist volumetric material.
9 */
10
11 #include "ray.h"
12
13 #include "source.h"
14
15 /*
16 * A mist volume is used to specify a region in the scene where a certain
17 * light source (or sources) is going to contribute to scattering. The
18 * material can add to the existing global medium, and override any ray
19 * settings for scattering albedo and eccentricity. Overlapping mist
20 * regions should agree w.r.t. albedo and eccentricity, and
21 * should have disjoint source lists.
22 *
23 * A pattern, if used, should compute the line integral of extinction,
24 * and will modify the first three arguments directly. This will tend
25 * to invalidate results when there are other objects intersected within
26 * the mist region.
27 *
28 * The string arguments for MAT_MIST are the identifiers for the important
29 * light sources, which will be looked up in the source array. The last
30 * source found matching a name is the one used. A relayed light source
31 * may be indicated by the relay surface name, followed by a '>' character,
32 * followed by the relayed source name (which may be another relay).
33 *
34 * Up to five real arguments may be given for MAT_MIST:
35 *
36 * [ext_r ext_g ext_b [albedo [gecc]]]
37 *
38 * The primaries indicate medium extinction per unit length (absorption
39 * plus scattering). The albedo is the ratio of scattering to extinction,
40 * and is set globally by the -ma option (salbedo) and overridden here.
41 * The Heyney-Greenstein eccentricity parameter (-mg seccg) indicates how much
42 * scattering favors the forward direction. A value of 0 means isotropic
43 * scattering. A value approaching 1 indicates strong forward scattering.
44 */
45
46 #define RELAYDELIM '>' /* relay delimiter character */
47
48 extern COLOR cextinction; /* global coefficient of extinction */
49 extern double salbedo; /* global scattering albedo */
50 extern double seccg; /* global scattering eccentricity */
51
52
53 static int
54 inslist(sl, n) /* return index of source n if it's in list sl */
55 register int *sl;
56 register int n;
57 {
58 register int i;
59
60 for (i = sl[0]; i > 0; i--)
61 if (sl[i] == n)
62 return(i);
63 return(0);
64 }
65
66
67 static int
68 srcmatch(sp, id) /* check for an id match on a light source */
69 register SRCREC *sp;
70 register char *id;
71 {
72 extern char *index();
73 register char *cp;
74 /* check for relay sources */
75 while ((cp = index(id, RELAYDELIM)) != NULL) {
76 if (!(sp->sflags & SVIRTUAL) || sp->so == NULL)
77 return(0);
78 if (strncmp(id, sp->so->oname, cp-id) || sp->so->oname[cp-id])
79 return(0);
80 id = cp + 1; /* relay to next */
81 sp = source + sp->sa.sv.sn;
82 }
83 if (sp->sflags & SVIRTUAL || sp->so == NULL)
84 return(0);
85 return(!strcmp(id, sp->so->oname));
86 }
87
88
89 static
90 add2slist(r, sl) /* add source list to ray's */
91 register RAY *r;
92 register int *sl;
93 {
94 static int slspare[MAXSLIST+1]; /* in case of emergence */
95 register int i;
96
97 if (sl == NULL || sl[0] == 0) /* nothing to add */
98 return;
99 if (r->slights == NULL)
100 (r->slights = slspare)[0] = 0; /* just once per ray path */
101 for (i = sl[0]; i > 0; i--)
102 if (!inslist(r->slights, sl[i])) {
103 if (r->slights[0] >= MAXSLIST)
104 error(USER, "scattering source list overflow");
105 r->slights[++r->slights[0]] = sl[i];
106 }
107 }
108
109
110 m_mist(m, r) /* process a ray entering or leaving some mist */
111 OBJREC *m;
112 register RAY *r;
113 {
114 RAY p;
115 int *myslist = NULL;
116 int newslist[MAXSLIST+1];
117 COLOR mext;
118 double re, ge, be;
119 register int i, j;
120 /* check arguments */
121 if (m->oargs.nfargs > 5)
122 objerror(m, USER, "bad arguments");
123 /* get source indices */
124 if (!(r->crtype & SHADOW) && m->oargs.nsargs > 0 &&
125 (myslist = (int *)m->os) == NULL) {
126 if (m->oargs.nsargs > MAXSLIST)
127 objerror(m, USER, "too many sources in list");
128 myslist = (int *)malloc((m->oargs.nsargs+1)*sizeof(int));
129 if (myslist == NULL)
130 goto memerr;
131 myslist[0] = 0; /* size is first in list */
132 for (j = 0; j < m->oargs.nsargs; j++) {
133 i = nsources; /* look up each source id */
134 while (i--)
135 if (srcmatch(source+i, m->oargs.sarg[j]))
136 break;
137 if (i < 0) {
138 sprintf(errmsg, "unknown source \"%s\"",
139 m->oargs.sarg[j]);
140 objerror(m, WARNING, errmsg);
141 } else if (inslist(myslist, i)) {
142 sprintf(errmsg, "duplicate source \"%s\"",
143 m->oargs.sarg[j]);
144 objerror(m, WARNING, errmsg);
145 } else
146 myslist[++myslist[0]] = i;
147 }
148 m->os = (char *)myslist;
149 }
150 if (m->oargs.nfargs > 2) { /* compute extinction */
151 setcolor(mext, m->oargs.farg[0], m->oargs.farg[1],
152 m->oargs.farg[2]);
153 raytexture(r, m->omod); /* get modifiers */
154 multcolor(mext, r->pcol);
155 } else
156 setcolor(mext, 0., 0., 0.);
157 /* start transmitted ray */
158 if (rayorigin(&p, r, TRANS, 1.) < 0)
159 return(1);
160 VCOPY(p.rdir, r->rdir);
161 p.slights = newslist;
162 if (r->slights != NULL) /* copy old list if one */
163 for (j = r->slights[0]; j >= 0; j--)
164 p.slights[j] = r->slights[j];
165 else
166 p.slights[0] = 0;
167 if (r->rod > 0.) { /* entering ray */
168 addcolor(p.cext, mext);
169 if (m->oargs.nfargs > 3)
170 p.albedo = m->oargs.farg[3];
171 if (m->oargs.nfargs > 4)
172 p.gecc = m->oargs.farg[4];
173 add2slist(&p, myslist); /* add to list */
174 } else { /* leaving ray */
175 if (myslist != NULL) { /* delete from list */
176 for (j = myslist[0]; j > 0; j--)
177 if (i = inslist(p.slights, myslist[j]))
178 p.slights[i] = -1;
179 for (i = 0, j = 1; j <= p.slights[0]; j++)
180 if (p.slights[j] != -1)
181 p.slights[++i] = p.slights[j];
182 if (p.slights[0] - i < myslist[0]) { /* fix old */
183 addcolor(r->cext, mext);
184 if (m->oargs.nfargs > 3)
185 r->albedo = m->oargs.farg[3];
186 if (m->oargs.nfargs > 4)
187 r->gecc = m->oargs.farg[4];
188 add2slist(r, myslist);
189 }
190 p.slights[0] = i;
191 }
192 re = colval(r->cext,RED) - colval(mext,RED);
193 ge = colval(r->cext,GRN) - colval(mext,GRN);
194 be = colval(r->cext,BLU) - colval(mext,BLU);
195 setcolor(p.cext, re<0. ? 0. : re,
196 ge<0. ? 0. : ge,
197 be<0. ? 0. : be);
198 if (m->oargs.nfargs > 3)
199 p.albedo = salbedo;
200 if (m->oargs.nfargs > 4)
201 p.gecc = seccg;
202 }
203 rayvalue(&p); /* calls rayparticipate() */
204 copycolor(r->rcol, p.rcol); /* return value */
205 r->rt = r->rot + p.rt;
206 return(1);
207 memerr:
208 error(SYSTEM, "out of memory in m_mist");
209 }
